    4. massive CPU Auslastung
    • da_Woody
      da_Woody @Thomas Braun last edited by
      hmm, eigentlich so gemacht wie es in der beschreibung steht...
      anyway. nach dem stop ja offensichtlich weg.
      trotzdem kommt
      No connection to databases possible ...
      woody@ioBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller@3.3.22
      > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 22
      npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
      npm ERR! Exit status 22
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T13_08_27_568Z-debug.log
      notfalls hab ich mal eine 2. VM jetzt am laufen. wenns hart auf hart geht, versuch ich dort mal ein jännerbackup einspielen...
      @apollon77 jetzt hab ich länger gewartet...
        apollon77 @da_Woody last edited by
        @da_woody Ja jetzt kommt ja auch kein "can not lock database" - das war darauf bezogen.
        Ok, welche Version ist da denn jetzt drauf wirklich? Es gibt noch eine Idee die ich habe weil es ja jsonl ist.
        editiere /opt/iobroekr/iobroker-data/iobroker.json und schauee dort beide stellen wo ein "connectTiemout" steht und schreibe dort 5000 rein falls 2000 drin steht. Das war früher mal ein Issue - ist ab der 4.0.10 erledigt weil wir dann mindestens 5s warten 🙂
        Danach nochmal versuchen
        • da_Woody
          da_Woody @apollon77 last edited by
          @apollon77 gute frage, will einfach nicht starten...
          woody@ioBroker:/opt/iobroker$ iob start
          woody@ioBroker:/opt/iobroker$ iob status
          internal/modules/cjs/loader.js:905
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
              at internal/main/run_main_module.js:17:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
            @da_woody Naja das liegt daran das der npm install es kaputt gemacht hat ... als müssen wir da anfangen
            da_Woody 1 Reply Last reply Reply Quote 1
            • da_Woody
              @apollon77 muss kurz mit dem hund raus, bin aber zu jeder schandtat bereit... 😉
                @da_woody siehe oben connectTimeout auf 500 setzen, nochmal versuchen
                  Homoran Global Moderator Administrators @apollon77 last edited by
                  @apollon77 sagte in massive CPU Auslastung:
                  5000, oder?
                  • da_Woody
                    da_Woody @Homoran last edited by da_Woody
                    @homoran klar, war auch ein tippfehler drinnen...
                    @apollon77 keine änderung...
                    gerade mal mit winscp geschaut. das verzeichniss /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js gibts nicht.
                    • da_Woody
                      da_Woody @da_Woody last edited by
                      @da_woody was ich aber gefunden habe:
                      /opt/iobroker/node_modules/iobroker.backitup/lib/restore/iobroker.js
                      /home/woody/node_modules/iobroker.js-controller/iobroker.js
                        @da_woody sagte in massive CPU Auslastung:
                        Naja das ist der Additional controller den Du dir weiter oben mal selbst verpasst hast. Das sollte aber egal sein.
                        Schreib mal anstelle 5000 eine 10000 an beiden stellen mit connectTimeout rein!! Dann ist die Frage wartet er ca. 10s bevor der Fehler kommt oder kürzer?
                        • da_Woody
                          @apollon77 beide connectTimeout auf 10000 geändert, gespeichert. nach iob start ist der prompt sofort wieder da max 1sec. keine 10sec.
                          woody@ioBroker:~$ iob start
                          woody@ioBroker:~$ iob status
                            throw err;
                            requireStack: []
                          woody@ioBroker:~$
                            @da_woody Grmmppfffff ... du solltest ein "npm install iobroker.js-controller@3.3.22 --production" versuchen. Der kann nicht starten weil er grad nicht installiert ist. Also erstmal installieren und da gabs den "Connot connect to DB "Fehler
                            • da_Woody
                              @apollon77 sorry... 😄
                              ok
                              woody@ioBroker:~$ npm install iobroker.js-controller@3.3.22 --production
                              > iobroker.js-controller@3.3.22 preinstall /home/woody/node_modules/iobroker.js-controller
                              > iobroker.js-controller@3.3.22 install /home/woody/node_modules/iobroker.js-controller
                              object _design/custom updated
                              object _design/system updated
                              ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                              ioBroker wants to make sure to deliver the most stable smart home system.
