    4. eBus Adapter Vaillant
      floret88 @floret88 last edited by
      @floret88 nach 2 stündigen Drehen am Poti und x Neustarts des Raspberrys und X mal runter nehmen des VRC habe ich die Nase voll, und lass es bleiben! Abwarten auf den eBus Adapter v3 von John30.
      Haben fertig, schönes Wochenende
        Cino last edited by
        Ich hab den hier, funktioniert top
        https://www.esera.de/produkte/ebus/135/1-wire-hub-platine
          floret88 @Cino last edited by
          @cino Den habe ich auch, und funkt leider nicht zufriedenstellend.
            Cino @floret88 last edited by Cino
            @floret88 wenn du willst kann ich dir meine config mal schicken.
            ebusctl i
            version: ebusd 21.2.v21.2
            update check: OK
            signal: acquired
            symbol rate: 23
            max symbol rate: 360
            min arbitration micros: 319
            max arbitration micros: 9955
            min symbol latency: 0
            max symbol latency: 28
            reconnects: 0
            masters: 3
            conditional: 3
            poll: 1
            update: 10
            address 03: master #11
            address 08: slave #11, scanned "MF=Vaillant;ID=BAI00;SW=0104;HW=7803", loaded "vaillant/bai.308523.inc", "vaillant/08.bai.csv"
            address 10: master #2
            address 15: slave #2, scanned "MF=Vaillant;ID=70000;SW=0614;HW=6903", loaded "vaillant/15.700.csv"
            address 31: master #8, ebusd
            address 36: slave #8, ebusd
            address ec: slave, scanned "MF=Vaillant;ID=SOL00;SW=0614;HW=6903", loaded "vaillant/ec.sol.sc.csv"
            a# /etc/default/ebusd:
            # config file for ebusd service.
            # Options to pass to ebusd (run "ebusd -?" for more info):
            #EBUSD_OPTS="--scanconfig"
            EBUSD_OPTS="--configpath=http://ebusd.eu/config/ -d /dev/ttyUSB0 -p 8888  --latency=0 --receivetimeout=100000 -l /var/log/ebusd.log  --scanconfig=full  --httpport=8889 --htmlpath=/var/ebusd/html"
            # MULTIPLE EBUSD INSTANCES WITH SYSV
            # In order to run multiple ebusd instances on a SysV enabled system, simply
            # define several EBUSD_OPTS with a unique suffix for each. Recommended is to
            # use a number as suffix for all EBUSD_OPTS settings. That number will then be
            # taken as additional "instance" parameter to the init.d script in order to
            # start/stop an individual ebusd instance instead of all instances.
            # Example: (uncomment the EBUSD_OPTS above)
            #EBUSD_OPTS1="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 -p 8888 -l /var/log/ebusd1.log"
            #EBUSD_OPTS2="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900acTF-if00-port0 -p 8889 -l /var/log/ebusd2.log"
            #EBUSD_OPTS3="--scanconfig -d /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A900beCG-if00-port0 -p 8890 -l /var/log/ebusd3.log"
            # MULTIPLE EBUSD INSTANCES WITH SYSTEMD
            # In order to run muiltiple ebusd instances on a systemd enabled system, just
            # copy the /usr/lib/systemd/system/ebusd.service file to /etc/systemd/system/
            # with a different name (e.g. ebusd-2.service), remove the line starting with
            # 'EnvironmentFile=', and replace the '$EBUSD_OPTS' with the options for that
            # particular ebusd instance.
              Dan.Master last edited by
              Also meine Config die quasi Fehlerfrei zusammen mit dem ESERA EBUS Adapter seit Januar läuft:
              EBUSD_OPTS="--scanconfig=full --configpath=/etc/ebusd/ -d /dev/ttyUSB0 -p 8888 --latency=0 --receivetimeout=
              100000 -l /var/log/ebusd.log --httpport=8889 --htmlpath=/var/www/"
              # MULLE EBUSD INSTANCES WITH SYSV In order to run multiple ebusd instances on a SysV enabled system,
              # simply define several EBUSD_OPTS with a unique suffix for each. Recommended is to use a number as
              # suffix for all EBUSD_OPTS settings. That number will then be taken as additional "instance"
              # parameter to the init.d script in order to start/stop an individual ebusd instance instead of all
              # instances. Example: (uncomment the EBUSD_OPTS above)
              /log/ebusd1.log"
              /log/ebusd2.log"
              /log/ebusd3.log"
              Und der Auszug aus dem ebusctl info
              pi@raspberrypi:~ $ ebusctl i
              signal: acquired
              symbol rate: 58
              max symbol rate: 150
              min arbitration micros: 326
              max arbitration micros: 573
              min symbol latency: 5
              max symbol latency: 14
              reconnects: 0
              masters: 5
              conditional: 0
              poll: 1
              update: 10
              address 00: master #1
              address 05: slave #1, scanned "MF=Vaillant;ID=VR921;SW=2206;HW=5703"
              address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0308;HW=0403", loaded "vaillant/08.hmu.csv"
              address 71: master #9
              address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0308;HW=0403"
              Die 921 wird nicht erkannt (Das Internetmodul).
              Der ESERA ist Busmäig ca 2.5m entfernt von der Wärmepumpe vond dort wird er weiter geleitet zum 921 und 700er.
              Ich habe den abgleich direkt am ESERA mit Laptop via HTERM gemacht. Auch ich musste das Poti anpassen.
              DerDani
              • MassiveAttack
                MassiveAttack last edited by
                Ich hatte auch den Esera Adapter, und damit so meine Probleme. Hauptsächlich gehts da um die latency. Kurzum, nachdem ich den selbstgebastelten Adapter von John verwende, funktioniert alles tadellos.
                Du kannst an der Config drehen und wenden was du willst, bringt aber nur mäßigen Erfolg. Glaub mir, ich habe Stunden oder eher Tage damit verbracht 🙂
                • Hasont
                  Hasont last edited by Hasont
                  Hallo, ich verwende den EBus schon einige Jahre zum Auslesen von Werten und der Einstellung der Heizkurve.
