    4. js-controller 4.0 jetzt im BETA/LATEST!
      saeft_2003 Most Active last edited by saeft_2003
      Ich hatte heute Nacht um 2:30 Uhr beim backup fahren mit backitup ein wenig chaos, ziemlich viele Adapter wurden neugestartet. Ich habe noch die 4.0.14 und alle Adapter haben die letzte stable.
      Mit dem js-controller 3.x.x hatte ich mit backitup nie Probleme, kann das mit dem 4.0.14 zusammenhängen?
      host.iobroker
      	2022-02-21 08:00:35.355	warn	"system.host.raspberrypi" is offline
      host.iobroker
      	2022-02-21 04:49:24.719	warn	"system.host.raspberrypi" is offline
      backitup.0
      	2022-02-21 02:34:33.558	error	umount: /opt/iobroker/backups: not mounted.
      linux-control.0
      	2022-02-21 02:33:11.479	warn	This object will not be created in future versions. Please report this to the developer.
      linux-control.0
      	2022-02-21 02:33:11.479	warn	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      linux-control.0
      	2022-02-21 02:33:11.437	warn	This object will not be created in future versions. Please report this to the developer.
      linux-control.0
      	2022-02-21 02:33:11.435	warn	Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      backitup.0
      	2022-02-21 02:32:33.572	error	Error: Command failed: sudo mount -t cifs -o username=patrick,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.106/homes/Patrick/Drive/Backitup_iobroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      synology.0
      	2022-02-21 02:32:07.665	warn	This object will not be created in future versions. Please report this to the developer.
      synology.0
      	2022-02-21 02:32:07.664	warn	Object synology.0.SurveillanceStation.getSnapshotCamera is invalid: Default value has to be type "string" but received type "number"
      host.iobroker
      	2022-02-21 02:30:42.032	warn	instance system.adapter.backitup.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.032	warn	instance system.adapter.telegram.2 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.032	warn	instance system.adapter.telegram.1 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.032	warn	instance system.adapter.telegram.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.032	warn	instance system.adapter.telegram.3 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.031	warn	instance system.adapter.text2command.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.031	warn	instance system.adapter.mqtt.1 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.031	warn	instance system.adapter.zigbee.2 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:42.030	warn	Cannot get view: Connection is closed.
      host.iobroker
      host.iobroker
      	2022-02-21 02:30:42.029	warn	Cannot get view: Connection is closed.
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      	2022-02-21 02:30:42.024	warn	instance system.adapter.zigbee.1 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.994	warn	instance system.adapter.zigbee.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.961	warn	instance system.adapter.sonoff.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.932	warn	instance system.adapter.ping.2 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.853	warn	instance system.adapter.ping.1 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.816	warn	instance system.adapter.ping.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.777	warn	instance system.adapter.mqtt.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.747	warn	instance system.adapter.hm-rega.0 terminated due to SIGTERM
      host.iobroker
      	2022-02-21 02:30:41.713	warn	instance system.adapter.javascript.0 terminated due to SIGTERM
      backitup.0
      	2022-02-21 02:30:37.928	warn	get state error: Connection is closed.
      backitup.0
      	2022-02-21 02:30:37.927	warn	get state error: Connection is closed.
      backitup.0
      backitup.0
      backitup.0
      	2022-02-21 02:30:37.926	warn	get state error: Connection is closed.
      backitup.0
      backitup.0
      	2022-02-21 02:30:37.925	warn	get state error: Connection is closed.
      backitup.0
      backitup.0
      	2022-02-21 02:30:37.920	warn	get state error: Connection is closed.
      backitup.0
      	2022-02-21 02:30:37.907	warn	get state error: Connection is closed.
      backitup.0
      	2022-02-21 02:30:37.906	warn	get state error: Connection is closed.
      backitup.0
      shelly.0
      	2022-02-21 02:30:37.213	error	Error in function httpIoBrokerState for state SHRGBW2#A7E1AB#1.name and request{"url":"http://192.168.178.136/settings","timeout":5000,"headers":{"Authorization":"Basic cGF0cmljazptc3BrcDM5OQ=="}} for 192.168.178.136 (shellyrgbw2 / shellyrgbw2-A7E1AB / SHRGBW2#A7E1AB#1) (Error: Connection is closed.)
      backitup.0
      	2022-02-21 02:30:37.188	warn	get state error: DB closed
      backitup.0
      backitup.0
      backitup.0
      	2022-02-21 02:30:37.181	warn	get state error: Connection is closed.
      mihome-vacuum.0
      	2022-02-21 02:30:35.994	error	Socket Close
      influxdb.0
      	2022-02-21 02:30:30.033	error	Error: connect ECONNREFUSED 192.168.178.97:8086
      influxdb.0
      	2022-02-21 02:30:20.005	error	Error: connect ECONNREFUSED 192.168.178.97:8086
      apollon77 M 2 Replies Last reply Reply Quote 0
        apollon77 @da_Woody last edited by
        @da_woody Na ok, doppelt hält besser ;-))
          apollon77 @saeft_2003 last edited by
          @saeft_2003 SIGTERM heisst das die beendet wurden ... Schau mal ob was im /var/log/syslog steht was zu dem zeitunkt war ... vllt RAM issues?
            Moko @saeft_2003 last edited by
            @saeft_2003 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
            da wird mir von BackItUp die V2.2.3 angeboten, lt #1 soll ist aber die v 2.3.3+ erforderlich
            Könnte also damit zusammenhänegn.
            S apollon77 2 Replies Last reply Reply Quote 0
              saeft_2003 Most Active @apollon77 last edited by
              @apollon77
              Hier das syslog. Ich persönlich kann daraus wenig lesen.
