      Einstein67 @simatec last edited by Einstein67
      @simatec said in Test Adapter Backitup v2.3.x:
      Restore sollte via http und https in 2.3.2 wieder tun
      Danke! Das werde ich testen 😉
      EDIT: Test war zu 100% erfolgreich!
      Gesichtert habe ich: Iobroker, Influx, Grafana, Scripte und Zigbee
      Wiederhergestellt: Grafana, Influx und Iobroker (mehr brauchst ja nicht)
      ... und hat alles perfekt funktioniert.
        crunchip Forum Testing Most Active @simatec last edited by crunchip
        @simatec bin gerade zwar erst von 2.3.0 auf 2.3.1, hatte jedoch diese Meldungen beim update
        ich habe Hosttyp: single
        Objects type: jsonl
        States type: jsonl
        2022-02-13 17:06:27.572 - info: backitup.0 (15941) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-02-13 17:06:28.086 - error: backitup.0 (15941) Connection is closed.
        2022-02-13 17:06:28.089 - error: backitup.0 (15941) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2022-02-13 17:06:28.090 - error: backitup.0 (15941) unhandled promise rejection: States DB is not allowed to start in the current Multihost environment
        2022-02-13 17:06:28.092 - error: backitup.0 (15941) Error: States DB is not allowed to start in the current Multihost environment
        at Redis. (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
        at processTicksAndRejections (internal/process/task_queues.js:95:5)
        2022-02-13 17:06:28.093 - error: backitup.0 (15941) States DB is not allowed to start in the current Multihost environment
        2022-02-13 17:06:33.341 - info: backitup.0 (16133) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.8
        2022-02-13 17:06:33.540 - info: backitup.0 (16133) [iobroker] backup was activated at 05:30 every 1 day(s)
        • simatec
          simatec Developer Most Active @crunchip last edited by
          @crunchip Welche js-controller Version läuft?
            @simatec 4.0.8
            • simatec
              @crunchip sagte in Test Adapter Backitup v2.3.x:
              @simatec 4.0.8
              Dann melde den Fehler mal bitte dort im Thread
                Josh @simatec last edited by Josh
                @simatec Also jetzt ist bei mir die Verwirrung komplett.
                Was muss wo installiert oder eingetragen sein? Nochmal zur Erinnerung: Die InfluxDB2 läuft bei mir nicht in ioBroker, sondern in einem separaten Container.
                Welcher Pfad wäre der richtige? Hier das Ergebnis meiner Versuche:
                Pfad leer lassen = not found
                Pfad "/usr/local/bin/influx" eintragen = not found
                Pfad "/var/lib/influxdb" = permission denied
                Auf welchem System muss die Influx-cli installiert sein? ioBroker-Installation oder Influx-Installation?
                Auf welchem System muss der User iobroker der Gruppe influxdb zugeordnet werden?
                In der Anleitung finde ich folgende Infos:
                Um ein InfluxDB Backup ausführen zu können, muss Influxd auf dem iobroker-System installiert sein.
                Hierbei ist es egal, ob die Datenbank lokal verwaltet wird oder auf einen anderen Server läuft.
                Auf meinem ioBroker-System finde ich keine Influxd-Datei. Wo soll die denn sein?
                simatec 2 Replies Last reply Reply Quote 0
                • simatec
                  simatec Developer Most Active @Josh last edited by
                  @josh wenn bei /usr/local/bin/influx not found kommt, dann hast du bei der Installation etwas falsch gemacht. Prüfe mal ob dort im Pfad was liegt
                  • simatec
                    @josh Die nächsten Tage kommt dazu ne Doku.
                    Im Moment ist 2.3.x noch Beta
                      @simatec sagte in Test Adapter Backitup v2.3.x:
                      Auf welchem System muss da was im Pfad liegen? ioBroker oder Influx-LXC?
                      EDIT:
                      Ich habe die influx-cli im Influx-LXC installiert. Da ist in dem Pfad auch was drin. Aber in der ioBroker-Installation nicht.
                      Ggf. warte ich auch noch bis zum Release bzw. bis die Doku fertig ist.
                      simatec Thomas Braun 2 Replies Last reply Reply Quote 0
                      • simatec
                        @josh influx-cli muss in den iobroker
                        Im influx lxc stört sie aber auch nicht. Damit kannst du über cli Administrationen durchführen
                          Thomas Braun Most Active @Josh last edited by Thomas Braun
                          @josh
                          Sauber installiert würden die hier liegen:
                          echad@chet:/opt/iobroker $ which influx influxd
                          /usr/bin/influx
                          /usr/bin/influxd
                          Paketnamen wären:
                          apt policy influxdb
                          influxdb         influxdb2        influxdb2-cli    influxdb-client  influxdb-python
                          • simatec
                            simatec Developer Most Active @Thomas Braun last edited by
                            @thomas-braun Poste mal bitte ne kleine Anleitung, wie de User an die aktuelle Repo kommen und dann mit apt install das ganze sauber installieren können.
