    • simatec
      simatec Developer Most Active @Adnim last edited by
      @adnim Bitte Issue aufmachen
        Adnim @simatec last edited by
        @simatec sagte in Test Adapter shuttercontrol v1.4.x:
        ok
        https://github.com/simatec/ioBroker.shuttercontrol/issues/368
        MiniAdnim created this issue in simatec/ioBroker.shuttercontrol
        closed Manuelles Verfahren bei Öffnen mit Lichtsensor #368
          bommel_030 @simatec last edited by
          @simatec
          Debuglog wie gewünscht. Alles was nicht Shutter WC betrifft entfernt.
          2022-02-15 06:26:23.817 - debug: shuttercontrol.0 (1612) TriggerID changed: hm-rpc.0.00171BE9932110.7.STATE Value: true
          2022-02-15 06:26:23.817 - debug: shuttercontrol.0 (1612) WC - shutter conversion is:false
          2022-02-15 06:26:23.818 - debug: shuttercontrol.0 (1612) WC - shutter trigger drive-up is:5
          2022-02-15 06:26:23.818 - debug: shuttercontrol.0 (1612) WC - shutter trigger change is:upDown
          2022-02-15 06:26:24.742 - debug: shuttercontrol.0 (1612) insidetemperature changed: hm-rpc.0.001D1A499061C9.1.ACTUAL_TEMPERATURE Value: 20.2
          2022-02-15 06:26:24.819 - debug: shuttercontrol.0 (1612) #1 save trigger height: 0% for device WC
          2022-02-15 06:26:24.819 - debug: shuttercontrol.0 (1612) #1 save trigger action: none for device WC
          2022-02-15 06:26:24.819 - info: shuttercontrol.0 (1612) #1 Set ID: WC value: 5%
          2022-02-15 06:26:24.820 - info: shuttercontrol.0 (1612) triggered #1 Set ID: WC value: 5%
          2022-02-15 06:26:24.825 - debug: shuttercontrol.0 (1612) WC - window is still open -> driving now to :5
          2022-02-15 06:28:04.823 - debug: shuttercontrol.0 (1612) Shutter state changed: WC old value = 0 new value = 5
          2022-02-15 06:28:04.823 - debug: shuttercontrol.0 (1612) WC Old value = 0. New value = 5. automatic is active
          2022-02-15 06:28:05.101 - debug: shuttercontrol.0 (1612) Shutter state changed: WC old value = 0 new value = 5
          2022-02-15 06:28:05.101 - debug: shuttercontrol.0 (1612) WC Old value = 0. New value = 5. automatic is active
          2022-02-15 06:28:44.416 - debug: shuttercontrol.0 (1612) Shutter state changed: WC old value = 0 new value = 5
          2022-02-15 06:28:44.416 - debug: shuttercontrol.0 (1612) WC Old value = 0. New value = 5. automatic is active
          2022-02-15 06:38:29.543 - debug: shuttercontrol.0 (1612) TriggerID changed: hm-rpc.0.00171BE9932110.7.STATE Value: false
          2022-02-15 06:38:29.544 - debug: shuttercontrol.0 (1612) WC - shutter conversion is:false
          2022-02-15 06:38:29.550 - debug: shuttercontrol.0 (1612) WC - shutter current state.val is:5
          2022-02-15 06:38:29.550 - debug: shuttercontrol.0 (1612) WC - shutter current Height is:5
          2022-02-15 06:38:29.550 - debug: shuttercontrol.0 (1612) WC - shutter trigger Height is:0
          2022-02-15 06:38:29.550 - debug: shuttercontrol.0 (1612) WC - shutter trigger Action is:none
          2022-02-15 06:38:29.550 - debug: shuttercontrol.0 (1612) WC - shutter trigger Change is:upDown
          2022-02-15 06:38:29.596 - info: shuttercontrol.0 (1612) Window is still closed -> drive to last height: Set ID: WC value: 0%
          2022-02-15 06:38:29.607 - debug: shuttercontrol.0 (1612) save back trigger action: none for device: WC
          2022-02-15 06:40:09.601 - debug: shuttercontrol.0 (1612) Shutter state changed: WC old value = 5 new value = 0
          2022-02-15 06:40:09.601 - debug: shuttercontrol.0 (1612) WC Old value = 5. New value = 0. automatic is active
          2022-02-15 06:40:09.842 - debug: shuttercontrol.0 (1612) Shutter state changed: WC old value = 5 new value = 0
          2022-02-15 06:40:09.842 - debug: shuttercontrol.0 (1612) WC Old value = 5. New value = 0. automatic is active
          2022-02-15 06:40:49.403 - debug: shuttercontrol.0 (1612) Shutter state changed: WC old value = 5 new value = 0
          2022-02-15 06:40:49.403 - debug: shuttercontrol.0 (1612) WC Old value = 5. New value = 0. automatic is active
          • D3ltoroxp
            D3ltoroxp last edited by
            Kurze Frage zum Random fahren. Wie war das ? Sonnenaufgan die Rollos fahren von mir aus um 8:00 Uhr. Dann kann ich für jedes Rollo oder Raum eine andere Zusatzzeit einstellen. Mal 5 Sekunden, andere 10 usw. Das heißt aber auch, die fahren jeden Tag immer in der gleichen Reihenfolge hoch.
