    4. massive CPU Auslastung
      Thomas Braun Most Active @da_Woody last edited by
      @da_woody sagte in massive CPU Auslastung:
      kann das wetterstation gewesen sein?
      Klar. Insbesondere, wenn das (unnötigerweise wohl) als root läuft. Dessen Prozesse kann man nicht so einfach rauskicken.
        apollon77 @da_Woody last edited by
        @da_woody Nein, die hat ja nix mit dem File zu tun. Ich denke du warst ggf nach dem Stoppen zu schnell
        • da_Woody
          da_Woody @Thomas Braun last edited by
          hmm, eigentlich so gemacht wie es in der beschreibung steht...
          anyway. nach dem stop ja offensichtlich weg.
          trotzdem kommt
          No connection to databases possible ...
          woody@ioBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
          > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.16
          > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm ERR! code ELIFECYCLE
          npm ERR! errno 22
          npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
          npm ERR! Exit status 22
          npm ERR!
          npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T13_08_27_568Z-debug.log
          notfalls hab ich mal eine 2. VM jetzt am laufen. wenns hart auf hart geht, versuch ich dort mal ein jännerbackup einspielen...
          @apollon77 jetzt hab ich länger gewartet...
            @da_woody Ja jetzt kommt ja auch kein "can not lock database" - das war darauf bezogen.
            Ok, welche Version ist da denn jetzt drauf wirklich? Es gibt noch eine Idee die ich habe weil es ja jsonl ist.
            editiere /opt/iobroekr/iobroker-data/iobroker.json und schauee dort beide stellen wo ein "connectTiemout" steht und schreibe dort 5000 rein falls 2000 drin steht. Das war früher mal ein Issue - ist ab der 4.0.10 erledigt weil wir dann mindestens 5s warten 🙂
            Danach nochmal versuchen
            • da_Woody
              da_Woody @apollon77 last edited by
              @apollon77 gute frage, will einfach nicht starten...
              woody@ioBroker:/opt/iobroker$ iob start
              woody@ioBroker:/opt/iobroker$ iob status
              internal/modules/cjs/loader.js:905
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                  at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                  at internal/main/run_main_module.js:17:47 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
                @da_woody Naja das liegt daran das der npm install es kaputt gemacht hat ... als müssen wir da anfangen
                da_Woody 1 Reply Last reply Reply Quote 1
                • da_Woody
                  @apollon77 muss kurz mit dem hund raus, bin aber zu jeder schandtat bereit... 😉
                    @da_woody siehe oben connectTimeout auf 500 setzen, nochmal versuchen
                      Homoran Global Moderator Administrators @apollon77 last edited by
                      @apollon77 sagte in massive CPU Auslastung:
                      5000, oder?
                      • da_Woody
                        da_Woody @Homoran last edited by da_Woody
                        @homoran klar, war auch ein tippfehler drinnen...
                        @apollon77 keine änderung...
                        gerade mal mit winscp geschaut. das verzeichniss /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js gibts nicht.
                        • da_Woody
                          da_Woody @da_Woody last edited by
                          @da_woody was ich aber gefunden habe:
                          /opt/iobroker/node_modules/iobroker.backitup/lib/restore/iobroker.js
                          /home/woody/node_modules/iobroker.js-controller/iobroker.js
                            Naja das ist der Additional controller den Du dir weiter oben mal selbst verpasst hast. Das sollte aber egal sein.
                            Schreib mal anstelle 5000 eine 10000 an beiden stellen mit connectTimeout rein!! Dann ist die Frage wartet er ca. 10s bevor der Fehler kommt oder kürzer?
                            • da_Woody
                              @apollon77 beide connectTimeout auf 10000 geändert, gespeichert. nach iob start ist der prompt sofort wieder da max 1sec. keine 10sec.