                            Die offizielle Doku von influx ist ja da nicht aktuell
                            Thomas Braun J 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @simatec last edited by Thomas Braun
                              @simatec
                              Grafana-Repo:
                              sudo apt-get install -y apt-transport-https
                              sudo apt-get install -y software-properties-common wget
                              wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                              echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                              InfluxDB-Repo:
                              sudo apt update
                              sudo apt install -y gnupg2 curl wget
                              wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                              echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                              Nach einem abschließenden
                              sudo apt update
                              kann dann wie üblich per Paketmanager apt die Software installiert werden.
                              Nach Wahl:
                              sudo apt install grafana
                              sudo apt install influxdb influxdb-cli
                              sudo apt install influxdb2
                              simatec 1 Reply Last reply Reply Quote 1
                              • simatec
                                Also ist auch die aktuelle Repo für influx 2 gültig
                                Dann schreibe ich mal die nächsten Tage ne Doku für Backitup
                                  Ja, liegt beides im gleichen Repo:
                                  echad@chet:/opt/iobroker $ apt policy influxdb influxdb2
                                  influxdb:
                                    Installed: (none)
                                    Candidate: 1.8.10-1
                                    Version table:
                                       1.8.10-1 500
                                          500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
                                          100 /var/lib/dpkg/status
                                       1.6.7~rc0-1+b5 500
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  influxdb2:
                                    Installed: (none)
                                    Candidate: 2.1.1
                                    Version table:
                                       2.1.1 500
                                  Hinweis am Rande: Influxdb2 benötigt ein 64bit-Betriebssystem.
                                    @simatec heute update von 2.3.1 auf 2.3.2, mit controller 4.0.9
                                    jetzt wird die config angemeckert und wieder redis server, "meta"...
                                    an der Konfig wurde nichts geändert, sollte so passen und funktioniert auch alles, gesichert wird
                                    • iobroker
                                    • javascript
                                    • zigbee
                                    • history
                                    • jarvis
                                      per ftp und nas
                                    2022-02-14 11:29:26.273 - info: backitup.0 (12087) Got terminate signal TERMINATE_YOURSELF
                                    2022-02-14 11:29:26.296 - info: backitup.0 (12087) cleaned everything up...
                                    2022-02-14 11:29:26.298 - info: backitup.0 (12087) terminating
                                    2022-02-14 11:29:26.300 - info: backitup.0 (12087) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2022-02-14 11:30:50.769 - info: backitup.0 (30267) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2022-02-14 11:30:51.339 - warn: backitup.0 (30267) Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                    2022-02-14 11:30:51.342 - warn: backitup.0 (30267) Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                    2022-02-14 11:30:51.349 - warn: backitup.0 (30267) redis get system.adapter.backitup.0.alive, error - Connection is closed.
                                    2022-02-14 11:30:51.353 - warn: backitup.0 (30267) redis get system.adapter.backitup.0.sigKill, error - Connection is closed.
                                    2022-02-14 11:30:51.369 - error: backitup.0 (30267) backitup.0 invalid config
                                    2022-02-14 11:30:57.054 - info: backitup.0 (30278) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.9
                                    2022-02-14 11:30:57.241 - info: backitup.0 (30278) [iobroker] backup was activated at 05:30 every 1 day(s)
                                    nach einem Neustart der Instanz kommt kein Fehler mehr
                                      apollon77 @crunchip last edited by apollon77
                                      @crunchip Ich mal wieder ... bitte mehr Log von davor ... irgendwie sind da ZWEI backitup Instanzen mit verschiednen prozess IDs ... Um zu sehen was da los ist braucht es bitte mehr log von davor. Sie aus als ob da eine Instanz gestartet wurd die sehr früh wieder gekillt wurde bzw die DB Verbindung weg war.
                                      PS: Es wäre echt cool wenn du für die Controller Beta Tests den Host mindestens auf Loglevel info stellen könntest, sonst raten wir uns nen Wolf
                                      EDIT2: Also am Ende scheint es wohl an sich ok zu sein ... Einmal wurde instanz beendet (wegen dem Update nehme ich an), controller hat Sie neu gestartet. Dann ist irgendwas komisches passiert und die Verbindung zur DB ist gekillt worden (was hattest du? Redis oder jsonl?) Deswegen ist der Adapterstart auf Fehler gelazfen und wurde danach vom Controller neu gestartet was dann tat.