            Könnte man da vllt einfach eine Random Zeit einbauen, das die einfach auch in unterschiedlicher Reihenfolge fahren. Jeden Tag anders ? Würde grad im Urlaub eine Anwesenheit besser simulieren oder wenn man nicht zu Hause ist.
            Schmakus 1 Reply Last reply Reply Quote 0
            • Schmakus
              Schmakus Developer @D3ltoroxp last edited by Schmakus
              @d3ltoroxp said in Test Adapter shuttercontrol v1.4.x:
              interessante Idee! Zumindest wählbar. Mach doch ein Issue auf Github auf, damit die Idee nicht verloren geht.
              • Jens16
                Jens16 last edited by Negalein
                ich habe Zeitverzögerung für das versetzte Fahren der Rollläden bei allen Einstellungen auf 20 Sekunden eingestellt.
                Beim öffnen funktioniert dass auch soweit aber beim schließen funktioniert es leider nicht, da fahren Wohnbereich und Schlafbereich ohne Versatz.
                2022-02-17 07:43:00.084 - info: shuttercontrol.0 (759) Living up #13 Set ID: Wohnzimmer Jalousie 1 ShutterPosition1 value: 100%
                2022-02-17 07:43:20.110 - info: shuttercontrol.0 (759) Living up #13 Set ID: Badezimmer Jalousie ShutterPosition1 value: 100%
                2022-02-17 07:44:00.044 - info: shuttercontrol.0 (759) Sleep up #22 Set ID: Schlafzimmer Jalousie 1 ShutterPosition1 value: 100%
                2022-02-17 07:44:20.073 - info: shuttercontrol.0 (759) Sleep up #22 Set ID: Kinderzimmer Jalousie ShutterPosition1 value: 100%
                2022-02-17 17:23:00.097 - info: shuttercontrol.0 (8337) Sleep down #27 Set ID: Schlafzimmer Jalousie 1 ShutterPosition1 value: 23%
                2022-02-17 17:23:00.112 - info: shuttercontrol.0 (8337) Living down #18 Set ID: Wohnzimmer Jalousie 1 ShutterPosition1 value: 24%
                2022-02-17 17:23:20.156 - info: shuttercontrol.0 (8337) Sleep down #27 Set ID: Kinderzimmer Jalousie ShutterPosition1 value: 23%
                2022-02-17 17:23:20.159 - info: shuttercontrol.0 (8337) Living down #18 Set ID: Badezimmer Jalousie ShutterPosition1 value: 23%
                Mod-Edit: Code in </> Code-Tag gepackt!
                • Jens16
                  So heute hat es funktioniert ohne etwas in den Einstellungen geändert zu haben.
