    • s.bormann
      s.bormann Most Active @buchner51 last edited by
      @buchner51 sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
      @s-bormann sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
      @s-bormann
        "nuki-extended.0.smartlocks": {
          "common": {
            "name": "Nuki Smartlocks",
            "write": false
          "type": "channel",
          "native": {},
          "from": "system.adapter.nuki-extended.0",
          "user": "system.user.admin",
          "ts": 1622990362526,
          "_id": "nuki-extended.0.smartlocks",
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
        "nuki-extended.0.smartlocks.haustür_": {
          "common": {
            "name": "Haustür ",
            "write": false
          "type": "channel",
          "native": {},
          "ts": 1622990362528,
          "_id": "nuki-extended.0.smartlocks.haustür_",
          "acl": {
            "object": 1636,
        "nuki-extended.0.smartlocks.haustür_._ACTION": {
          "common": {
            "name": "Trigger an action",
            "role": "value",
            "type": "number",
            "write": true,
            "states": {
              "0": "NO_ACTION",
              "1": "UNLOCK",
              "2": "LOCK",
              "3": "UNLATCH",
              "4": "LOCK_N_GO",
              "5": "LOCK_N_GO_WITH_UNLATCH"
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_._ACTION",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK": {
          "common": {
            "name": "Trigger LOCK action",
            "role": "button",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO": {
          "common": {
            "name": "Trigger LOCK_N_GO action",
            "role": "button",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH": {
          "common": {
            "name": "Trigger LOCK_N_GO_WITH_UNLATCH action",
            "role": "button",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.LOCK_N_GO_WITH_UNLATCH",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH": {
          "common": {
            "name": "Trigger UNLATCH action",
            "role": "button",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLATCH",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK": {
          "common": {
            "name": "Trigger UNLOCK action",
            "role": "button",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.bridgeId": {
          "common": {
            "name": "Bridge ID of the Nuki",
            "role": "value",
            "type": "number",
            "write": false
          "type": "state",
          "native": {},
          "ts": 1622990362529,
          "_id": "nuki-extended.0.smartlocks.haustür_.bridgeId",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.hex": {
          "common": {
            "name": "Hex ID of the Nuki",
            "role": "text",
            "type": "string",
            "write": false
          "type": "state",
          "native": {},
          "ts": 1622990362563,
          "_id": "nuki-extended.0.smartlocks.haustür_.hex",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.id": {
          "common": {
            "name": "ID of the Nuki",
            "role": "value",
            "type": "number",
            "write": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.id",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.info": {
          "common": {
            "name": "Additional Information",
            "write": false
          "type": "channel",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.info",
          "acl": {
            "object": 1636,
        "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion": {
          "common": {
            "name": "The firmware version",
            "role": "value",
            "type": "number",
            "write": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.info.firmwareVersion",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.name": {
          "common": {
            "name": "Name of the Bridge / Nuki",
            "role": "text",
            "type": "string",
            "write": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.name",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state": {
          "common": {
            "name": "Current states",
            "write": false
          "type": "channel",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state",
          "acl": {
            "object": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState": {
          "common": {
            "name": "Indicates battery charge level",
            "role": "value",
            "type": "number",
            "write": false
          "type": "state",
          "native": {},
          "ts": 1622995898502,
          "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryChargeState",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.batteryCharging": {
          "common": {
            "name": "Indicates battery charging",
            "role": "indicator",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "ts": 1622995898501,
          "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCharging",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.batteryCritical": {
          "common": {
            "name": "Indicates critical battery level",
            "role": "indicator.lowbat",
            "type": "boolean",
            "write": true,
            "read": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.batteryCritical",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.deviceType": {
          "common": {
            "name": "Type of device",
            "role": "value",
            "type": "number",
            "write": false,
            "states": {
              "0": "Nuki Smart Lock",
              "2": "Nuki Opener"
          "type": "state",
          "native": {},
          "ts": 1622990531628,
