    4. IObroker stürzt total ab
      fresha last edited by fresha
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 16GB
      Festplattenart: SSD
      Betriebssystem: Unraid
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Skript/Manuell
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
      Und wieder ist es passiert das Iobroker komplett abstürzt. In einer Woche ist es jetzt zum 4 mal passiert.
      2022-02-17 16:00:02.834  - info: ical.0 (3516) processing URL: Hausmuell https://www.awu-oberhavel.de/fuer-haushalte/zusatzinfos/tourenplan/?no_cache=1&export=hm&city=xxx
      2022-02-17 16:00:02.835  - info: ical.0 (3516) processing URL: Pappe https://www.awu-oberhavel.de/fuer-haushalte/zusatzinfos/tourenplan/?no_cache=1&export=pap&city=xxx
      2022-02-17 16:00:02.853  - info: ical.0 (3516) processing URL: Gelber Sack https://www.awu-oberhavel.de/fuer-haushalte/zusatzinfos/tourenplan/?no_cache=1&export=lvp&city=xxx
      2022-02-17 16:00:02.875  - info: trashschedule.0 (695) State value to set for "trashschedule.0.type.pappePapier.nextWeekday" has to be type "string" but received type "number"
      2022-02-17 16:00:02.946  - info: trashschedule.0 (695) State value to set for "trashschedule.0.type.leichtstoffverpackung.nextWeekday" has to be type "string" but received type "number"
      2022-02-17 16:00:05.009  - info: trashschedule.0 (695) State value to set for "trashschedule.0.type.pappePapier.nextWeekday" has to be type "string" but received type "number"
      2022-02-17 16:00:05.060  - info: trashschedule.0 (695) State value to set for "trashschedule.0.type.leichtstoffverpackung.nextWeekday" has to be type "string" but received type "number"
      2022-02-17 16:00:07.910  - info: ical.0 (3516) Terminated (NO_ERROR): Without reason
      2022-02-17 16:00:08.424  - info: host.2354f6144ce1 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2022-02-17 16:00:16.296  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109994608_8753. New secret 1645110016295_7962
      2022-02-17 16:00:16.305  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:00:16.305  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:00:16.504  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:00:34.640  - info: javascript.0 (129) script.js.LanbonL8.Raumtemperatur: Temp = 22
      2022-02-17 16:00:45.473  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110016295_7962. New secret 1645110045472_2288
      2022-02-17 16:00:45.481  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:00:45.481  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:00:45.688  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:01:06.253  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110045472_2288. New secret 1645110066252_2858
      2022-02-17 16:01:06.268  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:01:06.268  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:01:06.468  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:01:25.590  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110066252_2858. New secret 1645110085588_2227
      2022-02-17 16:01:25.607  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:01:25.608  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:01:25.807  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:01:46.166  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110085588_2227. New secret 1645110106166_4883
      2022-02-17 16:01:46.177  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:01:46.177  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:01:46.383  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:02:05.477  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110106166_4883. New secret 1645110125476_4093
      2022-02-17 16:02:05.488  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:02:05.489  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:02:05.689  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:02:26.071  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110125476_4093. New secret 1645110146070_1372
      2022-02-17 16:02:26.080  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:02:26.080  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
      2022-02-17 16:02:26.281  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:02:30.748  - error: trashschedule.0 (695) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.749  - error: trashschedule.0 (695) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.748  - error: fritzdect.0 (778) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.751  - error: backitup.0 (725) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.752  - error: tr-064.0 (253) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.757  - error: web.0 (793) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.767  - error: history.0 (193) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.770  - error: echarts.0 (763) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.760  - error: influxdb.0 (748) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.761  - error: discovery.0 (314) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.767  - error: node-red.1 (159) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.770  - error: telegram.0 (167) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.775  - error: socketio.0 (808) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.754  - error: tr-064.0 (253) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.775  - error: socketio.0 (808) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.782  - error: web.0 (793) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.796  - error: info.0 (329) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.798  - error: info.0 (329) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.749  - error: fritzdect.0 (778) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.761  - error: influxdb.0 (748) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.770  - error: telegram.0 (167) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.768  - error: history.0 (193) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.774  - error: echarts.0 (763) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.775  - error: node-red.1 (159) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.752  - error: backitup.0 (725) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.804  - error: sony-bravia.0 (848) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.805  - error: sony-bravia.0 (848) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.802  - error: admin.0 (114) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.808  - error: admin.0 (114) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.807  - error: javascript.0 (129) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.779  - error: zigbee.0 (283) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.780  - error: mihome-vacuum.0 (223) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.780  - error: mqtt.0 (238) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.751  - error: node-red.1 (144) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.782  - error: text2command.0 (680) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.773  - error: alexa2.0 (268) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.762  - error: discovery.0 (314) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.781  - error: mqtt.0 (238) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.784  - error: alexa2.0 (268) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.781  - error: mihome-vacuum.0 (223) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.783  - error: text2command.0 (680) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.785  - error: node-red.1 (144) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.808  - error: ping.0 (1058) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:30.779  - error: zigbee.0 (283) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.820  - error: ping.0 (1058) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:30.810  - error: javascript.0 (129) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.750  - error: trashschedule.0 (695) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.753  - error: trashschedule.0 (695) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.756  - error: tr-064.0 (253) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.756  - error: tr-064.0 (253) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.764  - error: discovery.0 (314) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.765  - error: discovery.0 (314) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.770  - error: history.0 (193) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.771  - error: history.0 (193) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.774  - error: telegram.0 (167) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.775  - error: telegram.0 (167) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.777  - error: echarts.0 (763) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.778  - error: node-red.1 (159) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.778  - error: echarts.0 (763) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.778  - error: node-red.1 (159) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.780  - error: socketio.0 (808) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.782  - error: zigbee.0 (283) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.783  - error: mqtt.0 (238) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.783  - error: zigbee.0 (283) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.784  - error: mqtt.0 (238) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.784  - error: mihome-vacuum.0 (223) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.785  - error: mihome-vacuum.0 (223) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.780  - error: socketio.0 (808) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.785  - error: alexa2.0 (268) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.786  - error: alexa2.0 (268) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.789  - error: text2command.0 (680) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.790  - error: text2command.0 (680) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.795  - error: web.0 (793) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.796  - error: node-red.1 (144) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.796  - error: web.0 (793) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.796  - error: node-red.1 (144) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.800  - error: info.0 (329) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.801  - error: fritzdect.0 (778) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.801  - error: influxdb.0 (748) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.801  - error: fritzdect.0 (778) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.801  - error: info.0 (329) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.802  - error: influxdb.0 (748) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.804  - error: backitup.0 (725) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.805  - error: backitup.0 (725) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.807  - error: sony-bravia.0 (848) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.807  - error: sony-bravia.0 (848) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.810  - error: admin.0 (114) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.811  - error: admin.0 (114) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.822  - error: ping.0 (1058) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.823  - error: ping.0 (1058) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:35.823  - error: javascript.0 (129) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:35.823  - error: javascript.0 (129) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.755  - error: trashschedule.0 (695) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.756  - error: trashschedule.0 (695) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.757  - error: tr-064.0 (253) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.758  - error: tr-064.0 (253) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.766  - error: discovery.0 (314) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.766  - error: discovery.0 (314) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.772  - error: history.0 (193) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.773  - error: history.0 (193) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.776  - error: telegram.0 (167) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.776  - error: telegram.0 (167) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.780  - error: echarts.0 (763) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.780  - error: echarts.0 (763) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.781  - error: node-red.1 (159) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.782  - error: socketio.0 (808) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.782  - error: node-red.1 (159) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.782  - error: socketio.0 (808) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.784  - error: zigbee.0 (283) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.784  - error: mqtt.0 (238) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.784  - error: zigbee.0 (283) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.784  - error: mqtt.0 (238) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.786  - error: mihome-vacuum.0 (223) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.786  - error: mihome-vacuum.0 (223) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.787  - error: alexa2.0 (268) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.788  - error: alexa2.0 (268) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.792  - error: text2command.0 (680) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.792  - error: text2command.0 (680) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.797  - error: web.0 (793) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.797  - error: web.0 (793) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.798  - error: node-red.1 (144) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.799  - error: node-red.1 (144) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.803  - error: fritzdect.0 (778) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.803  - error: fritzdect.0 (778) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.803  - error: info.0 (329) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.805  - error: influxdb.0 (748) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.805  - error: influxdb.0 (748) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.804  - error: info.0 (329) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.805  - error: backitup.0 (725) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.806  - error: backitup.0 (725) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.809  - error: sony-bravia.0 (848) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.809  - error: sony-bravia.0 (848) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.812  - error: admin.0 (114) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.813  - error: admin.0 (114) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.823  - error: ping.0 (1058) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.824  - error: ping.0 (1058) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:40.825  - error: javascript.0 (129) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:40.825  - error: javascript.0 (129) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:45.231  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645110146070_1372. New secret 1645110165230_4970
      2022-02-17 16:02:45.239  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:02:45.239  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
      2022-02-17 16:02:45.440  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
      2022-02-17 16:02:45.758  - error: trashschedule.0 (695) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:45.758  - error: trashschedule.0 (695) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:02:45.760  - error: tr-064.0 (253) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:02:45.760  - error: tr-064.0 (253) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      022-02-17 16:03:50.834  - error: fritzdect.0 (778) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:50.835  - error: backitup.0 (725) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:50.836  - error: backitup.0 (725) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:50.839  - error: info.0 (329) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:50.840  - error: admin.0 (114) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:50.840  - error: info.0 (329) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:50.840  - error: admin.0 (114) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:50.852  - error: ping.0 (1058) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:50.852  - error: ping.0 (1058) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:50.858  - error: sony-bravia.0 (848) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:50.858  - error: sony-bravia.0 (848) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:50.861  - error: javascript.0 (129) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:50.863  - error: javascript.0 (129) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:55.785  - error: trashschedule.0 (695) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:55.787  - error: tr-064.0 (253) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2022-02-17 16:03:55.789  - error: telegram.0 (167) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:55.785  - error: trashschedule.0 (695) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:55.786  - warn: trashschedule.0 (695) get state error: Connection is closed.
      2022-02-17 16:03:55.786  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.787  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.788  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.789  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.790  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.791  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.792  - warn: trashschedule.0 (695) get state error: DB closed
      2022-02-17 16:03:55.788  - error: tr-064.0 (253) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2022-02-17 16:03:55.854  - warn: node-red.1 (144) get state error: DB closed
      2022-02-17 16:03:55.857  - warn: node-red.1 (144) get state error: DB closed
      2022-02-17 16:03:55.892  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_10: Connection is closed.
      2022-02-17 16:03:55.892  - warn: ping.0 (1058) get state error: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_27: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) get state error: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_36: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_73: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_46: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_47: Connection is closed.
      2022-02-17 16:03:55.893  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_53: Connection is closed.
      2022-02-17 16:03:55.894  - warn: ping.0 (1058) get state error: Connection is closed.
      2022-02-17 16:03:55.894  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_54: Connection is closed.
      2022-02-17 16:03:55.894  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_56: Connection is closed.
      2022-02-17 16:03:55.894  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_59: Connection is closed.
      2022-02-17 16:03:55.894  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_61: Connection is closed.
      2022-02-17 16:03:55.894  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_62: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_63: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) get state error: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_64: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_65: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_66: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_68: Connection is closed.
      2022-02-17 16:03:55.895  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_70: Connection is closed.
      2022-02-17 16:03:55.896  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_74: Connection is closed.
      2022-02-17 16:03:55.896  - warn: ping.0 (1058) get state error: Connection is closed.
      2022-02-17 16:03:55.896  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_76: Connection is closed.
      2022-02-17 16:03:55.896  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_99: Connection is closed.
