    4. Parser - Temperatursumme für Ausbringung Rasendünger
      Linedancer last edited by Linedancer
      ich rechne das direkt per Blockly mit meinen eigenen Daten. Die Temperaturen kommen dabei aus dem "Das Wetter" Adapter.
      Hier das Blockly dazu:
       <variables>
         <variable id="(szd7z@+_}[pfg9;t}z8">WaermesummeJahr</variable>
         <variable id="*p+kgd%FGcH}Evf_4zAD">Waermesumme</variable>
       </variables>
       <block type="schedule" id="nb6O:Ol~vdm1*OLiv$Ij" x="87" y="13">
         <field name="SCHEDULE">{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}</field>
           <block type="variables_set" id="CE.xM}HMUgq[hH;w6tz#">
             <field name="VAR" id="(szd7z@+_}[pfg9;t}z8">WaermesummeJahr</field>
               <block type="get_value" id="P:4nQPL!1YX;#E/,t]#|">
                 <field name="OID">0_userdata.0.Wetter.Waermesumme</field>
               <block type="variables_set" id="1]1}{i_+k(cle$%Vs,.[">
                 <field name="VAR" id="*p+kgd%FGcH}Evf_4zAD">Waermesumme</field>
                   <block type="math_arithmetic" id="t4JS5ViHiw31B3J_+EuH">
                     <field name="OP">DIVIDE</field>
                       <shadow type="math_number" id="St9?P3}e%@AR:hpu)=ry">
                         <field name="NUM">1</field>
                       <block type="math_arithmetic" id="x((|`-tM+kJr}dDE?e-q">
                         <field name="OP">ADD</field>
                           <shadow type="math_number" id="Q$wshD!)iqe=GaRD|?Y,">
                           <block type="get_value" id="{i!4/S8r+n574OG`OUKq">
                             <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value</field>
                           <shadow type="math_number" id="VS_6uKt^HS%}X;oLKmaf">
                           <block type="get_value" id="Cdd)3)rB~!3@kxINY:5+">
                             <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value</field>
                       <shadow type="math_number" id="C-b%[WMZ$)R!b7sLvI/C">
                         <field name="NUM">2</field>
                   <block type="controls_if" id="/Z+`G8(HAit;xuQ{W$kT">
                       <block type="logic_compare" id="oA4/tA1P*@k|r6OFT2c$">
                         <field name="OP">GT</field>
                           <block type="variables_get" id="w:zjAKuOX;Za,.;)0-Wb">
                           <block type="math_number" id="iJF,TlT@Gd085Om^Q|qB">
                             <field name="NUM">0</field>
                       <block type="controls_if" id="($}xrY%GKN|e;[m{0B9L">
                         <mutation elseif="2"></mutation>
                           <block type="logic_compare" id="i.e:uQ%$rjK:]ED?Q=f-">
                             <field name="OP">EQ</field>
                               <block type="time_get" id="^mZ%ArDgJR^j$,g)c-EF">
                                 <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="true"></mutation>
                                 <field name="OPTION">Mt</field>
                                 <field name="LANGUAGE">de</field>
                               <block type="text" id=",~Q5GNYN[mRIt!02W%Yy">
                                 <field name="TEXT">Januar</field>
                           <block type="math_change" id="NE~$CS]ZaF79;=cS*c5M">
                             <value name="DELTA">
                               <shadow type="math_number" id="Q7gYzfC/OzZsQ(w4f-Yn">
                               <block type="math_arithmetic" id="r^Mk1X{s4,Xf5AUWlRI#">
                                   <shadow type="math_number" id="[1dj7UJgwGGf@-2Brg]|">
                                   <block type="variables_get" id="AAP?+Q@|]ihuLPdb%Jbm">
                                   <shadow type="math_number" id="CH=@K^_]#`WIoyXx*G*K">
                                     <field name="NUM">0.5</field>
                         <value name="IF1">
                           <block type="logic_compare" id="xdU]7+I(fR9!7vT^z^#j">
                               <block type="time_get" id="03v3)B$6Wm(,Cx^cZ*^(">
                               <block type="text" id="R.1p60Q:GuH7Yngd;ho~">
                                 <field name="TEXT">Februar</field>
                         <statement name="DO1">
                           <block type="math_change" id="Oq{MCrx-wsM)],s]Mc^D">
                               <shadow type="math_number">
                               <block type="math_arithmetic" id="VX)]lo#E+c6k:g~,D*j;">
                                   <block type="variables_get" id="v7JU0pEn!b1fmX:TH8mT">
                                   <shadow type="math_number" id="{Q.[dB:ldR0f4#B=J8Fp">
                                     <field name="NUM">0.75</field>