                                        crunchip Forum Testing Most Active @apollon77 last edited by crunchip
                                        @apollon77 bin jetzt unterwegs, komm erst spät abend wieder nach hause.
                                        Mehr log gibts nicht, siehe js controller Thread, die host logstufe steht auf 'warn' ( werde ich fürs nächste mal zurück auf info stellen)
                                        Die letzten drei backitup Updates machten Probleme seit js controller v4, alle anderen updates funktionieren.
                                        Ich verwende jsonl, und das auch schon vor controller v4.
                                        ich hatte auch redis sicher in der Instanz deaktiviert, da die config angemeckert wurde.
                                          @simatec @thomas-braun Habe die influx-cli nun über den Paketmanager im ioBroker Container installiert und den Pfad zur DB leer gelassen. Läuft jetzt bei mir.
                                          Vielen Dank für die Unterstützung.
                                            @apollon77 @simatec habe jetzt host auf info und bin mit backitup zum Test zurück auf 2.3.1 und anschließend wieder hoch auf 2.3.2
                                            downgrade
                                            2022-02-15 00:26:29.488 - info: host.IoBroker iobroker upgrade backitup@2.3.1
                                            2022-02-15 00:26:31.962 - info: host.IoBroker iobroker Update backitup from @2.3.2 to @2.3.1
                                            2022-02-15 00:26:32.036 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                                            2022-02-15 00:26:32.218 - info: host.IoBroker "system.adapter.backitup.0" disabled
                                            2022-02-15 00:26:32.220 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                            2022-02-15 00:26:32.394 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
                                            2022-02-15 00:26:32.388 - info: backitup.0 (5928) Got terminate signal TERMINATE_YOURSELF
                                            2022-02-15 00:26:32.392 - info: backitup.0 (5928) cleaned everything up...
                                            2022-02-15 00:26:32.394 - info: backitup.0 (5928) terminating
                                            2022-02-15 00:26:32.395 - info: backitup.0 (5928) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2022-02-15 00:26:32.626 - info: host.IoBroker iobroker NPM version: 6.14.16Installing iobroker.backitup@2.3.1... (System call)
                                            2022-02-15 00:26:33.364 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2022-02-15 00:28:06.222 - info: host.IoBroker iobroker + iobroker.backitup@2.3.1updated 1 package in 92.668s
                                            2022-02-15 00:28:12.743 - info: host.IoBroker iobroker 154 packages are looking for funding run `npm fund` for details
                                            2022-02-15 00:28:12.824 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is started
                                            2022-02-15 00:28:13.015 - info: host.IoBroker "system.adapter.backitup.0" enabled
                                            2022-02-15 00:28:13.589 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 32195
                                            2022-02-15 00:28:13.591 - info: host.IoBroker iobroker Update "system.adapter.backitup.0"
                                            2022-02-15 00:28:13.802 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                            2022-02-15 00:28:13.965 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
                                            2022-02-15 00:28:14.061 - info: host.IoBroker iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                            2022-02-15 00:28:14.247 - info: host.IoBroker iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                            2022-02-15 00:28:14.259 - info: host.IoBroker iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                            2022-02-15 00:28:14.269 - info: host.IoBroker iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                            2022-02-15 00:28:14.279 - info: host.IoBroker iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                            2022-02-15 00:28:14.289 - info: host.IoBroker iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                            2022-02-15 00:28:14.299 - info: host.IoBroker iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                            2022-02-15 00:28:14.329 - info: host.IoBroker iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                            2022-02-15 00:28:14.386 - info: host.IoBroker iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                            2022-02-15 00:28:14.404 - info: host.IoBroker iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                            2022-02-15 00:28:14.421 - info: host.IoBroker iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                            2022-02-15 00:28:15.064 - info: host.IoBroker stopInstance system.adapter.backitup.0 killing pid 32195
                                            2022-02-15 00:28:15.067 - info: backitup.0 (32195) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                            2022-02-15 00:28:15.524 - info: host.IoBroker iobroker exit 0
                                            2022-02-15 00:28:15.688 - warn: backitup.0 (32195) redis get system.adapter.backitup.0.alive, error - Connection is closed.
                                            2022-02-15 00:28:15.693 - warn: backitup.0 (32195) redis get system.adapter.backitup.0.sigKill, error - Connection is closed.
                                            2022-02-15 00:28:15.726 - warn: backitup.0 (32195) Did not add default (none) value on creation of backitup.0.info.ccuNextTime: Connection is closed.