                  Leider gelingt es mir nicht die Auto Raumtemperatur welche an der calorMatic 430 eingestellt werden kann auch über die VIS einzustellen.
                  Wenn ich mir die eBusDaten über [IP IoBroker]:8891/data auslese werden meine Änderungen an der calorMatic 430 als "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" angezeigt. Diese kann ich über das Terminal mit ebusctl r ActualRoomTempDesiredHc1 oder ebusctl r DisplayedHc1RoomTempDesired ebenfalls auslesen.
                  Eine Änderung mit ebusctl w -c 430 ActualRoomTempDesiredHc1 22 oder ebusctl w -c 430 DisplayedHc1RoomTempDesired 22 wird mit ERR: element not found beantwortet. Somit gehe ich davon aus, dass er in "ActualRoomTempDesiredHc1" und "DisplayedHc1RoomTempDesired" keine Werte schreiben kann.
                  Ich kann mir aber auch nicht vorstellen, dass man grad diesen Komfortwert zur kurzfristigen Erhöhung oder Absenkung der Soll Zimmertemperatur nicht auch extern verstellen kann.
                  Hat hierzu jemand eine Idee oder Lösung?
                  LG
                  Horst
                    cactus-online @Hasont last edited by
                    @hasont ist das nicht eine Frage für die eBus Leute und nicht für ioBroker?
                    Btw: Warum postest Du den absolut identischen Text hier im Forum in zwei verschiedenen Threads?
                      Rolf_Bfd last edited by
                      @hasont
                      Hallo Horst,
                      hast du inzwischen eine Lösung gefunden, um den Raumsollwert zu ändern?
                      VG, Ralf
                      Hasont 1 Reply Last reply Reply Quote 0
                      • Hasont
                        Hasont @Rolf_Bfd last edited by Hasont
                        @rolf_bfd
                        Hallo Ralf, danke der Nachfrage aber leider nicht.
                        Auf manuell könnte ich Umschalten und da dann auch die Grad eingeben.
                        Wenn man es dann aber nicht wieder zurück stellt bleibt das so.
                        Bei Automatik geht das bei der nächsten Änderung nach Zeit auf den vorher eingestellten Wert zurück.
                        Wäre somit wesentlich komfortabler.
                        LG Horst
                          Cino last edited by
                          Mal eine generelle Frage hier.
                          Ich musste den RPI mit dem Ebusd neu aufsetzen. Über HTTP habe ich jetzt eine Liste voll mit Sachen.
                           "700": {
                            "messages": {   "AdaptHeatCurve": {
                              "name": "AdaptHeatCurve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "BankHolidayEndPeriod": {
                              "name": "BankHolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "BankHolidayStartPeriod": {
                              "name": "BankHolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Friday": {
                              "name": "ccTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Monday": {
                              "name": "ccTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Saturday": {
                              "name": "ccTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Sunday": {
                              "name": "ccTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Thursday": {
                              "name": "ccTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Tuesday": {
                              "name": "ccTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ccTimer.Wednesday": {
                              "name": "ccTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ContinuosHeating": {
                              "name": "ContinuosHeating",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "currenterror": {
                              "name": "currenterror",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CylinderChargeHyst": {
                              "name": "CylinderChargeHyst",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CylinderChargeOffset": {
                              "name": "CylinderChargeOffset",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Date": {
                              "name": "Date",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DisplayedOutsideTemp": {
                              "name": "DisplayedOutsideTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "errorhistory": {
                              "name": "errorhistory",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FrostOverRideTime": {
                              "name": "FrostOverRideTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1ActualFlowTempDesired": {
                              "name": "Hc1ActualFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1AutoOffMode": {
                              "name": "Hc1AutoOffMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1CircuitType": {
                              "name": "Hc1CircuitType",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1ExcessTemp": {
                              "name": "Hc1ExcessTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1FlowTemp": {
                              "name": "Hc1FlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1HeatCurve": {
                              "name": "Hc1HeatCurve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1HeatCurveAdaption": {
                              "name": "Hc1HeatCurveAdaption",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1MaxFlowTempDesired": {
                              "name": "Hc1MaxFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1MinFlowTempDesired": {
                              "name": "Hc1MinFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1MixerMovement": {
                              "name": "Hc1MixerMovement",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1PumpStatus": {
                              "name": "Hc1PumpStatus",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1RoomTempSwitchOn": {
                              "name": "Hc1RoomTempSwitchOn",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1Status": {
                              "name": "Hc1Status",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1SummerTempLimit": {
                              "name": "Hc1SummerTempLimit",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2ActualFlowTempDesired": {
                              "name": "Hc2ActualFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2AutoOffMode": {
                              "name": "Hc2AutoOffMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2CircuitType": {
                              "name": "Hc2CircuitType",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2ExcessTemp": {
                              "name": "Hc2ExcessTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2FlowTemp": {
                              "name": "Hc2FlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2HeatCurve": {
                              "name": "Hc2HeatCurve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2HeatCurveAdaption": {
                              "name": "Hc2HeatCurveAdaption",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2MaxFlowTempDesired": {
                              "name": "Hc2MaxFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2MinFlowTempDesired": {
                              "name": "Hc2MinFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2MixerMovement": {
                              "name": "Hc2MixerMovement",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2PumpStatus": {
                              "name": "Hc2PumpStatus",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2RoomTempSwitchOn": {
                              "name": "Hc2RoomTempSwitchOn",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2Status": {
                              "name": "Hc2Status",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2SummerTempLimit": {
                              "name": "Hc2SummerTempLimit",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3ActualFlowTempDesired": {
                              "name": "Hc3ActualFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3AutoOffMode": {
                              "name": "Hc3AutoOffMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3CircuitType": {
                              "name": "Hc3CircuitType",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3ExcessTemp": {
                              "name": "Hc3ExcessTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3FlowTemp": {
                              "name": "Hc3FlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3HeatCurve": {
                              "name": "Hc3HeatCurve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3HeatCurveAdaption": {
                              "name": "Hc3HeatCurveAdaption",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3MaxFlowTempDesired": {
                              "name": "Hc3MaxFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3MinFlowTempDesired": {
                              "name": "Hc3MinFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3MixerMovement": {
                              "name": "Hc3MixerMovement",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3PumpStatus": {
                              "name": "Hc3PumpStatus",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3RoomTempSwitchOn": {
                              "name": "Hc3RoomTempSwitchOn",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3Status": {
                              "name": "Hc3Status",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc3SummerTempLimit": {
                              "name": "Hc3SummerTempLimit",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcStorageTempBottom": {
                              "name": "HcStorageTempBottom",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcStorageTempTop": {
                              "name": "HcStorageTempTop",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HolidayEndPeriod": {
                              "name": "HolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HolidayStartPeriod": {
                              "name": "HolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HolidayTemp": {
                              "name": "HolidayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcBankHolidayEndPeriod": {
                              "name": "HwcBankHolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcBankHolidayStartPeriod": {
                              "name": "HwcBankHolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcFlowTemp": {
                              "name": "HwcFlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcHolidayEndPeriod": {
