    4. js-controller 4.0 jetzt im BETA/LATEST!
      apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
      @ofbeqnpolkkl6mby5e13 Issue bei vis bitte
      • O
        oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
        @apollon77
        Das behebt das Problem nicht:
        2022-02-21 10:40:38.147  - info: host.iobroker "system.adapter.vis.0" enabled
        2022-02-21 10:40:39.910  - info: vis.0 (2892) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
        2022-02-21 10:40:40.184  - info: vis.0 (2892) vis license is OK.
        2022-02-21 10:40:40.242  - error: vis.0 (2892) uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
        2022-02-21 10:40:40.245  - error: vis.0 (2892) Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
            at Object.openSync (fs.js:497:3)
            at Object.writeFileSync (fs.js:1528:35)
            at copyFileSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:16:8)
            at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:36:17
            at Array.forEach (<anonymous>)
            at copyFolderRecursiveSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:31:15)
            at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:34:17
        2022-02-21 10:40:40.246  - error: vis.0 (2892) Exception-Code: EACCES: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
        2022-02-21 10:40:40.762  - info: vis.0 (2892) terminating
        2022-02-21 10:40:40.764  - warn: vis.0 (2892) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2022-02-21 10:40:41.371  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
        Ich führe mal ein iobroker fix durch.
        Nach iobroker fix:
        2022-02-21 10:51:21.640  - info: vis.0 (1348) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
        2022-02-21 10:51:21.904  - info: vis.0 (1348) vis license is OK.
        2022-02-21 10:51:23.094  - info: vis.0 (1348) Terminated (NO_ERROR): Without reason
        2022-02-21 10:51:23.691  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
        Danach wieder hoch zu 1.4.12. Jetzt läuft vis wieder. Nur hätte ich mir das alles sparen können, weil mein ursprüngliches Problem weiterhin existiert...
        Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
          Wie sehen die Rechte denn an
          aus?
          • O
            oFbEQnpoLKKl6mbY5e13 @Thomas Braun last edited by
            Wie gesagt, das Problem konnte durch iobroker fix behoben werden.
            # ls -l /opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css
            -rw-rw-rw- 1 iobroker iobroker 70 Feb 21 11:05 /opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css
              saeft_2003 Most Active @apollon77 last edited by saeft_2003
              @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
              @saeft_2003 naja mit 630MB frei ist dann die Frage wie gross denn so das Backup ist wenn es tut? bzw wieviele Daten sind es denn die da gesichert werden
              Das backup hat 90MB.
              edit: ich habe ohne den ram zu erhöhen ein Backup manuell gestartet das lief ohne Probleme durch.
                @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                • O
                  @apollon77
                  Restore mit VIS v1.4.12 geht mindestens bei mir nicht und hat mit JS-Controller nichts zu tun. Das Problem, weshalb ich auf einen älteren Stand wollte, ist aber Off-Topic.
                  Danke für die Hilfe!
                    apollon77 @saeft_2003 last edited by
                    @saeft_2003 Kannst du mir mal einen gefallen tun?
                    Mach mal eine Shell auf mit "top", dann drücke "Shift-M" - das sortiert dir die EInträge nach RAM nutzung. Dnan am besten davon nen Screenshot
                    Jetzt bitte mal zwei Dinge tun:
                    1.) in einer zweiten Shell ein "iob backup" ausführen
                    2.) Backup über BackItUp manuell starten
                    Und bei beiden Dingen bitte mal das "top" beobachten ... Wo steigt der RAM Verbrauch an und wenn ja in welchem prozess?
                    Vllt kommen wir so ein bissl dahinter
                      Marty56 @apollon77 last edited by
                      @apollon77
                      Ich habe meine zweite iobroker Instanz (Raspberry 3) ohne Probleme umgestellt.
                      Dort hatte ich früher die States auf redis umgestellt und würde jetzt gern auf JSONL migrieren.
                      iobroker status
                      Objects type: jsonl
                      States  type: redis
                      Ist das unproblematisch?