                                            2022-02-15 00:28:15.731 - warn: backitup.0 (32195) Did not add default (none) value on creation of backitup.0.info.iobrokerNextTime: Connection is closed.
                                            2022-02-15 00:28:16.000 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                            2022-02-15 00:28:17.216 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 32206
                                            2022-02-15 00:28:21.396 - info: backitup.0 (32206) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.9
                                            2022-02-15 00:28:21.585 - info: backitup.0 (32206) [iobroker] backup was activated at 05:30 every 1 day(s)
                                            upgrade
                                            2022-02-15 00:32:00.792 - info: host.IoBroker iobroker upgrade backitup@2.3.2
                                            2022-02-15 00:32:04.180 - info: host.IoBroker iobroker Update backitup from @2.3.1 to @2.3.2
                                            2022-02-15 00:32:04.376 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
                                            2022-02-15 00:32:04.654 - info: host.IoBroker "system.adapter.backitup.0" disabled
                                            2022-02-15 00:32:04.656 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                            2022-02-15 00:32:04.829 - info: backitup.0 (32206) Got terminate signal TERMINATE_YOURSELF
                                            2022-02-15 00:32:04.831 - info: backitup.0 (32206) cleaned everything up...
                                            2022-02-15 00:32:04.832 - info: backitup.0 (32206) terminating
                                            2022-02-15 00:32:04.835 - info: backitup.0 (32206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            2022-02-15 00:32:04.858 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
                                            2022-02-15 00:32:05.139 - info: host.IoBroker iobroker NPM version: 6.14.16
                                            2022-02-15 00:32:05.143 - info: host.IoBroker iobroker Installing iobroker.backitup@2.3.2... (System call)
                                            2022-02-15 00:32:06.102 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2022-02-15 00:32:09.971 - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2022-02-15 00:33:14.507 - info: host.IoBroker iobroker + iobroker.backitup@2.3.2updated 1 package in 68.184s
                                            2022-02-15 00:33:20.581 - info: host.IoBroker iobroker 154 packages are looking for funding run `npm fund` for details
                                            2022-02-15 00:33:20.647 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is started
                                            2022-02-15 00:33:20.854 - info: host.IoBroker "system.adapter.backitup.0" enabled
                                            2022-02-15 00:33:21.515 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 1538
                                            2022-02-15 00:33:21.534 - info: host.IoBroker iobroker Update "system.adapter.backitup.0"
                                            2022-02-15 00:33:21.773 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                            2022-02-15 00:33:21.806 - info: host.IoBroker iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                            2022-02-15 00:33:21.893 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
                                            2022-02-15 00:33:22.160 - info: host.IoBroker iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                            2022-02-15 00:33:22.170 - info: host.IoBroker iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                            2022-02-15 00:33:22.179 - info: host.IoBroker iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                            2022-02-15 00:33:22.189 - info: host.IoBroker iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                            2022-02-15 00:33:22.201 - info: host.IoBroker iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                            2022-02-15 00:33:22.212 - info: host.IoBroker iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                            2022-02-15 00:33:22.223 - info: host.IoBroker iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                            2022-02-15 00:33:22.232 - info: host.IoBroker iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                            2022-02-15 00:33:22.241 - info: host.IoBroker iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                            2022-02-15 00:33:22.251 - info: host.IoBroker iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                            2022-02-15 00:33:22.920 - info: host.IoBroker stopInstance system.adapter.backitup.0 killing pid 1538
                                            2022-02-15 00:33:22.923 - info: backitup.0 (1538) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                            2022-02-15 00:33:23.354 - info: host.IoBroker iobroker exit 0
                                            2022-02-15 00:33:23.468 - warn: backitup.0 (1538) Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                            2022-02-15 00:33:23.472 - warn: backitup.0 (1538) Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                            2022-02-15 00:33:23.475 - warn: backitup.0 (1538) redis get system.adapter.backitup.0.alive, error - Connection is closed.
                                            2022-02-15 00:33:23.477 - warn: backitup.0 (1538) redis get system.adapter.backitup.0.sigKill, error - Connection is closed.
                                            2022-02-15 00:33:23.483 - error: backitup.0 (1538) backitup.0 invalid config
                                            2022-02-15 00:33:23.739 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                            2022-02-15 00:33:25.172 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 1550
                                            2022-02-15 00:33:29.116 - info: backitup.0 (1550) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.9
                                            2022-02-15 00:33:29.236 - info: backitup.0 (1550) [iobroker] backup was activated at 05:30 every 1 day(s)
                                            170
                                            2780
                                            2344140