              Feb 21 02:30:20 iobroker kernel: [1838536.805459] CIFS: Attempting to mount //192.168.178.106/homes/Patrick/Drive/Backitup_iobroker
              Feb 21 02:30:35 iobroker kernel: [1838552.512326] io.javascript.0 invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
              Feb 21 02:30:35 iobroker kernel: [1838552.512363] CPU: 1 PID: 1273723 Comm: io.javascript.0 Not tainted 5.10.0-9-amd64 #1 Debian 5.10.70-1
              Feb 21 02:30:35 iobroker kernel: [1838552.512364] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org 04/01/2014
              Feb 21 02:30:35 iobroker kernel: [1838552.512368] Call Trace:
              Feb 21 02:30:35 iobroker kernel: [1838552.512469]  dump_stack+0x6b/0x83
              Feb 21 02:30:35 iobroker kernel: [1838552.512479]  dump_header+0x4a/0x1f0
              Feb 21 02:30:35 iobroker kernel: [1838552.512485]  oom_kill_process.cold+0xb/0x10
              Feb 21 02:30:35 iobroker kernel: [1838552.512502]  out_of_memory+0x1bd/0x500
              Feb 21 02:30:35 iobroker kernel: [1838552.512522]  __alloc_pages_slowpath.constprop.0+0xb8c/0xc60
              Feb 21 02:30:35 iobroker kernel: [1838552.512531]  __alloc_pages_nodemask+0x2da/0x310
              Feb 21 02:30:35 iobroker kernel: [1838552.512533]  pagecache_get_page+0x16d/0x380
              Feb 21 02:30:35 iobroker kernel: [1838552.512537]  filemap_fault+0x69e/0x900
              Feb 21 02:30:35 iobroker kernel: [1838552.512553]  ? xas_load+0x5/0x70
              Feb 21 02:30:35 iobroker kernel: [1838552.512687]  ext4_filemap_fault+0x2d/0x40 [ext4]
              Feb 21 02:30:35 iobroker kernel: [1838552.512711]  __do_fault+0x36/0x120
              Feb 21 02:30:35 iobroker kernel: [1838552.512720]  handle_mm_fault+0x11e7/0x1bf0
              Feb 21 02:30:35 iobroker kernel: [1838552.512727]  ? __hrtimer_init+0xd0/0xd0
              Feb 21 02:30:35 iobroker kernel: [1838552.512739]  do_user_addr_fault+0x1b8/0x3f0
              Feb 21 02:30:35 iobroker kernel: [1838552.512747]  ? switch_fpu_return+0x40/0xb0
              Feb 21 02:30:35 iobroker kernel: [1838552.512753]  exc_page_fault+0x78/0x160
              Feb 21 02:30:35 iobroker kernel: [1838552.512760]  ? asm_exc_page_fault+0x8/0x30
              Feb 21 02:30:35 iobroker kernel: [1838552.512762]  asm_exc_page_fault+0x1e/0x30
              Feb 21 02:30:35 iobroker kernel: [1838552.512776] RIP: 0033:0x7fbbe2e15116
              Feb 21 02:30:35 iobroker kernel: [1838552.512782] Code: Unable to access opcode bytes at RIP 0x7fbbe2e150ec.
              Feb 21 02:30:35 iobroker kernel: [1838552.512783] RSP: 002b:00007fffc6c9daf0 EFLAGS: 00010293
              Feb 21 02:30:35 iobroker kernel: [1838552.512785] RAX: 0000000000000000 RBX: 00000000000002c0 RCX: 00007fbbe2e15116
              Feb 21 02:30:35 iobroker kernel: [1838552.512786] RDX: 0000000000000400 RSI: 00007fffc6c9dbf0 RDI: 000000000000000e
              Feb 21 02:30:35 iobroker kernel: [1838552.512786] RBP: 00007fffc6ca0c20 R08: 0000000000000000 R09: 0000000005273c20
              Feb 21 02:30:35 iobroker kernel: [1838552.512794] R10: 00000000000002c0 R11: 0000000000000293 R12: 0000000000000000
              Feb 21 02:30:35 iobroker kernel: [1838552.512795] R13: 0000000000000000 R14: 0000000000000001 R15: 00000000044f5880
              Feb 21 02:30:35 iobroker kernel: [1838552.512797] Mem-Info:
              Feb 21 02:30:35 iobroker kernel: [1838552.512803] active_anon:512550 inactive_anon:628612 isolated_anon:0
              Feb 21 02:30:35 iobroker kernel: [1838552.512803]  active_file:142 inactive_file:587 isolated_file:0
              Feb 21 02:30:35 iobroker kernel: [1838552.512803]  unevictable:0 dirty:0 writeback:4
              Feb 21 02:30:35 iobroker kernel: [1838552.512803]  slab_reclaimable:6015 slab_unreclaimable:10178
              Feb 21 02:30:35 iobroker kernel: [1838552.512803]  mapped:380 shmem:196 pagetables:35831 bounce:0
              Feb 21 02:30:35 iobroker kernel: [1838552.512803]  free:22728 free_pcp:290 free_cma:0
              Feb 21 02:30:35 iobroker kernel: [1838552.512808] Node 0 active_anon:2050200kB inactive_anon:2514448kB active_file:568kB inactive_file:2348kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1520kB dirty:0kB writeback:16kB shmem:784kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1413120kB writeback_tmp:0kB kernel_stack:10256kB all_unreclaimable? no
              Feb 21 02:30:35 iobroker kernel: [1838552.512808] Node 0 DMA free:15892kB min:216kB low:268kB high:320kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15908kB mlocked:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512814] lowmem_reserve[]: 0 2930 4765 4765 4765
              Feb 21 02:30:35 iobroker kernel: [1838552.512817] Node 0 DMA32 free:49068kB min:41428kB low:51784kB high:62140kB reserved_highatomic:0KB active_anon:1479580kB inactive_anon:1377092kB active_file:132kB inactive_file:324kB unevictable:0kB writepending:132kB present:3129192kB managed:3033884kB mlocked:0kB pagetables:78680kB bounce:0kB free_pcp:528kB local_pcp:388kB free_cma:0kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512819] lowmem_reserve[]: 0 0 1834 1834 1834
              Feb 21 02:30:35 iobroker kernel: [1838552.512821] Node 0 Normal free:25952kB min:25932kB low:32412kB high:38892kB reserved_highatomic:0KB active_anon:570620kB inactive_anon:1137356kB active_file:644kB inactive_file:2084kB unevictable:0kB writepending:20kB present:1974272kB managed:1878560kB mlocked:0kB pagetables:64644kB bounce:0kB free_pcp:628kB local_pcp:396kB free_cma:0kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512824] lowmem_reserve[]: 0 0 0 0 0