                         <value name="IF2">
                           <block type="logic_compare" id="-s:$$`c8GnF@Vk!AA.a=">
                               <block type="time_get" id="kY`sffSg9U]rm5T0:WBk">
                                 <field name="OPTION">M</field>
                               <block type="math_number" id="3jh3=Z?G+u.?j{gW$Z|l">
                         <statement name="DO2">
                           <block type="math_change" id="8)!Lbk4v}GS,oen5+;7N">
                               <shadow type="math_number" id="JqDSo,acEx$%p3!O{jkQ">
                               <block type="variables_get" id="?V!RA2)3`hUW.)87#}h1">
                           <block type="update" id="7`B7I#{644I};S_]kVPj">
                               <block type="math_rndfixed" id="7Wzhnn[RAh@Zj%|v,0.+">
                                 <field name="n">1</field>
                                 <value name="x">
                                   <shadow type="math_number" id="T8wW+mWT~^!O2wO^!hyr">
                                     <field name="NUM">3.1234</field>
                                   <block type="variables_get" id="xe3O2[ak][_{t~|*QTBn">
                       <block type="controls_if" id="n,,ptrB;cQ@}M?D.^uL1">
                           <block type="logic_operation" id="g9TET@Bp,gR.[slMFfdi" inline="false">
                             <field name="OP">AND</field>
                               <block type="logic_compare" id="TmcSiSeTIbyxMxvjt=1J">
                                   <block type="get_value" id="/}i8@bG*@4]Q}?Cf.-TV">
                                   <block type="math_number" id=";`.ii6h[7M{oii}N|_q~">
                                     <field name="NUM">200</field>
                               <block type="logic_compare" id="6/^r]lc)ug4n4[!uv6:o">
                                 <field name="OP">LT</field>
                                   <block type="time_get" id="5|#hrg(]sD:84R?,Ty2+">
                                   <block type="math_number" id="9aK=zz+92p]?k)Lp]$Jl">
                                     <field name="NUM">4</field>
                           <block type="exec" id="HI{fYzGIIkdcR3q4R]rV">
                             <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                             <field name="WITH_STATEMENT">FALSE</field>
                             <field name="LOG">warn</field>
                             <value name="COMMAND">
                               <shadow type="text" id=")KS:jMelh@IC(Kn2)f8!">
                                 <field name="TEXT">signal-cli -u +491726731765 send -m "IoBroker lässt Grüßen!" +491726731765</field>
                               <block type="text_join" id=";9ySagY7N|{Yh[J`,^8^">
                                 <value name="ADD0">
                                   <block type="text" id="dwhL9StzAqjU~YK|b/CU">
                                     <field name="TEXT">signal-cli -u +4915xxxxxxxx send -m "</field>
                                 <value name="ADD1">
                                   <block type="text_join" id="BY4wScn^GpL7[MIf:K]s">
                                     <value name="ADD0">
                                       <block type="text" id="y*5lHDb]Ugl!)sW@Ei;I">
                                         <field name="TEXT">Die Wärmesumme Nutzgarten hat 200 überschritten</field>
                                     <value name="ADD1">
                                       <block type="text_newline" id="aV4*8r$8pdKpa!/F-s:D">
                                         <field name="Type">\n</field>
                                     <value name="ADD2">
                                       <block type="text" id="9XW!#68:9a(2}c6_DQK:">
                                         <field name="TEXT">Es ist Zeit mit der Gartenarbeit zu starten</field>
                                 <value name="ADD2">
                                   <block type="text" id="x#ctUyD8$D19]wPJVTEm">
                                     <field name="TEXT">" +4917xxxxxx</field>
           <block type="schedule" id="HEcsFvM)6F1t|ajRJU{f">
             <field name="SCHEDULE">{"time":{"exactTime":true,"start":"00:02"},"period":{"years":1,"yearDate":1,"yearMonth":1}}</field>
               <block type="update" id="s!}T`ul7U%HF`@7`*B$A">
                   <block type="math_number" id=":ky}ct0Wy=V)}6c%]V9e">
      Bernd 0 1 Reply Last reply Reply Quote 0
      • Bernd 0
        Bernd 0 @Linedancer last edited by
        @linedancer
        Hi Linedancer,
        vielen Dank für dein Script. Das funktioniert aber nur, wenn ich es seit 01.01. hätte laufen lassen, oder?
        Jetzt mitten im Jahr einsteigen wird nicht funktionieren, oder?