                        apollon77 @Marty56 last edited by
                        @marty56 Na klar, einfach per iob setup custom machen
                          @apollon77 Danke. Hat unproblematisch geklappt.
                            e-i-k-e last edited by e-i-k-e
                            Aktualisiere gerade ein Slave von 4.0.10 auf 4.0.15.
                            Habe es nun bereits mit sudo -H -u iobroker npm install iobroker.js-controller versucht.
                            Bei den anderen Geräten hatte ich dieses Problem nicht.
                            Was kann ich tun?
                            pi@raspberrypi-display2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                            > iobroker.js-controller@4.0.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                            > node lib/preinstallCheck.js
                            NPM version: 6.14.16
                            > iobroker.js-controller@4.0.10 install /opt/iobroker/node_modules/iobroker.js-controller
                            > node iobroker.js setup first
                            No connection to objects 192.168.3.100:6379[redis]
                            /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                    throw e;
                            Error: Connection is closed.
                                at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                at Object.onceWrapper (events.js:520:26)
                                at Socket.emit (events.js:400:28)
                                at TCP.<anonymous> (net.js:686:12)
                            Emitted 'error' event on ScanStream instance at:
                                at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                                at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                                at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                                at processTicksAndRejections (internal/process/task_queues.js:95:5)
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno 1
                            npm ERR! iobroker.js-controller@4.0.10 install: `node iobroker.js setup first`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the iobroker.js-controller@4.0.10 install script.
                            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                            npm ERR!     /home/iobroker/.npm/_logs/2022-02-21T20_58_28_730Z-debug.l
                            Keine Ahnung was jetzt los ist.. 😲
                            pi@raspberrypi-display2:~ $ iobroker stop
                            pi@raspberrypi-display2:~ $ iobroker fix
                            library: loaded
                            Library version=2022-02-10
                            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                              apollon77 @e-i-k-e last edited by
                              @e-i-k-e Wie geht es dem Redis? Steht ggf etwas im Redis log? Ich hab das gefühl das sich der beendet mittendrin.
                                e-i-k-e @apollon77 last edited by
                                @apollon77
                                Hast du zufällig den Pfad parat?
                                Ich habe den kompletten Container inkl. Reids mal neu gestartet. Keine Änderung.
                                  Thomas Braun Most Active @e-i-k-e last edited by
                                  @e-i-k-e
                                  less -R /var/log/redis/redis-server.log
                                  und
                                  systemctl status redis
                                  anschauen.
                                  • Diginix
                                    Diginix last edited by Diginix
                                    @AlCalzone @apollon77
                                    Hab eben per CLI admin, web und ws aktualisiert und dann ist der js-controller mal wieder RAM technisch eskaliert mit über 2 GB. Hat sich dann aber ohne mein Zutun wieder stabilisiert. Wahrs. reichten die 6 GB RAM der VM gerade so aus.
                                    Mem:           5941        4407         131           1        1402        1242
                                    Swap:             0           0           0
                                    apollon77 3 Replies Last reply Reply Quote 0
                                      e-i-k-e @Thomas Braun last edited by
                                      Danke.
                                      Im Log steht immer das gleiche, nichts auffälliges.
                                      11670:C 20 Feb 2022 22:13:49.210 * DB saved on disk
                                      11670:C 20 Feb 2022 22:13:49.228 * RDB: 7 MB of memory used by copy-on-write
                                      139:M 20 Feb 2022 22:13:49.345 * Background saving terminated with success
                                      139:M 20 Feb 2022 22:15:49.680 * 10000 changes in 60 seconds. Saving...
                                      139:M 20 Feb 2022 22:15:49.698 * Background saving started by pid 11703
                                      11703:C 20 Feb 2022 22:16:04.583 * DB saved on disk
                                      11703:C 20 Feb 2022 22:16:04.601 * RDB: 14 MB of memory used by copy-on-write
                                      139:M 20 Feb 2022 22:16:04.688 * Background saving terminated with success
                                      139:M 20 Feb 2022 22:18:21.814 * 10000 changes in 60 seconds. Saving...