              Feb 21 02:30:35 iobroker kernel: [1838552.512826] Node 0 DMA: 1*4kB (U) 0*8kB 1*16kB (U) 0*32kB 2*64kB (U) 1*128kB (U) 1*256kB (U) 0*512kB 1*1024kB (U) 1*2048kB (M) 3*4096kB (M) = 15892kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512834] Node 0 DMA32: 630*4kB (UME) 1320*8kB (UME) 619*16kB (UME) 243*32kB (UME) 99*64kB (UME) 44*128kB (UME) 29*256kB (UME) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 50152kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512842] Node 0 Normal: 1387*4kB (UME) 1298*8kB (UME) 289*16kB (UME) 102*32kB (UE) 17*64kB (UME) 5*128kB (ME) 3*256kB (M) 0*512kB 0*1024kB 0*2048kB 0*4096kB = 26316kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512874] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512875] 8830 total pagecache pages
              Feb 21 02:30:35 iobroker kernel: [1838552.512876] 7856 pages in swap cache
              Feb 21 02:30:35 iobroker kernel: [1838552.512877] Swap cache stats: add 1562502, delete 1554576, find 3083600/3244591
              Feb 21 02:30:35 iobroker kernel: [1838552.512878] Free swap  = 0kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512878] Total swap = 998396kB
              Feb 21 02:30:35 iobroker kernel: [1838552.512879] 1279864 pages RAM
              Feb 21 02:30:35 iobroker kernel: [1838552.512879] 0 pages HighMem/MovableOnly
              Feb 21 02:30:35 iobroker kernel: [1838552.512879] 47776 pages reserved
              Feb 21 02:30:35 iobroker kernel: [1838552.512880] 0 pages hwpoisoned
              Feb 21 02:30:35 iobroker kernel: [1838552.512881] Tasks state (memory values in pages):
              Feb 21 02:30:35 iobroker kernel: [1838552.512881] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
              Feb 21 02:30:35 iobroker kernel: [1838552.512900] [    229]     0   229    24377      144   192512      126          -250 systemd-journal
              Feb 21 02:30:35 iobroker kernel: [1838552.512902] [    253]     0   253     5349       61    65536      188         -1000 systemd-udevd
              Feb 21 02:30:35 iobroker kernel: [1838552.512904] [    332]   106   332     1960       16    49152       97             0 rpcbind
              Feb 21 02:30:35 iobroker kernel: [1838552.512906] [    333]   101   333    22094       35    73728      155             0 systemd-timesyn
              Feb 21 02:30:35 iobroker kernel: [1838552.512916] [    335]     0   335    24956       62    81920      296             0 dhclient
              Feb 21 02:30:35 iobroker kernel: [1838552.512918] [    400]     0   400     1671       26    49152       41             0 cron
              Feb 21 02:30:35 iobroker kernel: [1838552.512920] [    401]   104   401     2052       97    53248       54          -900 dbus-daemon
              Feb 21 02:30:35 iobroker kernel: [1838552.512922] [    404]     0   404    55185       76    81920      780             0 rsyslogd
              Feb 21 02:30:35 iobroker kernel: [1838552.512924] [    406]     0   406     3453      113    69632      105             0 systemd-logind
              Feb 21 02:30:35 iobroker kernel: [1838552.512926] [    411]     0   411     1446        9    49152       20             0 agetty
              Feb 21 02:30:35 iobroker kernel: [1838552.512928] [    434]     0   434     3323       35    69632      210         -1000 sshd
              Feb 21 02:30:35 iobroker kernel: [1838552.512932] [1273690]  1001 1273690   420833   140565 14921728    67271             0 iobroker.js-con
              Feb 21 02:30:35 iobroker kernel: [1838552.512933] [1273708]  1001 1273708   280204    54679  4939776     2385             0 io.admin.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512935] [1273723]  1001 1273723  2883545    55819  9297920    48279             0 io.javascript.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512938] [1273750]  1001 1273750   224800    36362  5824512    32505             0 io.javascript.1
              Feb 21 02:30:35 iobroker kernel: [1838552.512940] [1274065]  1001 1274065   175424    13320  2797568     2461             0 io.hm-rega.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512942] [1274080]  1001 1274080   176478    13639  2772992     1416             0 io.hm-rpc.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512944] [1274095]  1001 1274095   172917     9742  2609152     1408             0 io.hm-rpc.1
              Feb 21 02:30:35 iobroker kernel: [1838552.512945] [1274127]  1001 1274127   263921    19712  2650112     1842             0 io.mihome-vacuu
              Feb 21 02:30:35 iobroker kernel: [1838552.512947] [1274142]  1001 1274142   176006    12473  2838528     2037             0 io.mqtt.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512955] [1274157]  1001 1274157   173256    10657  2531328     1599             0 io.nut.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512960] [1274172]  1001 1274172   173748     9653  2588672     2500             0 io.ping.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512963] [1274189]  1001 1274189   172723     9326  2564096     2009             0 io.ping.1
              Feb 21 02:30:35 iobroker kernel: [1838552.512964] [1274229]  1001 1274229   172795     9735  2564096     1514             0 io.ping.2