          "_id": "nuki-extended.0.smartlocks.haustür_.state.deviceType",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.doorState": {
          "common": {
            "name": "Türsensor-DoorClosed(2)-DoorOpen(3)",
            "role": "value",
            "type": "number",
            "write": false,
            "states": {
              "0": "UNAVAILABLE",
              "1": "DEACTIVATED",
              "2": "DOOR_CLOSED",
              "3": "DOOR_OPENED",
              "4": "DOOR_STATE_UNKNOWN",
              "5": "CALIBRATING"
            "custom": {
              "iqontrol.0": {
                "0": "",
                "1": "",
                "2": "",
                "enabled": true,
                "invert": false,
                "confirm": false,
                "pincode": "",
                "step": "",
                "roundDigits": 2,
                "timeFormat": "x",
                "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
                "targetValueId": "",
                "statesAddInput": false,
                "statesAddInputCaption": "Enter other value...",
                "showOnlyTargetValues": false,
                "readonly": false,
                "unit": "",
                "unit_zero": "LOCKED",
                "unit_one": "UNLATCHED",
                "min": "",
                "max": "",
                "type": "number",
                "role": "value",
                "targetValues": "",
                "states": {
                  "DOOR_CLOSED": "true",
                  "DOOR_OPENED": "false"
                "timeDisplayDontShowDistance": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.doorState",
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1642363067003
        "nuki-extended.0.smartlocks.haustür_.state.doorStateName": {
          "common": {
            "name": "Current door-state name of the Nuki",
            "role": "text",
            "type": "string",
            "write": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.doorStateName",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate": {
          "common": {
            "name": "Timestamp of last data update / refresh",
            "role": "date",
            "type": "string",
            "write": false
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.lastDataUpdate",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate": {
          "common": {
            "name": "Timestamp of last state change",
            "role": "date",
            "type": "string",
            "write": false
          "type": "state",
          "native": {},
          "ts": 1622990362530,
          "_id": "nuki-extended.0.smartlocks.haustür_.state.lastStateUpdate",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.state.lockState": {
          "common": {
            "name": "Motorschloss-Locked(1)-Unlocked(3)",
            "role": "value",
            "type": "number",
            "write": false,
            "states": {
              "0": "UNCALIBRATED",
              "1": "LOCKED",
              "2": "UNLOCKING",
              "3": "UNLOCKED",
              "4": "LOCKING",
              "5": "UNLATCHED",
              "6": "UNLOCKED_LOCK_N_GO",
              "7": "UNLATCHING",
              "254": "MOTOR_BLOCKED",
              "255": "UNDEFINED"
            "custom": {
              "iqontrol.0": {
                "0": "",
                "1": "",
                "3": "",
                "enabled": true,
                "invert": false,
                "confirm": false,
                "pincode": "",
                "step": "",
                "roundDigits": 2,
                "timeFormat": "x",
                "readonly": false,
                "unit": "",
                "unit_zero": "",
                "unit_one": "",
                "min": "",
                "max": "",
                "type": "number",
                "role": "value",
                "targetValues": {},
                "states": {
                  "1": "true",
                  "3": "false"
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.lockState",
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1642363118406
        "nuki-extended.0.smartlocks.haustür_.state.locked": {
          "common": {
            "name": "Indication if door is locked (boolean of lockState)",
            "role": "sensor.lock",
            "type": "boolean",
            "write": false,
            "states": {
              "0": "false",
              "1": "true",
              "2": "false",
              "3": "false",
              "4": "true",
              "5": "false",
              "6": "false",
              "7": "false",
              "254": "false",
              "255": "false"
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.locked",
          "acl": {
            "object": 1636,
            "state": 1636,
          "ts": 1641742002315
        "nuki-extended.0.smartlocks.haustür_.state.mode": {
          "common": {
            "name": "Operation Mode of the Nuki or Opener",
            "role": "value",
            "type": "number",
            "write": false,
            "states": {
              "0": "UNINITIALIZED",
              "1": "PAIRING",
              "2": "NORMAL",
              "3": "CONTINUOUS",
              "4": "MAINTENANCE"
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.state.mode",
          "acl": {
            "object": 1636,
            "state": 1636,
        "nuki-extended.0.smartlocks.haustür_.type": {
          "common": {
            "role": "value",
            "type": "number",
            "write": false,
            "states": {
              "2": "Nuki Opener"
          "type": "state",
          "native": {},
          "_id": "nuki-extended.0.smartlocks.haustür_.type",
          "acl": {
            "object": 1636,
            "state": 1636,
      meinst du so als Json?
