    3. Einsteigerfragen
    4. Problem Installation auf Raspi4
      A Former User last edited by Homoran
      Bin nocham Probieren mit diesem Forum, daher der screenshot.
      Anbei die Textausgabe
      [22:46:00] root@openhabraspi4:/opt/iobroker# npm i iobroker.js-controller --production > install_npm.txt
      In file included from ../../nan/nan.h:58,
      from ../src/unix_dgram.cc:5:
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void ()(v8::Localv8::Object)’ to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void*)’} [-Wcast-function-type]
      (node::addon_register_func) (regfunc),
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
      NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(unix_dgram, Initialize)
      from ../src/main.cpp:3:
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(diskusage, Init)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 22
      npm ERR! iobroker.js-controller@3.3.22 install: node iobroker.js setup first
      npm ERR! Exit status 22
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! /home/iobroker/.npm/_logs/2022-02-15T22_02_34_452Z-debug.log
      [23:02:34] root@openhabraspi4:/opt/iobroker# npm i iobroker.js-controller --production >> /home/iobroker/install_npm.txt
      npm ERR! errno 22
      npm ERR!
      MOD-Edit: Code in code-tags gesetzt!
      Ich lasse mich gern belehren - auch wenn es mir unverständlich erscheint - daß ein funktionstypen missmatch in einer headerdatei
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),  .....
      durch den Aufruf des make Lauf als root entsteht?
      MOD EDIT: LOG in Code Tags gesetzt
        Thomas Braun Most Active @Guest last edited by Thomas Braun
        @goofy1800
        Die Meldungen vom kompilieren sind harmlos. Aber du eierst da immer noch als root rum.
        Und bitte CodeTags verwenden. Spoiler sind nicht so wichtig.
          @Thomas-Braun
          habe das ganze eben nochmals als normaler user mit sudo gemacht: -> ditto gleiche Fehlermeldung
          Thomas Braun wendy2702 3 Replies Last reply Reply Quote 0
            @goofy1800
            Du hast dir ja jetzt auch den cacache mit falschen Rechten zugeballert.
            • wendy2702
              wendy2702 @Guest last edited by
              @goofy1800 Was gemacht ?
              Vollständiges Logfile bitte.
              Ist das eine komplette neu installation oder eine vorhandene Linux installation?
                @goofy1800 sagte in Problem Installation auf Raspi4:
                Aufruf des Installations-Skripts mit
                sudo curl blablubb
                oder was hast du jetzt gemacht?
                  @Thomas-Braun
                  Ich finde diese Antworten "jetzt hast du dir auch noch den cache zugeballert" gegenüber einem Forumsneuling vorsichtig ausgedrückt nicht gerade zielführend...
                  wie der Aufruf mit sudo geht hat sich auch zu mir rumgesprochen....
                  @wendy2702
                  bestehende seit ca. einem Jahr laufende Linuxinstallation mit uA. einer z-wave.me Installation u. einem vpn-server.
                  Vor iobroker hatte ich versuchsweise "openhab" installiert, aber wieder entfernt.```
                  code_text
                  [23:19:06] root@openhabraspi4:/home/moelli# sudo curl -sLf https://iobroker.net/install.sh | bash -
                  library: loaded
                  Library version=2022-02-10
                      Welcome to the ioBroker installer!
                      Installer version: 2022-02-13
                      Installing prerequisites (1/4)
                  OK:1 https://repo.mosquitto.org/debian buster InRelease
                  Holen:2 https://repo.z-wave.me/z-way/raspbian buster InRelease [1.806 B]
                  OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:4 http://archive.raspberrypi.org/debian buster InRelease
                  Ign:5 http://repos.azulsystems.com/debian stable InRelease
                  OK:6 http://repos.azulsystems.com/debian stable Release
                  OK:7 https://packages.grafana.com/oss/deb stable InRelease
                  OK:8 http://deb.debian.org/debian buster-backports InRelease
                  OK:9 https://deb.nodesource.com/node_14.x buster InRelease
                  OK:10 https://repos.influxdata.com/debian buster InRelease
                  OK:11 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
                  Es wurden 1.806 B in 5 s geholt (390 B/s).