                              "name": "HwcHolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcHolidayStartPeriod": {
                              "name": "HwcHolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcLockTime": {
                              "name": "HwcLockTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcMaxFlowTempDesired": {
                              "name": "HwcMaxFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcOpMode": {
                              "name": "HwcOpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcParallelLoading": {
                              "name": "HwcParallelLoading",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcSFMode": {
                              "name": "HwcSFMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcStorageTemp": {
                              "name": "HwcStorageTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcStorageTempBottom": {
                              "name": "HwcStorageTempBottom",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcStorageTempTop": {
                              "name": "HwcStorageTempTop",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcTempDesired": {
                              "name": "HwcTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Friday": {
                              "name": "hwcTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Monday": {
                              "name": "hwcTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Saturday": {
                              "name": "hwcTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Sunday": {
                              "name": "hwcTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Thursday": {
                              "name": "hwcTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Tuesday": {
                              "name": "hwcTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "hwcTimer.Wednesday": {
                              "name": "hwcTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HydraulicScheme": {
                              "name": "HydraulicScheme",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Installer1": {
                              "name": "Installer1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Installer2": {
                              "name": "Installer2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "KeyCodeforConfigMenu": {
                              "name": "KeyCodeforConfigMenu",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MaintenanceDate": {
                              "name": "MaintenanceDate",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MaintenanceDue": {
                              "name": "MaintenanceDue",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MaxCylinderChargeTime": {
                              "name": "MaxCylinderChargeTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MaxRoomHumidity": {
                              "name": "MaxRoomHumidity",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MultiRelaySetting": {
                              "name": "MultiRelaySetting",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Friday": {
                              "name": "noiseReductionTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Monday": {
                              "name": "noiseReductionTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Saturday": {
                              "name": "noiseReductionTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Sunday": {
                              "name": "noiseReductionTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Thursday": {
                              "name": "noiseReductionTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Tuesday": {
                              "name": "noiseReductionTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "noiseReductionTimer.Wednesday": {
                              "name": "noiseReductionTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "OpMode": {
                              "name": "OpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "OpModeEffect": {
                              "name": "OpModeEffect",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "OutsideTempAvg": {
                              "name": "OutsideTempAvg",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PhoneNumber1": {
                              "name": "PhoneNumber1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PhoneNumber2": {
                              "name": "PhoneNumber2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySum": {
                              "name": "PrEnergySum",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHc": {
                              "name": "PrEnergySumHc",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHcLastMonth": {
                              "name": "PrEnergySumHcLastMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHcThisMonth": {
                              "name": "PrEnergySumHcThisMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHwc": {
                              "name": "PrEnergySumHwc",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHwcLastMonth": {
                              "name": "PrEnergySumHwcLastMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHwcThisMonth": {
                              "name": "PrEnergySumHwcThisMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSum": {
                              "name": "PrFuelSum",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSumHc": {
                              "name": "PrFuelSumHc",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSumHcLastMonth": {
                              "name": "PrFuelSumHcLastMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSumHcThisMonth": {
                              "name": "PrFuelSumHcThisMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSumHwc": {
                              "name": "PrFuelSumHwc",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSumHwcLastMonth": {
                              "name": "PrFuelSumHwcLastMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrFuelSumHwcThisMonth": {
                              "name": "PrFuelSumHwcThisMonth",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PumpAdditionalTime": {
                              "name": "PumpAdditionalTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SFMode": {
                              "name": "SFMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SolarYieldTotal": {
                              "name": "SolarYieldTotal",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SystemFlowTemp": {
                              "name": "SystemFlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Friday": {
                              "name": "tariffTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Monday": {
                              "name": "tariffTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Saturday": {
                              "name": "tariffTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Sunday": {
                              "name": "tariffTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Thursday": {
                              "name": "tariffTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Tuesday": {
                              "name": "tariffTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "tariffTimer.Wednesday": {
                              "name": "tariffTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Time": {
                              "name": "Time",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Friday": {
                              "name": "ventilationTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Monday": {
                              "name": "ventilationTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Saturday": {
                              "name": "ventilationTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Sunday": {
                              "name": "ventilationTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Thursday": {
                              "name": "ventilationTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Tuesday": {
                              "name": "ventilationTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ventilationTimer.Wednesday": {
                              "name": "ventilationTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WaterPressure": {
                              "name": "WaterPressure",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "YieldTotal": {
                              "name": "YieldTotal",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1ActualRoomTempDesired": {
                              "name": "z1ActualRoomTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1BankHolidayEndPeriod": {
                              "name": "z1BankHolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1BankHolidayStartPeriod": {
                              "name": "z1BankHolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTemp": {
                              "name": "z1CoolingTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Friday": {
                              "name": "z1CoolingTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Monday": {
                              "name": "z1CoolingTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Saturday": {
                              "name": "z1CoolingTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Sunday": {
                              "name": "z1CoolingTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Thursday": {
                              "name": "z1CoolingTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Tuesday": {
                              "name": "z1CoolingTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1CoolingTimer.Wednesday": {
                              "name": "z1CoolingTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1DayTemp": {
                              "name": "z1DayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1HolidayEndPeriod": {
                              "name": "z1HolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1HolidayStartPeriod": {
                              "name": "z1HolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1HolidayTemp": {
                              "name": "z1HolidayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Name1": {
                              "name": "z1Name1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Name2": {
                              "name": "z1Name2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1NightTemp": {
                              "name": "z1NightTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1OpMode": {