                              To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                              THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                              For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                              If you want to disable the error reporting you can use the command
                              'iobroker plugin disable sentry'
                              This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                              npm WARN saveError ENOENT: no such file or directory, open '/home/woody/package.json'
                              npm WARN enoent ENOENT: no such file or directory, open '/home/woody/package.json'
                              npm WARN woody No description
                              npm WARN woody No repository field.
                              npm WARN woody No README data
                              npm WARN woody No license field.
                              + iobroker.js-controller@3.3.22
                              updated 1 package and audited 485 packages in 8.91s
                              12 packages are looking for funding
                                run `npm fund` for details
                              found 21 vulnerabilities (13 low, 5 moderate, 3 high)
                                run `npm audit fix` to fix them, or `npm audit` for details
                              woody@ioBroker:~$
                              sieht mal nicht so schlecht aus... denk ich mal.
                              was bedeutet das run npm audit fix to fix them, or npm audit for details jetzt? soll ich den fix ausführen vor iob start?
                              ich kann diese meldungen nicht wirklich interpretieren ob notwendig, oder nicht.
                                /home/woody/
                                Jetzt haste es wieder in deinem Home Dir ausgeführt und nicht in /opt/iobroker ... also nochmal bitte an deer richtigen Stelle.
                                npm audit ... ignorieren bzw wenn alles wieder tut machste einmal "iob fix" und das kommt eh nie wieder
                                • da_Woody
                                  @apollon77 oh mann. die shell geschichten treiben mich noch ins irrenhaus.
                                  woody@ioBroker:/opt/iobroker$ npm install iobroker.js-controller@3.3.22 --production
                                  Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                  npm ERR! errno 24
                                  npm ERR! Exit status 24
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T15_24_17_456Z-debug.log
                                  jetzt kommen wieder die errors und plötzlich port 9000?
                                    @da_woody Ok, versuch mal ob er vllt den 4.0.10 installiert manuell ... so langsam gehen mir die ideeen aus ... und du bist sicher das nicht iiiiirgendwas auf der kiste noch läuft?
                                    opossum 1 Reply Last reply Reply Quote 0
                                    • opossum
                                      opossum @apollon77 last edited by
                                      Hallo, @apollon77,
                                      sorry, wenn ich mich hier reinhänge. Ich könnte anbieten, mit @da_Woody via Telefon und Anydesk die VM und den ioB neu aufzusetzen. Dann erst mal sein Backup zurückspielen und dann erst den Contoller 4.0.10. Habe ihm das auch per Chat angeboten. VM aufsetzen und IOB installieren dauert ja nicht lange. Da hätte man dann erst einmal eine "Grundstock", mit dem man arbeiten könnte. Ginge auch sofort.
                                        apollon77 @opossum last edited by
                                        @opossum So etwas wäre mein nächster Vorshclag gewesen ... Und eine super Idee. Ist natürlich @da_Woody entscheiden, aber vielen Dank für das Angebot von mir in jedem Fall!
                                        • da_Woody
                                          da_Woody last edited by da_Woody
                                          login as: woody
                                          woody@192.168.0.250's password:
                                          Linux ioBroker 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
                                          The programs included with the Debian GNU/Linux system are free software;
                                          the exact distribution terms for each program are described in the
                                          individual files in /usr/share/doc/*/copyright.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                          permitted by applicable law.
                                          Last login: Wed Feb 16 16:18:11 2022 from 192.168.7.209
                                          woody@ioBroker:~$ cd /opt/iobroker
                                          woody@ioBroker:/opt/iobroker$ ps auxww|grep io
                                          root        12  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/0]
                                          root        16  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/1]
                                          root       212  0.0  0.0      0     0 ?        I<   16:17   0:00 [rpciod]
                                          root       215  0.0  0.0      0     0 ?        I<   16:17   0:00 [xprtiod]
                                          message+   370  0.0  0.0   9100  4280 ?        Ss   16:17   0:07 /usr/bin/dbus-daemon --system --address=systemd: --nofork -        -nopidfile --systemd-activation --syslog-only
                                          woody    11698  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep io
                                          woody@ioBroker:/opt/iobroker$ ps auxww|grep backup
                                          woody    11732  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep backup
                                          sieht für mich nicht danach aus...
                                          versucht mit 4.0.10. auch nicht. hab aber das log mal rausgefischt das am schluß angegeben ist. vllt hilft das?
