    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Thomas Braun Most Active @tombox last edited by Thomas Braun
      @tombox
      UPS zickt noch etwas:
      2022-02-21 20:55:03.692  - error: parcel.0 (4495) https://onlinetools.ups.com/mychoice/v1/shipments/details/AddressToken?loc=de_DE
      2022-02-21 20:55:03.692  - error: parcel.0 (4495) TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "AuthenticationToken"
      Oh, irgendwelche Troubles mit meinem PW... Da muss ich erstmal bei mir schauen...
      Zickt doch nix:
      2022-02-21 21:21:23.655  - info: parcel.0 (4698) Login to DHL
      2022-02-21 21:21:24.404  - info: parcel.0 (4698) Login to DHL successful
      2022-02-21 21:21:24.424  - info: parcel.0 (4698) Login to DPD
      2022-02-21 21:21:26.057  - info: parcel.0 (4698) Login to DPD successful
      2022-02-21 21:21:26.065  - info: parcel.0 (4698) Login to T17 User
      2022-02-21 21:21:28.593  - info: parcel.0 (4698) Login to 17T successful
      2022-02-21 21:21:28.601  - info: parcel.0 (4698) Login to Amazon
      2022-02-21 21:21:32.240  - info: parcel.0 (4698) Login to Amazon successful
      2022-02-21 21:21:32.249  - info: parcel.0 (4698) Login to GLS
      2022-02-21 21:21:35.789  - info: parcel.0 (4698) Login to GLS successful
      2022-02-21 21:21:35.797  - info: parcel.0 (4698) Login to UPS
      2022-02-21 21:21:36.801  - info: parcel.0 (4698) Login to UPS successful
      2022-02-21 21:21:43.721  - info: parcel.0 (4698) undefined is not a valid state value for id "parcel.0.17tuser.trackinginfo.json"
        senger1985 @Thomas Braun last edited by
        Hab noch eine weitere Meldung, zu UPS(denke ich):
        parcel.0
        2022-02-21 21:49:12.261	error	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "addresstoken"
        parcel.0
        2022-02-21 21:49:12.259	error	https://onlinetools.ups.com/mychoice/v1/shipments/details/AddressToken?loc=de_DE
        parcel.0
        2022-02-21 21:49:02.271	error	TypeError: Cannot read property 'MYCEnrollmentSummary' of undefined
        Siehe unterste Meldung
        • Wszene
          Wszene @tombox last edited by
          @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
          Amazon:
          Login eingeben
          Wenn nötig vorab ein OTP token aus der 2FA App eingeben.
          Ich habe da mal eine Frage
          Wo bekomme ich denn den Token her?
          • Christoph1337
            Christoph1337 last edited by Christoph1337
            @tombox
            Schön das du die optische Anpassung eingebaut hast! 🙂
            Kann man irgendwie verhindern, dass man beim Start des Adaptern immer eine Liste aller aktuellen und vergangenen Pakete bekommt?
            Idealerweise würde man hier lediglich noch nicht zugestellte Pakete als Benachrichtigung erhalten.
            Was auch später noch klasse wäre, wäre eine Liste als Widget.
            Ich verwende da meistens die von @liv-in-sky, die funktioniert super.
             //HIER WIRD PFAD UND FILENAME DEFINIERT
             const path = "/htmlexample.html";                   //FIlenamen definieren
             const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
             let   braucheEinFile=false;                          // bei true wird ein file geschrieben
             let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
             let dpVIS=DPPath         //WICHTIG wenn braucheEinVISWidget auf true gesetzt !!  dp zusätzlich für VIS-HTML-Basic-Widget
            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 2
            var htmlFeld1='Gerät';                            // überschrift Tabellen Spalte1
            var htmlFeld2='Wert';                              // überschrift Tabellen Spalte2
            //hier werden die styles für die tabelle definiert
            //ÜBERSCHRIFT ÜBER TABELLE
            let   htmlUberschrift=true;                           // mit Überschrift über der tabelle
            const htmlFeldUeber='Stromkosten';              // Überschrift
            const htmlFarbUber="#2C7FB6";                         // Farbe der Überschrift
            //MEHRERE TABELLEN NEBENEINANDER
            let   mehrfachTabelle=Spalten;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
            const htmlFarbZweiteTabelle="#42A6EA";                // Farbe der Überschrift bei jeder 2.ten Tabelle
            const htmlFarbTableColorUber="#2C7FB6";               // Überschrift in der tabelle - der einzelnen Spalten
            //GANZE TABELLE
            const htmlSchriftart="RobotoCondensed-Regular";
            const htmlSchriftgroesse="13px";
            //FELDER UND RAHMEN
            const htmlFarbFelderschrift="#DADFDA";                  // SchriftFarbe der Felder
            const htmlFarbFelderschrift2="#E3FBE2";                 // SchriftFarbe der Felder für jede 2te Tabelle
            const htmlFarbTableColorGradient1="#3F403F";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
            const htmlFarbTableColorGradient2="#3F403F";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
            const htmlFarbTableBorderColor="#2C7FB6";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
            const htmlRahmenLinien=1;                            // Format für Rahmen(Gitter)linien 1=alle - 2=nur vertikal - 3= nur horizontal - 4=keine
            // HIER NICHTS  ÄNDERN
            const htmlEnd=      '</table></body>';
            const htmlStart=    '<!DOCTYPE html><html lang="de"><head><title>Vorlage</title><meta http-equiv="content-type" content="text/html; charset=utf-8"></head><body>';
            const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
