    4. massive CPU Auslastung
    • da_Woody
      da_Woody @apollon77 last edited by
      @apollon77 noch kein eigenes thema? ok.
      ich teste schon den ganzen tag herum. in der früh downgrade gemacht auf 3.3.22. ok nicht kontrolliert. alle scripte ausgeschalten, einige adapter gestoppt. danach teilweise normale werte bei CPU und RAM. mit ausreissern auf über 100%.
      js-controller update auf 4.0.9, aber, zeile 103, Update js-controller from @4.0.8 to @4.0.9?
      woody@ioBroker:~$ iob backup
      host.ioBroker 137495 states saved
      host.ioBroker 176283 objects saved
      Backup created: /opt/iobroker/backups/2022_02_15-12_24_08_backupiobroker.tar.gz
      woody@ioBroker:~$ iob stop
      woody@ioBroker:~$ iob update
      Used repository: Beta (latest)
      Adapter    "admin"        : 5.3.0    , installed 5.3.0
      Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.3.2    , installed 2.3.2
      Adapter    "birthdays"    : 1.0.0    , installed 1.0.0
      Adapter    "bydbatt"      : 1.0.7    , installed 1.0.7
      Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "followthesun" : 0.3.8    , installed 0.3.8
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
      Adapter    "ical"         : 1.11.6   , installed 1.11.6
      Adapter    "influxdb"     : 2.4.0    , installed 2.4.0
      Adapter    "info"         : 1.9.18   , installed 1.9.18
      Adapter    "iot"          : 1.9.5    , installed 1.9.5
      Adapter    "iqontrol"     : 2.0.0-rc2.1, installed 2.0.0-rc2.1
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Controller "js-controller": 4.0.9    , installed 4.0.8  [Updatable]
      Adapter    "linux-control": 1.1.4    , installed 1.1.4
      Adapter    "logparser"    : 1.1.0    , installed 1.1.0
      Adapter    "meteoalarm"   : 2.1.1    , installed 2.1.1
      Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
      Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
      Adapter    "octoprint"    : 3.0.1    , installed 3.0.1
      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
      Adapter    "ping"         : 1.5.2    , installed 1.5.2
      Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
      Adapter    "shelly"       : 5.1.3    , installed 5.1.3
      Adapter    "shuttercontrol": 1.4.11  , installed 1.4.11
      Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
      Adapter    "snmp"         : 0.5.0    , installed 0.5.0
      Adapter    "socketio"     : 4.1.2    , installed 4.1.2
      Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
      Adapter    "synology"     : 1.1.3    , installed 2.0.1
      Adapter    "trashschedule": 1.4.2    , installed 1.4.2
      Adapter    "vis"          : 1.4.12   , installed 1.4.12
      Adapter    "weatherunderground": 3.3.1, installed 3.3.1
      Adapter    "web"          : 4.1.4    , installed 4.1.4
      Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
      Adapter    "whatsapp-cmb" : 0.1.6    , installed 0.1.6
      Adapter    "wled"         : 0.6.3    , installed 0.6.3
      Adapter    "ws"           : 1.1.4    , installed 1.1.4
      woody@ioBroker:~$ iob fix
      library: loaded
      Library version=2022-02-10
          Welcome to the ioBroker installation fixer!
          Script version: 2022-02-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      [sudo] Passwort für woody:
      OK:1 http://security.debian.org/debian-security buster/updates InRelease
      OK:2 http://deb.debian.org/debian buster InRelease
      Holen:3 http://deb.debian.org/debian buster-updates InRelease [51,9 kB]
      OK:4 https://deb.nodesource.com/node_14.x buster InRelease
      Es wurden 51,9 kB in 1 s geholt (101 kB/s).
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      woody@ioBroker:~$ iob upgrade self
      Stopped Objects DB
      Stopped States DB
      NPM version: 6.14.16
      Installing iobroker.js-controller@4.0.9... (System call)
      > iobroker.js-controller@4.0.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      > iobroker.js-controller@4.0.9 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Successfully migrated 179884 objects to Redis Sets
      object _design/system updated
      The following notifications happened during sync:
      - Ignoring Directory "fronius.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "proxmox" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "proxmox.admin" because officially not created as meta object. Please remove directory!
