    4. Umstellung auf "axios"
    • AlCalzone
      AlCalzone Developer @OliverIO last edited by
      @oliverio sagte in Umstellung auf "axios":
      Ob latin ein gültiger Wert ist weiß ich nicht.
      Laut https://nodejs.org/api/buffer.html#buffers-and-character-encodings müsste das latin1 sein (mit 1 am Ende).
        glitzi @OliverIO last edited by glitzi
        Super DANKE!!!
        nach einer knappen Stunde finde ich den Fehler nicht...
        19:27:04.325	error	javascript.0 (32211) script.js.Guntamatic.Guntamatic_Daten_aus_Http_Seite_Parsen_axios compile failed: at script.js.Guntamatic.Guntamatic_Daten_aus_Http_Seite_Parsen_axios:
        createState('Guntamatic_Betrieb_0');
        createState('Guntamatic_Aussentemperatur_1');
        createState('Guntamatic_Kesseltemperatur_3');
        createState('Guntamatic_Leistung_5');
        createState('Guntamatic_Rücklauf_6');
        createState('Guntamatic_CO2_Gehalt_8');
        createState('Guntamatic_Puffer_oben_17');
        createState('Guntamatic_Puffer_unten_19');
        createState('Guntamatic_Pumpe_HP0_20');
        createState('Guntamatic_Warmwasser_21');
        createState('Guntamatic_Vorlauf_31');
        createState('Guntamatic_Füllstand_65');
        createState('Guntamatic_Kesselfreigabe_68');
        createState('Guntamatic_Programm_69');
        createState('Guntamatic_Programm_HK1_71');
        createState('Guntamatic_Stoer0_79');
        createState('Guntamatic_Stoer1_80');
        createState('Guntamatic_Asche_entleeren_85');
        createState('Guntamatic_Brennstoffzähler_89');
        createState('Guntamatic_Pufferladung_90');
        createState('Guntamatic_CO2_Gehalt_korrigiert');
        schedule("*/5 * * * * *",
        axios.post('http://10.10.10.7/daqdata.cgi?key=226125AC4E4C9CD8144ABF4CA958AF294A4F', {
            responseEncoding: 'latin1'
          .then(function (response) {
            console.log(response);
            if (response.data) {
              var parts = response.data.split('\n');
              var parts_Guntamatic = parts[0];
              setState('Guntamatic_Betrieb_0', parts_Guntamatic, true);
              var parts_Guntamatic = parts[1];
              setState('Guntamatic_Aussentemperatur_1', parts_Guntamatic, true);
              var parts_Guntamatic = parts[3];
              setState('Guntamatic_Kesseltemperatur_3', parts_Guntamatic, true);
              var parts_Guntamatic = parts[5];
              setState('Guntamatic_Leistung_5', parts_Guntamatic, true);
              var parts_Guntamatic = parts[6];
              setState('Guntamatic_Rücklauf_6', parts_Guntamatic, true);
              var parts_Guntamatic = parts[8];
              setState('Guntamatic_CO2_Gehalt_8', parts_Guntamatic, true);
              var parts_Guntamatic = parts[17];
              setState('Guntamatic_Puffer_oben_17', parts_Guntamatic, true);
              var parts_Guntamatic = parts[19];
              setState('Guntamatic_Puffer_unten_19', parts_Guntamatic, true);
              var parts_Guntamatic = parts[20];
              setState('Guntamatic_Pumpe_HP0_20', parts_Guntamatic, true);
              var parts_Guntamatic = parts[21];
              setState('Guntamatic_Warmwasser_21', parts_Guntamatic, true);
              var parts_Guntamatic = parts[31];
              setState('Guntamatic_Vorlauf_31', parts_Guntamatic, true);
              var parts_Guntamatic = parts[65];
              setState('Guntamatic_Füllstand_65', parts_Guntamatic, true);
              var parts_Guntamatic = parts[68];
              setState('Guntamatic_Kesselfreigabe_68', parts_Guntamatic, true);
              var parts_Guntamatic = parts[69];
              setState('Guntamatic_Programm_69', parts_Guntamatic, true);
              var parts_Guntamatic = parts[71];
              setState('Guntamatic_Programm_HK1_71', parts_Guntamatic, true);
              var parts_Guntamatic = parts[79];
              setState('Guntamatic_Stoer0_79', parts_Guntamatic, true);
              var parts_Guntamatic = parts[80];
              setState('Guntamatic_Stoer1_80', parts_Guntamatic, true);
              var parts_Guntamatic = parts[85];
              setState('Guntamatic_Asche_entleeren_85', parts_Guntamatic, true);
              var parts_Guntamatic = parts[89];
              setState('Guntamatic_Brennstoffzähler_89', parts_Guntamatic, true);
              var parts_Guntamatic = parts[90];
              setState('Guntamatic_Pufferladung_90', parts_Guntamatic, true);
        CO2 Korrigieren da der Wert im Leerlauf teils 18.00 annimmt.
