    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      sigi234 Forum Testing Most Active @tombox last edited by sigi234
      @tombox
      ich bekomme bei der Installation des Adapters folgenden Fehler:
      host.MedionHome)
      2022-02-16 14:48:37.774	error	host.Medion(Home) instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: }
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Object.<anonymous> (C:\Program Files\iobroker\Home\node_modules\canvas\lib\bindings.js:3:18)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.MedionHome)
      host.MedionHome)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: was compiled against a different Node.js version using
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\Home\node_modules\canvas\build\Release\canvas.node'
      host.MedionHome)
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: ^
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      host.MedionHome)
      2022-02-16 14:48:37.773	error	host.Medion(Home) Caught by controller[0]: internal/modules/cjs/loader.js:1144
      host.MedionHome)
      2022-02-16 14:48:34.607	error	host.Medion(Home) iobroker npm-rebuild: Rebuilding native modules failed
      host.MedionHome)
      2022-02-16 14:47:37.952	error	host.Medion(Home) instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.MedionHome)
      2022-02-16 14:47:37.952	error	host.Medion(Home) Caught by controller[0]: }
      host.MedionHome)
      2022-02-16 14:47:37.952	error	host.Medion(Home) Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.MedionHome)
      2022-02-16 14:47:37.952	error	host.Medion(Home) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Object.<anonymous> (C:\Program Files\iobroker\Home\node_modules\canvas\lib\bindings.js:3:18)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.MedionHome)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: was compiled against a different Node.js version using
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\Home\node_modules\canvas\build\Release\canvas.node'
      host.MedionHome)
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: ^
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      host.MedionHome)
      2022-02-16 14:47:37.951	error	host.Medion(Home) Caught by controller[0]: internal/modules/cjs/loader.js:1144
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: }
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: at Object.<anonymous> (C:\Program Files\iobroker\Home\node_modules\canvas\lib\bindings.js:3:18)
      host.MedionHome)
      2022-02-16 14:47:34.029	error	host.Medion(Home) Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: was compiled against a different Node.js version using
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: Error: The module '\\?\C:\Program Files\iobroker\Home\node_modules\canvas\build\Release\canvas.node'
      host.MedionHome)
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: ^
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      host.MedionHome)
      2022-02-16 14:47:34.028	error	host.Medion(Home) Caught by controller[0]: internal/modules/cjs/loader.js:1144
      host.MedionHome)
      2022-02-16 14:47:31.429	error	host.Medion(Home) iobroker npm-rebuild: Rebuilding native modules failed
      Muss man unter Windows was berücksichtigen?
      Plattform: Windows
      RAM: 16 GB
      NODE.JS: V14.19.0
      NPM: 6.14.16
      JS Controller: 4.0.10
      Admin: 5.3.0
      Web: 4.1.4
      Socket.io: 4.1.0
      Script Engine: 5.2.19
        tombox @sigi234 last edited by tombox
        @sigi234
        canvas hat leider ein rebuild problem
        https://github.com/Automattic/node-canvas/pull/1982
        cd C:\Program Files\iobroker\Home\
        npm install canvas
        Apollon77 created this issue in Automattic/node-canvas
        closed Replace binary for rebuild cases #1982
          tombox @x4N70 last edited by
          @x4n70 Gute Nachricht ich habe mir nochmal die amazon verschlüsselung auf der seite angeschaut vielleicht kommt man auch ohne full browser aus.
            @tombox
            Amazon läuft. 👍
              MartyBr @sigi234 last edited by
              @sigi234 Das sieht super aus. Bist du bereit, den View/das Widget hier zu teilen?
                sigi234 Forum Testing Most Active @MartyBr last edited by
                @martybr sagte in Test Adapter Paketverfolgung DHL, Briefe, Amazon, DPD, 17T:
                VIEW_Sendungsverfolgung_Inventwo_sigi234.txt
                  @sigi234
                  Vielen Dank!!!!
                    @x4n70 Es ist eine version ohne chromium/puppeeter auf github bitte mal probieren ob das auf arm64 geht
                    sigi234 X 2 Replies Last reply Reply Quote 0
                      @tombox
                      Hallo, funktioniert die Telegram Benachrichtigung bei Statusänderung via Javascript auch für email ?
                      Habe es mal geändert , kommt keine Mail?
                      const alreadySentMessages = {}
                      on({ id: "parcel.0.allProviderObjects", change: "ne" }, function (obj) {
                          const sendungen = JSON.parse(obj.state.val)
                          const ids = Object.keys(sendungen)
                          for (const id of ids) {
                              if (alreadySentMessages[id] === sendungen[id].status) {
                                  return
                              sendTo('email.0', sendungen[id].name + '\n' + sendungen[id].status);
                              alreadySentMessages[id] = sendungen[id].status
                        @sigi234 Eigentlich ja, kannst aber das komplexen Format verwenden
                        https://github.com/iobroker-community-adapters/ioBroker.email#usage
                        • Christoph1337
                          Christoph1337 last edited by
                          Sehr geil! Gleich mal testen.
                          Schade das Lieferungen.app immernoch keine api anbietet.
                          Ob man das irgendwie anders aus der Seite lutschen kann?
                          • X
                            x4N70 @tombox last edited by
                            @tombox So, jetzt konnte ich testen. Installation hat funktioniert, nach dem Hinzufügen des Adapters musste ich ioBroker Neustarten, dass mir der Adapter angezeigt wurde und ich eine Instanz anlegen konnte, hat aber vermutlich nix mit deinem Adapter zu tun.