                              "name": "z1OpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1QuickVetoTemp": {
                              "name": "z1QuickVetoTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1RoomTemp": {
                              "name": "z1RoomTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1RoomZoneMapping": {
                              "name": "z1RoomZoneMapping",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1SFMode": {
                              "name": "z1SFMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Shortname": {
                              "name": "z1Shortname",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Friday": {
                              "name": "z1Timer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Monday": {
                              "name": "z1Timer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Saturday": {
                              "name": "z1Timer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Sunday": {
                              "name": "z1Timer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Thursday": {
                              "name": "z1Timer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Tuesday": {
                              "name": "z1Timer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1Timer.Wednesday": {
                              "name": "z1Timer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z1ValveStatus": {
                              "name": "z1ValveStatus",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2ActualRoomTempDesired": {
                              "name": "z2ActualRoomTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2BankHolidayEndPeriod": {
                              "name": "z2BankHolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2BankHolidayStartPeriod": {
                              "name": "z2BankHolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTemp": {
                              "name": "z2CoolingTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Friday": {
                              "name": "z2CoolingTimer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Monday": {
                              "name": "z2CoolingTimer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Saturday": {
                              "name": "z2CoolingTimer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Sunday": {
                              "name": "z2CoolingTimer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Thursday": {
                              "name": "z2CoolingTimer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Tuesday": {
                              "name": "z2CoolingTimer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2CoolingTimer.Wednesday": {
                              "name": "z2CoolingTimer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2DayTemp": {
                              "name": "z2DayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2HolidayEndPeriod": {
                              "name": "z2HolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2HolidayStartPeriod": {
                              "name": "z2HolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2HolidayTemp": {
                              "name": "z2HolidayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Name1": {
                              "name": "z2Name1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Name2": {
                              "name": "z2Name2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2NightTemp": {
                              "name": "z2NightTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2OpMode": {
                              "name": "z2OpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2QuickVetoTemp": {
                              "name": "z2QuickVetoTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2RoomTemp": {
                              "name": "z2RoomTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2RoomZoneMapping": {
                              "name": "z2RoomZoneMapping",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2SFMode": {
                              "name": "z2SFMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Shortname": {
                              "name": "z2Shortname",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Friday": {
                              "name": "z2Timer.Friday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Monday": {
                              "name": "z2Timer.Monday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Saturday": {
                              "name": "z2Timer.Saturday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Sunday": {
                              "name": "z2Timer.Sunday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Thursday": {
                              "name": "z2Timer.Thursday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Tuesday": {
                              "name": "z2Timer.Tuesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2Timer.Wednesday": {
                              "name": "z2Timer.Wednesday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z2ValveStatus": {
                              "name": "z2ValveStatus",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3ActualRoomTempDesired": {
                              "name": "z3ActualRoomTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3BankHolidayEndPeriod": {
                              "name": "z3BankHolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3BankHolidayStartPeriod": {
                              "name": "z3BankHolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3DayTemp": {
                              "name": "z3DayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3HolidayEndPeriod": {
                              "name": "z3HolidayEndPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3HolidayStartPeriod": {
                              "name": "z3HolidayStartPeriod",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3HolidayTemp": {
                              "name": "z3HolidayTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3Name1": {
                              "name": "z3Name1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3Name2": {
                              "name": "z3Name2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3NightTemp": {
                              "name": "z3NightTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3OpMode": {
                              "name": "z3OpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3QuickVetoTemp": {
                              "name": "z3QuickVetoTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3RoomTemp": {
                              "name": "z3RoomTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3RoomZoneMapping": {
                              "name": "z3RoomZoneMapping",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3SFMode": {
                              "name": "z3SFMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3Shortname": {
                              "name": "z3Shortname",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "z3ValveStatus": {
                              "name": "z3ValveStatus",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                           "bai": {
                            "messages": {   "AccessoriesOne": {
                              "name": "AccessoriesOne",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "AccessoriesTwo": {
                              "name": "AccessoriesTwo",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ACRoomthermostat": {
                              "name": "ACRoomthermostat",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "averageIgnitiontime": {
                              "name": "averageIgnitiontime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "BlockTimeHcMax": {
                              "name": "BlockTimeHcMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "BoilerType": {
                              "name": "BoilerType",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ChangesDSN": {
                              "name": "ChangesDSN",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CirPump": {
                              "name": "CirPump",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CounterStartattempts1": {
                              "name": "CounterStartattempts1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CounterStartattempts2": {
                              "name": "CounterStartattempts2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CounterStartAttempts3": {
                              "name": "CounterStartAttempts3",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CounterStartAttempts4": {
                              "name": "CounterStartAttempts4",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "currenterror": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DateTime": {
                              "name": "DateTime",
                              "passive": false,
                              "write": false,
                              "lastup": 1645901322,
                              "zz": 8,
                              "fields": {
                               "dcfstate": {"value": "valid"},
                               "btime": {"value": "19:48:43"},
                               "bdate": {"value": "26.02.2022"},
                               "temp2": {"value": 6.438}
                             "dcfState": {
                              "name": "dcfState",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DCFTimeDate": {
                              "name": "DCFTimeDate",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DCRoomthermostat": {
                              "name": "DCRoomthermostat",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DeactivationsIFC": {
                              "name": "DeactivationsIFC",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DeactivationsTemplimiter": {
                              "name": "DeactivationsTemplimiter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DeltaFlowReturnMax": {
                              "name": "DeltaFlowReturnMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DisplayMode": {
                              "name": "DisplayMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DSN": {
                              "name": "DSN",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DSNOffset": {
                              "name": "DSNOffset",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "DSNStart": {
                              "name": "DSNStart",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "EBusHeatcontrol": {