            const htmlTabStyleCol= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"3\" cellspacing=\"3\" cellpadding=\"3\"  rules=\"cols\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                   "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
            const htmlTabStyleRow= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"3\" cellspacing=\"3\" cellpadding=\"3\"  rules=\"rows\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
            const htmlTabStyleAll= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"3\" cellspacing=\"3\" cellpadding=\"3\"  rules=\"all\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
            const htmlTabStyleNone= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"3\" cellspacing=\"3\" cellpadding=\"3\"  rules=\"none\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
            const htmlTabUeber1="<tr style=\"color:"+htmlFarbTableColorUber+"; font-weight: bold\">";
            const htmlTabUeber3="</tr>";
            ////NICHTS ÄNDERN  - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 2
            var htmlTabUeber2="<td  align=center>&ensp;"+htmlFeld1+"&ensp;</td><td align=center>&ensp;"+htmlFeld2+"&ensp;</td>";
            var htmlTabUeber2_1="<td  align=center style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td  align=center style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                "&ensp;</td>";
            var htmlOut="";
            function writeHTML(){
                  var htmlTabStyle;
                switch (+htmlRahmenLinien) {
                case 1: htmlTabStyle=htmlTabStyleAll; break;
                case 2: htmlTabStyle=htmlTabStyleCol; break;
                case 3: htmlTabStyle=htmlTabStyleRow; break;
                case 4: htmlTabStyle=htmlTabStyleNone; break;
            htmlOut="";
            var counter=-1;
            var htmlTabUeber="";
            switch (mehrfachTabelle) {
                case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
             //HIER SIND DIE § WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert
             var val1;  var val0;
             //SCHLEIFE FÜR DIE WERTE
              for (var x=0;x<myList.length;x++){
                  counter++;
                  if(myList[x][1]!=null){
                                        val0  = myList[x][0];
                                        val1  = myList[x][1]
                                        //if (val1==false) {val1="❌"} else{val1="✅"}
                  //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 2 Felder definiert, braucht man hier 2 Werte
                      case 1:                    htmlOut=htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td></tr>"; break;
                      case 2:  if(counter%2==0)  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td>"; }
                                            else {htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td></tr>";} break;
                      case 3: if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td>"; }
                                            else { if(counter%3==1 )  { htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td>";}
                                                             else    {htmlOut = htmlOut+"<td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td></tr>";}
                                                       } break;
                      case 4: if(counter%4==0)  {htmlOut = htmlOut+"<tr><td>&ensp;"+val0+"&ensp;</td><td align=center>&ensp;"+val1+"&ensp;</td>"; }
                                                else {if(counter%2==1 )  { htmlOut = htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td>";}
                                                             else    {if(counter%2==1 && counter%4==3)  { htmlOut= htmlOut+"<td style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align=center style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td></tr>";}
        else    {htmlOut = htmlOut = htmlOut+"<td>&ensp;"+val0+"&ensp;</td><td>&ensp;"+val1+"&ensp;</td>";}}
                                                       } break;
                  } //switch ende
                }; //Schleifen ende
                       //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                        var htmlOutVIS="";
                        htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                        //log(htmlOutVIS);
                        if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
              //mit oder ohne überschrift
              htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
              //log(htmlOut);
            } // function ende
             //hier wird schleife gestartet und das file geschrieben
             //schedule("*/20 * * * * *",  function () {
              writeHTML();
              if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
              tombox @Wszene last edited by
              @wszene Naja wenn du 2FA bei amazon aktiviert hast, hast du doch eine AuthApp aktiv wo du deine Token herbekommst oder wie kommst du an dein 2FA Token
              @senger1985 Ich habe den check bei ups verbessert
              @Christoph1337 Es ist eigentlich absicht damit man sieht das bei adapter start alles funktioniert. Eigentlich sollte der Adapter ja nie neugestartet werden außer jetzt wo die Updatefrequenz hoch ist
              Gibt es denn ein Beispiel oder Adapter der so ein Widget eingebaut hat?
              Wszene Christoph1337 2 Replies Last reply Reply Quote 1
              • Wszene
                Die Nummer bekommen wir per SMS zugesendet
                • Christoph1337
                  Christoph1337 @tombox last edited by
                  @tombox
                  Vielleicht kann man den Versand ja beim Start optional machen. Einfach eine Checkbox im Adapter?
