    4. js-controller 4.0 jetzt im BETA/LATEST!
      e-i-k-e last edited by Negalein
      Erhalte soeben nach einem Neustart von ioBroker folgendes.
      Error in GUI!
      Please open the browser console (F12), copy error text from there and create the issue on github
      Without this information it is not possible to analyse the error.
      It should looks like
      error
      If in the second line you will see at :3000/static/js/main.chunk.js:36903 and not the normal file name,
      please try to reproduce an error with opened browser console. In this case the special "map" files will be loaded and the developers can see the real name of functions and files.
      Loading chunk 14 failed. (error: https://192.168.3.100:8081/static/js/14.b28d85a4.chunk.js)
      ChunkLoadError: Loading chunk 14 failed.function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}(error: https://192.168.3.100:8081/static/js/14.b28d85a4.chunk.js)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Function.u.e (https://192.168.3.100:8081/:1:3973)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at https://192.168.3.100:8081/static/js/main.22a9d49c.chunk.js:2:1113786function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at V (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5666268)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Zi (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5656452)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at jl (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5643113)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Sl (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5643041)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Cl (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5642904)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at zl (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5639870)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5589364function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at t.unstable_runWithPriority (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5672574)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Ga (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5589141)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Ka (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5589309)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Za (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5589244)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at pl (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5637247)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Object.enqueueSetState (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5593262)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at o.m.setState (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5664084)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at https://192.168.3.100:8081/static/js/main.22a9d49c.chunk.js:2:1126466function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at u (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5676516)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Generator._invoke (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5676304)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at Generator.throw (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:5676945)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at r (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:35792)function(e,t){return Object(ze.jsxs)("div",{children:[e,Object(ze.jsx)("br",{})]},t)}    at l (https://192.168.3.100:8081/static/js/6.501acaca.chunk.js:2:36031)
      :8081/static/js/14.b28d85a4.chunk.js:1          Failed to load resource: net::ERR_CONNECTION_REFUSED
      :8081/img/no-image.png:1          Failed to load resource: net::ERR_CONNECTION_REFUSED
      browserError.png:1          Failed to load resource: net::ERR_CONNECTION_REFUSED
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649045191&name=admin' failed:
      SocketClient.connect @ socket.io.js:94
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649047813&name=admin' failed:
      168instrument.ts:125 notConnectedError
      (anonymous) @ instrument.ts:125
      :8081/#tab-intro:1 Uncaught (in promise) timeout
      800instrument.ts:125 notConnectedError
      instrument.ts:125 [2022-02-23T20:44:11.805Z] Try to connect
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649051805&name=admin' failed:
      instrument.ts:125 [2022-02-23T20:44:12.831Z] Start reconnect 3
      instrument.ts:125 [2022-02-23T20:44:12.831Z] ws connection error: CLOSE_ABNORMAL
      instrument.ts:125 [2022-02-23T20:44:12.831Z] Reconnect is already running 3
      instrument.ts:125 [2022-02-23T20:44:16.807Z] Try to connect
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649056825&name=admin' failed:
      instrument.ts:125 [2022-02-23T20:44:17.850Z] Start reconnect 4
      instrument.ts:125 [2022-02-23T20:44:17.851Z] ws connection error: CLOSE_ABNORMAL
      instrument.ts:125 [2022-02-23T20:44:17.851Z] Reconnect is already running 4
      instrument.ts:125 [2022-02-23T20:44:22.817Z] Try to connect
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649062840&name=admin' failed:
      instrument.ts:125 [2022-02-23T20:44:23.875Z] Start reconnect 5
      instrument.ts:125 [2022-02-23T20:44:23.875Z] ws connection error: CLOSE_ABNORMAL
      instrument.ts:125 [2022-02-23T20:44:23.875Z] Reconnect is already running 5
      instrument.ts:125 [2022-02-23T20:44:29.803Z] Try to connect
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649069820&name=admin' failed:
      instrument.ts:125 [2022-02-23T20:44:30.850Z] Start reconnect 5
      instrument.ts:125 [2022-02-23T20:44:30.850Z] ws connection error: CLOSE_ABNORMAL
      instrument.ts:125 [2022-02-23T20:44:30.850Z] Reconnect is already running 5
      instrument.ts:125 [2022-02-23T20:44:36.803Z] Try to connect
      instrument.ts:125 [2022-02-23T20:44:40.804Z] No READY flag received in 3 seconds. Re-init
      socket.io.js:344 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649076827&name=admin' failed: WebSocket is closed before the connection is established.
      SocketClient.close @ socket.io.js:344
      instrument.ts:125 [2022-02-23T20:44:40.821Z] Start reconnect 5
      instrument.ts:125 [2022-02-23T20:44:40.821Z] ws connection error: CLOSE_ABNORMAL
      2instrument.ts:125 [2022-02-23T20:44:40.821Z] Reconnect is already running 5
      instrument.ts:125 [2022-02-23T20:44:46.804Z] Try to connect
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649086826&name=admin' failed:
      instrument.ts:125 [2022-02-23T20:44:47.882Z] Start reconnect 5
      instrument.ts:125 [2022-02-23T20:44:47.882Z] ws connection error: CLOSE_ABNORMAL
      instrument.ts:125 [2022-02-23T20:44:47.882Z] Reconnect is already running 5
      instrument.ts:125 [2022-02-23T20:44:53.805Z] Try to connect
      socket.io.js:94 WebSocket connection to 'wss://192.168.3.100:8081/?sid=1645649093828&name=admin' failed:
      instrument.ts:125 [2022-02-23T20:44:54.863Z] Start reconnect 5
      instrument.ts:125 [2022-02-23T20:44:54.863Z] ws connection error: CLOSE_ABNORMAL
      instrument.ts:125 [2022-02-23T20:44:54.863Z] Reconnect is already running 5
      instrument.ts:125 [2022-02-23T20:45:00.805Z] Try to connect
      sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7:1          Failed to load resource: the server responded with a status of 400 ()
      wendy2702 apollon77 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @e-i-k-e last edited by
        @e-i-k-e Habe ich auch hin und wieder. Ist bei mir nach reload der Seite dann immer erledigt
          e-i-k-e @wendy2702 last edited by
          @wendy2702
          Ist bei mir auch so.