              Feb 21 02:30:35 iobroker kernel: [1838552.512966] [1274286]  1001 1274286   187077    24335  2985984     1427             0 io.sonoff.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512968] [1274319]  1001 1274319   175677    12997  2895872     1545             0 io.synology.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512970] [1274341]  1001 1274341   175988    12757  2912256     1743             0 io.tr-064.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512971] [1274380]  1001 1274380   209154    18377  2662400     2822             0 io.zigbee.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512973] [1274413]  1001 1274413   212758    16391  3313664     2803             0 io.zigbee.1
              Feb 21 02:30:35 iobroker kernel: [1838552.512975] [1274445]  1001 1274445   211742    13406  3264512     3747             0 io.zigbee.2
              Feb 21 02:30:35 iobroker kernel: [1838552.512977] [1274452]  1001 1274452   175270    11699  2764800     1958             0 io.mqtt.1
              Feb 21 02:30:35 iobroker kernel: [1838552.512978] [1274519]  1001 1274519   173079     9515  2469888     1963             0 io.countdown.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512980] [1274588]  1001 1274588   211349    18556  2908160     1669             0 io.influxdb.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512981] [1274603]  1001 1274603   232267     9879  1585152     1831             0 io.info.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512983] [1275025]  1001 1275025   192570    11901  2879488     3024             0 io.iot.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512984] [1275041]  1001 1275041   240467    10679  2740224     3098             0 io.linux-contro
              Feb 21 02:30:35 iobroker kernel: [1838552.512986] [1275058]  1001 1275058   172695     8925  2498560     1826             0 io.logparser.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512987] [1275075]  1001 1275075   206360     9281  2588672     2586             0 io.pollenflug.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512989] [1275091]  1001 1275091   167334    12910  2048000      968             0 io.proxmox.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512990] [1275121]  1001 1275121   173299     9808  2584576     1708             0 io.simple-api.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512992] [1275137]  1001 1275137   172058     8177  2445312     2109             0 io.simple-api.1
              Feb 21 02:30:35 iobroker kernel: [1838552.512993] [1275152]  1001 1275152   171965     8289  2400256     1965             0 io.text2command
              Feb 21 02:30:35 iobroker kernel: [1838552.512995] [1275167]  1001 1275167   175459    12542  2826240     1692             0 io.unifi.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512996] [1275198]  1001 1275198   237177    12649  2392064     1695             0 io.web-speedy.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512998] [1275213]  1001 1275213   229010    43409  2822144     2171             0 io.web.0
              Feb 21 02:30:35 iobroker kernel: [1838552.512999] [1275229]  1001 1275229   174522    11168  2617344     1545             0 io.wled.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513001] [1275244]  1001 1275244   241574    12758  3018752     1612             0 io.worx.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513002] [1275259]  1001 1275259   169710    11964  2564096     2063             0 io.yahka.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513003] [1275275]  1001 1275275   168920     9048  2469888     2349             0 io.yahka.1
              Feb 21 02:30:35 iobroker kernel: [1838552.513005] [1275291]  1001 1275291   180288    16648  2453504     1698             0 io.statistics.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513008] [1275306]  1001 1275306   252476    14494  2510848     2233             0 io.parcel.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513009] [1275322]  1001 1275322   171846     8764  2433024     2017             0 io.discovery.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513012] [1301135]  1001 1301135   235578     7945  2654208     5980             0 io.telegram.3
              Feb 21 02:30:35 iobroker kernel: [1838552.513014] [1301142]  1001 1301142   236032     8910  2703360     5506             0 io.telegram.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513015] [1301149]  1001 1301149   235385     8489  2584576     5413             0 io.telegram.1
              Feb 21 02:30:35 iobroker kernel: [1838552.513017] [1301156]  1001 1301156   235942     9652  2666496     4758             0 io.telegram.2
              Feb 21 02:30:35 iobroker kernel: [1838552.513019] [1303553]  1001 1303553   239849    12969  2674688      461             0 io.backitup.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513021] [1303606]  1001 1303606   242181    15146  2809856      128             0 io.alexa2.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513023] [1315015]  1001 1315015   181667    20991  3096576       99             0 io.shelly.0
              Feb 21 02:30:35 iobroker kernel: [1838552.513027] [1358029]  1001 1358029   470069   268611 16216064        0             0 node
              Feb 21 02:30:35 iobroker kernel: [1838552.513033] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/iobroker.service,task=node,pid=1358029,uid=1001
              Feb 21 02:30:35 iobroker kernel: [1838552.513327] Out of memory: Killed process 1358029 (node) total-vm:1880276kB, anon-rss:1074444kB, file-rss:0kB, shmem-rss:0kB, UID:1001 pgtables:15836kB oom_score_adj:0
              Feb 21 02:30:35 iobroker kernel: [1838552.648865] oom_reaper: reaped process 1358029 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
              Feb 21 02:30:36 iobroker systemd[1]: iobroker.service: A process of this unit has been killed by the OOM killer.
