    4. Fehlermeldung bei Insatallation von Javascript/Node.js
      cburger last edited by
      Hallo Zusammen,
      möchte mich gerade im Javascript üben, allerdings bekomme ich schon eine Fehlermeldung bei der Installation des Javascript/node.js Adapter:
      In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
      #include <dns_sd.h>
      ! compilation terminated.
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      gyp
      ERR! build error
      gyp
      ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      ! gyp ERR! System Linux 4.4.50-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns
      gyp ERR! node -v v4.8.0
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      ! npm
      ERR! Linux 4.4.50-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.yahka" "--production" "--prefix" "/opt/iobroker"
      ! npm ERR! node v4.8.0npm ERR! npm v2.15.11
      npm ERR! code ELIFECYCLE
      ! npm ERR! mdns@2.3.3 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.
      npm ERR! This is most likely a problem with the mdns package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs mdns
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls mdns
      npm ERR! There is likely additional logging output above.
      ! npm
      ERR! Please include the following file with any support request:
      npm ERR! /npm-debug.log
      ERROR: host.raspberrypi3 Cannot install iobroker.yahka: 1
      ERROR: process exited with code 25</dns_sd.h>
      Danke für eure Hilfe
      Christoph
        @cburger:
        bei der Installation des Javascript/node.js Adapter `
        @cburger:
        Cannot install iobroker.yahka: 1 `
        Das ist der Homekit-Adapter.
        Rainer
          Danke - muss mich da wohl erst reinarbeiten …
            apollon77 last edited by
            man braucht in dem Fall noch ein paa weitere Linux-Libraries:
            sudo apt-get install libavahi-compat-libdnssd-dev
            z.B.
              Danke apollon77 für die schnelle Antwort.
              Hatte Probleme mit Javascript Entwicklung und dachte diese Instanz sei die Lösung.
