    4. Test eCharts Adapter
      WernerS @Homoran last edited by
      hier das Ergebnis
      :~ $ iobroker -i
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start                                               Starts the js-controller
        iobroker stop                                                stops the js-controller
        iobroker restart                                             Restarts js-controller
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter
        iobroker install <adapter>                                   Installs a specified adapter
        iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter from system
        iobroker del <adapter>.<instance>                            Remove adapter instance
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload                                              Upload management
        iobroker object                                              Object management
        iobroker state                                               State management
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
      Options:
            --help     Show help  [boolean]
        -v, --version  Show version  [boolean]
      :~ $ node -v
      v15.7.0
      :~ $ nodejs -v
      v15.7.0
        Homoran Global Moderator Administrators @WernerS last edited by
        @werners sagte in Test eCharts Adapter:
        hier das Ergebnis
        nö!
        iobroker -i
        ist nicht
        @homoran sagte in Test eCharts Adapter:
        iobroker update -i
        aber das Grundübel ist deine grausame node/npm Basis.
        node -v v15.7.0
        ist eine Entwicklerversion (weil ungerade) und zusammen mit
        NPM version: 7.4.3
        nicht für ioBroker geeignet
          iobroker -i
          sorry für das iobroker -i
          was kann ich da jetzt tun? downgraden?
          Werner
          Homoran W 2 Replies Last reply Reply Quote 0
            downgraden?
            solltest du unbedingt machen.
            jede weitere Fehlersuche ergibt vorher keinen Sinn
              WernerS @WernerS last edited by
              @werners
              habe gerade gesehen es gibt eine 16.
              ich schau mal wie das update geht und melde mich dann wieder.
              Werner
                Homoran Global Moderator Administrators @WernerS last edited by Homoran
                Du hast aber schon gelesen, was ich geschrieben habe?
                Was steht denn bei dir im Info-Adapter zu deinem System?
                  Den Info adapter sehe ich zwar kann aber keine Instanz anlegen. Ist der dann nicht auf meinem master?
                  Werner
                    wo? ich sehe nichts 😉
                    ganz links in der Menüspalte sollte ein Eintrag (i) Info stehen
                    Das wählst du aus
                      ist wohl heute nicht so mein Tag. Ich hoffe jetzt ist es richtig 🙂
                      iobroker-slave01
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm
                      CPUs
                      Geschwindigkeit
                          600 MHz
                      Modell
                          ARMv7 Processor rev 4 (v7l)
                      RAM
                          924.21 MB
                      System-Betriebszeit
                          01:18:00
                      Node.js
                          v15.14.0 (Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                      NPM
                          7.7.6
                      Datenträgergröße
                          14.33 GB
                      freier Festplattenspeicher
                          10.81 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          16:09:32
                      Aktive Instanzen
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker-slave01
                      iobroker
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm
                      CPUs
                      Geschwindigkeit
                          1200 MHz
                      Modell
                      RAM
                          924.84 MB
                      System-Betriebszeit
                          01:48:38
                      Node.js
                          v15.7.0 (Es gibt eine neuere Version: v15.14.0 Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                      NPM
                          7.4.3
                      Datenträgergröße
                          14.33 GB
                          7.37 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          16:27:04
                      Aktive Instanzen
                          19
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker
                      iobroker-slave02
                      Plattform
                          linux
                      Betriebssystem
                          linux
                      Architektur
                          arm64
                      CPUs
                      Geschwindigkeit
                          600 MHz
                      Modell
                          unknown
                      RAM
                          3.71 GB
                      System-Betriebszeit
                          01:15:05
                      Node.js
                          v16.13.2 (Es gibt eine neuere Version: v16.14.0 Die Version v16.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                      NPM
                          8.4.1
                      Datenträgergröße
                          14.33 GB
                          11.03 GB
                      Anzahl der Adapter
                          390
                      Betriebszeit
                          03:04:26
                      Aktive Instanzen
                      location
                          /opt/iobroker/
                      Hostname
                          iobroker-slave02
                        Node.js v15.14.0 (Die Version v15.x von Node.js wird derzeit nicht vollständig unterstützt. - Empfohlene Version v14.19.0)
                        und warum willst du dann auf v16?
                        nicht ganz.
                        Hat aber geklappt
                          Thomas Braun Most Active @WernerS last edited by Thomas Braun
                          Nein. Ungerade nodeJS-Versionen willst du nicht.
