    4. Node.red funktioniert unter Windows nicht
      Hc-Yami last edited by
      Guten Tag,
      leider läuft meine node.red Instanz nicht. Bzw. läuft sie, aber Alexa findet keine Geräte unter alexa.local:
      node-red.0	2018-03-25 15:12:54.513	info	Save C:/ioBroker/iobroker-data/node-red/flows.json
      node-red.0	2018-03-25 15:12:54.013	error
      node-red.0	2018-03-25 15:12:54.013	error	at Flow.start (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:89:35)
      node-red.0	2018-03-25 15:12:54.013	error	at createNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:305:18)
      node-red.0	2018-03-25 15:12:54.013	error	at new AlexaLocalNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red-contrib-alexa-local\index.js:29:25)
      node-red.0	2018-03-25 15:12:54.013	error	at require (internal/module.js:12:17)
      node-red.0	2018-03-25 15:12:54.013	error	at Module.require (module.js:353:17)
      node-red.0	2018-03-25 15:12:54.013	error	at Function.Module._load (module.js:300:12)
      node-red.0	2018-03-25 15:12:54.013	error	at Module.load (module.js:343:32)
      node-red.0	2018-03-25 15:12:54.013	error	at Object.Module._extensions..js (module.js:416:10)
      node-red.0	2018-03-25 15:12:54.013	error	at Module._compile (module.js:373:25)
      node-red.0	2018-03-25 15:12:54.013	error	at exports.runInThisContext (vm.js:53:16)
      node-red.0	2018-03-25 15:12:54.013	error	25 Mar 15:12:54 - [error] [alexa-local:be811848.8589e8] SyntaxError: Unexpected token =
      node-red.0	2018-03-25 15:12:27.904	error
      node-red.0	2018-03-25 15:12:27.904	error	at Flow.start (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:89:35)
      node-red.0	2018-03-25 15:12:27.904	error	at createNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\red\runtime\nodes\flows\Flow.js:305:18)
      node-red.0	2018-03-25 15:12:27.904	error	at new AlexaLocalNode (C:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red-contrib-alexa-local\index.js:29:25)
      node-red.0	2018-03-25 15:12:27.904	error	at require (internal/module.js:12:17)
      node-red.0	2018-03-25 15:12:27.904	error	at Module.require (module.js:353:17)
      node-red.0	2018-03-25 15:12:27.904	error	at Function.Module._load (module.js:300:12)
      node-red.0	2018-03-25 15:12:27.904	error	at Module.load (module.js:343:32)
      node-red.0	2018-03-25 15:12:27.904	error	at Object.Module._extensions..js (module.js:416:10)
      node-red.0	2018-03-25 15:12:27.904	error	at Module._compile (module.js:373:25)
      node-red.0	2018-03-25 15:12:27.904	error	at exports.runInThisContext (vm.js:53:16)
      node-red.0	2018-03-25 15:12:27.904	error	25 Mar 15:12:27 - [error] [alexa-local:be811848.8589e8] SyntaxError: Unexpected token =
      node-red.0	2018-03-25 15:12:27.763	warn
      node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [info] Flows file : C:\ioBroker\iobroker-data\node-red\flows.json
      node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
      node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] ------------------------------------------------------
      node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] [node-red/tail] Not currently supported on Windows.
      node-red.0	2018-03-25 15:12:27.763	warn	25 Mar 15:12:27 - [warn] [node-red/rpi-gpio] Info : Ignoring Raspberry Pi specific node
      node-red.0	2018-03-25 15:12:15.685	info	Starting node-red: --max-old-space-size=128 C:\ioBroker\node_modules\iobroker.node-red/node_modules/node-red/red.js -v --settings C:/ioBroker/iobroker-data/node-red/settings.js
      node-red.0	2018-03-25 15:12:15.591	info	starting. Version 1.5.1 in C:/ioBroker/node_modules/iobroker.node-red, node: v4.5.0
      host.Server	2018-03-25 15:12:14.686	info	instance system.adapter.node-red.0 started with pid 8220
      Hat jemand eine Idee dazu?
        apollon77 last edited by
        Was ist "alexa-local"? Hast Du irgendwelche zusätzliches Module/Nodes angegeben/Installiert?
          tatsächlich habe ich das getan.
          Um Alexa lokal anzusteuern, benötigt man ja das Alexa.local plugin:
          https://www.npmjs.com/package/node-red- … lexa-local
          Das habe ich ganz einfach über die node.red Oberfläche getan.
            Und genau das verursacht deine Probleme:
            Da musst Du jetzt selbst schauen was kaputt ist. Kein ioBroker Problem.
              @Hc-Yami:
              Das habe ich ganz einfach über die node.red Oberfläche getan. `
              Wie denn das?
              oder geht es hier um node-red standalone?
              ganz einfach geht anders:
              npm-modul ganz einfach da eintragen und Instanz neu starten 😉
              Rainer
