    4. js-controller 4.0 jetzt im BETA/LATEST!
      apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by apollon77
      @ofbeqnpolkkl6mby5e13 Versuch mal vis downgrade auf 4.0.5 und danach wieder hoch auf 4.0.12 Und bitte mit dem Log ein Vis issue anlegen
      • O
        oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
        @apollon77
        JS-Controller oder vis?
          @ofbeqnpolkkl6mby5e13 Issue bei vis bitte
          • O
            oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
            @apollon77
            Das behebt das Problem nicht:
            2022-02-21 10:40:38.147  - info: host.iobroker "system.adapter.vis.0" enabled
            2022-02-21 10:40:39.910  - info: vis.0 (2892) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
            2022-02-21 10:40:40.184  - info: vis.0 (2892) vis license is OK.
            2022-02-21 10:40:40.242  - error: vis.0 (2892) uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
            2022-02-21 10:40:40.245  - error: vis.0 (2892) Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
                at Object.openSync (fs.js:497:3)
                at Object.writeFileSync (fs.js:1528:35)
                at copyFileSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:16:8)
                at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:36:17
                at Array.forEach (<anonymous>)
                at copyFolderRecursiveSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:31:15)
                at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:34:17
            2022-02-21 10:40:40.246  - error: vis.0 (2892) Exception-Code: EACCES: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
            2022-02-21 10:40:40.762  - info: vis.0 (2892) terminating
            2022-02-21 10:40:40.764  - warn: vis.0 (2892) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2022-02-21 10:40:41.371  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
            Ich führe mal ein iobroker fix durch.
            Nach iobroker fix:
            2022-02-21 10:51:21.640  - info: vis.0 (1348) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
            2022-02-21 10:51:21.904  - info: vis.0 (1348) vis license is OK.
            2022-02-21 10:51:23.094  - info: vis.0 (1348) Terminated (NO_ERROR): Without reason
            2022-02-21 10:51:23.691  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
            Danach wieder hoch zu 1.4.12. Jetzt läuft vis wieder. Nur hätte ich mir das alles sparen können, weil mein ursprüngliches Problem weiterhin existiert...
            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
              Wie sehen die Rechte denn an
              aus?
              • O
                oFbEQnpoLKKl6mbY5e13 @Thomas Braun last edited by
                Wie gesagt, das Problem konnte durch iobroker fix behoben werden.
                # ls -l /opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css
                -rw-rw-rw- 1 iobroker iobroker 70 Feb 21 11:05 /opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css
                  saeft_2003 Most Active @apollon77 last edited by saeft_2003
                  @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                  @saeft_2003 naja mit 630MB frei ist dann die Frage wie gross denn so das Backup ist wenn es tut? bzw wieviele Daten sind es denn die da gesichert werden
                  Das backup hat 90MB.
                  edit: ich habe ohne den ram zu erhöhen ein Backup manuell gestartet das lief ohne Probleme durch.
                    @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                    • O
                      @apollon77
                      Restore mit VIS v1.4.12 geht mindestens bei mir nicht und hat mit JS-Controller nichts zu tun. Das Problem, weshalb ich auf einen älteren Stand wollte, ist aber Off-Topic.
                      Danke für die Hilfe!
                        apollon77 @saeft_2003 last edited by
                        @saeft_2003 Kannst du mir mal einen gefallen tun?
                        Mach mal eine Shell auf mit "top", dann drücke "Shift-M" - das sortiert dir die EInträge nach RAM nutzung. Dnan am besten davon nen Screenshot
                        Jetzt bitte mal zwei Dinge tun:
                        1.) in einer zweiten Shell ein "iob backup" ausführen
                        2.) Backup über BackItUp manuell starten
                        Und bei beiden Dingen bitte mal das "top" beobachten ... Wo steigt der RAM Verbrauch an und wenn ja in welchem prozess?
                        Vllt kommen wir so ein bissl dahinter
                          Marty56 @apollon77 last edited by
                          @apollon77
                          Ich habe meine zweite iobroker Instanz (Raspberry 3) ohne Probleme umgestellt.
                          Dort hatte ich früher die States auf redis umgestellt und würde jetzt gern auf JSONL migrieren.
                          iobroker status
                          Objects type: jsonl
                          States  type: redis
                          Ist das unproblematisch?
                            apollon77 @Marty56 last edited by
                            @marty56 Na klar, einfach per iob setup custom machen
                              @apollon77 Danke. Hat unproblematisch geklappt.
                                e-i-k-e last edited by e-i-k-e
                                Aktualisiere gerade ein Slave von 4.0.10 auf 4.0.15.
                                Habe es nun bereits mit sudo -H -u iobroker npm install iobroker.js-controller versucht.
                                Bei den anderen Geräten hatte ich dieses Problem nicht.
                                Was kann ich tun?
                                pi@raspberrypi-display2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                > iobroker.js-controller@4.0.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                > node lib/preinstallCheck.js
                                NPM version: 6.14.16
                                > iobroker.js-controller@4.0.10 install /opt/iobroker/node_modules/iobroker.js-controller
                                > node iobroker.js setup first
                                No connection to objects 192.168.3.100:6379[redis]
                                /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                        throw e;
                                Error: Connection is closed.