                            Allerdings habe ich die Variante #1 deiner Installationsanleitung ja schon installiert gehabt, also hier bin ich dann keine Hilfe, ob es ohne die geht, ohne den Rest geht es wohl.
                            Erfahrungen:
                            • DHL geht
                            • Bei Amazon klappt der Login nicht. Musste nach dem ersten Versuch erst mal mein Passwort ändern, klappt aber nach wie vor nicht "Login to Amazon failed, please login to Amazon and check your credentials"
                            Weiter Konten habe ich nicht, wie ist das mit 17track oder auch DPD etc? Brauche ich überall einen Account oder geht das auch anders? Habe ich noch nie drüber nachgedacht, sonst bekomme ich eben Tracking-Nummern mit Link per E-Mail und muss maximal die PLZ noch eingeben fürs Tracking.
                              kiste01 @tombox last edited by
                              @tombox
                              Ich hatte die Installation des Adapters irgendwie verbogen, aber jetzt ist alles repariert.
                              Die aktuelle Version habe ich eben (17.02.2022 10:00) installiert und sowohl DHL als auch Amazon mit 2FA funktionieren. Ich habe allerdings mehrere SMS sowohl von DHL als auch Amazon bekommen. Und das, obwohl das log successful zeigt. Davon darf man sich dann nicht verunsichern lassen.
                              TOP!!!
                                tombox @x4N70 last edited by tombox
                                @x4n70 Wenn man ein Provider nicht nutzen will dann keine Zugangsdaten eingeben.
                                Was passiert wenn du im icognito modus im browser dich bei amazon einloggst dann geht alles?
                                • X
                                  @tombox Hat weniger mit "nicht nutzen wollen" zu tun, bin inzwischen auch komplett durch diesen Thread hier durch. Geht mir um einen Weg, wie Tracking-Nummern in den Adapter möglichst automatisiert reinkommen. Ein Ansatz wäre irgendwie über Telegram Text2Command (dann kann ich am Handy die Nummern aus E-Mails oder sonstwoher extrahieren und direkt an Parcel "schicken") oder über einen Simple-API Call z.B. als Apple Shortcut oder JavaScript-Bookmark oder ähnliches eingerichtet (muss man aber auf jedem Geräte einzeln machen)...
                                  Zu Amazon: Inkognito heißt was genau? ioBroker in einem Inkognito-Browserfenster aufmachen? Nein, oder?
                                  • Christoph1337
                                    Christoph1337 last edited by Christoph1337
                                    @tombox
                                    Kannst du den DP "parcel.0.allProviderJson" so anpassen, dass es ein extra Feld für "Displayname" für die Inhalte von "parcel.0.17tuser.trackinginfo..FRemark" und "parcel.0.amazon..name" gibt?
                                    Außerdem wäre es toll zu jedem Paket auch ein DateTime Item zu haben. Das kann man besser weiterverarbeiten als die Textangaben.
                                    • X
                                      x4N70 @x4N70 last edited by
                                      Update von mir:
                                      • Amazon tut jetzt, habe nichts anders gemacht
                                      • 17track habe ich mich registriert und getestet, Verbindung klappt, mein DPD-Paket hat es aber nicht korrekt erkannt (auf der 17t-Webseite wird es als "La Poste"-Paket deklariert und hat keine weiteren Infos
                                      • Machst Du oder jemand ein allgemeineres Skript, dass analog zu den Briefankündigungen benachrichtigt? Sprich, wenn sich was geändert hat, schicke Telegram mit dem Inhalt der DPs des Pakets... Blockly könnte ich noch hinbekommen, aber die Geschichte wie im Briefbenachrichtigung-Skript ("wenn ich nicht schon gesendet habe, dann...") bekomme ich nicht hin.
                                      Ich denke das ist der zweite Knackpunkt neben der Anzahl der Dienste bzw. dem Login-Vorgang, der den Adapter "publikumstauglich" macht -> was kann ich halbwegs einfach mit den DPs anfangen, sprich, standardmäßig nach Telegram oder sowas.
                                        senger1985 @tombox last edited by
                                        @tombox der Adapter läuft bei mir wunderbar, aber ich hätte eine Frage, bzgl. der Amazon-Lieferungen.
                                        Ich habe heute Nacht was bestellt und die Lieferung sollte Freitag eintreffen, laut Amazon.
                                        Heute habe ich eine Mail bekommen, dass die Lieferung, heute schon ankommen soll und sie ist auch schon in der Auslieferung, aber dieser Status wird mir in den Datenpunkten nicht angezeigt, sondern noch der ursprüngliche Auslieferungstag.
                                        Verbunden bin ich, laut Log.
                                          Gruter last edited by
                                          Login geht bei 17T, DPD und Amazon bei mir nicht mehr, gestern ging es noch, habe nirgends ein Kennwort geändert.
                                          • DJMarc75
                                            DJMarc75 last edited by
                                            Servus,
                                            ob man in der parcel.0.allProviderJson bei DHL "Zustellung erfolgreich." den Punkt am Ende herausnehmen kann ?
                                            Ist rein kosmetisch 💄
                                            VG
                                            1.0k
                                            17track amazon briefe dhl dpd gls ups
                                            123
                                            1537
                                            528945