                  2022-02-18 07:41:00.086 - info: shuttercontrol.0 (8337) Living up #13 Set ID: Wohnzimmer Jalousie 1 ShutterPosition1 value: 100%
                  2022-02-18 07:41:20.116 - info: shuttercontrol.0 (8337) Living up #13 Set ID: Badezimmer Jalousie ShutterPosition1 value: 100%
                  2022-02-18 07:42:00.065 - info: shuttercontrol.0 (8337) Sleep up #22 Set ID: Schlafzimmer Jalousie 1 ShutterPosition1 value: 100%
                  2022-02-18 07:42:20.146 - info: shuttercontrol.0 (8337) Sleep up #22 Set ID: Kinderzimmer Jalousie ShutterPosition1 value: 100%
                  2022-02-18 11:38:06.445 - info: info.0 (744) Reading/updating systemdata.
                  2022-02-18 11:38:07.034 - info: info.0 (744) cpu Temp res = {"main":38.459,"cores":[],"max":38.459,"socket":[],"chipset":null}
                  2022-02-18 17:25:00.093 - info: shuttercontrol.0 (8337) Living down #18 Set ID: Wohnzimmer Jalousie 1 ShutterPosition1 value: 24%
                  2022-02-18 17:25:20.108 - info: shuttercontrol.0 (8337) Living down #18 Set ID: Badezimmer Jalousie ShutterPosition1 value: 23%
                  2022-02-18 17:26:00.036 - info: shuttercontrol.0 (8337) Sleep down #27 Set ID: Schlafzimmer Jalousie 1 ShutterPosition1 value: 23%
                    Aufruf last edited by Aufruf
                    erstmal vielen Dank für den tollen Adapter. Ich hatte bisher drei Rollladen in einem Bereich (zugeordnet zu Wohnbereich Automatik) und die Steuerung hat super funktioniert. Ich hatte hierzu zusätzlich in meiner VIS einen Button der den Control Datenpunkt "closeLiving" steuert zum schließen aller Rollladen im Wohnbereich. Nun hab ich zwei weitere Rollladen im Kinder Bereich hinzugefügt und hierfür wiederum auch einen Button für closeChildren.
                    Wenn ich einen der beiden Control Befehle setze (closeLiving oder closeChildren // mit open aber gleiches Spiel) fahren aber alle Rollladen und nicht nur der Bereich. Das ist unabhängig von der VIS und passiert auch wenn ich direkt in den Objekten auf den jeweiligen Control Befehl drücke. Hat hier jemand eine Idee woran das liegen könnte?
                    • Dirk Peter
                      Dirk Peter last edited by
                      @simatec
                      Hallo, ich habe hier mal den Verlauf des Adapters voller Windböen dokumentiert. Angesteuert habe ich das ganze über ein kleines Skript. Dieses schaltet bei einer Windböe über 20 km/h auf true für 30 min. Wenn eine neue Böe auftritt so verlängert sich das ganze.
                      Hier das ergebnis:
                      shuttercontrol.0  11635	2022-02-21 06:48:30.076	info	Children Up #22 Set ID: HmIPW-DRBL4 DG-KZ-2-2 value: 100%
                      shuttercontrol.0  11635	2022-02-21 06:48:10.114	info	Living up #13 Set ID: HmIPW-DRBL4 DG-Bad value: 100%
                      shuttercontrol.0  11635	2022-02-21 06:48:00.043	info	Living up #13 Set ID: HmIPW-DRBL4 EG-GZ value: 100%
                      shuttercontrol.0  11635	2022-02-21 06:48:00.040	info	Children Up #22 Set ID: HmIPW-DRBL4 DG-KZ-1-1 value: 100%
                      shuttercontrol.0  11635	2022-02-21 06:15:57.554	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-KZ-2-1 value: 18%
                      shuttercontrol.0  11635	2022-02-21 06:15:47.516	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-KZ-1-2 value: 18%
                      shuttercontrol.0  11635	2022-02-21 06:15:27.465	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-SZ value: 18%
                      shuttercontrol.0  11635	2022-02-21 05:43:09.738	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-KZ-2-1 value: 0%
                      shuttercontrol.0  11635	2022-02-21 05:42:59.716	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-KZ-1-2 value: 0%
                      shuttercontrol.0  11635	2022-02-21 05:42:39.670	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-SZ value: 0%