        L Homoran 2 Replies Last reply Reply Quote 0
          Linedancer @Bernd 0 last edited by
          @bernd-0
          Da hast du recht.
          Du kannst natürlich den aktuellen Wert von der Website die du parsen wolltest in den Datenpunkt Waermesumme (den du händisch anlegen musst) reinschreiben, dann zählt das Blockly von diesen Wert weiter.
            Homoran Global Moderator Administrators @Bernd 0 last edited by
            @bernd-0 ich weiß ja nicht wo du wohnst.
            Aber die Suchen nach Grünlandtemperatursumme (oder Teilen davon) brint etliche Seitn, die sich auslesen lassen.
            z.B. für RLP:
            https://www.dlr.rlp.de/Agrarmeteorologie/Landwirtschaft/Ackerbau-Gruenland/Monitoring/Gruenland-Temperatur
            • Bernd 0
              Bernd 0 @Homoran last edited by
              @homoran Leider konnte ich keine Seite finden, die für meinen Standort (nähe Nürnberg) mir den Wert anzeigt.
                Homoran Global Moderator Administrators @Bernd 0 last edited by Homoran
                @bernd-0 sagte in Parser - Temperatursumme für Ausbringung Rasendünger:
                und was ist mit:
                https://www.wetter-by.de/Agrarmeteorologie-BY/Landwirtschaft/Ackerbau/Gruenlandtemperatur
                welcher Ort?
                • Bernd 0
                  @homoran hmm. Scheinbar auch zu blöd zu googlen. 😞 Ort wäre: Röckersbühl
                    und ich hab den Mund zu voll genommen - da sind auch keine Daten in plain Text drin 😞
                    ich bleib dran
                    EDIT:
                    Auf der Suche nach der herkunft der Daten bin ich über ein "parser blocking (cross site) Script...." gestolpert.
                    Ich fürchte dass selbst wenn ich da irgendwo die Daten finde du mit dem Parser kein Ergebnis bekommst
                    • Bernd 0
                      @homoran Vielen Dank, dass du mir helfen willst 🙂
                      T Homoran 2 Replies Last reply Reply Quote 0
                        tombox @Bernd 0 last edited by tombox
                        @bernd-0 Also ich nutze
                        https://www.isip.de/isip/servlet/isip-de/entscheidungshilfen/gruenland
                        Wenn man die beste gefunden hat kann ich sie schnell parsen
                          Hab da was gefunden:
                          Ist nicht ganz an der selben Stelle:
                          https://www.wetter-rosstal.de/statistik.php?typ=tempsum
                          Wärmesumme\s\ss[^;]+;[^>]+>([\d\,]+)
                          Bitte überprüfe noch die die Nutzungsbedingungen der Seite!
                            Homoran Global Moderator Administrators @tombox last edited by Homoran
                            @tombox sagte in Parser - Temperatursumme für Ausbringung Rasendünger:
                            ich fand die Seite auch gut, die Station Röckersbühl habe ich da auch gefunden, aber kam nicht an die Daten ran
                            • Bernd 0
                              @homoran said in Parser - Temperatursumme für Ausbringung Rasendünger:
                              Wärmesumme\s\ss[^;]+;[^>]+>([\d,]+)
                              Ich bräuchte nicht die Temperatursumme sondern die Gründlandtemperatur.
                              https://www.wetter-rosstal.de/statistik.php?jahre=&typ2=gruenland&typ=gruenland&end=121&year=0&size=0&diag_typ=2&prozent=0&monthtyp=0&monthtyp2=0#diagramm
                                @bernd-0 dann nimm die doch 🙂
                                r-Summe\ss[^;]+;[^>]+>([\d\,]+)
                                Typ Zahl mit Komma
                                • Bernd 0
                                  Klasse!
                                  Jetzt habe ich sogar zwei Lösungen, welche funktionieren. Sowohl das Blockly-Script von @Linedancer und die Parser Abfrage dank @Homoran.
                                  Vielen Dank!
                                  • Bernd 0
                                    @Homoran
                                    Versuche gerade das regex von dir zu verstehen mit https://regex101.com/ aber so wirklich komme ich nicht dahinter. Schreibt man das regex von Hand oder erhält man das durch Markierung des Textes?
                                      das musst du schon von Hand schreiben.
                                      Hier hatte ich das mal etwas näher erklärt
                                      https://forum.iobroker.net/topic/50790/gelöst-parser-und-umlaute/6?_=1644850297611
                                      • Bernd 0
                                        @homoran Super - vielen Dank. Das hat geholfen!
                                        1203