      habe mir das jetzt mal in Ruhe angeschaut. Das Nuki implementiert das ganz anders, als es bei meiner Keymatic der Fall ist (die hatte ich als Vorlage genommen). Aber ich glaube, mit ein paar Anpassungen sollte es jetzt laufen:
      • Bitte die aktuelle Github-Version laden
      • Da sind beim Türschloss folgende neue Optionen drin, die so konfiguriert werden müssen:
      • Als Datenpunkte konfigurierst Du folgendes:
      • Beim Datenpunkt state.locked gehst Du auf den Schrabenschlüssel und konfigurierst folgendes:
        • Typ: Bool
        • Rolle: Schalter
        • Target-Value-List:
          • true -> nuki-extended.0.smartlocks.haustür_._ACTION.UNLOCK --> true
          • false -> nuki-extended.0.smartlocks.haustür_._ACTION.LOCK --> true
      Bitte probier das mal so und gib Rückmeldung. Wenn das klappt, stelle ich den Beitrag ins Wiki.
      @s-bormann: super ist wirklich TOP.
      ich habe es etwas anders gemacht:
      Mit diesen Einstellungen musste ich nichts weiteres hinterlegen.
      Wenn du es ins Wiki stellst muss keiner mehr suchen.
      Nochmal Danke, hab jetzt leider etwas länger benötigt.
      Habs ins Wiki eingefügt. Vielen Dank!
      • s.bormann
        s.bormann Most Active @dirkhe last edited by
        @dirkhe sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
        @s-bormann probiere mal $dialog.hide(). Ggf musst du dann die weiteren schritte in ein settimeout(function() {}, 100) setzen,
        Zwei Dumme ein Gedanke, das hatte ich gerade gemacht - und damit läuft es (auch mit $dialog.modal('close'))
        • evolvo187
          evolvo187 @s.bormann last edited by
          @s-bormann,
          Zwischenschritt: In der Toolbar ist der Border-Fehler behoben und man kann für selected einen anderen Icon-Hintergrund auswählen.
          Der Toolbar Border-Fehler in der normalen Ansicht ist behoben. 👍
          Aber wenn man mit der Maus draufgeht ist er noch da.
          Mich stört es nicht da ich am Tablet und Handy nicht sehe.
          Nur als hin weiß !
          Danke für den Icon-Hintergrund 😊
          • dslraser
            @s-bormann
            Hallo Sebastian,
            ich muss nochmal auf das leidige Thema HMIP Thermostate (über rpc Adapter) zurück kommen.
            Sollte da jetzt eigentlich mit dem HMIP Thermostat (also als Gerät in iQontrol) auch Automatik/ Manuell und Boost „Out of the Box“ funktionieren ?
            Ich hatte und habe es ein ganze Weile nur so laufen
            Heute habe ich mal wieder versucht Control Mode einzubinden, aber das schaltet bei mir nur „Unsinn“ Z.B. wenn ich auf Manuell klicke geht Boost an un Automatik geht dann auf off(kann man in der Rasberrymatik gut beobachten)
            Müssen in diesem Gerät noch immer Value List usw erstellt werden, oder soll das so, also ohne Schraubenschlüssel funktionieren?