      - Ignoring Directory "switchbot-hub.admin" because officially not created as meta object. Please remove directory!
        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\xxx\r\n-----END RSA PRIVATE KEY-----\r\n",
        "defaultPublic": "-----BEGIN CERTIFICATE-----\r\xxx\r\n-----END CERTIFICATE-----\r\n"
      Update certificate defaultPrivate
      The object "system.certificates" was updated successfully.
      Update certificate defaultPublic
      + iobroker.js-controller@4.0.9
      added 1 package from 2 contributors, removed 1 package and updated 26 packages in 91.61s
      74 packages are looking for funding
        run `npm fund` for details
      woody@ioBroker:~$ iob start
      woody@ioBroker:~$ iob status
       Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.ioBroker"]
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      woody@ioBroker:~$
      verwirrung wird nicht weniger...
      alles auf latest gezogen, neuen downgrad gemacht.
      woody@ioBroker:~$ npm install iobroker.js-controller@3.3.22
      > iobroker.js-controller@3.3.22 preinstall /home/woody/node_modules/iobroker.js-controller
      > iobroker.js-controller@3.3.22 install /home/woody/node_modules/iobroker.js-controller
      object _design/custom updated
      ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
      ioBroker wants to make sure to deliver the most stable smart home system.
      To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
      THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
      For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
      If you want to disable the error reporting you can use the command
      'iobroker plugin disable sentry'
      This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
      npm WARN saveError ENOENT: no such file or directory, open '/home/woody/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/home/woody/package.json'
      npm WARN woody No description
      npm WARN woody No repository field.
      npm WARN woody No README data
      npm WARN woody No license field.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      + iobroker.js-controller@3.3.22
      updated 1 package and audited 485 packages in 9.215s
      12 packages are looking for funding
      found 21 vulnerabilities (13 low, 5 moderate, 3 high)
        run `npm audit fix` to fix them, or `npm audit` for details
         │      New major version of npm available! 6.14.16 → 8.5.0      │
         │   Changelog: https://github.com/npm/cli/releases/tag/v8.5.0   │
         │               Run npm install -g npm to update!               │
      woody@ioBroker:~$
      No connection to databases possible ...
      woody@ioBroker:~$
      admin neu gestartet, den ganzen rechner neu gestartet:
      top zickt immer noch rum.
      top - 15:50:41 up 29 min,  1 user,  load average: 2,10, 2,15, 1,91
      Tasks: 114 total,   3 running, 111 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 67,9 us,  3,6 sy,  0,0 ni, 25,0 id,  0,2 wa,  0,0 hi,  0,7 si,  2,6 st
      MiB Mem :   5962,7 total,   1450,6 free,   4010,7 used,    501,5 buff/cache
      MiB Swap:    975,0 total,    974,7 free,      0,3 used.   1719,4 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
        351 iobroker  20   0 1890260   1,0g  35556 R 125,5  17,8  25:26.79 iobroker.js-con
        509 iobroker  20   0 1086652 237768  30856 S  11,3   3,9   3:28.99 io.mqtt.0
        785 iobroker  20   0  950776 351280  31000 S   5,3   5,8   0:37.79 io.simple-api.0
        536 iobroker  20   0  726040 134820  31164 S   2,3   2,2   1:16.09 io.shelly.0
        416 iobroker  20   0 1132504 423056  30760 S   0,7   6,9   1:39.00 io.javascript.0
        629 iobroker  20   0  676236  82032  30828 S   0,7   1,3   0:33.52 io.sonoff.0
         10 root      20   0       0      0      0 R   0,3   0,0   0:01.00 rcu_sched
        730 iobroker  20   0   10,6g  73164  32436 S   0,3   1,2   0:03.34 io.linux-contro
        763 iobroker  20   0  672868  76884  31208 S   0,3   1,3   0:13.60 io.octoprint.0
        845 iobroker  20   0  962872 108392  31388 S   0,3   1,8   0:10.23 io.web.0
        860 iobroker  20   0  671248  71196  30932 S   0,3   1,2   0:02.64 io.meldungslist
          1 root      20   0   21920   9760   7656 S   0,0   0,2   0:01.22 systemd
          2 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kthreadd
          3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
          4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
          6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-kblockd
          8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
          9 root      20   0       0      0      0 S   0,0   0,0   0:00.09 ksoftirqd/0
         11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_bh
         12 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 migration/0
         14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
         15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
         16 root      rt   0       0      0      0 S   0,0   0,0   0:00.36 migration/1
         17 root      20   0       0      0      0 S   0,0   0,0   0:00.44 ksoftirqd/1
         19 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
         20 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kdevtmpfs
         21 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
         22 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
         23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
         24 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
         25 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
         26 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kcompactd0
         27 root      25   5       0      0      0 S   0,0   0,0   0:00.00 ksmd
         28 root      39  19       0      0      0 S   0,0   0,0   0:00.34 khugepaged
         29 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 crypto
         30 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
         31 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
         32 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 edac-poller
         33 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 devfreq_wq
         34 root      rt   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
         36 root      20   0       0      0      0 S   0,0   0,0   0:00.08 kswapd0
         54 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
         55 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 ipv6_addrconf
         65 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kstrp
      inder proxmox GUI sind teilweise "normale" werte, bis zu extrem.