                                    at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                    at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                    at Object.onceWrapper (events.js:520:26)
                                    at Socket.emit (events.js:400:28)
                                    at TCP.<anonymous> (net.js:686:12)
                                Emitted 'error' event on ScanStream instance at:
                                    at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                                    at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                                    at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                                    at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! iobroker.js-controller@4.0.10 install: `node iobroker.js setup first`
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the iobroker.js-controller@4.0.10 install script.
                                npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                npm ERR!     /home/iobroker/.npm/_logs/2022-02-21T20_58_28_730Z-debug.l
                                Keine Ahnung was jetzt los ist.. 😲
                                pi@raspberrypi-display2:~ $ iobroker stop
                                pi@raspberrypi-display2:~ $ iobroker fix
                                library: loaded
                                Library version=2022-02-10
                                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                  apollon77 @e-i-k-e last edited by
                                  @e-i-k-e Wie geht es dem Redis? Steht ggf etwas im Redis log? Ich hab das gefühl das sich der beendet mittendrin.
                                    e-i-k-e @apollon77 last edited by
                                    @apollon77
                                    Hast du zufällig den Pfad parat?
                                    Ich habe den kompletten Container inkl. Reids mal neu gestartet. Keine Änderung.
                                      Thomas Braun Most Active @e-i-k-e last edited by
                                      @e-i-k-e
                                      less -R /var/log/redis/redis-server.log
                                      und
                                      systemctl status redis
                                      anschauen.
                                      • Diginix
                                        Diginix last edited by Diginix
                                        @AlCalzone @apollon77
                                        Hab eben per CLI admin, web und ws aktualisiert und dann ist der js-controller mal wieder RAM technisch eskaliert mit über 2 GB. Hat sich dann aber ohne mein Zutun wieder stabilisiert. Wahrs. reichten die 6 GB RAM der VM gerade so aus.
                                        Mem:           5941        4407         131           1        1402        1242
                                        Swap:             0           0           0
                                        apollon77 3 Replies Last reply Reply Quote 0
                                          e-i-k-e @Thomas Braun last edited by
                                          Danke.
                                          Im Log steht immer das gleiche, nichts auffälliges.
                                          11670:C 20 Feb 2022 22:13:49.210 * DB saved on disk
                                          11670:C 20 Feb 2022 22:13:49.228 * RDB: 7 MB of memory used by copy-on-write
                                          139:M 20 Feb 2022 22:13:49.345 * Background saving terminated with success
                                          139:M 20 Feb 2022 22:15:49.680 * 10000 changes in 60 seconds. Saving...
                                          139:M 20 Feb 2022 22:15:49.698 * Background saving started by pid 11703
                                          11703:C 20 Feb 2022 22:16:04.583 * DB saved on disk
                                          11703:C 20 Feb 2022 22:16:04.601 * RDB: 14 MB of memory used by copy-on-write
                                          139:M 20 Feb 2022 22:16:04.688 * Background saving terminated with success
                                          139:M 20 Feb 2022 22:18:21.814 * 10000 changes in 60 seconds. Saving...
                                          pi@ioBroker-Rock:~$ systemctl status redis
                                          * redis-server.service - Advanced key-value store
                                               Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                               Active: active (running) since Mon 2022-02-21 22:27:17 CET; 46min ago
                                                 Docs: http://redis.io/documentation,
                                                       man:redis-server(1)
                                              Process: 114 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
                                             Main PID: 135 (redis-server)
                                                Tasks: 4 (limit: 18952)
                                               Memory: 1.7G
                                                  CPU: 6min 39.212s
                                               CGroup: /system.slice/redis-server.service
                                                       `-135 /usr/bin/redis-server 0.0.0.0:6379
                                          Fünf weitere Slave laufen aber auch problemlos mit dem Master und der Redis DB.
                                          M apollon77 2 Replies Last reply Reply Quote 0
                                            Marty56 @e-i-k-e last edited by
                                            Ich beobachte einen seltsamen Effekt, den ich nicht verstehe.
                                            Ich habe iob mit dem Update auf von js-controller 4 von Objects type: jsonl
                                            States type: redis auf Objects type: jsonl States type: jsonl umgestellt, was auch ohne Probleme geklappt hat und einige Stunden stabil lief.
                                            Dann hatte ich mir gedacht, dass ich redis ausschalte, um ein bisschen Speicher zu sparen. Diese Änderung führte zu einer dramatischen Instabilität. Iob konnte kein Web Interface mehr anzeigen, die über SSH gestartet Console hat mich nach einigen Sekunden wieder rausgeschmissen und Debmatic ist auch nicht mehr gestartet. Ansonsten habe ich noch NextPVR installiert. Debmatic und NextPVR haben keine Abhängigkeiten von redis.
                                            Es wirkt so, als ob es dennoch Prozesse gibt, die immer noch redis Verfügbarkeit benötigen und wenn sie die nicht bekommen, das System extrem belasten.
                                            Gottseidank konnte ich in der kurzen Zeitspanne, in der die Console funktioniert hat, den redis Server wieder via SSH einschalten und jetzt läuft es wieder stabil.
                                            Hat jemand eine Idee? Kann man irgendwie herausbekommen, wer den Redis Server benutzt?
                                            M arteck apollon77 3 Replies Last reply Reply Quote 0
                                            747
                                            171585
