    4. massive CPU Auslastung
      apollon77 @da_Woody last edited by
      @da_woody sagte in massive CPU Auslastung:
      /home/woody/
      Jetzt haste es wieder in deinem Home Dir ausgeführt und nicht in /opt/iobroker ... also nochmal bitte an deer richtigen Stelle.
      npm audit ... ignorieren bzw wenn alles wieder tut machste einmal "iob fix" und das kommt eh nie wieder
      • da_Woody
        da_Woody @apollon77 last edited by
        @apollon77 oh mann. die shell geschichten treiben mich noch ins irrenhaus.
        woody@ioBroker:/opt/iobroker$ npm install iobroker.js-controller@3.3.22 --production
        > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
        npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        npm ERR! code ELIFECYCLE
        npm ERR! errno 24
        npm ERR! iobroker.js-controller@3.3.22 install: `node iobroker.js setup first`
        npm ERR! Exit status 24
        npm ERR!
        npm ERR! Failed at the iobroker.js-controller@3.3.22 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2022-02-16T15_24_17_456Z-debug.log
        jetzt kommen wieder die errors und plötzlich port 9000?
          @da_woody Ok, versuch mal ob er vllt den 4.0.10 installiert manuell ... so langsam gehen mir die ideeen aus ... und du bist sicher das nicht iiiiirgendwas auf der kiste noch läuft?
          opossum 1 Reply Last reply Reply Quote 0
          • opossum
            opossum @apollon77 last edited by
            Hallo, @apollon77,
            sorry, wenn ich mich hier reinhänge. Ich könnte anbieten, mit @da_Woody via Telefon und Anydesk die VM und den ioB neu aufzusetzen. Dann erst mal sein Backup zurückspielen und dann erst den Contoller 4.0.10. Habe ihm das auch per Chat angeboten. VM aufsetzen und IOB installieren dauert ja nicht lange. Da hätte man dann erst einmal eine "Grundstock", mit dem man arbeiten könnte. Ginge auch sofort.
              apollon77 @opossum last edited by
              @opossum So etwas wäre mein nächster Vorshclag gewesen ... Und eine super Idee. Ist natürlich @da_Woody entscheiden, aber vielen Dank für das Angebot von mir in jedem Fall!
              • da_Woody
                da_Woody last edited by da_Woody
                @apollon77 sagte in massive CPU Auslastung:
                login as: woody
                woody@192.168.0.250's password:
                Linux ioBroker 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Wed Feb 16 16:18:11 2022 from 192.168.7.209
                woody@ioBroker:~$ cd /opt/iobroker
                woody@ioBroker:/opt/iobroker$ ps auxww|grep io
                root        12  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/0]
                root        16  0.0  0.0      0     0 ?        S    16:17   0:00 [migration/1]
                root       212  0.0  0.0      0     0 ?        I<   16:17   0:00 [rpciod]
                root       215  0.0  0.0      0     0 ?        I<   16:17   0:00 [xprtiod]
                message+   370  0.0  0.0   9100  4280 ?        Ss   16:17   0:07 /usr/bin/dbus-daemon --system --address=systemd: --nofork -        -nopidfile --systemd-activation --syslog-only
                woody    11698  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep io
                woody@ioBroker:/opt/iobroker$ ps auxww|grep backup
                woody    11732  0.0  0.0   6088   888 pts/1    S+   21:12   0:00 grep backup
                sieht für mich nicht danach aus...
                versucht mit 4.0.10. auch nicht. hab aber das log mal rausgefischt das am schluß angegeben ist. vllt hilft das?