                              "name": "EBusHeatcontrol",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "EbusSourceOn": {
                              "name": "EbusSourceOn",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "EbusVoltage": {
                              "name": "EbusVoltage",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "errorhistory": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "expertlevel_ReturnTemp": {
                              "name": "expertlevel_ReturnTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ExternalFaultmessage": {
                              "name": "ExternalFaultmessage",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "externalFlowTempDesired": {
                              "name": "externalFlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "externalHwcSwitch": {
                              "name": "externalHwcSwitch",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ExternGasvalve": {
                              "name": "ExternGasvalve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ExtFlowTempDesiredMin": {
                              "name": "ExtFlowTempDesiredMin",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ExtStorageModulCon": {
                              "name": "ExtStorageModulCon",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "extWP": {
                              "name": "extWP",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanHours": {
                              "name": "FanHours",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanMaxSpeedOperation": {
                              "name": "FanMaxSpeedOperation",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanMinSpeedOperation": {
                              "name": "FanMinSpeedOperation",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanPWMSum": {
                              "name": "FanPWMSum",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanPWMTest": {
                              "name": "FanPWMTest",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanSpeed": {
                              "name": "FanSpeed",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanSpeedOffsetMax": {
                              "name": "FanSpeedOffsetMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanSpeedOffsetMin": {
                              "name": "FanSpeedOffsetMin",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FanStarts": {
                              "name": "FanStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Flame": {
                              "name": "Flame",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlameSensingASIC": {
                              "name": "FlameSensingASIC",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FloorHeatingContact": {
                              "name": "FloorHeatingContact",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowsetHcMax": {
                              "name": "FlowsetHcMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowsetHwcMax": {
                              "name": "FlowsetHwcMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowSetPotmeter": {
                              "name": "FlowSetPotmeter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowTemp": {
                              "name": "FlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowTempDesired": {
                              "name": "FlowTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowTempMax": {
                              "name": "FlowTempMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Fluegasvalve": {
                              "name": "Fluegasvalve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FluegasvalveOpen": {
                              "name": "FluegasvalveOpen",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Gasvalve3UC": {
                              "name": "Gasvalve3UC",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Gasvalve": {
                              "name": "Gasvalve",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "GasvalveASICFeedback": {
                              "name": "GasvalveASICFeedback",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "GasvalveUC": {
                              "name": "GasvalveUC",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "GasvalveUCFeedback": {
                              "name": "GasvalveUCFeedback",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcHours": {
                              "name": "HcHours",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcPumpMode": {
                              "name": "HcPumpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcPumpStarts": {
                              "name": "HcPumpStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcStarts": {
                              "name": "HcStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HcUnderHundredStarts": {
                              "name": "HcUnderHundredStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HeatingSwitch": {
                              "name": "HeatingSwitch",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HoursTillService": {
                              "name": "HoursTillService",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcDemand": {
                              "name": "HwcDemand",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcHours": {
                              "name": "HwcHours",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcImpellorSwitch": {
                              "name": "HwcImpellorSwitch",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcPostrunTime": {
                              "name": "HwcPostrunTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcSetPotmeter": {
                              "name": "HwcSetPotmeter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcStarts": {
                              "name": "HwcStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcSwitch": {
                              "name": "HwcSwitch",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcTemp": {
                              "name": "HwcTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcTempDesired": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcTempMax": {
                              "name": "HwcTempMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcTypes": {
                              "name": "HwcTypes",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcUnderHundredStarts": {
                              "name": "HwcUnderHundredStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcWaterflow": {
                              "name": "HwcWaterflow",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "HwcWaterflowMax": {
                              "name": "HwcWaterflowMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Ignitor": {
                              "name": "Ignitor",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "InitialisationEEPROM": {
                              "name": "InitialisationEEPROM",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "IonisationVoltageLevel": {
                              "name": "IonisationVoltageLevel",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "maintenancedata_HwcTempMax": {
                              "name": "maintenancedata_HwcTempMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "maxIgnitiontime": {
                              "name": "maxIgnitiontime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "minIgnitiontime": {
                              "name": "minIgnitiontime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ModulationTempDesired": {
                              "name": "ModulationTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "OutdoorstempSensor": {
                              "name": "OutdoorstempSensor",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "OverflowCounter": {
                              "name": "OverflowCounter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ParamToken": {
                              "name": "ParamToken",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PartloadHcKW": {
                              "name": "PartloadHcKW",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PartloadHwcKW": {
                              "name": "PartloadHwcKW",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PartnumberBox": {
                              "name": "PartnumberBox",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PositionValveSet": {
                              "name": "PositionValveSet",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PowerValue": {
                              "name": "PowerValue",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrAPSCounter": {
                              "name": "PrAPSCounter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrAPSSum": {
                              "name": "PrAPSSum",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergyCountHc1": {
                              "name": "PrEnergyCountHc1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergyCountHc2": {
                              "name": "PrEnergyCountHc2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergyCountHc3": {
                              "name": "PrEnergyCountHc3",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergyCountHwc1": {
                              "name": "PrEnergyCountHwc1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergyCountHwc2": {
                              "name": "PrEnergyCountHwc2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergyCountHwc3": {
                              "name": "PrEnergyCountHwc3",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHc1": {
                              "name": "PrEnergySumHc1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHc2": {
                              "name": "PrEnergySumHc2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHc3": {
                              "name": "PrEnergySumHc3",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHwc1": {
                              "name": "PrEnergySumHwc1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHwc2": {
                              "name": "PrEnergySumHwc2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrEnergySumHwc3": {
                              "name": "PrEnergySumHwc3",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ProductionByte": {
                              "name": "ProductionByte",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PrVortexFlowSensorValue": {
                              "name": "PrVortexFlowSensorValue",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PumpHours": {
