    4. Iobroker backitup error.. Wo liegt das problem
      elmos04 @wendy2702 last edited by
      @wendy2702
      Java Zigbee und den iobroker
      E wendy2702 2 Replies Last reply Reply Quote 0
        elmos04 @elmos04 last edited by
        @elmos04
        das steht im iobroker Protokoll
        code_text
        p.0
        2022-02-13 17:52:31.393	error	[iobroker] chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please run "iobroker fix"!!
        backitup.0
        2022-02-13 17:52:30.642	info	[iobroker] backup was activated at 02:40 every 1 day(s)
        backitup.0
        2022-02-13 17:52:30.556	info	starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
        host.raspberrypi
        2022-02-13 17:52:27.918	info	instance system.adapter.backitup.0 started with pid 26735
        host.raspberrypi
        2022-02-13 17:52:25.539	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        backitup.0
        2022-02-13 17:52:24.868	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        backitup.0
        2022-02-13 17:52:24.866	info	terminating
        backitup.0
        2022-02-13 17:52:24.865	info	cleaned everything up...
        host.raspberrypi
        2022-02-13 17:52:24.865	info	stopInstance system.adapter.backitup.0 send kill signal
        backitup.0
        2022-02-13 17:52:24.863	info	Got terminate signal TERMINATE_YOURSELF
        • wendy2702
          wendy2702 @elmos04 last edited by
          Was sind die xxx.json files? Sind das Widgets oder Views?
          Werden die noch benötigt?
          Kannst du mal den Inhalt eines solchen Files posten?
          Z.B.
          cat  /opt/iobroker/iobroker-data/files/vis.0/Tech/6_Fach_Taster_2_Blaulicht.json
          • wendy2702
            @elmos04 sagte in Iobroker backitup error.. Wo liegt das problem:
            @elmos04
            Du muss auch mal anfangen die Logfiles zu lesen. Da steht zumindest mal ein Hinweis drin was gemacht werden soll
            Homoran E 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @wendy2702 last edited by
              @wendy2702 sagte in Iobroker backitup error.. Wo liegt das problem:
              Lesen -Ja
              Verstehen - nein
              • wendy2702
                wendy2702 @Homoran last edited by
                @homoran sagte in Iobroker backitup error.. Wo liegt das problem:
                Lesen -Ja
                Verstehen - nein
                OK.
                Aber ich hoffe ja das die Leute auch Interesse haben das irgendwann mal zu verstehen.
                  code_text
                  /* -- do not edit following lines - START --
                    "expert": true,
                    "engineType": "Blockly",
                    "debug": false,
                    "verbose": false
                  -- do not edit previous lines - END --*/
                  on({id: 'zigbee.0.04cf8cdf3c7d6fde.button_2_click', val: true}, async function (obj) {
                    var value = obj.state.val;
                    getState("hm-rpc.1.LTK0075338.1.STATE", function (err, state) {
                        setState("hm-rpc.1.LTK0075338.1.STATE"/*Blaulicht.STATE*/, state ? !state.val : true);
                    console.log('Blaulicht Taster geschaltet');
                  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@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspbepi@raspberrypi:~ $
                    Homoran Global Moderator Administrators @elmos04 last edited by
                    das sind skripte
                    Was machen die unter vis?
                      @wendy2702
                      Sorry aber ich weiss ja nicht was ich machen soll iobroker fix wurde schon gemacht
                        elmos04 @Homoran last edited by
                        @homoran das hat der Backitup adapter mir aus dem alten backup kopiert
                        • wendy2702
                          das sind skripte
                          @elmos04 : weisst du wie deine Blocklys oder anderen Scripte alle heißen? Siehst du diese in iobroker?
                            @wendy2702
                            ja das sind Skripte. die kenne ich
                            • simatec
                              simatec Developer Most Active @elmos04 last edited by
                              Gleiche Meldung
                              Nein diesesmal ist es 6_Fach_Taster_2_Blaulicht.json
                              Da ist irgendwas krum. Was sind das überhaupt für Dateien? Sind die von dir?
                                elmos04 @simatec last edited by
                                @simatec
                                Ja das sind Skripte. Ein Blockly welches das Blaulicht einschaltet wenn der Taster gedrückt wird.
                                • wendy2702
                                  @elmos04 OK. Siehst du diese Scripte im Script Tab?
                                  Funktionieren Sie?
                                  Ist das Script: 6_Fach_Taster_1_Büro_licht noch vorhanden und funktioniert?
                                    @wendy2702
                                    die Skripte habe ich alle neu gemacht. die alten habe ich gelöscht. viele Fehler
                                    • simatec
                                      Backitup macht nur das, was vorher konfiguriert wurde.
                                      Backitup legt keine Daten in VIS von alleine ab
                                      Mach folgendes
                                      sudo cp /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json /home/pi/
                                      sudo rm /opt/iobroker/iobroker-data/files/vis.0/Tech/*.json
                                      wendy2702 1 Reply Last reply Reply Quote 1
                                      • wendy2702
                                        wendy2702 @simatec last edited by
                                        @simatec sagte in Iobroker backitup error.. Wo liegt das problem:
                                        Mach folgendes
                                        Damit ist dann auch sein View weg
                                        simatec 1 Reply Last reply Reply Quote 1
                                          @elmos04
                                          Wenn ich so versuche die brauchbaren Informationen aus deinen Posts zusammenzuklauben, dann ergibt sich mir folgendes Szenario am wahrscheinlichsten.
                                          Du hast mit einem Restore eines defekten Backups deine gesamte Installation zerschossen.
                                          • simatec
                                            simatec Developer Most Active @wendy2702 last edited by
                                            @wendy2702 Erstmal egal ... die können wir später zurück kopieren
                                            Erstmal muss er den ganzen Datenmüll da rausbekommen
                                            156
                                            19313