      2022-02-17 16:03:55.897  - warn: ping.0 (1058) Could not perform strict object check of state ping.0.2354f6144ce1.192_168_178_200: Connection is closed.
      2022-02-17 16:03:55.897  - warn: ping.0 (1058) get state error: Connection is closed.
      2022-02-17 16:03:55.832  - warn: mihome-vacuum.0 (223) get state error: DB closed
      2022-02-17 16:03:55.849  - warn: mihome-vacuum.0 (223) get state error: DB closed
      • wendy2702
        wendy2702 @fresha last edited by wendy2702
        @fresha Was für ein System? Welche HW? Welches OS? Wie installiert?
        Einen komplett Absturz sehe ich im log nicht, lediglich einen Datenbank connection lost.
        Oder fehlt der JS-Controller restart im log? Der Teil wäre von interesse?
        Welche Version überhaupt?
        Homoran F 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @wendy2702 last edited by Homoran
          @wendy2702 sagte in IObroker stürzt total ab:
          @fresha sagte in IObroker stürzt total ab:
          Unraid
          • wendy2702
            wendy2702 @Homoran last edited by
            @homoran Unraid ist was wie Proxmox....
            Fehlen also noch angaben
              Thomas Braun Most Active @wendy2702 last edited by
              @wendy2702
              Eher ein NAS, mit Proxmox/Virtualisierung hat das nicht primär zu tun.
              • wendy2702
                wendy2702 @Thomas Braun last edited by
                @thomas-braun Ich widerspreche 🙂
                  fresha @wendy2702 last edited by fresha
                  @wendy2702
                  Sorry, für die fehlende Daten:
                  Hardware: mini ITX Board
                  IObroker im Docker installiert
                  Zumindest lässt sich die Iobroker Webseite nicht mehr öffnen und MQTT scheint auch tot zu sein.
                  Hier noch der Log vom Docker:
                  Recived termination signal (SIGTERM).
                  Shutting down ioBroker...
                  ------------------------- 2022-02-17 13:49:30 -------------------------
                  ----- Welcome to your ioBroker-container! -----
                  ----- Startupscript is now running. -----
                  ----- Please be patient! -----
                  ----- Debugging information -----
                  ----- System -----
                  ----- arch: x86_64 -----
                  ----- Docker-Image -----
                  ----- image: v6.0.0 -----
                  ----- build: 2022-02-11T07:56:40+00:00 -----
                  ----- Versions -----
                  ----- node: v14.19.0 -----
                  ----- npm: 6.14.16 -----
                  ----- ENV -----
                  ----- SETGID: 100 -----
                  ----- SETUID: 99 -----
                  ----- USBDEVICES: /dev/ttyACM0 -----
                  ----- Step 1 of 5: Preparing container -----
                  Different UID and/ or GID is set by ENV.
                  Changing UID to 99 and GID to 100...
                  usermod: no changes
                  Done.
                  ----- Step 2 of 5: Detecting ioBroker installation -----
                  groupmod: GID '100' already exists
                  Existing installation of ioBroker detected in /opt/iobroker.
                  ----- Step 3 of 5: Checking ioBroker installation -----
                  (Re)Setting folder permissions (This might take a while! Please be patient!)...
                  Done.
                  Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
                  Done.
                  ----- Step 4 of 5: Applying special settings -----
                  Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                  For more information take a look at readme.md on Github!
                  Usb-device-support is activated by ENV.
                  Setting permissions for /dev/ttyACM0...
                  Done.
                  ----- Step 5 of 5: ioBroker startup -----
                  Starting ioBroker...