            In der Adapter Beschreibung auf Github sind HMIP Thermostate nicht extra beschrieben.
            s.bormann 1 Reply Last reply Reply Quote 1
            • s.bormann
              s.bormann Most Active @evolvo187 last edited by
              @evolvo187 sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
              @s-bormann,
              Nur als hin weiß !
              Sorry, wird noch gefixed. Update kommt heute Abend. VG!
              • s.bormann
                s.bormann Most Active @dslraser last edited by s.bormann
                @dslraser sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                @s-bormann
                Hallo Sebastian,
                eigentlich dachte ich, es würde out of the box funktionieren. Da ich selbst aber nur klassische HM Thermostate habe, konnte ich es selbst nicht testen. Aktuell ist es im HM-IP-Thermostat Profil so hinterlegt:
                • AUTO-Mode: setzt .BOOST_MODE auf false und .CONTROL_MODE auf 0
                • MANU-Mode: setzt .BOOST_MODE auf false und .CONTROL_MODE auf 1
                • BOOST-Mode: setzt .BOOST_MODE auf true
                Stimmt diese Zuordnung so nicht? Oder - noch schlimmer, bei EQ3 aber durchaus denkbar - haben die es für die einzelnen HM-IP-Thermostate (gibt ja recht viele unterschiedliche) auch unterschiedlich implementiert??
                VG
                dslraser M 2 Replies Last reply Reply Quote 0
                • s.bormann
                  @dslraser Kannst Du mir mal bitte Deine Listen für die Batterien exportieren? Danke!
                  • dslraser
                    dslraser Forum Testing Most Active @s.bormann last edited by
                    2022-02-17_iqontrol_0_lists.json.zip
                    • dslraser
                      dslraser Forum Testing Most Active @s.bormann last edited by dslraser
                      @s-bormann
                      Hallo Sebastian,
                      VG
                      Ich habe es jetzt als normales Thermostat eingebunden. (und Value List) und Boost über ADITIONAL_CONTROL
                      Boost Schraubenschlüssel
                      Und bei CONTROL_MODE Schraubenschlüssel
                      M M 2 Replies Last reply Reply Quote 0
                        muuulle @dslraser last edited by muuulle
                        Moin Sebastian,
                        hier ist noch etwas in der Json Tabelle komisch.
                        Icon 1
                        Es wird erst der Ausdruck „Lampe-ein“ durch Bildbezeichnung „lampe-ein.png“ ersetzt.
                        Icon 2
                        Es wird erst der Ausdruck „ein“ durch Bildbezeichnung „ Toggle-ein.png“ ersetzt.
                        Hier wird etwas doppelt ersetzt, oder? 🤔
                        Edit
                        Ich hab die Datei in „Element-gelb.png“ umbenannt. Jetzt passiert das nicht mehr!
                          mapelt @s.bormann last edited by
                          VG
                          Das stimmt nicht. Bei meinen Homematic IP Thermostaten ist controlMode ein Textfeld. Also "MANUAL" oder "AUTOMATIC"
                          • dslraser
                            dslraser Forum Testing Most Active @mapelt last edited by
                            @mapelt sagte in Test Adapter iQontrol 1.11.x Vis (Entwicklungs-Thread):
                            Über welchen Adapter kommen Deine HMIP Geräte in ioBroker ?
                              mapelt @dslraser last edited by
                              @dslraser
                              Ich habe den WLAN Access Point. Ob es da auch noch Unterschiede zwische CCU und Access Point gibt?
                              • dslraser
                                @dslraser
                                Ja, da es ja ein anderer Adapter ist. Ich z.B. nutze den rpc Adapter, bei Dir wird es dann der HMIP Adapter sein.
                                  @dslraser
                                  Ja genau
                                  Der Boostmodus funktioniert auch nicht. BOOST_STATE habe ich mit dem boostMode Datenpunkt verbunden.
                                  Habe ich da einen Denkfehler?