        parts[5] = Leistung parts[8] = CO2 Gehalt
        if (parts[5] == 0) {
                            setState("Guntamatic_CO2_Gehalt_korrigiert" , 0, true);
                            } else {
                                    setState("Guntamatic_CO2_Gehalt_korrigiert", parts[8], true)
         .catch(function (error) {
            console.log(error)
        OliverIO 1 Reply Last reply Reply Quote -1
        • OliverIO
          OliverIO @glitzi last edited by
          @glitzi sagte in Umstellung auf "axios":
          Viele Fehler
          https://beautifytools.com/javascript-validator.php
          beachtet du die Hinweise im Skripteditor nicht?
          Das korrekte einrücken nicht vergessen. Das erspart schon mal viele Logikfehler. Dem Parser ist es zwar egal, aber du suchst dich dann zu tode wenn die blöcke nicht auf der gleichen Ebene enden wie sie begonnen haben. Manche Editoren können da einem helfen. Einfach den kompletten Text mal dort reinkopieren und die Formatierung/beautyfier drüber laufen lassen.
          Auch wenn das ; nicht unbedingt notwendig ist, sollte man es immer setzen, da ansonsten der parser manchmal meckert und dann ist es besser immer einheitlich zu bleiben und den Code lesbar zu gestalten
          https://developer.mozilla.org/de/docs/Web/JavaScript/Reference/Errors/Missing_semicolon_before_statement
          Eine Variable sollte nur einmal innerhalb eines Blocks deklariert werden (var)
          und Klammern sollten in der richtigen Reihenfolge und in der korrekten Anzahl geöffnet und wieder geschlossen werden
          Line	Col	Errors
          39	11	'parts_Guntamatic' is already defined.
          42	11	'parts_Guntamatic' is already defined.
          45	11	'parts_Guntamatic' is already defined.
          48	11	'parts_Guntamatic' is already defined.
          51	11	'parts_Guntamatic' is already defined.
          54	11	'parts_Guntamatic' is already defined.
          57	11	'parts_Guntamatic' is already defined.
          60	11	'parts_Guntamatic' is already defined.
          63	11	'parts_Guntamatic' is already defined.
          66	11	'parts_Guntamatic' is already defined.
          69	11	'parts_Guntamatic' is already defined.
          72	11	'parts_Guntamatic' is already defined.
          75	11	'parts_Guntamatic' is already defined.
          78	11	'parts_Guntamatic' is already defined.
          81	11	'parts_Guntamatic' is already defined.
          84	11	'parts_Guntamatic' is already defined.
          87	11	'parts_Guntamatic' is already defined.
          90	11	'parts_Guntamatic' is already defined.
          93	11	'parts_Guntamatic' is already defined.
          104	89	Missing semicolon.
          111	23	Missing semicolon.
          112	12	Expected ')' and instead saw ';'.
          114	1	Expected ')' and instead saw '}'.
          114	2	Missing semicolon.
          114	2	Expected an identifier and instead saw ')'.
          114	2	Expected an assignment or function call and instead saw an expression.
          114	3	Unrecoverable syntax error. (96% scanned).
          coyote G 3 Replies Last reply Reply Quote 0
          • coyote
            coyote Most Active @OliverIO last edited by
            Hallo, ich hänge mich hier einfach mal ran, denke es ist nicht nötig nochmal einen eigenen Thread dafür aufzumachen.
            Ich habe auch noch ein paar Scripte mit "request", vielleicht kann mir da auch jemand bei der Umstellung auf "axios" helfen?!
            Hier der Teil des Scripts:
            var request = require("request");
            var fs = require('fs');
            // Speichert das Bild der Haustür bei Posteinwurf
            function saveImage() {
            	request.get({
            			url: source_url,
            			encoding: 'binary'
            		}, function(err, response, body) {
            			fs.writeFile('/tmp/' + 'Postbild.jpg', body, 'binary', function(err) {
            				if (err) {
            					log('Fehler beim Bild speichern: ' + err, 'warn');
            				} else {
            					log('Webcam Bild gespeichert');
            // Bilder werden nach vis gespeichert
            	setTimeout(function() {
            		const bild1 = fs.readFileSync('/tmp/Postbild.jpg');
            		writeFile('vis.0', '/Postbild.jpg', bild1);
            	}, 4000);
              @oliverio
              Danke für die Gute Unterstützung…
              Leider bin ich hier blutiger Anfänger, kannst du mir das eventuell im Script Kennzeichen?
                ich bin etwas weiter, siehe Antwort...