                0 info it worked if it ends with ok
                1 verbose cli [
                1 verbose cli   '/usr/bin/node',
                1 verbose cli   '/usr/bin/npm',
                1 verbose cli   'install',
                1 verbose cli   'iobroker.js-controller@4.0.10',
                1 verbose cli   '--production'
                1 verbose cli ]
                2 info using npm@6.14.16
                3 info using node@v14.19.0
                4 verbose npm-session ec259e75475dbf14
                5 silly install loadCurrentTree
                6 silly install readLocalPackageData
                7 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 1004ms
                8 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller/-/iobroker.js-controller-4.0.10.tgz 97ms
                9 silly pacote version manifest for iobroker.js-controller@4.0.10 fetched in 1127ms
                10 timing stage:loadCurrentTree Completed in 3105ms
                11 silly install loadIdealTree
                12 silly install cloneCurrentTreeToIdealTree
                13 timing stage:loadIdealTree:cloneCurrentTree Completed in 29ms
                14 silly install loadShrinkwrap
                15 timing stage:loadIdealTree:loadShrinkwrap Completed in 1076ms
                16 silly install loadAllDepsIntoIdealTree
                17 silly resolveWithNewModule iobroker.js-controller@4.0.10 checking installable status
                18 silly removeObsoleteDep removing iobroker.js-controller@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                19 silly removeObsoleteDep removing @alcalzone/esbuild-register@2.5.1-1 from the tree as its been replaced by a newer version or is no longer required
                20 silly removeObsoleteDep removing esbuild@0.11.23 from the tree as its been replaced by a newer version or is no longer required
                21 silly removeObsoleteDep removing jsonc-parser@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                22 silly removeObsoleteDep removing @iobroker/js-controller-adapter@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                23 silly removeObsoleteDep removing node-schedule@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                24 silly removeObsoleteDep removing cron-parser@3.5.0 from the tree as its been replaced by a newer version or is no longer required
                25 silly removeObsoleteDep removing luxon@1.28.0 from the tree as its been replaced by a newer version or is no longer required
                26 silly removeObsoleteDep removing semver@7.3.5 from the tree as its been replaced by a newer version or is no longer required
                27 silly removeObsoleteDep removing @iobroker/js-controller-cli@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                28 silly removeObsoleteDep removing debug@4.3.3 from the tree as its been replaced by a newer version or is no longer required
                29 silly removeObsoleteDep removing ms@2.1.2 from the tree as its been replaced by a newer version or is no longer required
                30 silly removeObsoleteDep removing @iobroker/js-controller-common-db@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                31 silly removeObsoleteDep removing @iobroker/db-objects-file@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                32 silly removeObsoleteDep removing @iobroker/db-base@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                33 silly removeObsoleteDep removing @iobroker/js-controller-common@4.0.9 from the tree as its been replaced by a newer version or is no longer required
                34 silly removeObsoleteDep removing @alcalzone/pak@0.7.0 from the tree as its been replaced by a newer version or is no longer required
                35 silly removeObsoleteDep removing execa@5.1.1 from the tree as its been replaced by a newer version or is no longer required
                36 silly removeObsoleteDep removing cross-spawn@7.0.3 from the tree as its been replaced by a newer version or is no longer required
                37 silly removeObsoleteDep removing path-key@3.1.1 from the tree as its been replaced by a newer version or is no longer required
                38 silly removeObsoleteDep removing shebang-command@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                39 silly removeObsoleteDep removing shebang-regex@3.0.0 from the tree as its been replaced by a newer version or is no longer required
                40 silly removeObsoleteDep removing get-stream@6.0.1 from the tree as its been replaced by a newer version or is no longer required
                41 silly removeObsoleteDep removing human-signals@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                42 silly removeObsoleteDep removing merge-stream@2.0.0 from the tree as its been replaced by a newer version or is no longer required
                43 silly removeObsoleteDep removing npm-run-path@4.0.1 from the tree as its been replaced by a newer version or is no longer required
                44 silly removeObsoleteDep removing onetime@5.1.2 from the tree as its been replaced by a newer version or is no longer required
                45 silly removeObsoleteDep removing mimic-fn@2.1.0 from the tree as its been replaced by a newer version or is no longer required
                • Jabba_the_Hutt
                  Jabba_the_Hutt last edited by
                  nachdem ja der Port 9000 blockiert war/ist ...
                  was bringt
                  sudo netstat -tulpen | grep -i 9000
                  • da_Woody
                    da_Woody @Jabba_the_Hutt last edited by
                    @jabba_the_hutt moin. jetzt gar nichts mehr... 😄
                    gestern spät abends noch mit @opossum rumgefummelt. wir hatten schon eine neue VM fertig mit backup, mussten dann aber feststellen, daß das backup zu jung war. war schon auf jsonl. dann drauf gepfiffen und die ioBroker VMs platt gemacht.
                    nachdem dann auch noch proxmox rumgezickt hat, ich konnte keine IP an die MAC binden, haben wir dann aufgehört und machen heute weiter.
                    inzwischen hab ich mal eine debian11 VM mit richtiger IP. kurze nacht...
                      @da_woody strange. Aber schau mal im /opt/iobroker/iobroker-Data/backup-objects. Da müssten noch ältere Backups liegen. Die von „filedb“ Zeiten werden Suchaktion nicht gelöscht. Damit solltet Du die letzten „file“ objects und states json herbekommen.