                                  • dslraser
                                    Nein, wahrscheinlich hast Du keinen Denkfehler. Ich denke im Moment ist das Gerät HMIP-Thermostat so nicht direkt für Dich verwendbar. Das kann Dir aber @s-bormann beantworten.
                                    Du könntest mal diesen Weg wie hier beschrieben versuchen.
                                      @dslraser
                                      Ich warte mal ab. Im Thermostat fehlt mir noch die Möglichkeit der direkten Temperaturauswahl. Es geht über zusätzliche Steuerelemente, aber schön ist es nicht.
                                      @s-bormann
                                      Es wäre schön wenn man die Temperatur nicht nur über den Slider auswählen könnte. Das wurde schon mehrfach angefragt. 😉
                                      Ist es korrekt, dass der Ventilstatus nicht in % angezeigt wird?
                                      dslraser s.bormann 3 Replies Last reply Reply Quote 0
                                      • dslraser
                                        dslraser Forum Testing Most Active @mapelt last edited by dslraser
                                        @mapelt
                                        nur mal kurz zusammengeklöppelt. Einen alias als Werteliste und über Additional_Control eingebunden. Das wäre dann so (noch nicht ganz fertig)
                                        Handyansicht
                                        Mac (jetzt so)
                                        alias als Beispiel (erstmal nur kurz einige Temperaturen, lässt sich ja beliebig erweitern)
                                          "common": {
                                            "name": "Wohnzimmer",
                                            "role": "state",
                                            "type": "number",
                                            "write": true,
                                            "read": true,
                                            "states": {
                                              "5.0": "5.0",
                                              "16.0": "16.0",
                                              "17.0": "17.0",
                                              "18.0": "18.0",
                                              "19.0": "19.0",
                                              "20.0": "20.0",
                                              "21.0": "21.0",
                                              "22.0": "22.0",
                                              "22.5": "22.5",
                                              "23.0": "23.0"
                                            "alias": {
                                              "id": "hm-rpc.2.INT0000014.1.SET_POINT_TEMPERATURE"
                                            "ts": 1645384978164,
                                            "custom": {
                                              "iqontrol.0": {
                                                "enabled": true,
                                                "readonly": false,
                                                "invert": false,
                                                "confirm": false,
                                                "pincode": "",
                                                "unit": "",
                                                "unit_zero": "",
                                                "unit_one": "",
                                                "min": "",
                                                "max": "",
                                                "step": "",
                                                "roundDigits": 2,
                                                "timeFormat": "x",
                                                "timeDisplayDontShowDistance": false,
                                                "type": "string",
                                                "role": "state",
                                                "states": {
                                                  "5.0": "5.0",
                                                  "16.0": "16.0",
                                                  "17.0": "17.0",
                                                  "18.0": "18.0",
                                                  "19.0": "19.0",
                                                  "20.0": "20.0",
                                                  "21.0": "21.0",
                                                  "22.0": "22.0",
                                                  "22.5": "22.5",
                                                  "23.0": "23.0"
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636
                                          "_id": "alias.0.Heizung.Wohnzimmer",
                                          "type": "state",
                                          "ts": 1645389677465
                                        • s.bormann
                                          s.bormann Most Active @mapelt last edited by
                                          @dslraser
                                          @s-bormann
                                          dass es so viele HM-Thermostat-Versionen gibt nervt ziemlich. Wäre schön von EQ3 gewesen, sich hier mal an den eigenen Standard zu halten. So ist es kaum möglich, alle möglichen Varianten abzubilden. Aber bei Gelegenheit mach ich mir mal Gedanken, wie man das ganze ein wenig flexibler gestalten kann.
                                          Das mit den Wunsch-Temperaturen schreibe ich mir auch auf, sollte ja irgendwie machbar sein.
                                          VG
                                          • dslraser
                                            @s-bormann
                                            Hier kommt noch dazu, das es zwei verschiedene Adapter sind.
                                            rpc und HMIP
                                            296
                                            7637
                                            6949506