                • bahnuhr
                  ich muss jetzt auch mal fragen.
                  • warum wird von request auf axios umgestellt?
                  • was ist mit den alten Scripten ?
                  • gibts hier ein todo ?
                  Gibts da irgendwo mehr infos ?
                  Habe ca. 200 Scripte wo ca. bei der Hälfte (geschätzt) request drin ist.
                  Thomas Braun Wal 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @bahnuhr last edited by
                    @bahnuhr
                    Weil es nicht mehr gepflegt wird:
                    https://www.npmjs.com/package/request
                    https://github.com/request/request/issues/3142
                    mikeal created this issue in request/request
                    open Request’s Past, Present and Future #3142
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @Thomas Braun last edited by
                      @thomas-braun sagte in Umstellung auf "axios":
                      Und ab wann funktionieren dann meine Scripte nicht mehr ?
                      oder viel wichtiger: Was mun man tun um dies zu ändern ?
                        Thomas Braun Most Active @bahnuhr last edited by Thomas Braun
                        @bahnuhr sagte in Umstellung auf "axios":
                        Vermutlich spätestens dann, wenn request aus nodejs aussortiert wird.
                        Ich vermute, das wird aber ob der breiten Verwendung von request noch lange mitgeschleift werden müssen. Ist ja schon geraume Zeit als 'deprecated' markiert.
                        • Wal
                          Wal Developer @bahnuhr last edited by
                          Ja bei google.
                          Du musst auch nicht axios nehmen, es funktioniert auch http.
                            glitzi @glitzi last edited by
                            @OliverIO
                            Puhh ich glaube ich bin etwas weiter... trotzdem drehe ich mich irgendwie im Kreis .
                            16:53:20.267	error	javascript.0 (6088) script.js.Guntamatic.Guntamatic_Daten_aus_Http_Seite_Parsen_axios: schedule callback missing
                            const axios=require('axios');
                            	axios.post('http://xx.xx.xx.xx/daqdata.cgi?key=xxxx', {
                            	.then(function(response) {
                            			//console.log(response);
                            					setState("Guntamatic_CO2_Gehalt_korrigiert", 0, true);
                            				} else {
                            					setState("Guntamatic_CO2_Gehalt_korrigiert", parts[8], true);
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @Wal last edited by
                              @wal sagte in Umstellung auf "axios":
                              hast du mal ein Beispiel ?
                              • OliverIO
                                OliverIO @bahnuhr last edited by
                                @bahnuhr
                                das ist aber alles sehr ähnlich.
                                Noch einfacher geht nicht wirklich
                                  tombox @Thomas Braun last edited by tombox
                                  @thomas-braun Ich denke auch mit 50.000 Dependents wird es wohl nie entfernt werden können. Also kann der kleine ioBroker Skripter sich mit der Umstellung noch zeit lassen.
                                  @glitzi
                                  der schedule wird nicht richtig aufgemacht
                                  schedule("*/5 * * * * *", function(){
                                  OliverIO G 2 Replies Last reply Reply Quote 0
                                  • OliverIO
                                    OliverIO @tombox last edited by OliverIO
                                    @tombox
                                    und wenn es aus iobroker entfernt wird, dann lädt man es selbst nach.
                                    es ist ja nicht so das es da sicherheitsbedenken gibt, sonder das die bibliothekt zu ende entwickelt ist.
                                      tombox @OliverIO last edited by
                                      @oliverio Korrekt solange es kein security problem gibt wäre es auch ziemlich gemein es aus der iobroker skript default package rauszunehmen
                                        glitzi @tombox last edited by
                                        @tombox
                                        SUPER, vielen Dank! jetzt läuft es !!!
                                          glitzi @AlCalzone last edited by
                                          @alcalzone
                                          Leider scheint das Encoding nicht zu funktionieren, ist hier etwas falsch?
                                          	axios.post('http://xx.xx.xx.xx/daqdata.cgi?key=abcde', {
                                          		responseEncoding: 'utf-8'
                                          OliverIO 2 Replies Last reply Reply Quote 0
                                          • OliverIO
                                            @glitzi
                                            das sind zu wenig informationen.
                                            in was ist den die quelle encodiert?
                                            utf8 scheint es ja nicht zu sein.
                                            woran erkennst du es das das encoding nicht funktioniert?
                                            1887