                  Als Beispiel kann ich z.B. das hier nennen:
                  https://forum.iobroker.net/topic/28789/script-fürtabelle-der-batterie-zustände
                  Es gibt auch einige andere dieser Tabellen.
                  Ziemlich nützlich und prima für die einfache Darstellung in der VIS.
                  Xsev 1 Reply Last reply Reply Quote 0
                  • Xsev
                    Xsev @Christoph1337 last edited by Xsev
                    Wie stellt ihr denn die Amazon Lieferungen in Vis dar, die sich aktuell in der Lieferung befinden, hab mittlerweile ne große Liste mit zugestellten Paketen aber die sich in Zustellung befinden gehen halt total unter. Hätte auf meiner Vis Infoseite gerne eine Benachrichtigung das sich ein Paket heute in Zustellung befindet, evtl. sogar Paketdienstleister übergreifend. Hat das jemand realisiert?
                    Christoph1337 T 2 Replies Last reply Reply Quote 0
                    • Christoph1337
                      Christoph1337 @Xsev last edited by
                      @xsev Genau das habe ich ja eben nachgefragt. ⬆
                      • Xsev
                        @christoph1337 Ja wobei ich persönlich jetzt keine Tabelle benötige, mir würde ein einfacher Datenpunkt genügen, mir dem ich mir eine dezente Info auf meinem Infoscreen schalten kann. Habs gern minimalistisch aber das ja Geschmackssache. 😉
                          tombox @Xsev last edited by
                          @xsev Könnte nochmal filtern die "In Zustellung" im status haben aber kenne nicht alle Texte aller anbieter
                          • Xsev
                            Xsev @tombox last edited by Xsev
                            @tombox ja sowas wollte ich per Skript selber lösen aber bsp. Amazon hat durch die Lieferzeit, die in der Nachricht steht immer unterschiedliche Meldungen, daher konnte ich den Wert nicht triggern. Aber du hast da sicher deutlich mehr Möglichkeiten wie ich. Das wäre halt ideal wenn man bsp. ein Delivery-today hätte der dann auf true gestellt wird und das über den Status "in Zustellung" abgefragt werden könnte.
                            edit:
                            Ich hab aktuell nur DHL und Amazon in Betrieb, daher weiß ich auch nicht wie es bei den anderer Anbietern ist. DHL ist da mit den Infos die im Adapter geliefert werden genial.
                            • DJMarc75
                              DJMarc75 last edited by
                              @tombox
                              Also im Moment sind die Telegrams der kompletten Pakete und Briefe bei jedem Neustart noch absolut ok. Ist da was geplant wenns ins latest geht ?
                              Grüßle
                              • DJMarc75
                                DJMarc75 last edited by DJMarc75
                                @tombox
                                habe eben Amazon bei mir mit eingefügt und ich bekomme alle 15 Minuten per Telegram ALLE zugestellten Paketbenachrichtigungen zugesendet..... oder ich muss irgendwas vergessen haben zu installieren
                                • Rene55
                                  Rene55 @DJMarc75 last edited by
                                  @djmarc75 Den Effekt habe ich seit heute auch. Nur das (zugestellte) Amazon-Paket von heute sehe ich zwar in den Datenpunkten, aber keine Nachricht per Telegram. @tombox Muss ich im Amazonkonto den/die Störenfriede irgendwie "beruhigen" ?
                                  • Wszene
                                    Ich habe es jetzt auch erfolgreich zum laufen gebracht
                                    Hier mal meine Amazon VIS
                                      tombox @DJMarc75 last edited by
                                      @DJMarc75
                                      @Rene55
                                      Wiederholende Benachrichtigung von Amazon Paket bei den es auch ein DHL Status gibt wurde behoben.
                                      Alle Benachrichtigung bei Neustart muss erstmal so bleiben ich müsste mir sonst alle Benachrichtigungen merken und der Datenpunkt würde dann schnell sehr groß werden.
                                      @Xsev Ich habe mal ein Datenpunkt inDelivery eingebaut
                                      Xsev Rene55 2 Replies Last reply Reply Quote 2
                                      • Xsev
                                        @tombox Super! Danke! Schau ich mir heute gleich an.
                                        Ich hab DPD mal in Betrieb genommen. Da hab ich gerade 2 Lieferungen, leider werden keine Daten synchronisiert. Laut log ist DPD Login erfolgreich. Es erscheint nur ein Jsondatenpunkt "JsonSendungen". Ist das richtig?
                                        • Rene55
                                          Rene55 @tombox last edited by
                                          @tombox Die alten Meldungen bei Neustart sind ja auch kein Thema. Über Nacht habe ich 132 Telegram-Nachrichten bekommen - das sind ein paar zuviel. Ich werd gleich mal updaten und beobachten.
                                            @xsev Sollten eigentlich alles kommen
                                            https://my.dpd.de/myParcel.aspx
                                            sind da Sendungen?
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            526372