        Thomas Braun Most Active @da_Woody last edited by Thomas Braun
        @da_woody sagte in js-controller 4.0 jetzt im BETA/LATEST!:
        Da stehst du im falschen Verzeichnis.
        Vorher in /opt/iobroker wechseln.
        • da_Woody
          da_Woody @Thomas Braun last edited by
          @thomas-braun wurde vor paar tagen erklärt, daß das automatisch passiert.
          soll heißen, das ich jetzt 2 js-controller im system habe?
          würde die last erklären, oder?
            Nicht, wenn du direkt mit npm hantierst. Das installiert immer in das Verzeichnis, in welchem es aufgerufen wurde.
            Wenn der wrapper
            iobroker add MODULNAME
            verwendet wird ist es egal, der setzt das richtige Verzeichnis.
            Möglich.
            Ebenfalls möglich.
            • da_Woody
              da_Woody @Thomas Braun last edited by da_Woody
              @thomas-braun dann kann ich nur verweisen:
              Eine alte 3.3.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen.
                @da_woody
                Stimmt ja auch. Der Befehl muss aber halt im richtige Verzeichnis ausgeführt werden. Der Hinweis fehlt an der Stelle. Aber als Beta-Tester sollte man das eh wissen und selbstständig daran denken. Ist halt 'Handwerkzeug' für einen Beta-Testling.
                • da_Woody
                  @thomas-braun ok, passt. für dich ist beta tester gleich linux guru...
                    @da_woody
                    Nö.
                    Aber 'Handwerkzeug' ist 'Handwerkzeug'. Ich vermute, npm tickt auf Windows auch nicht anders, hat also mit dem Betriebssystem nix zu tun.
                    • da_Woody
                      @thomas-braun was kommst du mir jetzt mit windows???
                      du liest irgenwo root, springst sofort an.
                      du liest windows, springst sofort an.
                      manchmal versteh ich dich nicht...
                        @da_woody
                        Was denn?
                        Nein, für Beta-Testing braucht man kein Linux-Guru sein, weil npm / nodejs als plattformunabhänigige Laufzeitumgebung überall mehr oder weniger gleich tickt.
                        Dann kannst du auch genauso behaupten, man müsse ein 'Windows-Guru' sein.
                        Muss man halt auch nicht. Aber man muss seine verwendeten Werkzeuge kennen. Nicht mehr und nicht weniger habe ich gesagt.
                        da_Woody 1 Reply Last reply Reply Quote 1
                        • da_Woody
                          @thomas-braun ich bezeichne mich sicher nicht als 'Windows-Guru", aber dort hab ich noch nie npm gebraucht.
                          werkzeuge kann man nur verwenden, wenn man sich damit auskennt. wie ich schon oft geschrieben habe, der pinguin ist nicht meins. bin aber lernfähig. du bist offensichtlich mit linux "aufgewachsen", kennst die regeln dort auswendig. ich bin halt mit dos "aufgewachsen" und kenn mich mit windoof besser aus.
                          sinn und zweck eines forums ist, einem unbedarfteren zu helfen und nicht ihn mit wertfreien ansagen runter zu machen...
