    2. English
    3. ioBroker general
    4. adapter LOGs monitoring for errors with mail notifications
    • shaarkys
      shaarkys last edited by
      I'm quite new with ioBroker and using is mostly for integrations with WeConnect, HaasSoohn, Easee, which I share then via MQTT to Homey. From time to time it may happen that one of the adapter is in error state - I tried to search but didn't find answer - is there any way how to monitor logs for errors or adapter states and send fatal errors via email ? I'm not looking for a way to script everything from scratch, rather I wonder I have overlooked some module with such functionality ?
      Can someone share some info / guidance ?
      What I have found so far is Log parser, which is mainly used for Visualisation and it's kind of overkill for the basic need...
      Much appreciated.
      Thank you.
        liv-in-sky @shaarkys last edited by
        @shaarkys
        I played around with this script - long ago
        maybe you can change this for your task
        if a special error or warning appears - the script sends a true to the datapoint and after 2 seconds the datapoint will be switched to false again
        const dpPrefix = "javascript."+ instance +".";
        //definition des dp's - BLOCK 1
        createState(dpPrefix + "OwnLogEntries.Meross",false, { name: 'Meross',  type: 'boolean', role:"switch", read:  true,  write: true,});
        createState(dpPrefix + "OwnLogEntries.Test",false, { name: 'Test',  type: 'boolean', role:"switch", read:  true,  write: true,});
        createState(dpPrefix + "OwnLogEntries.Warn515",false, { name: 'Test',  type: 'boolean', role:"switch", read:  true,  write: true,});
        createState(dpPrefix + "OwnLogEntries.Display7219Matrix",false, { name: 'Test',  type: 'boolean', role:"switch", read:  true,  write: true,});
        // für jeden definierten fehler der trigger - BLOCK 2
        function checkErrors(data) {
          //Alarm 1
         // hier mit regex um genauer zu filtern
            if(data.message.match(/ Error Test /g)){                               // hier angleichen fehler meldung
           setState(dpPrefix + "OwnLogEntries.Test",true);                         // hier angleichen dp
           setStateDelayed(dpPrefix + "OwnLogEntries.Test",false,2000);            // hier angleichen dp
           //Alarm2
           if(data.message.includes("instance system.adapter.meross.0 terminated with code 156")){       // hier angleichen fehler meldung
           setState(dpPrefix + "OwnLogEntries.Meross",true);                                             // hier angleichen dp
           setStateDelayed(dpPrefix + "OwnLogEntries.Meross",false,2000);                                // hier angleichen dp
        function checkWarnings(data) {
                   //Warn1
           if(data.message.includes("(515) BT already scanning!")){       // hier angleichen warning meldung
           setState(dpPrefix + "OwnLogEntries.Warn515",true);                                             // hier angleichen dp
           setStateDelayed(dpPrefix + "OwnLogEntries.Warn515",false,2000);                                // hier angleichen dp
        function checkWarnings2(data) {
              log("bin drin","warn")     //Warn1
           if(data.message.includes("7219Matrix")){       // hier angleichen warning meldung
           setState(dpPrefix + "OwnLogEntries.Display7219Matrix",true);                                             // hier angleichen dp
           setStateDelayed(dpPrefix + "OwnLogEntries.Display7219Matrix",false,2000);                                // hier angleichen dp
        onLog("error", checkErrors);
        onLog("warn", checkWarnings);
        onLog("warn", checkWarnings2);
        shaarkys 1 Reply Last reply Reply Quote 1
        • shaarkys
          shaarkys @liv-in-sky last edited by
          @liv-in-sky thank you, I was worried that there is no adapter I can simply re-use. Will take a look, thank you very much for sharing!
            @shaarkys
            if you have any questions - don't hesitate to ask