                      shuttercontrol.0  11635	2022-02-21 04:10:03.543	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-KZ-2-1 value: 18%
                      shuttercontrol.0  11635	2022-02-21 04:09:53.518	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-KZ-1-2 value: 18%
                      shuttercontrol.0  11635	2022-02-21 04:09:33.471	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-SZ value: 18%
                      shuttercontrol.0  11635	2022-02-21 03:39:45.791	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-KZ-2-1 value: 0%
                      shuttercontrol.0  11635	2022-02-21 03:39:35.759	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-KZ-1-2 value: 0%
                      shuttercontrol.0  11635	2022-02-21 03:39:15.714	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-SZ value: 0%
                      shuttercontrol.0  11635	2022-02-21 03:08:58.941	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-KZ-2-1 value: 18%
                      shuttercontrol.0  11635	2022-02-21 03:08:48.906	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-KZ-1-2 value: 18%
                      shuttercontrol.0  11635	2022-02-21 03:08:28.873	info	Alarm Wind 1 ended Set ID: HmIPW-DRBL4 DG-SZ value: 18%
                      shuttercontrol.0  11635	2022-02-21 02:36:23.758	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-KZ-2-1 value: 0%
                      shuttercontrol.0  11635	2022-02-21 02:36:13.733	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-KZ-1-2 value: 0%
                      shuttercontrol.0  11635	2022-02-21 02:35:53.665	info	Alarm #100 Set ID: HmIPW-DRBL4 DG-SZ value: 0%
                      Was auffällt, um 6:48 hätten alle Rollos hochfahren müssen! Es fuhren aber nur die Rollladen auf up, die durch den Windalarm nicht bewegt wurden. Der Rest der Rollos, die in der Nacht auf 18% stehen, sind im down Modus verblieben, mit der Anzeige von none. Die Rollos sind aber nicht von Hand verfahren wurden!
                      Wie ist die Funktion des Windalarms beabsichtigt, sollen die Rollos wirklich die ganze Nacht hoch und runter Fahren, dann muss ich mein Skript zum ansteuern noch etwas anpassen. Oder währe es nicht besser, wenn die Rollos bei Windalarm in die Sturmposition fahren und dort bis zur nächsten anstehenden Funktion z.B. up verharren!
                      Was ich mir auch vorstellen könnte, währe wenn man den Alarmzustand generell nur per Hand beenden könnte (maximale Sicherheit).
                      Ein weiterer Vorteil währe, das man die Alarmeingänge leichter ansteuern kann, auch von Anfängern, da man keine Schalthysteresen einbauen müsste, sondern die Alarmeingänge direkt verschalten könnte.
                      Danke für den Adapter, der zuverlässig bei mir arbeitet!
                      MfG Dirk Peter
                      simatec F 2 Replies Last reply Reply Quote 0
                      • simatec
                        simatec Developer Most Active @Dirk Peter last edited by
                        @dirk-peter
                        Die Funktion hat @FoxRo implementiert .... Er kann da sicher mehr zu sagen.
                        @FoxRo Bitte auch noch mal prüfen und ggfs. ein PR mit einem Fix pushen.
                          FoxRo @Dirk Peter last edited by
                          @dirk-peter
                          Grundsätzlich sollten sie natürlich nur zwischen der WIND und der letzten angeforderten Position hin und her fahren, wenn der Windalarm kommt und geht.
                          Ich habe es bei mir aktuell so, dass ich diesen mittels eines Buttons in der VIS aktiviere und deaktiviere. Später werde ich ihn wohl mittels Wetterstation aktivieren, dann aber entweder mit langer Zeitverzögerung + Uhrzeit für öffnen oder nur manuell wieder freigeben.
                          Aktuell ist es so implementiert, dass wenn ein Alarm kommt, dass er dann "stur" auf die entsprechende Alarm Position fährt und da verbleibt (aus Sicherheit), bis entweder ein nächster Alarm ausgelöst wird oder dieser wieder aufgehoben wird.