                  Changing npm registry to https://registry.npmjs.org
                  Installed gcc-c++
                      Creating ioBroker user and directory (2/4)
                  Created /etc/sudoers.d/iobroker
                  Directory /opt/iobroker created
                      Installing ioBroker (3/4)
                  /root/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /root/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                  npm ERR! errno 22
                  npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
                  npm ERR!
                  npm ERR!     /root/.npm/_logs/2022-02-15T22_20_44_642Z-debug.log
                      Finalizing installation (4/4)
                  Enabling autostart...
                  Autostart enabled!
                  Fixing directory permissions...
                      ioBroker was installed successfully
                      Open http://192.168.11.117 192.168.11.217 192.168.55.1 10.6.0.1:8081 in a browser and start configuring!
                  You need to re-login before doing anything else on the console!
                  [23:20:46] root@openhabraspi4:/home/moelli# sudo systemctl status iobroker
                  ● iobroker.service - ioBroker Server
                     Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset:
                     Active: activating (auto-restart) (Result: exit-code) since Tue 2022-02-15 23
                       Docs: http://iobroker.net
                    Process: 22589 ExecStart=/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobro
                   Main PID: 22589 (code=exited, status=1/FAILURE)
                  Thomas Braun wendy2702 2 Replies Last reply Reply Quote 0
                    @goofy1800
                    Jetzt mal ernsthaft:
                    Wo steht, dass der root (auch noch mit 'sudo' kombiniert...) das Installationsskript aufruft?
                    In der verlinkten Anleitung steht, dass der User pi ein einfaches
                    absetzt. Nicht mehr, nicht weniger.
                    Alternativ halt auch mit einem anderen Standarduser (der sudo-Rechte erlangen kann) auszuführen. Dann funktioniert das auch. Ich weiß das, ich hab das schon so gemacht.
                    • wendy2702
                      @goofy1800
                      Wieso hast du so viele Netzwerk Interfaces? Keine Ahnung ob das von der Fehlerhaften installation kommt oder deine Konfiguration das hergibt.
                      Was du mal versuchen kannst um noch bisschen was zu retten:
                      cd /opt/iobroker/
                      npm install iobroker.js-controller@3.3.22
                      Wenn fertig mal
                      iob fix
                      iob start
                        @Thomas-Braun
                        völlig egal mit welchem user (pi/moelli/root): es bleibt bei der Fehlermeldung der typmissmatch in der headerdatei.
                        @wendy2702
                        erstmal dankefür Deine Hilfe: netzwerkinterfaces für vpn
                        $ cd /opt/iobroker
                        $ npm install iobroker.js-controller@3.3.22
                        > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                        > node lib/preinstallCheck.js
                        NPM version: 6.14.16
                        > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
                        > node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                        /home/moelli/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                        /home/moelli/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                          COPY Release/unix_dgram.node
                        make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                        > node rebuild.js
                        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                        > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                        > node-gyp rebuild
                        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                          CXX(target) Release/obj.target/diskusage/src/main.o
                          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                          SOLINK_MODULE(target) Release/obj.target/diskusage.node
                          COPY Release/diskusage.node
                        make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                        > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
                         Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
                        Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
                        Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
                        Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
                        No connection to databases possible ...
                        npm ERR! errno 22
                        npm ERR!
                        npm ERR!     /home/moelli/.npm/_logs/2022-02-15T22_56_22_260Z-debug.logcode_text
                        der compiler motzt weiter über nan.h und node.h und erzeugt nicht js-controller. Insofern startet IOB auch nicht und es gibt keine Verbindung zu Port 9001.
                        Für mich sieht das nach einer Incompatibiltät zw java und dden benutzten C-Biblotheken aus.
                        Erst mal danke und gute nacht - gibt sonst auch noch Dinge die man um die Uhrzeit macht...
