    3. Einsteigerfragen
    4. web.0 Keine Verbindung
    • wendy2702
      wendy2702 @AtomicIX last edited by
      @atomicix geht denn deine VIS Seite auf?
      AtomicIX 1 Reply Last reply Reply Quote 0
      • AtomicIX
        AtomicIX @wendy2702 last edited by AtomicIX
        @wendy2702 Ja das funktioniert alles. Also die Demo Seite. Mehr habe ich da nicht drin.
        Hier noch mal das Log dazu:
        web.0
        2022-02-22 18:59:49.947	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        web.0
        2022-02-22 18:59:48.945	info	<== Disconnect system.user.admin from ::ffff:192.168.221.36 vis.0
        web.0
        2022-02-22 18:59:48.669	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        web.0
        2022-02-22 18:59:47.666	info	<== Disconnect system.user.admin from ::ffff:192.168.221.36 vis.0
        web.0
        2022-02-22 18:57:54.120	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        web.0
        2022-02-22 18:57:53.281	debug	Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command, dev1, dev2, dev3, dev4, demoTemperature, demoHumidity
        web.0
        2022-02-22 18:57:53.241	debug	Subscribes: vis.0.control.instance, vis.0.control.data, vis.0.control.command
        web.0
        2022-02-22 18:57:53.230	debug	2022-02-22T17:57:53.230Z Request authenticate [system.user.admin]
        web.0
        2022-02-22 18:57:53.121	debug	Connection from vis.0
        web.0
        2022-02-22 18:57:53.118	info	==> Connected system.user.admin from ::ffff:192.168.221.36
        web.0
        2022-02-22 18:57:47.945	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        web.0
        2022-02-22 18:57:47.099	debug	Subscribes: *, vis.0.control.instance, vis.0.control.data, vis.0.control.command
        web.0
        2022-02-22 18:57:47.084	debug	Subscribes: *
        web.0
        2022-02-22 18:57:47.083	debug	2022-02-22T17:57:47.082Z Request authenticate [system.user.admin]
        web.0
        2022-02-22 18:57:46.969	debug	Connection from vis.0
        web.0
        2022-02-22 18:57:46.943	info	==> Connected system.user.admin from ::ffff:192.168.221.36
        web.0
        2022-02-22 18:44:29.772	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
        web.0
        2022-02-22 18:44:28.773	info	http server listening on port 8082
        web.0
        2022-02-22 18:44:28.770	debug	Activating web files from objectDB
        web.0
        2022-02-22 18:44:28.770	debug	Activating extensions
        web.0
        2022-02-22 18:44:28.770	info	socket.io server listening on port 8082
        web.0
        2022-02-22 18:44:28.749	debug	Activating IOSocket
        web.0
        2022-02-22 18:44:28.748	debug	Using http createServer
        web.0
        2022-02-22 18:44:28.747	debug	Activating states & socket info
        web.0
        2022-02-22 18:44:28.686	info	starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
        web.0
        2022-02-22 18:44:28.638	debug	Plugin sentry Initialize Plugin (enabled=true)
        web.0
        2022-02-22 18:44:28.618	debug	statesDB connected
        web.0
        2022-02-22 18:44:28.618	debug	States connected to redis: 127.0.0.1:9000
        web.0
        2022-02-22 18:44:28.616	debug	States create User PubSub Client
        web.0
        2022-02-22 18:44:28.616	debug	States create System PubSub Client
        web.0
        2022-02-22 18:44:28.614	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        web.0
        2022-02-22 18:44:28.614	debug	objectDB connected
        web.0
        2022-02-22 18:44:28.612	debug	Objects connected to redis: 127.0.0.1:9001
        web.0
        2022-02-22 18:44:28.609	debug	Objects client initialize lua scripts
        web.0
        2022-02-22 18:44:28.609	debug	Objects create User PubSub Client
        web.0
        2022-02-22 18:44:28.609	debug	Objects create System PubSub Client
        web.0
        2022-02-22 18:44:28.608	debug	Objects client ready ... initialize now
        web.0
        2022-02-22 18:44:28.596	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        host.ioBroker
        2022-02-22 18:44:28.376	info	instance system.adapter.web.0 started with pid 2149
        host.ioBroker
        2022-02-22 18:44:25.876	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        web.0
        2022-02-22 18:44:25.367	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        web.0
        2022-02-22 18:44:25.367	debug	Plugin sentry destroyed
        web.0
        2022-02-22 18:44:25.366	info	terminating
        • wendy2702
          @atomicix Hast du diese Objekte:
          Zeig mal wie es bei dir aussieht.
          • AtomicIX
            @wendy2702
            • wendy2702
              Ich würde folgendes probieren:
              Web stoppen
              Alle Web Objekte löschen
              Web starten
              Wenn ok dann gut, sonst
              Server neu starten
              iob upload all
              EDIT: Tippfehler beseitigt
                Thomas Braun Most Active @wendy2702 last edited by
                @wendy2702 sagte in web.0 Keine Verbindung:
                iob Upload all
                Besser:
                iob upload all
                • wendy2702
                  wendy2702 @Thomas Braun last edited by
                  @thomas-braun sagte in web.0 Keine Verbindung:
                  iob Upload all
                  Besser:
                  iob upload all
                  Habe den Typo korrigiert
                  • AtomicIX
                    Hat sich nichts geändert 😞
                    • AtomicIX
                      Es läuft. Der Web Adapter ist GRÜN.
                      socket.io lief in der Version 4.1.4 , die aktuelle ist ja aber 3.1.5. Keine Ahnung wo die her kommt. Ich habe socket.io nie installiert.
                      AtomicIX 1 Reply Last reply Reply Quote 1
                      • wendy2702
                        wendy2702 @AtomicIX last edited by wendy2702
                        @AtomicIX
                        4.1.4 Die ist im latest, da kommt man nicht einfach so dran.
                        • AtomicIX
                          AtomicIX @AtomicIX last edited by
                          @wendy2702
                          @atomicix sagte in web.0 Keine Verbindung:
                          • FredF
                            FredF Most Active Forum Testing @AtomicIX last edited by
                            @atomicix @wendy2702
                            Wenn ich das richtig verstehe, wird dieses Problem in späteren Versionen gefixt.
                            Auch wenn bei mir diese Fehlemeldung kommt, bleibe aber auf stable... es funktioniert ja sonst alles.
                            https://github.com/ioBroker/ioBroker.web/issues/184
                            raintonr created this issue in ioBroker/ioBroker.web
                            closed After upgrading to 3.4.16 'not connected' warning triangle shown by each instance. #184
                            4123