                          D.h. wenn der Wind1 Alarm aktiviert wird, dann wird der Rollo auf Wind1 Position gefahren und verbleibt in dieser Sicherheitsposition. Die letzte Anforderung wird zwischengespeichert und wird dann angefahren, wenn der Alarm aufgehoben wird. (Ausnahme ist der Frost-Alarm - dieser darf immer hoch fahren)
                          Für Dich bedeutet dies, dass der Rollo in der Tat in Wind1 verbleibt, bis Wind1 deaktiviert wird oder du manuell einen der open Buttons drückst.
                          Als kurzfristigen Workaround könntest zur Openzeit den Windalarm deaktivieren, dann würden sie ebenfalls normal automatisch hoch fahren.
                          Ich muss mir mal überlegen, ob man mit einem Konfig-Schalter das Verhalten an dieser Stelle so gestalten könnte, dass man gezielt "UP" Bewegungen trotz aktivem Alarm zulassen kann.
                          Hoffe das hilft Dir fürs Erste weiter.
                          Viel Erfolg!
                          Dirk Peter 1 Reply Last reply Reply Quote 0
                          • Dirk Peter
                            Dirk Peter @FoxRo last edited by
                            @foxro
                            Hallo, danke für die Antwort. Ich werde dann mal meine äußere Steuerung dementsprechend anpassen.
                            MfG Dirk Peter
                            • tanzbaer
                              tanzbaer @simatec last edited by
                              @gucky28
                              Am besten du öffnest das Fenster und schließt es kurze Zeit später wieder. Die Zeit merken und im Log den Teil zu dieser besagten Zeit hier kopieren.
                              würde das Thema nochmal aufgreifen, da bei mir die gleiche Problematik besteht, allerdings hier nicht weiter verfolgt wurde.
                              Das Auf- und Zufahren hat bei einer früheren Version schon funktioniert.
                              Kurz nochmal zur Info:
                              • Die Rollos sind unten
                              • Fenster wird geöffnet und der Rollo fährt auf die eingestellte Position
                              • Fenster wird geschlossen, Rollo bleibt aber auf der Position stehen
                              Die Einstellungen sind wie folgt:
                              Anbei auch der Debuglog vom Öffnen und Schließen
                              2022-02-23 13:02:14.289 - debug: shuttercontrol.0 (23305) shutterDownButton RO_OG_Esszimmer:1.LEVEL old height: 100% new height: 0%
                              2022-02-23 13:02:14.382 - debug: shuttercontrol.0 (23305) Shutter state changed: RO_OG_Esszimmer:1.LEVEL old value = 100 new value = 0
                              2022-02-23 13:02:14.383 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL Old value = 100. New value = 0. automatic is active
                              2022-02-23 13:02:15.294 - debug: shuttercontrol.0 (23305) save current height after State Check: 100% from RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:02:19.291 - debug: shuttercontrol.0 (23305) Shuttercontrol save all shutter states
                              2022-02-23 13:02:40.257 - debug: shuttercontrol.0 (23305) Shutter state changed: RO_OG_Esszimmer:1.LEVEL old value = 100 new value = 0
                              2022-02-23 13:02:40.261 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
                              2022-02-23 13:02:40.262 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL drived manually to 0. Old value = 100. New value = 0
                              2022-02-23 13:02:41.267 - debug: shuttercontrol.0 (23305) save current height after State Check: 0% from RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:02:41.267 - debug: shuttercontrol.0 (23305) Shutter RO_OG_Esszimmer:1.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
                              2022-02-23 13:03:18.472 - debug: shuttercontrol.0 (23305) TriggerID changed: Systemvariablen.0.Zustände.Fenster.Fenster_OG_Essbereich.STATE Value: true
                              2022-02-23 13:03:18.475 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter conversion is:false
                              2022-02-23 13:03:18.477 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter trigger drive-up is:70
                              2022-02-23 13:03:18.477 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter trigger change is:upDown