                  ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
                  host.2354f6144ce1 check instance "system.adapter.admin.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.javascript.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.node-red.1" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.telegram.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.history.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.ical.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.mihome-vacuum.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.mqtt.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.ping.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.tr-064.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.alexa2.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.zigbee.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.birthdays.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.discovery.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.info.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.sony-bravia.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.text2command.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.trashschedule.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-bars.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-canvas-gauges.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-fancyswitch.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-history.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-hqwidgets.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-justgage.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-lcars.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-plumb.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-timeandweather.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-weather.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.backitup.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.fullybrowser.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.influxdb.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.echarts.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.fritzdect.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.vis-material-advanced.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.material.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.web.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.socketio.0" for host "2354f6144ce1"
                  host.2354f6144ce1 check instance "system.adapter.habpanel.0" for host "2354f6144ce1"
                  ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                  /bin/sh: 1: iw: not found
                  /bin/sh: 1: hcitool: not found
                  Thu, 17 Feb 2022 14:46:32 GMT node-telegram-bot-api deprecated In the future, content-type of files you send will default to "application/octet-stream". See https://github.com/yagop/node-telegram-bot-api/blob/master/doc/usage.md#sending-files for more information on how sending files has been improved and on how to disable this deprecation message altogether. at main.js:859:24
                  /opt/scripts/iobroker_startup.sh: line 505: 92 Segmentation fault gosu iobroker node node_modules/iobroker.js-controller/controller.js
                  Und hier der Log von Iobroker etwas vor dem crash.
                  2022-02-17 15:51:54.166  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.WZ_Spots: Bewegung erkannt Treppe unten
                  2022-02-17 15:51:54.167  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.WZ_Spots: Kein BWS ist nicht dunkel genug
                  2022-02-17 15:51:58.428  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109496591_2826. New secret 1645109518427_5298
                  2022-02-17 15:51:58.437  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:51:58.437  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:51:58.638  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:52:00.583  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Bewegung erkannt Flur Umkleide
                  2022-02-17 15:52:00.583  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Flurlicht ist noch aus
                  2022-02-17 15:52:00.583  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Kein BWS ist dunkel genug
                  2022-02-17 15:52:00.697  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.WZ_Spots: Bewegung erkannt Treppe oben
                  2022-02-17 15:52:00.698  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.WZ_Spots: Kein BWS ist nicht dunkel genug
                  2022-02-17 15:52:15.204  - info: javascript.0 (129) Stop script script.js.ttest
                  2022-02-17 15:52:15.209  - info: javascript.0 (129) Start javascript script.js.ttest
