    3. Einsteigerfragen
    4. Problem Installation auf Raspi4
      A Former User last edited by
      @Thomas-Braun
      völlig egal mit welchem user (pi/moelli/root): es bleibt bei der Fehlermeldung der typmissmatch in der headerdatei.
      @wendy2702
      erstmal dankefür Deine Hilfe: netzwerkinterfaces für vpn
      $ cd /opt/iobroker
      $ npm install iobroker.js-controller@3.3.22
      > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      In file included from ../../nan/nan.h:58,
                       from ../src/unix_dgram.cc:5:
      /home/moelli/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/moelli/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(unix_dgram, Initialize)
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
        CXX(target) Release/obj.target/diskusage/src/main.o
                       from ../src/main.cpp:3:
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(diskusage, Init)
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
      > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
       Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
      Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
      Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
      Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
      No connection to databases possible ...
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 22
      npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
      npm ERR! Exit status 22
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/moelli/.npm/_logs/2022-02-15T22_56_22_260Z-debug.logcode_text
      der compiler motzt weiter über nan.h und node.h und erzeugt nicht js-controller. Insofern startet IOB auch nicht und es gibt keine Verbindung zu Port 9001.
      Für mich sieht das nach einer Incompatibiltät zw java und dden benutzten C-Biblotheken aus.
      Erst mal danke und gute nacht - gibt sonst auch noch Dinge die man um die Uhrzeit macht...
        @goofy1800 sagte in Problem Installation auf Raspi4:
        Lass ihn motzen. Das ist vollkommen normal.
        Nicht normal ist das Nichterreichen der Datenbank.
        Läuft da schon was anderes auf dem Port?
          die Idee nach der Portbelegung zu schauen, war nicht schlecht:
          Port 9001 Ausgabe von netstat:
          $ sudo netstat -tulpn |grep 9001
          [sudo] Passwort für ****:
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      426/node
          code_text
          pid 426 betrifft noch einen openhab Prozeß "frontail", eigentlich ist openhab deinstalliert:
             426 	frontail 	vor 2 Tagen 	node /usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-high ...
                1180 	frontail 	vor 2 Tagen 	tail -n 200 -F /var/log/openhab/openhab.log /var/log/openhab/events.log
          werde demnächst weiter suchen, erstmal danke
            Abschalten von frontail und anschließender Aufruf des Installscriptes ergab dann folgendes:
            [20:44:16] root@openhabraspi4:/opt/iobroker# systemctl status iobroker
            ● iobroker.service - ioBroker Server
               Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset:
               Active: active (running) since Wed 2022-02-16 20:43:22 CET; 2min 11s ago
                 Docs: http://iobroker.net
             Main PID: 14896 (iobroker.js-con)
                Tasks: 11 (limit: 4915)
               CGroup: /system.slice/iobroker.service
                       └─14896 iobroker.js-controller
            Feb 16 20:43:22 openhabraspi4 systemd[1]: Started ioBroker Server.
            lines 1-10/10 (END)
            code_text
            ich kann aber über den Port 8081 dann die web-Oberfläche nicht aufrufen, egal ob über die IP Adresse oder localhost:8081 -> Verbindung abgelehnt.
            die Kontrolle mit netstat zeigt keinen offenen Port unter 8081 an,
            9001 erscheint.
            code[20:30:58] root@openhabraspi4:/home/moelli# netstat -tulpn | grep 8081
            _text
            [20:46:08] root@openhabraspi4:/opt/iobroker# netstat -tulpn | grep 9001
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      14896/iobroker.js-c
            etwas ratlos
              etwas ratlos
              Immer noch root.
              • wendy2702
                wendy2702 last edited by
                als USER:
                iob list instances
                  ich habe alle Varianten durchgespielt: root, pi, sonst. user
                  bei user kommt ungültige Gruppe user****:user****
                    @goofy1800
                    Du sollst halt nicht als root da rumhampeln.
                    Das ist jetzt Rat genug an der Stelle.
                      A Former User @Thomas Braun last edited by
                      pi@openhabraspi4:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                      library: loaded
                      Library version=2022-02-10
                         Welcome to the ioBroker installer!
                         Installer version: 2022-02-13
                         You might need to enter your password a couple of times.
                         Installing prerequisites (1/4)
                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                      OK:2 http://deb.debian.org/debian buster-backports InRelease
                      OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      OK:4 https://packages.grafana.com/oss/deb stable InRelease
                      Ign:5 http://repos.azulsystems.com/debian stable InRelease
                      OK:6 http://repos.azulsystems.com/debian stable Release
                      OK:7 https://repos.influxdata.com/debian buster InRelease
                      Holen:8 https://repo.z-wave.me/z-way/raspbian buster InRelease [1.806 B]
                      OK:9 https://deb.nodesource.com/node_16.x buster InRelease
                      OK:10 https://repo.mosquitto.org/debian buster InRelease
                      OK:11 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
                      Es wurden 1.806 B in 5 s geholt (390 B/s).
                      Changing npm registry to https://registry.npmjs.org
                      Installed gcc-c++
                         Creating ioBroker user and directory (2/4)
                      Created /etc/sudoers.d/iobroker
                      Directory /opt/iobroker created
                         Installing ioBroker (3/4)
                         Finalizing installation (4/4)
                      Enabling autostart...
                      Autostart enabled!
                      Fixing directory permissions...
                         ioBroker was installed successfully
                         Open http://192.168.11.117 192.168.11.217 192.168.55.1 10.6.0.1:8081 in a browser and start configuring!
                      You need to re-login before doing anything else on the console!
                      ode_text
                      ich finde Ihren Ton (rumhampeln) nicht gerade angemessen, man wweiß ja nicht wen man auf der Gegenseite vor sich hat - ....
                      Thomas Braun wendy2702 Homoran 3 Replies Last reply Reply Quote 0
                        Einen Goofy. Sehe ich.
                        • wendy2702
                          wendy2702 @Guest last edited by
                          Leute die versuchen einem zu helfen.
                          Laut fixer sollte IOB laufen.
                          Wie die IP Addressen zustande kommen erschliesst sich mir aktuell nicht da ich die Konfig vom PI nicht kenne, daher kann ich nicht sagen welche jetzt zu verwenden wäre.
                            Homoran Global Moderator Administrators @Guest last edited by Homoran
                            Ein lockerer Ton darf doch erlaubt sein. Bei dir motzt der compiler ja auc
                            @Ein ehemaliger Benutzer sagte in Problem Installation auf Raspi4:
                            da ist jemand , dem man in entspannter Atmosphäre helfen will.
                            • wendy2702
                              Oha....
                              da hat sich aber schnell wieder jemand von ioBroker verabschiedet.
                              1.5k
                              1334