                      • da_Woody
                        @apollon77 kein problem, hab jede menge backups auf dem NAS liegen. 😉
                        werden heute eins vom 31.1. einspielen. das war vor der js-c 4er aktion. das muss noch auf file stehn. wenn alles spielt, erstmal fettes VM backup. dann nochmal 4.10 versuchen.
                        aber thnx 4 tip!
                          @da_woody Dan wäre ich ja bei folgendes Vorschlag:
                          • 3.3.22 file ... laufen lassen und CPU und RAM und alles sichern und schauen was da so passiert das du eine Baseline hast
                          • 3.3.22 auf jsonl umstellen .... vergleichen
                          • 4.0.10 mit jsonl dann ... vergleichen
                          da_Woody 1 Reply Last reply Reply Quote 2
                          • da_Woody
                            da_Woody @apollon77 last edited by da_Woody
                            und genauso sind @opossum und ich auch vorgegangen. nach einem fehlversuch mit einem zu "jungen" backup, wo schon auf jsonl umgestellt war.
                            nachdem ich das IP problem durch eine "brutal" variante endlich erledigt hatte.
                            neue debian11 VM aufgesetzt. die hat sich dann eine IP aus dem DHCP bereich gekrallt. nachdem da immer wieder die selben MAC verwendet werden, habe ich mir die aus der VM genommen, an einer stelle das B durch C verändert, diese im router eingetragen, die gewünschte IP und namen dazu, abgespeichert. dann habe ich in der VM die MAC abgespeichert, voila, die gewünschte IP wurde im guest-agent angezeigt. anyway. insgesammt waren wir sicher mehr als 6 stunden mit anydesk und telefon verbunden mit pausen. 🙂
                            angefangen haben wir dann mit dem vorbereiten. sudo und co nachinstallieren, benutzer eintragen, ... den einzeiler, ioB insten, einrichten, ioB, javascript backups in den richtigen ordner kopiert, fertig. 1. VM backup im proxmox gemacht.
                            backitup angeworfen, kaffee/bierpause. wie schon beim fehlversuch, vis kann nicht installiert werden! beim nachforschen dann rausgefunden, man muss manuell erstmal manuell die ver. 1.4.6 insten, dann kann man erst updaten! @opossum hat dazu ein issue gefunden. dabei wurde angezeigt, daß von 1.4.8 ein downgrade auf eben 1.4.6 gemacht wird. update auf 1.4.12, passt.
                            gecheckt, alles up2date, js-controller noch auf 3.3.22, file file. nächstes backup im proxmox.
                            zwischendurch immer wieder CPU und RAM auslastung im auge gehabt. alles im grünen bereich.
                            manuell die umstellung auf jsonl gestartet. nach fertigstellung, noch immer sehr gute werte, backup.
                            4.0.10 mit jsonl, admin auch noch auf 5.2.3, alles paletti! 😄 aktueller stand:
                            das einzig seltsame, was noch immer ist, daß ich bei den admin verbindungen noch immer seltsame dinge abspielen...
                            2 geöffnete tabs:
                            objekte tab wieder geschlossen:
                            also statt 8 nur mehr 7 und einen admin weniger. hab allerdings auch schon gesehn, daß beim schlißen eines tabs 2 admins runtergezählt wurde. wer/was noname ist? keine ahnung. aber da wusste bis jetzt auch keiner was dazu...
                            HAH! geheimniss gelüftet!
                            extra noch einmal per anydesk auf dem bürorechner nachgeschaut, ob dort noch irgendwelche tabs offen sind. nein, definitiv nicht! dann die eingebung, firefox geschlossen, keine änderung. chrome gechlossen:
                            offensichtlich hat der chrome da noch einiges irgendwas im hintergrund eingelagert gehabt für eine wiederherstellung!
                            somit ist wirklich alles i.o.
                            danke.gif nochmal an @opossum für die hilfe!
                            latürnich auch an all die anderen, die in dem tread ihren senf.gif dauzu gegeben haben! highfive.gif
                            vielleicht hilft der bericht ja auch noch anderen...
                              crunchip Forum Testing Most Active last edited by crunchip
                              jede neue VM sollte eigentlich auch eine neue MAC bekommen, warum DHCP, stellt man eigentlich von vorn herein auf statisch.
                              Daher schrieb ich auch
                              @crunchip sagte in massive CPU Auslastung:
                              Installier eine Neue VM mit gleicher IP, iobroker installieren und iobroker backup zurück spielen.