                  2022-02-17 15:52:15.218  - info: javascript.0 (129) script.js.ttest: "date":"In 6 Tagen  ","event":"Annika Handy kündigen","_class":"ical_Meine Termine ical_6days","_date":"2022-02-22T23:00:00.000Z","_end":"2022-02-23T23:00:00.000Z","_IDID":"01ee3668-eb26-468e-9991-e2b456459cea","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"Meine Termine","_calColor":"#00ff59"},{"date":"In 6 Tagen  ","event":"Pappe/Papier","_class":"ical_Pappe ical_6days","_date":"2022-02-22T23:00:00.000Z","_end":"2022-02-23T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-pap-02-23","_allDay":true,"_private":false,"_rule":" ","location":"xxx","_calName":"Pappe","_calColor":"#0000ff"},{"date":"In einer Woche  ","event":"Leichtstoffverpackungen","_class":"ical_Gelber Sack ical_oneweek","_date":"2022-02-23T23:00:00.000Z","_end":"2022-02-24T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-lvp-02-24","_allDay":true,"_private":false,"_rule":" ","location":"Oberkrämer OT Bötzow - Wansdorfer Chaussee","_calName":"Gelber Sack","_calColor":"#ffff00"},{"date":"28.02.2022  ","event":"Hausmüll","_class":"ical_Hausmuell ","_date":"2022-02-27T23:00:00.000Z","_end":"2022-02-28T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-hm-02-28","_allDay":true,"_private":false,"_rule":" ","location":"xxx","_calName":"Hausmuell","_calColor":"#000000"},{"date":"10.03.2022  ","event":"Leichtstoffverpackungen","_class":"ical_Gelber Sack ","_date":"2022-03-09T23:00:00.000Z","_end":"2022-03-10T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-lvp-03-10","_allDay":true,"_private":false,"_rule":" ","location":"xxxx","_calName":"Gelber Sack","_calColor":"#ffff00"},{"date":"14.03.2022  ","event":"Hausmüll","_class":"ical_Hausmuell ","_date":"2022-03-13T23:00:00.000Z","_end":"2022-03-14T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-hm-03-14","_allDay":true,"_private":false,"_rule":" ","location":"Oberkrämer OT Bötzow - Wansdorfer Chaussee","_calName":"Hausmuell","_calColor":"#000000"}
                  2022-02-17 15:52:15.218  - info: javascript.0 (129) script.js.ttest: registered 0 subscriptions and 0 schedules
                  2022-02-17 15:52:17.015  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Bewegung erkannt Flur Umkleide
                  2022-02-17 15:52:17.016  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Flurlicht ist noch aus
                  2022-02-17 15:52:17.016  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Kein BWS ist dunkel genug
                  2022-02-17 15:52:21.899  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Bewegung erkannt Flur Haustür
                  2022-02-17 15:52:21.899  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Flurlicht ist noch aus
                  2022-02-17 15:52:21.899  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Kein BWS ist dunkel genug
                  2022-02-17 15:52:24.021  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Bewegung erkannt Flur Umkleide
                  2022-02-17 15:52:24.022  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Flurlicht ist noch aus
                  2022-02-17 15:52:24.022  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Kein BWS ist dunkel genug
                  2022-02-17 15:52:26.345  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Timer abgelaufen, schalte Licht wieder aus
                  2022-02-17 15:52:26.348  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109518427_5298. New secret 1645109546348_7644
                  2022-02-17 15:52:26.361  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:52:26.361  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:52:26.568  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:52:27.508  - info: javascript.0 (129) Stop script script.js.ttest
                  2022-02-17 15:52:27.512  - info: javascript.0 (129) Start javascript script.js.ttest
                  2022-02-17 15:52:27.519  - info: javascript.0 (129) script.js.ttest: {"date":"In 6 Tagen  ","event":"Annika Handy kündigen","_class":"ical_Meine Termine ical_6days","_date":"2022-02-22T23:00:00.000Z","_end":"2022-02-23T23:00:00.000Z","_IDID":"01ee3668-eb26-468e-9991-e2b456459cea","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"Meine Termine","_calColor":"#00ff59"},{"date":"In 6 Tagen  ","event":"Pappe/Papier","_class":"ical_Pappe ical_6days","_date":"2022-02-22T23:00:00.000Z","_end":"2022-02-23T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-pap-02-23","_allDay":true,"_private":false,"_rule":" ","location":"xxxx","_calName":"Pappe","_calColor":"#0000ff"},{"date":"In einer Woche  ","event":"Leichtstoffverpackungen","_class":"ical_Gelber Sack ical_oneweek","_date":"2022-02-23T23:00:00.000Z","_end":"2022-02-24T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-lvp-02-24","_allDay":true,"_private":false,"_rule":" ","location":"xxxx","_calName":"Gelber Sack","_calColor":"#ffff00"},{"date":"28.02.2022  ","event":"Hausmüll","_class":"ical_Hausmuell ","_date":"2022-02-27T23:00:00.000Z","_end":"2022-02-28T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-hm-02-28","_allDay":true,"_private":false,"_rule":" ","location":"xxxx","_calName":"Hausmuell","_calColor":"#000000"},{"date":"10.03.2022  ","event":"Leichtstoffverpackungen","_class":"ical_Gelber Sack ","_date":"2022-03-09T23:00:00.000Z","_end":"2022-03-10T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-lvp-03-10","_allDay":true,"_private":false,"_rule":" ","location":"xxx","_calName":"Gelber Sack","_calColor":"#ffff00"},{"date":"14.03.2022  ","event":"Hausmüll","_class":"ical_Hausmuell ","_date":"2022-03-13T23:00:00.000Z","_end":"2022-03-14T23:00:00.000Z","_section":"Die Leerung / Abholung erfolgt im Zeitraum von 06:00 bis 21:30 Uhr. Die Abfallbehältnisse sind frühestens am Vorabend, spätestens jedoch bis 6:00 Uhr jedes Abfuhrtages zur Entleerung bereitzustellen. Sie sind am Tag der Entleerung wieder von der öffentlichen Verkehrsfläche zu entfernen.","_IDID":"2022-hm-03-14","_allDay":true,"_private":false,"_rule":" ","location":"xxx","_calName":"Hausmuell","_calColor":"#000000"}