                              "name": "PumpHours",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PumpHwcFlowNumber": {
                              "name": "PumpHwcFlowNumber",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PumpHwcFlowSum": {
                              "name": "PumpHwcFlowSum",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "RemainingBoilerblocktime": {
                              "name": "RemainingBoilerblocktime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ReturnRegulation": {
                              "name": "ReturnRegulation",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ReturnTemp": {
                              "name": "ReturnTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ReturnTempMax": {
                              "name": "ReturnTempMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SecondPumpMode": {
                              "name": "SecondPumpMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SerialNumber": {
                              "name": "SerialNumber",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SetFactoryValues": {
                              "name": "SetFactoryValues",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SetMode": {
                              "name": "SetMode",
                              "passive": true,
                              "write": true,
                              "lastup": 1645901332,
                              "zz": 8,
                              "fields": {
                               "hcmode": {"value": "auto"},
                               "flowtempdesired": {"value": 61.5},
                               "hwctempdesired": {"value": null},
                               "hwcflowtempdesired": {"value": null},
                               "disablehc": {"value": 0},
                               "disablehwctapping": {"value": 0},
                               "disablehwcload": {"value": 1},
                               "remoteControlHcPump": {"value": 0},
                               "releaseBackup": {"value": 0},
                               "releaseCooling": {"value": 0}
                             "SHEMaxDeltaHwcFlow": {
                              "name": "SHEMaxDeltaHwcFlow",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SHEMaxFlowTemp": {
                              "name": "SHEMaxFlowTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SolPostHeat": {
                              "name": "SolPostHeat",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Statenumber": {
                              "name": "Statenumber",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Status01": {
                              "name": "Status01",
                              "passive": false,
                              "write": false,
                              "lastup": 1645901342,
                              "zz": 8,
                              "fields": {
                               "0": {"name": "temp1", "value": 47.0},
                               "1": {"name": "temp1", "value": 42.0},
                               "2": {"name": "temp2", "value": 6.438},
                               "3": {"name": "temp1", "value": 32.5},
                               "4": {"name": "temp1", "value": 36.5},
                               "5": {"name": "pumpstate", "value": "on"}
                             "Status02": {
                              "name": "Status02",
                              "passive": false,
                              "write": false,
                              "zz": 8,
                              "fields": {
                               "0": {"name": "hwcmode", "value": "auto"},
                               "1": {"name": "temp0", "value": 60},
                               "2": {"name": "temp1", "value": 75.0},
                               "3": {"name": "temp0", "value": 70},
                               "4": {"name": "temp1", "value": 50.0}
                             "Status16": {
                              "name": "Status16",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Status": {
                              "name": "Status",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StatusCirPump": {
                              "name": "StatusCirPump",
                              "passive": true,
                              "write": true,
                              "lastup": 1645901143,
                              "zz": 8,
                              "fields": {
                               "0": {"name": "", "value": "off"}
                             "Storageloadpump": {
                              "name": "Storageloadpump",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StorageLoadPumpHours": {
                              "name": "StorageLoadPumpHours",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StorageloadPumpStarts": {
                              "name": "StorageloadPumpStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StorageLoadTimeMax": {
                              "name": "StorageLoadTimeMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StoragereleaseClock": {
                              "name": "StoragereleaseClock",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StorageTemp": {
                              "name": "StorageTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StorageTempDesired": {
                              "name": "StorageTempDesired",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "StorageTempMax": {
                              "name": "StorageTempMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TargetFanSpeed": {
                              "name": "TargetFanSpeed",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TargetFanSpeedOutput": {
                              "name": "TargetFanSpeedOutput",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDiffBlock": {
                              "name": "TempDiffBlock",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDiffFailure": {
                              "name": "TempDiffFailure",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempGradientFailure": {
                              "name": "TempGradientFailure",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Templimiter": {
                              "name": "Templimiter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TemplimiterWithNTC": {
                              "name": "TemplimiterWithNTC",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempMaxDiffExtTFT": {
                              "name": "TempMaxDiffExtTFT",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Testbyte": {
                              "name": "Testbyte",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TimerInputHc": {
                              "name": "TimerInputHc",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ValveMode": {
                              "name": "ValveMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ValveStarts": {
                              "name": "ValveStarts",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "VolatileLockout": {
                              "name": "VolatileLockout",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "VolatileLockoutIFCGV": {
                              "name": "VolatileLockoutIFCGV",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "VortexFlowSensor": {
                              "name": "VortexFlowSensor",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WarmstartDemand": {
                              "name": "WarmstartDemand",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WarmstartOffset": {
                              "name": "WarmstartOffset",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WaterHcFlowMax": {
                              "name": "WaterHcFlowMax",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WaterPressure": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WaterpressureBranchControlOff": {
                              "name": "WaterpressureBranchControlOff",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WaterpressureMeasureCounter": {
                              "name": "WaterpressureMeasureCounter",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WaterpressureVariantSum": {
                              "name": "WaterpressureVariantSum",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WP": {
                              "name": "WP",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WPPostrunTime": {
                              "name": "WPPostrunTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "WPSecondStage": {
                              "name": "WPSecondStage",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                           "broadcast": {
                            "messages": {   "datetime": {
                              "name": "datetime",
                              "passive": true,
                              "write": false,
                              "lastup": 0
                             "error": {
                              "name": "error",
                              "passive": true,
                              "write": false,
                              "lastup": 0
                             "hwcStatus": {
                              "name": "hwcStatus",
                              "passive": true,
                              "write": false,
                              "lastup": 0
                             "id-u": {
                              "name": "id",
                              "passive": true,
                              "write": false,
                              "lastup": 0
                             "load": {
                              "name": "load",
                              "passive": true,
                              "write": false,
                              "lastup": 0
                             "outsidetemp": {
                              "name": "outsidetemp",
                              "passive": true,
                              "write": false,
                              "lastup": 1645901323,
                              "zz": 254,
                              "fields": {
                             "signoflife": {
                              "name": "signoflife",
                              "passive": true,
                              "write": false,
                              "lastup": 0
                             "vdatetime": {
                              "name": "vdatetime",
                              "passive": true,
                              "write": false,
                              "zz": 254,
                              "fields": {
                               "time": {"value": "19:48:42"},
