    3. Einsteigerfragen
    4. web.0 Keine Verbindung
    • AtomicIX
      AtomicIX @wendy2702 last edited by
      @wendy2702 habe ich, ändert sich aber nichts
      • wendy2702
        wendy2702 @AtomicIX last edited by
        @atomicix geht denn deine VIS Seite auf?
        AtomicIX 1 Reply Last reply Reply Quote 0
        • AtomicIX
          AtomicIX @wendy2702 last edited by AtomicIX
          @wendy2702 Ja das funktioniert alles. Also die Demo Seite. Mehr habe ich da nicht drin.
          Hier noch mal das Log dazu:
          web.0
          2022-02-22 18:59:49.947	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          web.0
          2022-02-22 18:59:48.945	info	<== Disconnect system.user.admin from ::ffff:192.168.221.36 vis.0
          web.0
          2022-02-22 18:59:48.669	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          web.0
          2022-02-22 18:59:47.666	info	<== Disconnect system.user.admin from ::ffff:192.168.221.36 vis.0
          web.0
          2022-02-22 18:57:54.120	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          web.0
          2022-02-22 18:57:53.281	debug	Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, dev1, dev2, dev3, dev4, demoTemperature, demoHumidity
          web.0
          2022-02-22 18:57:53.241	debug	Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
          web.0
          2022-02-22 18:57:53.230	debug	2022-02-22T17:57:53.230Z Request authenticate [system.user.admin]
          web.0
          2022-02-22 18:57:53.121	debug	Connection from vis.0
          web.0
          2022-02-22 18:57:53.118	info	==> Connected system.user.admin from ::ffff:192.168.221.36
          web.0
          2022-02-22 18:57:47.945	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          web.0
          2022-02-22 18:57:47.099	debug	Subscribes: *, vis.0.control.instance, vis.0.control.data, vis.0.control.command
          web.0
          2022-02-22 18:57:47.084	debug	Subscribes: *
          web.0
          2022-02-22 18:57:47.083	debug	2022-02-22T17:57:47.082Z Request authenticate [system.user.admin]
          web.0
          2022-02-22 18:57:46.969	debug	Connection from vis.0
          web.0
          2022-02-22 18:57:46.943	info	==> Connected system.user.admin from ::ffff:192.168.221.36
          web.0
          2022-02-22 18:44:29.772	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
          web.0
          2022-02-22 18:44:28.773	info	http server listening on port 8082
          web.0
          2022-02-22 18:44:28.770	debug	Activating web files from objectDB
          web.0
          2022-02-22 18:44:28.770	debug	Activating extensions
          web.0
          2022-02-22 18:44:28.770	info	socket.io server listening on port 8082
          web.0
          2022-02-22 18:44:28.749	debug	Activating IOSocket
          web.0
          2022-02-22 18:44:28.748	debug	Using http createServer
          web.0
          2022-02-22 18:44:28.747	debug	Activating states & socket info
          web.0
          2022-02-22 18:44:28.686	info	starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
          web.0
          2022-02-22 18:44:28.638	debug	Plugin sentry Initialize Plugin (enabled=true)
          web.0
          2022-02-22 18:44:28.618	debug	statesDB connected
          web.0
          2022-02-22 18:44:28.618	debug	States connected to redis: 127.0.0.1:9000
          web.0
          2022-02-22 18:44:28.616	debug	States create User PubSub Client
          web.0
          2022-02-22 18:44:28.616	debug	States create System PubSub Client
          web.0
          2022-02-22 18:44:28.614	debug	Redis States: Use Redis connection: 127.0.0.1:9000
          web.0
          2022-02-22 18:44:28.614	debug	objectDB connected
          web.0
          2022-02-22 18:44:28.612	debug	Objects connected to redis: 127.0.0.1:9001
          web.0
          2022-02-22 18:44:28.609	debug	Objects client initialize lua scripts
          web.0
          2022-02-22 18:44:28.609	debug	Objects create User PubSub Client
          web.0
          2022-02-22 18:44:28.609	debug	Objects create System PubSub Client
          web.0
          2022-02-22 18:44:28.608	debug	Objects client ready ... initialize now
          web.0
          2022-02-22 18:44:28.596	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          host.ioBroker
          2022-02-22 18:44:28.376	info	instance system.adapter.web.0 started with pid 2149
          host.ioBroker
          2022-02-22 18:44:25.876	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          web.0
          2022-02-22 18:44:25.367	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          web.0
          2022-02-22 18:44:25.367	debug	Plugin sentry destroyed
          web.0
          2022-02-22 18:44:25.366	info	terminating
          • wendy2702
            @atomicix Hast du diese Objekte:
            Zeig mal wie es bei dir aussieht.
            • AtomicIX
              @wendy2702
              • wendy2702
                Ich würde folgendes probieren:
                Web stoppen
                Alle Web Objekte löschen
                Web starten
                Wenn ok dann gut, sonst
                Server neu starten
                iob upload all
                EDIT: Tippfehler beseitigt
                  Thomas Braun Most Active @wendy2702 last edited by
                  @wendy2702 sagte in web.0 Keine Verbindung:
                  iob Upload all
                  Besser:
                  iob upload all
                  • wendy2702
                    wendy2702 @Thomas Braun last edited by
                    @thomas-braun sagte in web.0 Keine Verbindung:
                    iob Upload all
                    Besser:
                    iob upload all
                    Habe den Typo korrigiert
                    • AtomicIX
                      Hat sich nichts geändert 😞
                      • AtomicIX
                        Es läuft. Der Web Adapter ist GRÜN.
                        socket.io lief in der Version 4.1.4 , die aktuelle ist ja aber 3.1.5. Keine Ahnung wo die her kommt. Ich habe socket.io nie installiert.
                        AtomicIX 1 Reply Last reply Reply Quote 1
                        • wendy2702
                          wendy2702 @AtomicIX last edited by wendy2702
                          @AtomicIX
                          4.1.4 Die ist im latest, da kommt man nicht einfach so dran.
                          • AtomicIX
                            AtomicIX @AtomicIX last edited by
                            @wendy2702
                            @atomicix sagte in web.0 Keine Verbindung:
                            • FredF
                              FredF Most Active Forum Testing @AtomicIX last edited by
                              @atomicix @wendy2702
                              Wenn ich das richtig verstehe, wird dieses Problem in späteren Versionen gefixt.
                              Auch wenn bei mir diese Fehlemeldung kommt, bleibe aber auf stable... es funktioniert ja sonst alles.
                              https://github.com/ioBroker/ioBroker.web/issues/184
                              raintonr created this issue in ioBroker/ioBroker.web
                              closed After upgrading to 3.4.16 'not connected' warning triangle shown by each instance. #184
                              4121