                  2022-02-17 15:52:27.519  - info: javascript.0 (129) script.js.ttest: registered 0 subscriptions and 0 schedules
                  2022-02-17 15:52:35.755  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Timer abgelaufen, schalte Licht wieder aus
                  2022-02-17 15:52:43.128  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Timer abgelaufen, schalte Licht wieder aus
                  2022-02-17 15:52:47.834  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109546348_7644. New secret 1645109567833_4407
                  2022-02-17 15:52:47.843  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:52:47.843  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:52:48.044  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:52:51.976  - info: javascript.0 (129) Stop script script.js.ttest
                  2022-02-17 15:52:51.981  - info: javascript.0 (129) Start javascript script.js.ttest
                  2022-02-17 15:52:51.988  - info: javascript.0 (129) script.js.ttest: registered 0 subscriptions and 0 schedules
                  2022-02-17 15:52:51.989  - error: javascript.0 (129) script.js.ttest: SyntaxError: Unexpected token , in JSON at position 319
                  2022-02-17 15:52:51.989  - error: javascript.0 (129)     at JSON.parse (<anonymous>:null:null)
                  2022-02-17 15:52:51.989  - error: javascript.0 (129)     at script.js.ttest:5:15
                  2022-02-17 15:52:51.990  - error: javascript.0 (129)     at script.js.ttest:15:3
                  2022-02-17 15:52:51.990  - error: javascript.0 (129)     at Script.runInContext (vm.js:144:12)
                  2022-02-17 15:53:00.584  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Timer abgelaufen, schalte Licht wieder aus
                  2022-02-17 15:53:15.998  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109567833_4407. New secret 1645109595992_6215
                  2022-02-17 15:53:16.008  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:53:16.008  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:53:16.209  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:53:17.017  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Timer abgelaufen, schalte Licht wieder aus
                  2022-02-17 15:53:24.022  - info: javascript.0 (129) script.js.Licht_&_BWM.Bewegungsmelder.Logik.Flur: Timer abgelaufen, schalte Licht wieder aus
                  2022-02-17 15:53:37.501  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109595992_6215. New secret 1645109617499_7747
                  2022-02-17 15:53:37.519  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:53:37.520  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:53:37.720  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:54:05.586  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109617499_7747. New secret 1645109645585_9182
                  2022-02-17 15:54:05.597  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:54:05.597  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:54:05.798  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:54:26.893  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109645585_9182. New secret 1645109666892_8025
                  2022-02-17 15:54:26.910  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:54:26.910  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:54:27.111  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:54:55.101  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109666892_8025. New secret 1645109695099_2530
                  2022-02-17 15:54:55.108  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:54:55.109  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:54:55.309  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:55:12.729  - info: mqtt.0 (238) Client [mqtt-explorer-89721fab] connection closed: disconnected
                  2022-02-17 15:55:16.808  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109695099_2530. New secret 1645109716804_4345
                  2022-02-17 15:55:16.867  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:55:16.867  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:55:17.067  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:55:44.801  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109716804_4345. New secret 1645109744800_4424
                  2022-02-17 15:55:44.813  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:55:44.813  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:55:45.013  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:56:06.472  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109744800_4424. New secret 1645109766471_5071
                  2022-02-17 15:56:06.484  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:56:06.484  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:56:06.690  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:56:35.105  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109766471_5071. New secret 1645109795104_8298
                  2022-02-17 15:56:35.117  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:56:35.118  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:56:35.318  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:56:56.630  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109795104_8298. New secret 1645109816629_4706