                          Lass ihn motzen. Das ist vollkommen normal.
                          Nicht normal ist das Nichterreichen der Datenbank.
                          Läuft da schon was anderes auf dem Port?
                            die Idee nach der Portbelegung zu schauen, war nicht schlecht:
                            Port 9001 Ausgabe von netstat:
                            $ sudo netstat -tulpn |grep 9001
                            [sudo] Passwort für ****:
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      426/node
                            code_text
                            pid 426 betrifft noch einen openhab Prozeß "frontail", eigentlich ist openhab deinstalliert:
                               426 	frontail 	vor 2 Tagen 	node /usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-high ...
                                  1180 	frontail 	vor 2 Tagen 	tail -n 200 -F /var/log/openhab/openhab.log /var/log/openhab/events.log
                            werde demnächst weiter suchen, erstmal danke
                              Abschalten von frontail und anschließender Aufruf des Installscriptes ergab dann folgendes:
                              [20:44:16] root@openhabraspi4:/opt/iobroker# systemctl status iobroker
                                 Active: active (running) since Wed 2022-02-16 20:43:22 CET; 2min 11s ago
                               Main PID: 14896 (iobroker.js-con)
                                  Tasks: 11 (limit: 4915)
                                 CGroup: /system.slice/iobroker.service
                                         └─14896 iobroker.js-controller
                              Feb 16 20:43:22 openhabraspi4 systemd[1]: Started ioBroker Server.
                              lines 1-10/10 (END)
                              code_text
                              ich kann aber über den Port 8081 dann die web-Oberfläche nicht aufrufen, egal ob über die IP Adresse oder localhost:8081 -> Verbindung abgelehnt.
                              die Kontrolle mit netstat zeigt keinen offenen Port unter 8081 an,
                              9001 erscheint.
                              code[20:30:58] root@openhabraspi4:/home/moelli# netstat -tulpn | grep 8081
                              _text
                              [20:46:08] root@openhabraspi4:/opt/iobroker# netstat -tulpn | grep 9001
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      14896/iobroker.js-c
                              etwas ratlos
                                etwas ratlos
                                Immer noch root.
                                • wendy2702
                                  wendy2702 last edited by
                                  als USER:
                                  iob list instances
                                    ich habe alle Varianten durchgespielt: root, pi, sonst. user
                                    bei user kommt ungültige Gruppe user****:user****
                                      @goofy1800
                                      Du sollst halt nicht als root da rumhampeln.
                                      Das ist jetzt Rat genug an der Stelle.
                                        A Former User @Thomas Braun last edited by
                                        pi@openhabraspi4:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                                        library: loaded
                                           You might need to enter your password a couple of times.
                                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                        OK:2 http://deb.debian.org/debian buster-backports InRelease
                                        OK:4 https://packages.grafana.com/oss/deb stable InRelease
                                        OK:7 https://repos.influxdata.com/debian buster InRelease
                                        Holen:8 https://repo.z-wave.me/z-way/raspbian buster InRelease [1.806 B]
                                        OK:9 https://deb.nodesource.com/node_16.x buster InRelease
                                        OK:10 https://repo.mosquitto.org/debian buster InRelease
                                        Installed gcc-c++
                                        Autostart enabled!
                                        ode_text
                                        ich finde Ihren Ton (rumhampeln) nicht gerade angemessen, man wweiß ja nicht wen man auf der Gegenseite vor sich hat - ....
                                        Thomas Braun wendy2702 Homoran 3 Replies Last reply Reply Quote 0
                                          Einen Goofy. Sehe ich.
                                          • wendy2702
                                            Leute die versuchen einem zu helfen.
                                            Laut fixer sollte IOB laufen.
                                            Wie die IP Addressen zustande kommen erschliesst sich mir aktuell nicht da ich die Konfig vom PI nicht kenne, daher kann ich nicht sagen welche jetzt zu verwenden wäre.
                                            1333