                                          0 info it worked if it ends with ok
                                          1 verbose cli [
                                          1 verbose cli   '/usr/bin/node',
                                          1 verbose cli   '/usr/bin/npm',
                                          1 verbose cli   'install',
                                          1 verbose cli   'iobroker.js-controller@4.0.10',
                                          1 verbose cli   '--production'
                                          1 verbose cli ]
                                          2 info using npm@6.14.16
                                          3 info using node@v14.19.0
                                          4 verbose npm-session ec259e75475dbf14
                                          5 silly install loadCurrentTree
                                          6 silly install readLocalPackageData
                                          7 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 1004ms
                                          8 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller/-/iobroker.js-controller-4.0.10.tgz 97ms
                                          9 silly pacote version manifest for iobroker.js-controller@4.0.10 fetched in 1127ms
                                          10 timing stage:loadCurrentTree Completed in 3105ms
                                          11 silly install loadIdealTree
                                          12 silly install cloneCurrentTreeToIdealTree
                                          13 timing stage:loadIdealTree:cloneCurrentTree Completed in 29ms
                                          14 silly install loadShrinkwrap
                                          15 timing stage:loadIdealTree:loadShrinkwrap Completed in 1076ms
                                          16 silly install loadAllDepsIntoIdealTree
                                          17 silly resolveWithNewModule iobroker.js-controller@4.0.10 checking installable status
                                          18 silly removeObsoleteDep removing iobroker.js-controller@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          19 silly removeObsoleteDep removing @alcalzone/esbuild-register@2.5.1-1 from the tree as its been replaced by a newer version or is no longer required
                                          20 silly removeObsoleteDep removing esbuild@0.11.23 from the tree as its been replaced by a newer version or is no longer required
                                          21 silly removeObsoleteDep removing jsonc-parser@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                                          22 silly removeObsoleteDep removing @iobroker/js-controller-adapter@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          23 silly removeObsoleteDep removing node-schedule@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                          24 silly removeObsoleteDep removing cron-parser@3.5.0 from the tree as its been replaced by a newer version or is no longer required
                                          25 silly removeObsoleteDep removing luxon@1.28.0 from the tree as its been replaced by a newer version or is no longer required
                                          26 silly removeObsoleteDep removing semver@7.3.5 from the tree as its been replaced by a newer version or is no longer required
                                          27 silly removeObsoleteDep removing @iobroker/js-controller-cli@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          28 silly removeObsoleteDep removing debug@4.3.3 from the tree as its been replaced by a newer version or is no longer required
                                          29 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
                                          30 silly removeObsoleteDep removing @iobroker/js-controller-common-db@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          31 silly removeObsoleteDep removing @iobroker/db-objects-file@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          32 silly removeObsoleteDep removing @iobroker/db-base@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          33 silly removeObsoleteDep removing @iobroker/js-controller-common@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                                          34 silly removeObsoleteDep removing @alcalzone/pak@0.7.0 from the tree as its been replaced by a newer version or is no longer required
                                          35 silly removeObsoleteDep removing execa@5.1.1 from the tree as its been replaced by a newer version or is no longer required
                                          36 silly removeObsoleteDep removing cross-spawn@7.0.3 from the tree as its been replaced by a newer version or is no longer required
                                          37 silly removeObsoleteDep removing path-key@3.1.1 from the tree as its been replaced by a newer version or is no longer required
                                          38 silly removeObsoleteDep removing shebang-command@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                                          39 silly removeObsoleteDep removing shebang-regex@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                                          40 silly removeObsoleteDep removing get-stream@6.0.1 from the tree as its been replaced by a newer version or is no longer required
                                          41 silly removeObsoleteDep removing human-signals@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                          42 silly removeObsoleteDep removing merge-stream@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                                          43 silly removeObsoleteDep removing npm-run-path@4.0.1 from the tree as its been replaced by a newer version or is no longer required
                                          44 silly removeObsoleteDep removing onetime@5.1.2 from the tree as its been replaced by a newer version or is no longer required
                                          45 silly removeObsoleteDep removing mimic-fn@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                                          • Jabba_the_Hutt
                                            Jabba_the_Hutt last edited by
                                            nachdem ja der Port 9000 blockiert war/ist ...
                                            was bringt
                                            sudo netstat -tulpen | grep -i 9000
                                            146
                                            22589