              Feb 21 02:30:39 iobroker kernel: [1838555.789629] CIFS: VFS: \\192.168.178.106\homes Close interrupted close
              Feb 21 02:30:39 iobroker kernel: [1838555.810465] CIFS: VFS: \\192.168.178.106\homes Close interrupted close
              Feb 21 02:30:39 iobroker kernel: [1838555.888488] CIFS: VFS: \\192.168.178.106\homes Close unmatched open for MID:1e0
              Feb 21 02:30:39 iobroker kernel: [1838555.890503] CIFS: VFS: \\192.168.178.106\homes Close interrupted close
              Feb 21 02:30:39 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
              Feb 21 02:30:40 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
              Feb 21 02:30:40 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.logparser.0 => false [Process stopped]
              Feb 21 02:30:40 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.logparser.0 => false [system.adapter.logparser.0.logging]
              Feb 21 02:30:41 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.javascript.1 => false [Process stopped]
              Feb 21 02:30:41 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
              Feb 21 02:30:41 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.javascript.1 => false [system.adapter.javascript.1.logging]
              Feb 21 02:30:41 iobroker bash[1273690]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
              Feb 21 02:30:43 iobroker systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
              Feb 21 02:30:43 iobroker systemd[1]: iobroker.service: Failed with result 'oom-kill'.
              Feb 21 02:30:43 iobroker systemd[1]: iobroker.service: Consumed 7h 41min 18.309s CPU time.
              Feb 21 02:30:46 iobroker systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
              Feb 21 02:30:46 iobroker systemd[1]: Stopped ioBroker Server.
              Feb 21 02:30:46 iobroker systemd[1]: iobroker.service: Consumed 7h 41min 18.309s CPU time.
              Feb 21 02:30:46 iobroker systemd[1]: Started ioBroker Server.
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.history.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.javascript.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.telegram.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.telegram.2" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.telegram.3" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.alexa2.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.hm-rega.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.hm-rpc.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.hm-rpc.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.melcloud.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.mihome-vacuum.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.mqtt.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.nut.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.ping.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.ping.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.ping.2" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.rpi2.0" for host "raspberrypi"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.sonoff.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.synology.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.tr-064.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.tr-064.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.weatherunderground.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.zigbee.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.zigbee.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.zigbee.2" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.mqtt.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.coronavirus-statistics.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.countdown.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.daswetter.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.ebus.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.info.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.iot.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.linux-control.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.logparser.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.mihome.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.mihome.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.mobile.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.pollenflug.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.proxmox.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.simple-api.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.simple-api.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.text2command.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.unifi.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-bars.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-canvas-gauges.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-colorpicker.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-fancyswitch.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-hqwidgets.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-jqui-mfd.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-justgage.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-materialdesign.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-metro.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-players.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-timeandweather.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis-weather.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.vis.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.web-speedy.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.web.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.wled.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.worx.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.yahka.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.yahka.1" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.statistics.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.radar2.0" for host "raspberrypi"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.alexa-timer-vis.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.parcel.0" for host "iobroker"
              Feb 21 02:30:50 iobroker bash[1358044]: host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
              Feb 21 02:30:53 iobroker bash[1358044]: Cannot parse "/Bilder/vis-views.json
              Feb 21 02:30:53 iobroker bash[1358044]: Cannot parse "/Wettericons/vis-views.json