                              woody@ioBroker:~$ iob start
                              woody@ioBroker:~$ iob status
                                throw err;
                                requireStack: []
                              woody@ioBroker:~$
                                @da_woody Grmmppfffff ... du solltest ein "npm install iobroker.js-controller@3.3.22 --production" versuchen. Der kann nicht starten weil er grad nicht installiert ist. Also erstmal installieren und da gabs den "Connot connect to DB "Fehler
                                • da_Woody
                                  @apollon77 sorry... 😄
                                  ok
                                  woody@ioBroker:~$ npm install iobroker.js-controller@3.3.22 --production
                                  > iobroker.js-controller@3.3.22 preinstall /home/woody/node_modules/iobroker.js-controller
                                  > iobroker.js-controller@3.3.22 install /home/woody/node_modules/iobroker.js-controller
                                  object _design/custom updated
                                  object _design/system updated
                                  ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                                  ioBroker wants to make sure to deliver the most stable smart home system.
                                  To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                                  THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                                  For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                                  If you want to disable the error reporting you can use the command
                                  'iobroker plugin disable sentry'
                                  This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                                  npm WARN saveError ENOENT: no such file or directory, open '/home/woody/package.json'
                                  npm WARN enoent ENOENT: no such file or directory, open '/home/woody/package.json'
                                  npm WARN woody No description
                                  npm WARN woody No repository field.
                                  npm WARN woody No README data
                                  npm WARN woody No license field.
                                  + iobroker.js-controller@3.3.22
                                  updated 1 package and audited 485 packages in 8.91s
                                  12 packages are looking for funding
                                    run `npm fund` for details
                                  found 21 vulnerabilities (13 low, 5 moderate, 3 high)
                                    run `npm audit fix` to fix them, or `npm audit` for details
                                  woody@ioBroker:~$
                                  sieht mal nicht so schlecht aus... denk ich mal.
                                  was bedeutet das run npm audit fix to fix them, or npm audit for details jetzt? soll ich den fix ausführen vor iob start?
                                  ich kann diese meldungen nicht wirklich interpretieren ob notwendig, oder nicht.
                                    /home/woody/
                                    Jetzt haste es wieder in deinem Home Dir ausgeführt und nicht in /opt/iobroker ... also nochmal bitte an deer richtigen Stelle.
                                    npm audit ... ignorieren bzw wenn alles wieder tut machste einmal "iob fix" und das kommt eh nie wieder
                                    • da_Woody
                                      @apollon77 oh mann. die shell geschichten treiben mich noch ins irrenhaus.
                                      woody@ioBroker:/opt/iobroker$ npm install iobroker.js-controller@3.3.22 --production
                                      Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                      npm ERR! errno 24
                                      npm ERR! Exit status 24
                                      npm ERR!
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T15_24_17_456Z-debug.log
                                      jetzt kommen wieder die errors und plötzlich port 9000?
                                        @da_woody Ok, versuch mal ob er vllt den 4.0.10 installiert manuell ... so langsam gehen mir die ideeen aus ... und du bist sicher das nicht iiiiirgendwas auf der kiste noch läuft?
                                        opossum 1 Reply Last reply Reply Quote 0
                                        • opossum
                                          opossum @apollon77 last edited by
                                          Hallo, @apollon77,
                                          sorry, wenn ich mich hier reinhänge. Ich könnte anbieten, mit @da_Woody via Telefon und Anydesk die VM und den ioB neu aufzusetzen. Dann erst mal sein Backup zurückspielen und dann erst den Contoller 4.0.10. Habe ihm das auch per Chat angeboten. VM aufsetzen und IOB installieren dauert ja nicht lange. Da hätte man dann erst einmal eine "Grundstock", mit dem man arbeiten könnte. Ginge auch sofort.
                                            apollon77 @opossum last edited by
                                            @opossum So etwas wäre mein nächster Vorshclag gewesen ... Und eine super Idee. Ist natürlich @da_Woody entscheiden, aber vielen Dank für das Angebot von mir in jedem Fall!
                                            146
                                            22592