                              2022-02-23 13:03:18.479 - debug: shuttercontrol.0 (23305) #1 save trigger height: 0% for device RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:03:18.479 - debug: shuttercontrol.0 (23305) #1 save trigger action: Manu_Mode for device RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:03:18.480 - info: shuttercontrol.0 (23305) #1 Set ID: RO_OG_Esszimmer:1.LEVEL value: 70%
                              2022-02-23 13:03:18.482 - info: shuttercontrol.0 (23305) triggered #1 Set ID: RO_OG_Esszimmer:1.LEVEL value: 70%
                              2022-02-23 13:03:18.538 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - window is still open -> driving now to :70
                              2022-02-23 13:03:18.632 - debug: shuttercontrol.0 (23305) Shutter state changed: RO_OG_Esszimmer:1.LEVEL old value = 100 new value = 70
                              2022-02-23 13:03:18.632 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL Old value = 100. New value = 70. automatic is active
                              2022-02-23 13:03:19.083 - debug: shuttercontrol.0 (23305) Shutter state changed: RO_OG_Esszimmer:1.LEVEL old value = 100 new value = 0
                              2022-02-23 13:03:19.087 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
                              2022-02-23 13:03:19.088 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL drived manually to 0. Old value = 100. New value = 0
                              2022-02-23 13:03:19.542 - debug: shuttercontrol.0 (23305) save current height after State Check: 0% from RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:03:19.542 - debug: shuttercontrol.0 (23305) Shutter RO_OG_Esszimmer:1.LEVEL was moved manually to: 0% while window was open - prevent trigger from driving back
                              2022-02-23 13:03:37.251 - debug: shuttercontrol.0 (23305) Shutter state changed: RO_OG_Esszimmer:1.LEVEL old value = 100 new value = 70
                              2022-02-23 13:03:37.256 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL Updated trigger action to Manu_Mode to prevent moving after window close
                              2022-02-23 13:03:37.256 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL drived manually to 70. Old value = 100. New value = 70
                              2022-02-23 13:03:38.261 - debug: shuttercontrol.0 (23305) save current height after State Check: 70% from RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:03:38.262 - debug: shuttercontrol.0 (23305) Shutter RO_OG_Esszimmer:1.LEVEL was moved manually to: 70% while window was open - prevent trigger from driving back
                              2022-02-23 13:03:54.112 - debug: shuttercontrol.0 (23305) Brightness sensor value: 11770
                              2022-02-23 13:03:54.116 - debug: shuttercontrol.0 (23305) outsidetemperature changed: Systemvariablen.0.Umwelt.Wetterstation.Temperatur.Aktuell Value: 10.8
                              2022-02-23 13:04:04.113 - debug: shuttercontrol.0 (23305) Brightness State Down is: false
                              2022-02-23 13:04:04.113 - debug: shuttercontrol.0 (23305) Lightsensor changed: Systemvariablen.0.Umwelt.Wetterstation.Helligkeit.Aktuell Value: 11770
                              2022-02-23 13:04:16.230 - debug: shuttercontrol.0 (23305) TriggerID changed: Systemvariablen.0.Zustände.Fenster.Fenster_OG_Essbereich.STATE Value: false
                              2022-02-23 13:04:16.232 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter conversion is:false
                              2022-02-23 13:04:16.235 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter current state.val is:70
                              2022-02-23 13:04:16.235 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter current Height is:70
                              2022-02-23 13:04:16.235 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter trigger Height is:70
                              2022-02-23 13:04:16.236 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter trigger Action is:Manu_Mode
                              2022-02-23 13:04:16.236 - debug: shuttercontrol.0 (23305) RO_OG_Esszimmer:1.LEVEL - shutter trigger Change is:upDown
                              2022-02-23 13:04:16.244 - debug: shuttercontrol.0 (23305) #1 shutter trigger released RO_OG_Esszimmer:1.LEVEL already in place: 70%
                              2022-02-23 13:04:16.245 - debug: shuttercontrol.0 (23305) save back trigger action: Manu_Mode for device RO_OG_Esszimmer:1.LEVEL
                              2022-02-23 13:05:00.012 - debug: shuttercontrol.0 (23305) calculate astrodata ...