                  2022-02-17 15:56:56.643  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:56:56.643  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:56:56.844  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:57:25.357  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109816629_4706. New secret 1645109845356_3594
                  2022-02-17 15:57:25.371  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:57:25.371  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:57:25.575  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:57:46.545  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109845356_3594. New secret 1645109866545_4975
                  2022-02-17 15:57:46.557  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:57:46.557  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:57:46.757  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:58:14.992  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109866545_4975. New secret 1645109894991_9519
                  2022-02-17 15:58:15.019  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:58:15.019  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:58:15.220  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:58:36.461  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109894991_9519. New secret 1645109916459_4692
                  2022-02-17 15:58:36.498  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:58:36.498  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:58:36.699  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:59:04.596  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109916459_4692. New secret 1645109944596_3619
                  2022-02-17 15:59:04.611  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:59:04.611  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:59:04.812  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:59:26.378  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109944596_3619. New secret 1645109966377_1108
                  2022-02-17 15:59:26.386  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#" with regex /^ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:59:26.386  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/ZET/#"  with regex /^mqtt\.0\.ESP_Easy\.ZET(\..*)?/
                  2022-02-17 15:59:26.587  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 15:59:35.206  - info: javascript.0 (129) script.js.LanbonL8.Raumtemperatur: Temp = 21.5
                  2022-02-17 15:59:54.613  - info: mqtt.0 (238) Client [ESP_Easy_0] reconnected. Old secret 1645109966377_1108. New secret 1645109994608_8753
                  2022-02-17 15:59:54.632  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#" with regex /^ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:59:54.633  - info: mqtt.0 (238) Client [ESP_Easy_0] subscribes on "/ESP_Easy/DHT22/SET/#"  with regex /^mqtt\.0\.ESP_Easy\.DHT22\.SET(\..*)?/
                  2022-02-17 15:59:54.835  - info: mqtt.0 (238) Client [ESP_Easy_0] publishOnSubscribe send all known states
                  2022-02-17 16:00:00.036  - info: host.2354f6144ce1 instance system.adapter.ical.0 started with pid 3516
                  2022-02-17 16:00:01.681  - info: ical.0 (3516) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  2022-02-17 16:00:01.728  - info: ical.0 (3516) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v14.19.0, js-controller: 3.3.22
                  2022-02-17 16:00:02.796  - info: ical.0 (3516) processing URL: Meine Termine https://xxxxxxxxx/?export
                  2022-02-17 16:00:02.834  - info: ical.0 (3516) processing URL: Hausmuell https://www.awu-oberhavel.de/fuer-haushalte/zusatzinfos/tourenplan/?no_cache=1&export=hm&city=xxxx
                  2022-02-17 16:00:02.835  - info: ical.0 (3516) processing URL: Pappe https://www.awu-oberhavel.de/fuer-haushalte/zusatzinfos/tourenplan/?no_cache=1&export=pap&city=xxxxx
                  2022-02-17 16:00:02.853  - info: ical.0 (3516) processing URL: Gelber Sack https://www.awu-oberhavel.de/fuer-haushalte/zusatzinfos/tourenplan/?no_cache=1&export=lvp&city=xxxxxx
                    Ich widerspreche
                    • wendy2702
                      @fresha
                      welches OS im Container?
                      Ich würde erstmal das script ".ttest" und den MQTT Adapter deaktivieren.
                      Einen JS-Controller restart sehe ich aber immer noch nicht.
                      Und ob diese Zeile "Gesund" ist kann ich leider nicht sagen:
                      Denke da müssen die Docker kollegen mal schauen.
                        @wendy2702
                        Distributor ID: Debian
                        Description: Debian GNU/Linux 11 (bullseye)
                        Release: 11
                        Codename: bullseye
                        • eine neuer Fehler im Docker Log
                        TypeError: Cannot read property '0' of undefined
                        at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.sony-bravia/main.js:98:80)
                        at IncomingMessage.emit (events.js:412:35)
                        at endReadableNT (internal/streams/readable.js:1334:12)
                        at processTicksAndRejections (internal/process/task_queues.js:82:21)
                        560