              Feb 21 02:30:55 iobroker bash[1358044]: Send diag info: {"uuid":"e779604f-f36c-3ffb-f1ec-6db932f57ecf","language":"de","country":"Germany","hosts":[{"version":"4.0.14","platform":"Javascript/Node.js","type":"linux"},{"version":"3.2.16","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.18.1","arch":"x64","docker":false,"adapters":{"admin":{"version":"5.2.3","platform":"Javascript/Node.js"},"alexa2":{"version":"3.11.2","platform":"Javascript/Node.js"},"backitup":{"version":"2.2.3","platform":"Javascript/Node.js"},"broadlink2":{"version":"2.1.5","platform":"Javascript/Node.js"},"cloud":{"version":"4.1.0","platform":"Javascript/Node.js"},"coronavirus-statistics":{"version":"0.8.7","platform":"Javascript/Node.js"},"countdown":{"version":"1.2.5","platform":"Javascript/Node.js"},"daikin":{"version":"1.3.3","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.9","platform":"Javascript/Node.js"},"discovery":{"version":"2.7.3","platform":"Javascript/Node.js"},"dwd":{"version":"2.7.7","platform":"Javascript/Node.js"},"ebus":{"version":"2.5.1","platform":"Javascript/Node.js"},"egigeozone":{"version":"0.1.2","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"fontui":{"version":"0.1.0","platform":"Javascript/Node.js"},"fritzbox":{"version":"0.2.1","platform":"Javascript/Node.js"},"gartenbewaesserung":{"version":"0.0.7","platform":"Javascript/Node.js"},"geofency":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"1.10.5","platform":"Javascript/Node.js"},"hm-rega":{"version":"3.0.35","platform":"Javascript/Node.js"},"hm-rpc":{"version":"1.15.0","platform":"Javascript/Node.js"},"hmm":{"version":"1.0.1","platform":"Javascript/Node.js"},"ical":{"version":"1.11.4","platform":"Javascript/Node.js"},"icons-material-svg":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-mfd-png":{"version":"1.0.2","platform":"javascript/Node.js"},"icons-mfd-svg":{"version":"1.0.2","platform":"javascript/Node.js"},"influxdb":{"version":"1.9.5","platform":"Javascript/Node.js"},"info":{"version":"1.9.8","platform":"Javascript/Node.js"},"iot":{"version":"1.8.24","platform":"Javascript/Node.js"},"iqontrol":{"version":"0.2.16","platform":"Javascript/Node.js"},"javascript":{"version":"5.2.21","platform":"Javascript/Node.js"},"landroid":{"version":"1.0.3","platform":"Javascript/Node.js"},"linux-control":{"version":"1.1.3","platform":"Javascript/Node.js"},"logparser":{"version":"1.1.0","platform":"Javascript/Node.js"},"melcloud":{"version":"1.1.4","platform":"Javascript/Node.js"},"mihome":{"version":"1.3.7","platform":"javascript/Node.js"},"mihome-vacuum":{"version":"3.3.3","platform":"Javascript/Node.js"},"mobile":{"version":"1.0.1","platform":"javascript/Node.js"},"modbus":{"version":"3.4.14","platform":"Javascript/Node.js"},"mqtt":{"version":"2.4.1","platform":"Javascript/Node.js"},"mqtt-client":{"version":"1.1.1","platform":"Javascript/Node.js"},"node-red":{"version":"2.4.1","platform":"Javascript/Node.js"},"nut":{"version":"1.5.0","platform":"Javascript/Node.js"},"phantomjs":{"version":"1.1.2","platform":"Javascript/Node.js"},"pi-hole":{"version":"1.3.2","platform":"Javascript/Node.js"},"ping":{"version":"1.5.0","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"proxmox":{"version":"1.3.4","platform":"Javascript/Node.js"},"proxy":{"version":"1.2.2","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"rpi2":{"version":"1.3.1","platform":"Javascript/Node.js"},"samsung":{"version":"0.2.9","platform":"Javascript/Node.js"},"sayit":{"version":"1.7.0","platform":"Javascript/Node.js"},"shelly":{"version":"4.0.7","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.2","platform":"Javascript/Node.js"},"socketio":{"version":"3.1.5","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.7","platform":"Javascript/Node.js"},"synology":{"version":"1.1.3","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"1.0.4","platform":"javascript/Node.js"},"telegram":{"version":"1.11.1","platform":"Javascript/Node.js"},"terminal":{"version":"0.1.2","platform":"Javascript/Node.js"},"text2command":{"version":"2.1.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"trashschedule":{"version":"1.2.0","platform":"Javascript/Node.js"},"unifi":{"version":"0.5.10","platform":"Javascript/Node.js"},"vis":{"version":"1.4.5","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"0.1.5","platform":"Javascript/Node.js"},"vis-colorpicker":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.9","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-justgage":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-keyboard":{"version":"0.0.2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.73","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-players":{"version":"0.1.6","platform":"Javascript/Node.js"},"vis-plumb":{"version":"1.0.3","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.5.5","platform":"Javascript/Node.js"},"volumio":{"version":"0.1.2","platform":"Javascript/Node.js"},"weatherunderground":{"version":"3.3.1","platform":"Javascript/Node.js"},"web":{"version":"3.4.16","platform":"Javascript/Node.js"},"web-speedy":{"version":"0.2.0","platform":"Javascript/Node.js"},"wifilight":{"version":"1.1.0","platform":"Javascript/Node.js"},"wled":{"version":"0.6.3","platform":"Javascript/Node.js"},"worx":{"version":"1.5.5","platform":"Javascript/Node.js"},"yahka":{"version":"0.13.1","platform":"Javascript/Node.js"},"zigbee":{"version":"1.6.16","platform":"Javascript/Node.js"},"statistics":{"version":"1.0.9","platform":"Javascript/Node.js"},"ble":{"version":"0.12.0","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7.2","platform":"Javascript/Node.js"},"alexa-timer-vis":{"version":"0.1.9","platform":"Javascript/Node.js"},"fritzdect":{"version":"2.2.3","platform":"Javascript/Node.js"},"parcel":{"version":"0.0.3","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":80,"noCompactInstances":0,"model":"Common KVM processor","cpus":4,"mem":5046632448,"ostype":"Linux","city":"Lohr am Main","vis":6416}
              Feb 21 02:32:33 iobroker kernel: [1838670.225409] CIFS: Attempting to mount //192.168.178.106/homes/Patrick/Drive/Backitup_iobroker
              Feb 21 02:32:33 iobroker kernel: [1838670.312815] CIFS: Attempting to mount //192.168.178.106/homes/Patrick/Drive/Backitup_iobroker
              Feb 21 02:32:33 iobroker kernel: [1838670.312840] CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
              Feb 21 02:32:45 iobroker systemd[1]: opt-iobroker-backups.mount: Succeeded.