                              2022-02-23 13:05:00.012 - debug: shuttercontrol.0 (23305) Sun Azimut: 190.6°
                              2022-02-23 13:05:00.013 - debug: shuttercontrol.0 (23305) Sun Elevation: 30.8°
                              Evtl. gibt es ja bei der neuen Version noch eine Einstellung die ich übersehen habe.
                              Vielen Dank und schöne Grüße
                              Markus
                              • simatec
                                simatec Developer Most Active @tanzbaer last edited by
                                @tanzbaer So wie ich das im Log lese, werden deine Zustände nicht korrekt gespeichert?
                                Was nutzt du für Rollladenaktoren und wie liefern die den Status?
                                Ich würde "Überprüfen des aktuellen Rolladenstatus" mal aktivieren und je nach Fahrzeit auf 60 Sekunden setzen
                                tanzbaer 1 Reply Last reply Reply Quote 1
                                • Nightfly1983
                                  Nightfly1983 last edited by
                                  Bin in letzter Zeit absolut zufrieden mit allem wie es so funktioniert.
                                  Jetzt aber mal eine neue Frage:
                                  Ich habe bei meiner Balkontür zwei Sensoren angebracht, für ganz offen und Kippfunktion. Welches eingestellt ist erledigt ein Script.
                                  0=geschlossen
                                  1=gekippt
                                  2=offen
                                  Meine Einstellungen sind wie im bild zu sehen. Nun zur eigentlichen Frage, wenn ich die Tür ankippe fährt das Rollo auf die 20 hoch und bleibt auch da nach dem Schließen (da wäre wieder runterfahren schön), wenn ich die Tür ganz Öffne, fährt das Rollo komplett hoch, aber wenn ich sie wieder schließe fährt es auch wieder runter was nicht sein sollte.
                                  Oder hab ich einen Denkfehler?
                                  Danke vorab und weiter so, ihr habt alles toll umgesetzt.
                                  Nightfly1983 simatec 2 Replies Last reply Reply Quote 0
                                  • Nightfly1983
                                    Nightfly1983 @Nightfly1983 last edited by
                                    @nightfly1983 Als Ergänzung, wenn das Rollo zu war und die Tür komplett geöffnet wurde (Rollo fährt hoch), fährt das Rollo nach dem Schließen auf die 20 vom Kippen.
                                    • tanzbaer
                                      Ich verwende den Homematic Rolladenaktor HM-LC-Bl1-FM und benutze direkt das Level-Objekt aus dem HM-Adapter.
                                      Werde die Überprüfung des Rolladenstatus übers Wochenende mal testen.
                                      Vielen Dank schon mal.
                                        WeiserWolf last edited by WeiserWolf
                                        irgendwie bekomme ich die automatische Sonnenfunktion nicht ans laufen.
                                        Das sind die Einstellungen die ich außer meinen GPS Koordinaten getätigt habe, aber das Objekt "shuttercontrol.0.control.sunProtectChildren" ist immer false. Wenn ich dieses manuell auf true setze, fahren die Rollos sofort los. Da ich keine Temperatursensoren oder Helligkeit etc habe aktuell, habe ich daran nichts verändert. Oder ist hier zwingend etwas vorzusehen?
                                        Aktuell spiele ich auch nur mit dem Rollo in meinem Büro, hier soll es runterfahren um das Blenden durch die Sonne zu unterbinden, daher dachte ich sollte es so funktionieren.
                                        Hat vielleicht jemand einen heißen Tip, was ich wieder verbockt habe?
                                        Vielen Dank.
                                        Wolf
                                        • simatec
                                          simatec Developer Most Active @WeiserWolf last edited by
                                          @weiserwolf sagte in Test Adapter shuttercontrol v1.4.x:
                                          Prüfe mal, ob dein Rolladen Büro unter "shuttercontrol.0.shutters.autoSun" auf true steht
                                          • simatec
                                            simatec Developer Most Active @Nightfly1983 last edited by
                                            @nightfly1983 sagte in Test Adapter shuttercontrol v1.4.x:
                                            Rolladen muss für die Triggeränderung auf "öffnen und schließen" eingestellt werden (Rollladen fahren bei Änderung des Fenster/Tür Zustandes)
                                            331
                                            7376
                                            10231767