                            @da_woody
                            Wenn du die 'Eier hast' als root oder Beta-Tester oder was weiß ich hier aufzutreten, dann musst du auch damit rechnen, wenn da mehr oder weniger dezente Hinweise kommen, wenn die Schuhe offenbar eine Nummer zu groß sind.
                            Ist allerdings jetzt schwer OffTopic hier im Thread.
                            • Negalein
                              Negalein Global Moderator @apollon77 last edited by
                              @apollon77 sagte in massive CPU Auslastung:
                              @Homoran s hiebst du bitte die Performance Posts in was eigenes.
                              hab ich gerade erledigt
                                @da_woody
                                BTT: Deine Beobachtung mit der hohen Last wäre eigentlich nicht uninterressant. Eine saubere Installation vorausgesetzt.
                                So würde ich behaupten: Irgendwie krumm und schief und doppelt und 'irgendwie' installiert; kann man so gar nichts draus ableiten.
                                • AlCalzone
                                  @da_Woody @thomas-braun bitte diskutiert das woanders, z.B. im Chat
                                  laut letztem top ist ja beim Skript-Adapter jetzt Ruhe. MQTT ist noch ein bisschen busy:
                                  Ich kann mich aber immer noch nicht erinnern, die INPUT/OUTPUT-Werte gesehen zu haben. Ist doch nicht so schwer, da mal nen Screenshot zu machen, etwa so?
                                  • da_Woody
                                    @thomas-braun bitte hör endlich damit auf. wenn du meine logs lesen würdets, wirst du sehn, daß ich als woody unterwegs bin. lass dein root geschreibsel.
                                      @da_woody
                                      Tu ich.
                                      Wo hab ich denn was von root geschrieben?
                                      Ich hab nur geschrieben, dass du im falschen Vezeichnis stehst, nämlich im home von woody. Hab ich deinem Log entnommen.
                                      • da_Woody
                                        @thomas-braun immer wieder schreibst du "root hampeln" in diverse postings.
                                        endlich hast du mich aufgeklärt wo ein problem sein könnte! war das so schwer, das gleich im text zu schreiben?
                                        eine einfache erklärung, "du hast das vllt im falschen verzeichniss gemacht" mit einer lösungserklärung wie man das gerade biegen kann, fällt dir nicht ein.
                                        kann es jetzt sein, daß ich im system einen js-controller und in meinem woody, oder wo anders einen am laufen habe?
                                        keine ahnung ob man sowas in top sehen würde. für mich ist die ordnerstruktur unter linux noch immer ein "spanisches dorf"
                                        vllt wäre es ein lösung alle js-controller, wenn zu finden, zu deinsten und dann eine neue am richtigen platz reintackern?
                                        Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @da_Woody last edited by
                                          @da_woody sagte in massive CPU Auslastung:
                                          aber hier diesmal nicht!
                                          und was ist das?:
                                          @thomas-braun sagte in massive CPU Auslastung:
                                          dazu fehlen Informationen was genau bereits alles auf deinem System krumm ist.
                                            Wenn es angebracht ist tue ich das. Stimmt.
                                            Tun nämlich meist genau die Kandidaten, die es besser nicht tun würden. Ist nämlich oft nicht anderes als 'rumgehampel'.
                                            Wovon sprichst du konkret?
                                            Doch. Aber ich geb dir die Chance dein Handwerkszeug zu erlernen.
                                            Wie man in Verzeichnisse wechselt muss ich hoffentlich nicht erklären?
                                            Das ist nämlich dann die Frage 'wo fängst du an, wo hörst du auf?'
                                            Man würde einen Prozess js-controller (oder ähnlich) sehen, der unter dem user woody läuft. Ich würde das aber anders nachschauen. Mit htop geht es aber z. B. auch. Einfach nach dem user sortieren.
                                            Was willst denn wissen? User-Dateien liegen in /home/USERNAME, im login prompt als ~ abgekürzt. Das habe ich deinem log (ja, ich lese das!) entnehmen können.
                                            Andere Verzeichnisse als das home-Verzeichnis stehen immer mit absolutem Pfad im login prompt. Weil das ganze u. U. so wichtig ist hätten deine Helfer auch ganz gerne vollständige Ein- wie Ausgaben aus der Konsole, wenn um Hilfe gerufen wird.
                                            146
                                            20914