              Feb 21 02:33:07 iobroker bash[1358044]: /bin/sh: 1: iw: not found
              Feb 21 02:33:07 iobroker bash[1358044]: /bin/sh: 1: hcitool: not found
              Feb 21 02:33:15 iobroker bash[1358044]: ================================== > LOG REDIRECT system.adapter.logparser.0 => true [system.adapter.logparser.0.logging]
              Feb 21 02:34:08 iobroker bash[1358044]: [Yahka-0 8F5A@Garage auf@@On] characteristic value expected boolean and received undefined
              Feb 21 02:34:08 iobroker bash[1358044]: [Yahka-0 8F5A@Garage zu@@On] characteristic value expected boolean and received undefined
              Feb 21 02:34:08 iobroker bash[1358044]: [Yahka-0 8F5A@Bilder von Kameras@@On] characteristic value expected boolean and received undefined
              Feb 21 02:34:37 iobroker bash[1358044]: [Yahka-0 8F5A@Garage auf@@On] characteristic value expected boolean and received undefined
              Feb 21 02:34:37 iobroker bash[1358044]: [Yahka-0 8F5A@Garage zu@@On] characteristic value expected boolean and received undefined
              Feb 21 02:34:37 iobroker bash[1358044]: [Yahka-0 8F5A@Bilder von Kameras@@On] characteristic value expected boolean and received undefined
              Feb 21 03:10:01 iobroker CRON[1361033]: (root) CMD (test -e /run/systemd/system || SERVICE_MODE=1 /sbin/e2scrub_all -A -r)
              Feb 21 03:17:01 iobroker CRON[1361348]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Feb 21 04:17:01 iobroker CRON[1363947]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
              Feb 21 04:37:48 iobroker bash[1358044]: [Yahka-0 8F5A@Garage auf@@On] characteristic value expected boolean and received undefined
              Feb 21 04:37:48 iobroker bash[1358044]: [Yahka-0 8F5A@Garage zu@@On] characteristic value expected boolean and received undefined
                saeft_2003 Most Active @Moko last edited by saeft_2003
                @moko sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                Ok danke für die Info muss ich mir mal anschauen.
                Edit: ich hab die v jetzt angehoben von 2.2.3 auf 2.3.3 mal schauen wies heute Nacht läuft…
                • wendy2702
                  wendy2702 @saeft_2003 last edited by
                  @saeft_2003 laut syslog OOM Killer.
                  Leider fängt das syslog erst um 2:30Uhr an….
                  Interessant wäre ab dem Zeitpunkt wo Backit Up aktiv wird besser noch 1-2 Minuten vorher
                    saeft_2003 Most Active @wendy2702 last edited by
                    @wendy2702
                    Hier die Zeit vorher.
                    Feb 21 01:30:37 iobroker systemd[1]: opt-iobroker-backups.mount: Succeeded.
                    Feb 21 02:09:46 iobroker bash[1273690]: [Yahka-0 8F5A@Garage auf@@On] characteristic value expected boolean and received undefined
                    Feb 21 02:09:46 iobroker bash[1273690]: [Yahka-0 8F5A@Garage zu@@On] characteristic value expected boolean and received undefined
                    Feb 21 02:09:46 iobroker bash[1273690]: [Yahka-0 8F5A@Bilder von Kameras@@On] characteristic value expected boolean and received undefined
                    Feb 21 02:17:01 iobroker CRON[1357482]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                    Meint ihr dass das Problem mit der 2.3.3 behoben sein könnte, oder das wirklich zu wenig Arbeitsspeicher frei ist? 4,2 GB sind in der Regel von 4,9 GB belegt… 700 MB frei sollte doch reichen?
                    • wendy2702
                      @saeft_2003 4,9GB Arbeitsspeicher!?
                      Schau mal mit
                      free -m
                      Oder
                      htop
                      Wenn du ein Backup startest
                        saeft_2003 Most Active @wendy2702 last edited by saeft_2003
                        @wendy2702
                        Ja so zeigt es proxmox an. Eingestellt habe ich 5GB ich kann der Iobroker VM ohne Probleme noch mehr RAM geben.
                        Muss ich mir nachher mal anschauen…
                        Edit:
                        root@iobroker:~# free -m
                                      gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                        Speicher:       4812        3954         541           0         316         630
                        Swap:            974         221         753
                        Thomas Braun apollon77 3 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @saeft_2003 last edited by
                          @saeft_2003
                          Nein, das reicht nicht, wenn die Daten im RAM komprimiert werden.
                          Und als root agiert man nicht im Container.
                            apollon77 @Moko last edited by
                            @moko Also nein kann damit nichts zu tun haben ... und ja Backitup 2.3.3 ist noch im Latest ... wie auch der controller 4
                              apollon77 @saeft_2003 last edited by apollon77
                              Eindeutig ... In dem Fall war dein RAM voll und das Linux hat dir speicher frei geräumt.
                              Du hast 47 Instanzen Mit einem Verbrauch von 50MB im Schnitt brauchen 47 Instanzen mind als 2,35GB ... was sagt denn Dein System "free -m" im Normalfall?
                              EDIT: Ahh ist schon gepostet
                                @saeft_2003 naja mit 630MB frei ist dann die Frage wie gross denn so das Backup ist wenn es tut? bzw wieviele Daten sind es denn die da gesichert werden
                                O S 2 Replies Last reply Reply Quote 0
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                                  @apollon77
                                  Nachdem ich ja bereits auf JS-Controller 4.0.15 war. Musste ich heute leider wegen eines Problems ein Restore vom Vortag machen. Also habe ich JS-Controller 4.0.12 installiert und ein Restore gestartet. Leider kann VIS nun nicht mehr installiert werden:
                                  2022-02-21 10:17:49.796  - info: host.iobroker iobroker.js-controller version 4.0.12 js-controller starting
                                  2022-02-21 10:17:49.804  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                  2022-02-21 10:17:49.805  - info: host.iobroker hostname: iobroker, node: v14.19.0
                                  2022-02-21 10:17:49.807  - info: host.iobroker ip addresses: 192.168.0.202
                                  2022-02-21 10:17:50.127  - info: host.iobroker connected to Objects and States
                                  2022-02-21 10:17:50.157  - info: host.iobroker added notifications configuration of host
                                  2022-02-21 10:17:50.271  - info: host.iobroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                  2022-02-21 10:17:50.334  - info: host.iobroker 54 instances found
                                  2022-02-21 10:17:50.441  - info: host.iobroker starting 2 instances
                                  2022-02-21 10:17:50.470  - warn: host.iobroker startInstance cannot find adapter "vis@1.4.12". Try to install it... 1 attempt
                                  2022-02-21 10:17:50.472  - info: host.iobroker iobroker install vis@1.4.12 using installedFrom
                                  2022-02-21 10:17:50.680  - info: host.iobroker instance system.adapter.admin.0 started with pid 1259
                                  2022-02-21 10:17:52.878  - info: admin.0 (1259) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                  2022-02-21 10:17:52.988  - info: admin.0 (1259) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.12
                                  2022-02-21 10:17:53.049  - info: admin.0 (1259) requesting all states
                                  2022-02-21 10:17:53.050  - info: admin.0 (1259) requesting all objects
                                  2022-02-21 10:17:53.494  - info: admin.0 (1259) Request actual repository...