                               "date": {"value": "26.02.2022"}
                           "sc": {
                            "messages": {   "Col": {
                              "name": "Col",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ColKickPumpTime": {
                              "name": "ColKickPumpTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ColKickTempDelta": {
                              "name": "ColKickTempDelta",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "CollPump": {
                              "name": "CollPump",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "currenterror": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "D1Temp": {
                              "name": "D1Temp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "D2Temp": {
                              "name": "D2Temp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Date": {
                              "name": "Date",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "EDFunction": {
                              "name": "EDFunction",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "EnableScProtection": {
                              "name": "EnableScProtection",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "errorhistory": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FlowRate": {
                              "name": "FlowRate",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FrostProtectionEnabled": {
                              "name": "FrostProtectionEnabled",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "FrostProtectionLimit": {
                              "name": "FrostProtectionLimit",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc1PumpKol1PP1Port": {
                              "name": "Hc1PumpKol1PP1Port",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2aLegPumpP2Port": {
                              "name": "Hc2aLegPumpP2Port",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Hc2zPort": {
                              "name": "Hc2zPort",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "InitCircuit": {
                              "name": "InitCircuit",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "IsInBoostMode": {
                              "name": "IsInBoostMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "KickFunction": {
                              "name": "KickFunction",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "LpZpMaPort": {
                              "name": "LpZpMaPort",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MAPreferredStorage": {
                              "name": "MAPreferredStorage",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MaximalTemp2": {
                              "name": "MaximalTemp2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MaximalTemp": {
                              "name": "MaximalTemp",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "MultifunctionOutput": {
                              "name": "MultifunctionOutput",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "OMultifunction": {
                              "name": "OMultifunction",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "PumpAntiLockingFlags": {
                              "name": "PumpAntiLockingFlags",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "QuickVetoStart": {
                              "name": "QuickVetoStart",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ResetSolGain": {
                              "name": "ResetSolGain",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "RuntimeCollPump": {
                              "name": "RuntimeCollPump",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "RuntimeCollPumpSeconds": {
                              "name": "RuntimeCollPumpSeconds",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ScProtectionHysteresis": {
                              "name": "ScProtectionHysteresis",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ScProtectionLimit": {
                              "name": "ScProtectionLimit",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "ScProtectionTime": {
                              "name": "ScProtectionTime",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SolCollPumpDcIntegrator": {
                              "name": "SolCollPumpDcIntegrator",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SolCollPumpED": {
                              "name": "SolCollPumpED",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SolGain": {
                              "name": "SolGain",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SolOperationMode": {
                              "name": "SolOperationMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SP1": {
                              "name": "SP1",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SP2": {
                              "name": "SP2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SumSolGain": {
                              "name": "SumSolGain",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SumSolGainDayBefore": {
                              "name": "SumSolGainDayBefore",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "SystemMode": {
                              "name": "SystemMode",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDifferenceOff2": {
                              "name": "TempDifferenceOff2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDifferenceOff": {
                              "name": "TempDifferenceOff",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDifferenceOffTD12": {
                              "name": "TempDifferenceOffTD12",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDifferenceOn2": {
                              "name": "TempDifferenceOn2",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDifferenceOn": {
                              "name": "TempDifferenceOn",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "TempDifferenceOnTD12": {
                              "name": "TempDifferenceOnTD12",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Time": {
                              "name": "Time",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "Weekday": {
                              "name": "Weekday",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "YieldLastYear": {
                              "name": "YieldLastYear",
                              "passive": false,
                              "write": false,
                              "lastup": 0
                             "YieldThisYear": {
                              "name": "YieldThisYear",
                              "passive": false,
                              "write": false,
                              "lastup": 1645901350,
                              "zz": 236,
                              "decodeerror": "ERR: invalid position"
                           "scan.08": {
                            "messages": {   "": {
                              "name": "",
                              "passive": false,
                              "write": false,
                              "lastup": 1645900412,
                              "zz": 8,
                              "fields": {
                               "MF": {"value": "Vaillant"},
                               "ID": {"value": "BAI00"},
                               "SW": {"value": "0104"},
                               "HW": {"value": "7803"}
                             "id": {
                              "name": "id",
                              "passive": false,
                              "write": false,
                              "lastup": 1645900430,
                              "zz": 8,
                              "fields": {
                               "prefix": {"value": "21"},
                               "year": {"value": "19"},
                               "week": {"value": "48"},
                               "product": {"value": "0010021934"},
                               "supplier": {"value": "0001"},
                               "counter": {"value": "008767"},
                               "suffix": {"value": "N4"}
                           "scan.15": {
                            "messages": {   "": {
                              "name": "",
                              "passive": false,
                              "write": false,
                              "lastup": 1645900416,
                              "zz": 21,
                              "fields": {
                               "ID": {"value": "70000"},
                               "SW": {"value": "0614"},
                               "HW": {"value": "6903"}
                             "id": {
                              "name": "id",
                              "passive": false,
                              "write": false,
                              "lastup": 1645900435,
                              "zz": 21,
                              "fields": {
                               "year": {"value": "20"},
                               "week": {"value": "15"},
                               "product": {"value": "0020266797"},
                               "supplier": {"value": "0082"},
                               "counter": {"value": "019647"},
                               "suffix": {"value": "N5"}
                           "scan.ec": {
                            "messages": {   "": {
                              "name": "",
                              "passive": false,
                              "write": false,
                              "lastup": 1645900557,
                              "zz": 236,
                              "fields": {
                               "ID": {"value": "SOL00"},
                             "id": {
                              "name": "id",
                              "passive": false,
                              "write": false,
                              "lastup": 1645900568,
                              "zz": 236,
                              "fields": {
                           "global": {
                            "version": "21.3.v21.3",
                            "updatecheck": "version 22.1 available",
                            "signal": true,
                            "symbolrate": 35,
                            "maxsymbolrate": 134,
                            "minarbitrationmicros": 352,
                            "maxarbitrationmicros": 575,
                            "minsymbollatency": 0,
                            "maxsymbollatency": 7,
                            "qq": 49,
                            "reconnects": 0,
                            "masters": 3,
                            "messages": 718,
                          Was kann ich mit solchen Sachen anfangen?