                                      pi@ioBroker-Rock:~$ systemctl status redis
                                      * redis-server.service - Advanced key-value store
                                           Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                           Active: active (running) since Mon 2022-02-21 22:27:17 CET; 46min ago
                                             Docs: http://redis.io/documentation,
                                                   man:redis-server(1)
                                          Process: 114 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
                                         Main PID: 135 (redis-server)
                                            Tasks: 4 (limit: 18952)
                                           Memory: 1.7G
                                              CPU: 6min 39.212s
                                           CGroup: /system.slice/redis-server.service
                                                   `-135 /usr/bin/redis-server 0.0.0.0:6379
                                      Fünf weitere Slave laufen aber auch problemlos mit dem Master und der Redis DB.
                                      M apollon77 2 Replies Last reply Reply Quote 0
                                        Marty56 @e-i-k-e last edited by
                                        Ich beobachte einen seltsamen Effekt, den ich nicht verstehe.
                                        Ich habe iob mit dem Update auf von js-controller 4 von Objects type: jsonl
                                        States type: redis auf Objects type: jsonl States type: jsonl umgestellt, was auch ohne Probleme geklappt hat und einige Stunden stabil lief.
                                        Dann hatte ich mir gedacht, dass ich redis ausschalte, um ein bisschen Speicher zu sparen. Diese Änderung führte zu einer dramatischen Instabilität. Iob konnte kein Web Interface mehr anzeigen, die über SSH gestartet Console hat mich nach einigen Sekunden wieder rausgeschmissen und Debmatic ist auch nicht mehr gestartet. Ansonsten habe ich noch NextPVR installiert. Debmatic und NextPVR haben keine Abhängigkeiten von redis.
                                        Es wirkt so, als ob es dennoch Prozesse gibt, die immer noch redis Verfügbarkeit benötigen und wenn sie die nicht bekommen, das System extrem belasten.
                                        Gottseidank konnte ich in der kurzen Zeitspanne, in der die Console funktioniert hat, den redis Server wieder via SSH einschalten und jetzt läuft es wieder stabil.
                                        Hat jemand eine Idee? Kann man irgendwie herausbekommen, wer den Redis Server benutzt?
                                        M arteck apollon77 3 Replies Last reply Reply Quote 0
                                          Marty56 @Marty56 last edited by Marty56
                                          gelöscht
                                            Fortune95 @Marty56 last edited by
                                            @apollon77
                                            Node.js: v14.19.0
                                            js-controller: 4.0.15
                                            Habe gerade folgendes nach einem Neustart des Shelly Adapters im Log gefunden:
                                            2022-02-22 06:12:00.875 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                            2022-02-22 06:12:00.876 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                            at Socket.writeAfterFIN [as write] (net.js:468:14)
                                            at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                                            at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                            at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                            at writeOrBuffer (internal/streams/writable.js:358:12)
                                            at Writable.write (internal/streams/writable.js:303:10)
                                            at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                            at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                            at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                            at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                            2022-02-22 06:12:00.877 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                            2022-02-22 06:12:00.880 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                            2022-02-22 06:12:00.880 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                            at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                                            at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                                            2022-02-22 06:12:00.880 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                            2022-02-22 06:12:00.881 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                            2022-02-22 06:12:00.881 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                            at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                                            2022-02-22 06:12:00.881 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                            2022-02-22 06:12:00.882 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                            2022-02-22 06:12:00.882 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                            at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                                            2022-02-22 06:12:00.882 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                            2022-02-22 06:12:00.883 - warn: shelly.0 (15030) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                            2022-02-22 06:12:00.950 - error: host.iobroker Caught by controller[1]: Error: This socket has been ended by the other party
                                            2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                            2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                                            2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                            2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                            2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Writable.write (internal/streams/writable.js:303:10)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                                            2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                            2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: Error: This socket has been ended by the other party
                                            2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                            2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                                            2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                            2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                            2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                            2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write (internal/streams/writable.js:303:10)
                                            2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                            2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                            2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                            2022-02-22 06:12:00.962 - error: host.iobroker Caught by controller[3]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                            2022-02-22 06:12:00.962 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            747
                                            171592