                                  2022-02-21 10:17:54.165  - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                                  2022-02-21 10:17:54.350  - info: host.iobroker iobroker npm-install: NPM version: 6.14.16Installing iobroker.vis@1.4.12... (System call)
                                  2022-02-21 10:17:54.704  - info: host.iobroker instance system.adapter.backitup.0 started with pid 1305
                                  2022-02-21 10:17:56.967  - info: admin.0 (1259) received all objects
                                  2022-02-21 10:17:58.206  - info: admin.0 (1259) Repository received successfully.
                                  2022-02-21 10:17:58.305  - info: admin.0 (1259) http server listening on port 8081
                                  2022-02-21 10:17:58.306  - info: admin.0 (1259) Use link "http://localhost:8081" to configure.
                                  2022-02-21 10:17:58.927  - info: backitup.0 (1305) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.12
                                  2022-02-21 10:17:59.067  - info: backitup.0 (1305) [iobroker] backup was activated at 02:00 every 1 day(s)
                                  2022-02-21 10:17:59.159  - info: backitup.0 (1305) [ccu] backup was activated at 01:30 every 3 day(s)
                                  2022-02-21 10:18:49.379  - info: host.iobroker iobroker npm-install:
                                  2022-02-21 10:18:49.382  - info: host.iobroker iobroker npm-install: > iobroker.vis@1.4.12 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
                                  2022-02-21 10:18:51.086  - info: vis.0 (1361) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
                                  2022-02-21 10:18:51.281  - info: vis.0 (1361) vis license is OK.
                                  2022-02-21 10:18:51.851  - error: vis.0 (1361) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2022-02-21 10:18:51.853  - error: vis.0 (1361) unhandled promise rejection: Not exists
                                  2022-02-21 10:18:51.857  - error: vis.0 (1361) Error: Not exists
                                      at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2961:17)
                                      at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1042:26)
                                      at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1091:29)
                                      at processImmediate (internal/timers.js:466:21)
                                  2022-02-21 10:18:51.858  - error: vis.0 (1361) Not exists
                                  2022-02-21 10:18:52.364  - info: vis.0 (1361) terminating
                                  2022-02-21 10:18:52.366  - warn: vis.0 (1361) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  Was kann ich tun?
                                    apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by apollon77
                                    @ofbeqnpolkkl6mby5e13 Versuch mal vis downgrade auf 4.0.5 und danach wieder hoch auf 4.0.12 Und bitte mit dem Log ein Vis issue anlegen
                                    • O
                                      @apollon77
                                      JS-Controller oder vis?
                                        @ofbeqnpolkkl6mby5e13 Issue bei vis bitte
                                        • O
                                          oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
                                          @apollon77
                                          Das behebt das Problem nicht:
                                          2022-02-21 10:40:38.147  - info: host.iobroker "system.adapter.vis.0" enabled
                                          2022-02-21 10:40:39.910  - info: vis.0 (2892) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
                                          2022-02-21 10:40:40.184  - info: vis.0 (2892) vis license is OK.
                                          2022-02-21 10:40:40.242  - error: vis.0 (2892) uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
                                          2022-02-21 10:40:40.245  - error: vis.0 (2892) Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
                                              at Object.openSync (fs.js:497:3)
                                              at Object.writeFileSync (fs.js:1528:35)
                                              at copyFileSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:16:8)
                                              at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:36:17
                                              at Array.forEach (<anonymous>)
                                              at copyFolderRecursiveSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:31:15)
                                              at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:34:17
                                          2022-02-21 10:40:40.246  - error: vis.0 (2892) Exception-Code: EACCES: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
                                          2022-02-21 10:40:40.762  - info: vis.0 (2892) terminating
                                          2022-02-21 10:40:40.764  - warn: vis.0 (2892) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2022-02-21 10:40:41.371  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                                          Ich führe mal ein iobroker fix durch.
                                          Nach iobroker fix:
                                          2022-02-21 10:51:21.640  - info: vis.0 (1348) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
                                          2022-02-21 10:51:21.904  - info: vis.0 (1348) vis license is OK.
                                          2022-02-21 10:51:23.094  - info: vis.0 (1348) Terminated (NO_ERROR): Without reason
                                          2022-02-21 10:51:23.691  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                                          Danach wieder hoch zu 1.4.12. Jetzt läuft vis wieder. Nur hätte ich mir das alles sparen können, weil mein ursprüngliches Problem weiterhin existiert...
                                          Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
                                            Wie sehen die Rechte denn an
                                            aus?
                                            747
                                            171579