                          Ich würde einheitlich auf allen Systemen die nodeJS@14 einsetzen.
                            WernerS @Thomas Braun last edited by
                            ok das wusste ich nicht, werds mir aber merken.
                            Wie kann ich die up- bzw downgraden?
                            Hoffe dass klappt dann Problemlos, werde aber vorher von allen ein Image machen.
                            Werner
                              @werners
                              In meiner Signatur steht drin wie man durch die Versionen turnen kann.
                                Wer lesen kann ist im vorteil 🙂 Da habe ich natürlich nicht geschaut.
                                Werde es morgen früh gleich mal angehen und mich wieder melden.
                                Danke für den schnellen super guten Support
                                Werner
                                  smartias @WernerS last edited by
                                  @werners Hallo werners,
                                  kannst du mir bitte sagen, wo und wie du die zwei x-Achsen eingestellt hast?
                                  Für die erste Linie kann ich unten/oben/nichts einstellen, für die 2. Linie sehe ich dazu keine Option (E-Charts in der Version 1.0.3, Node.js
                                  v14.19.0)
                                  Matthias
                                    Homoran Global Moderator Administrators @smartias last edited by
                                    @smartias sagte in Test eCharts Adapter:
                                    hat er doch gar nicht
                                      @Homoran
                                      Hallo
                                      jetzt sieht das so aus
                                      iobroker
                                      Plattform
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm
                                      CPUs
                                      Geschwindigkeit
                                          1200 MHz
                                      Modell
                                      RAM
                                          923.21 MB
                                      System-Betriebszeit
                                          02:47:40
                                      Node.js
                                          v14.19.0
                                      NPM
                                          6.14.16
                                      Datenträgergröße
                                          14.33 GB
                                          6.99 GB
                                      Anzahl der Adapter
                                          390
                                      Betriebszeit
                                          02:47:41
                                      Aktive Instanzen
                                          16
                                      location
                                          /opt/iobroker/
                                      Hostname
                                          iobroker
                                      iobroker-slave02
                                      Plattform
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm64
                                      CPUs
                                      Geschwindigkeit
                                          800 MHz
                                      Modell
                                          unknown
                                      RAM
                                          3.71 GB
                                      System-Betriebszeit
                                          02:30:02
                                      Node.js
                                          v14.19.0
                                      NPM
                                          6.14.16
                                      Datenträgergröße
                                          14.33 GB
                                          11 GB
                                      Anzahl der Adapter
                                          390
                                      Betriebszeit
                                          02:32:21
                                      Aktive Instanzen
                                      location
                                          /opt/iobroker/
                                      Hostname
                                          iobroker-slave02
                                      iobroker-slave01
                                      Plattform
                                          linux
                                      Betriebssystem
                                          linux
                                      Architektur
                                          arm
                                      CPUs
                                      Geschwindigkeit
                                          1400 MHz
                                      Modell
                                      RAM
                                          924.21 MB
                                      System-Betriebszeit
                                          02:13:45
                                      Node.js
                                          v14.19.0
                                      NPM
                                          6.14.16
                                      Datenträgergröße
                                          14.33 GB
                                          10.03 GB
                                      Anzahl der Adapter
                                          390
                                      Betriebszeit
                                          00:01:55
                                      Aktive Instanzen
                                          10
                                      location
                                          /opt/iobroker/
                                      Hostname
                                          iobroker-slave01
                                      Ich habe dann echarts installiert und vis neu gestartet. Und siehe da das widget ist da.
                                      Danke für eure Hilfe
                                      Werner
                                        Node.js v14.19.0
                                        NPM 6.14.16
                                        so muss es sein!
                                          smartias @Homoran last edited by
                                          ok, dann hatte ich den Post falsch verstanden:
                                          @werners said in Test eCharts Adapter:
                                          2.) Ich habe 2 getrennte x Achsen. Er schreibt mir die Werte nicht nebeneinander sondern übereinander oder legt einen Wert über den anderen.
                                          Wie kann ich denn die Daten von gestern mit denen von heute vergleichen? Hatte gehofft, zwei X-Achsen und eine davon mit Offset könnten das leisten. Ohne die zweite Achse plottet mir der Offset den gestrigen Tag neben/vor die heutigen Daten.
                                            Nö! Da stand das schon so, aber in der Grafik war es nicht x sondern y
                                            hier der gewünschte Screenshot
                                            echarts
                                            101
                                            624
                                            143579