                              Die alte VM legst du zuvor still.
                              sonst musst du im nachhinein ja alles wieder "umbiegen"
                              aber schön, wenn es nun endlich läuft
                                @da_woody Super zusammenfassung und auch von mir nochmal Danke an @opossum !Einerseits super das es tut, andererseits blöd weil wir den echten Grund nicht kennen :-)) Aber hey, man kann nicht alles haben g
                                Drücke die Daumen: Und ja Tabs und Browser sind so ne sache
                                da_Woody 1 Reply Last reply Reply Quote 1
                                • da_Woody
                                  as u say... ich dreh jedes mal am rad, wenn ich in iQontrol was mache. einmal passts in FF, ein andermal in Chrome. bei beiden so gut wie nie! 😞
                                  der grund... tja, vllt wirklich, daß ich da gepfuscht hab und nicht immer im richtigen verzeichniss war... who knows.
                                  wollte ja gestern noch den bericht schreiben, nachdem ich aber die nacht zuvor nur 2 stunden gepennt hab, bin ich gestern weggebrochen. 😄
                                  bin jetzt mit allem auf latest, auch den js auf 4.0.12 angehoben. gefühlt sind die instanzen nach start schneller wieder gestartet, die CPUlast weiter runtegegangen!
                                  bitte überfallt jetzt aber nicht alle @opossum wenn ihr probleme habt!!! biglol.gif
                                  Axel Koeneke 1 Reply Last reply Reply Quote 1
                                  • Axel Koeneke
                                    Axel Koeneke @da_Woody last edited by
                                    Moin, habe diesen alten Fred durch googlen endeckt undmöchte dazu noch meine Beobachtung beitragen:
                                    Ich habe auf einer Proxmox-Büchse (Container), eine neue IOB installation fertiggestellt.
                                    Alles läuft sehr gut und flüssig und deutlich schneller, als auf meinen NUC6.
                                    Aber mir ist wieder die CPU Last in 15 minütigen Rythmus aufgefallen.
                                    Also nur die "Das Wetter" Instanz gestopt und siehe da - die Spitzenlast ist weg. Die durchschnittliche Last ging von ca 15% auf 5% zurück.
                                    Leider kann ich jetzt die 15 Minuten Peeks nicht mehr darstellen.
                                    Habt ihr den Adapter inzwischen als Ursache ausgeschlossen?
                                    Das Ganze läuft übrigens auf einem Geekom mini Air 11.
                                    VG
                                    Axel
                                    Codierknecht DJMarc75 2 Replies Last reply Reply Quote 0
                                    • Codierknecht
                                      Codierknecht Developer Most Active @Axel Koeneke last edited by
                                      @axel-koeneke
                                      Da wir das in einem anderen Fred gerade hatten:
                                      Schau mal in den Zeitplan der Instanz. Wenn "DasWetter" jeweils zur vollen (oder halben) Stunde aktualisiert wird, ist deren Server regelmäßig ziemlich ausgelastet - weil das fast alle zu diesen Zeiten machen.
                                      Was passiert, wenn der Adapter zu eher "ungewöhnlichen" Zeiten aktualisiert? Ändert das etwas an der Last?
                                      Axel Koeneke apollon77 2 Replies Last reply Reply Quote 0
                                      • Axel Koeneke
                                        Axel Koeneke @Codierknecht last edited by
                                        @codierknecht Werde ich gleich mal umstellen. Danke für den Tip
                                        • DJMarc75
                                          DJMarc75 @Axel Koeneke last edited by
                                          @axel-koeneke sagte in massive CPU Auslastung:
                                          Verhält sich bei mir auch so.
                                          @codierknecht sagte in massive CPU Auslastung:
                                          Bei mir sind so ziemlich "schräge" Zeiten eingetragen, ändert aber nix an der CPU-Last.
                                          Warum auch - wenn die Server bei dasWetter ausgelastet sind dann sollte dies nicht die CPU beeinflussen.
                                          Codierknecht Axel Koeneke 2 Replies Last reply Reply Quote 0
                                          • Codierknecht
                                            Codierknecht Developer Most Active @DJMarc75 last edited by
                                            @djmarc75 sagte in massive CPU Auslastung:
                                            Wenn der Adapter per Schleife versucht, eine funktionierende Verbindung hinzukriegen, schon 😉
                                            1.0k
                                            146
                                            22582