                          "700": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                          "passive": false,
                          "write": false,
                          "lastup": 0
                          "passive": false,
                          "write": false,
                          "lastup": 0
                          "ccTimer.Friday": {
                          "passive": false,
                          "write": false,
                          "lastup": 0
                          Generell habe ich nur vereinzelt Werte drin.
                          Hiltex 1 Reply Last reply Reply Quote 0
                          • Hiltex
                            Hiltex @Cino last edited by
                            @Cino was genau ist denn die Frage?
                            Die Bedeutung der Datenpunkte ist folgende:
                            AdaptHeatCurve = Adaptive Heizkurve (ist eine Einstellung in der Fachhandwerkerebene). Ich weiß nicht genau, was die macht. Anhand des Namens schätze euch jedoch, dass die Heizkurve dynamisch angepasst wird.
                            BankHolidayEndPeriod = Tage außer Haus (Ende)
                            BankHolidayStartPeriod = Tage außer Haus (Beginn)
                            ccTimer.Friday = Heizzeiten am Freitag
                            Was du jetzt damit machst, oder ob du diese Datenpunkte ignorierst, bleibt ganz dir überlassen 😉
                              Cino @Hiltex last edited by
                              @hiltex ja nimm doch mal z.B. jetzt
                              "700": {
                              "passive": false,
                              "write": false,
                              "lastup": 0
                              Ist die adaptive Heizkurve. Die ist bei mir deaktiviert. Jetzt habe ich hier aber bool was mir false oder true anzeigt.
                              messages ist klar, name auch.
                              Was ist jetzt passive, write und lastup?
                              Was ich sagen will ist, ich habe die messages, aber keine Werte mit denen ich arbeiten kann.
                              Muss ich die extra abfragen? Ich lausche ja am Bus nach meinem Verständnis. Und wenn ich in den Einstellungen nicht rumspiele dürfte ja kein message ankommen ausser die Broadcast Nachrichten.
                              Ich habe gerade ein Verständnisproblem.
                              • Hiltex
                                @cino ok, ich dachte das war die Frage danach, was die Datenpunkte bedeuten sollen.
                                passive - keine Ahnung
                                write - ob du den Wert verändern oder nur lesen kannst
                                Lastup - wann der Wert das letzte mal abgerufen wurde.
                                Vom Grunde her funktioniert das so: die Therme sendet ein paar Werte regelmäßig, die dann automatisch in ioBroker aktualisiert werden. Welche das genau sind hängt von deiner ganz speziellen Therme ab. Alle anderen Werte, die dich interessieren, musst du aktiv abfragen, sonst kommt da nix.
                                Da geht nur probieren und selbst herausfinden, was man gebrauchen kann und was nicht. Temperaturen sind oft sehr aussagekräftig, bzw. informativ. Mit solchen Sachen wir HcPumpStarts kann ich persönlich nicht viel anfangen
                                C 2 Replies Last reply Reply Quote 0
                                  @hiltex Jepp, aktiv abfragen ist angesagt. Guck mal wie sich das verändert hat.
                                  "700": {
                                  "passive": false,
                                  "write": false,
                                  "lastup": 1645906922,
                                  "zz": 21,
                                  "fields": {
                                  "yesno": {"value": "no"}
                                  • Hiltex
                                    @cino In Lastup steht jetzt die Uhrzeit der Aktualisierung als Unix-Time. Das googelst du am besten mal.
                                    Value: No erklärt sich vermutlich von selbst, was zz ist weiß ich nicht.
                                      @hiltex said in eBus Adapter Vaillant:
                                      Sag das nicht. Mit den ganzen Werten kann man sich förmlich ein Diagnosetool bauen über VIS.
                                        Cino last edited by
                                        Sind alle Werte in der Config eigentlich abrufbar? Hab mir einige ausgesucht und kriege Fehler.
                                        ebus.0
                                        2022-02-26 21:36:02.162	error	sent read -f -c Durchfluss FlowRate , received ERR: element not found for {"circuit":"Durchfluss","name":"FlowRate","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.159	error	sent read -f -c Gebläsedrehzahl FanSpeed , received ERR: element not found for {"circuit":"Gebläsedrehzahl","name":"FanSpeed","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.156	error	sent read -f -c Rücklauf expertlevel_ReturnTemp , received ERR: element not found for {"circuit":"Rücklauf","name":"expertlevel_ReturnTemp","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.153	error	sent read -f -c Pumpe1 CirPump , received ERR: element not found for {"circuit":"Pumpe1","name":"CirPump","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.150	error	sent read -f -c Wasserdruck WaterPressure , received ERR: element not found for {"circuit":"Wasserdruck","name":"WaterPressure","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.148	error	sent read -f -c Pumpe Hc1PumpStatus , received ERR: element not found for {"circuit":"Pumpe","name":"Hc1PumpStatus","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.144	error	sent read -f -c HK1Vorlauf Hc1FlowTemp , received ERR: element not found for {"circuit":"HK1Vorlauf","name":"Hc1FlowTemp","parameter":""}
                                        ebus.0
                                        2022-02-26 21:36:02.141	error	sent read -f -c HK1Vorlaufsoll Hc1ActualFlowTempDesired , received ERR: element not found for {"circuit":"HK1Vorlaufsoll","name":"Hc1ActualFlowTempDesired","parameter":""}
                                        • Hiltex
                                          @cino auch das ist abhängig von deiner ganz speziellen Konfiguration. Bei mir gibt es auch einige Werte, die nicht vorhanden sind und deshalb einen Fehler produzieren
                                            @hiltex gibt jetzt aber auch keine Möglichkeit mal alles zu pollen und dann zu gucken was ein Wert zurückgibt?
                                            ebus ebus adapter error erste schritte problem
                                            49
                                            388
                                            101636