            apollon77 @e-i-k-e last edited by
            @e-i-k-e Hat mit controller nix zu tun ... da sist wohl eher admin bzw das Javascriipt von Admin vs ein Admin restart
              apollon77 @gelberlemmy last edited by
              @gelberlemmy Ja log ist eindeutig. Auch um 20:30:42 wurde der Controller beendet. Frage ist nur warum ... wenn du es nicht warst dann schau mal ob in /var/log/syslog was dazu steht um diese Zeit, vllt ja RAM knapp?
              Und im Rahmen dieses "alles beenden" hat das SHelly wieder zu lange gebraucht. Also hier bei den Adaptern die solche DB closed werfen schauen ob es neuere Versionen gibt und die ggf probieren - sonst Issues anlegen
              lobomau gelberlemmy Diginix 3 Replies Last reply Reply Quote 1
              • lobomau
                lobomau @apollon77 last edited by
                @apollon77 ich habe gestern mein System geupdatet von 3.3.22 auf 4.0.15. Ich habe keine Probleme, scheint sogar etwas resourcenschonender zu sein.
                Ein Problem habe ich: ein slave ist ein Pi1 und hier bekomme nich so einfach node 12 installiert. Noch scheint es ja zu funktionieren. Aber wie lange noch oder kann das jetzt schon zu Problemen führen?
                Hier sieht man wie beim slave Pi3 die CPU-Temperatur zurückgegangen ist durch das Update des js-controllers von 58°C auf 55°C (jeweils tiefste Temperatur)
                Hosts:
                Thomas Braun lobomau 2 Replies Last reply Reply Quote 1
                  @lobomau sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                  was hast du da laufen ? 3 aktive instanzen ??
                    Thomas Braun Most Active @lobomau last edited by Thomas Braun
                    @lobomau
                    Beim P1 kannst du die unofficial Builds versuchen. Steht in meinem HowTo zu nodeJS als Sonderfall dabei. (Siehe meine Signatur)
                    • lobomau
                      lobomau @lobomau last edited by lobomau
                      @lobomau ioBrokerCT ist der Master, Pi3 und raspberrypi (Pi1) sind die slaves.
                      Edit: sorry... hatte es falsch verstanden... ja nur drei Instanzen auf dem Pi1.
                        arteck Developer Most Active @lobomau last edited by
                        ja was ... was läuft da ????
                        lobomau 1 Reply Last reply Reply Quote 0
                        • lobomau
                          lobomau @arteck last edited by
                          @arteck hauptsächlich geht es mir da nur um den smartmeter (wo ich jetzt auch nicht weiter updaten kann wegen nodejs 10.x) am Stromkasten. Zusätzlich läuft da noch RPI-Monitor und web-speedy.
                            @lobomau na das ist schon mal ne Aussage..
                            den smartmeter kannst du per ser2net anbinden dann brauchst du keine iobroker da laufen
                            mach ich auch so.. für einen adapter lohnt das nicht.. vor allem wenn das Pi1 ist
                            web-speedy kannst du auf den anderen host schieben
                              apollon77 @arteck last edited by
                              @arteck Offtopic hier 🙂
                              • gelberlemmy
                                gelberlemmy @apollon77 last edited by
                                @apollon77 danke für Deine Mühe. Zu wenig RAM kann nicht sein. Meine Maschine hat 6 GB. Ich werde es weiter verfolgen. Aktuell läuft alles ohne Probleme. Keine Ahnung was mein IOBroker dort hatte. Ich werde weiter beobachten. Noch einmal herzlichen Dank !
                                • Diginix
                                  Diginix @apollon77 last edited by
                                  @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                                  Wenn im Syslog auch der OOM Killer den js-controller beendet hat, könnte es ja ähnliche Ursachen wie bei meinen Auffälligkeiten sein. Dazu müsste @gelberlemmy ebenfalls mal den RAM und die in/out events vom js-controller loggen.
                                    Also für inzwischen ca. 3.400 Installationen einer controller 4.x (davon 2.000 auf der letzten 4.0.15) ist es hier sehr ruhig geworden 🙂
                                    Die Adapter Backitup, Node-Red und Admin sind inzwischen mit Ihren controller 4.0 optimierten Versionen auch im Stable Repository.
                                    Wenn also hier keiner mit einem guten Argument dagegen kommt geht der 4.0.15 Controller heute Abend ins Stable ...
                                    Thomas Braun O 2 Replies Last reply Reply Quote 4
                                      Thomas Braun Most Active @apollon77 last edited by
                                      @apollon77
                                      Wenn jemand der Anwesenden etwas gegen diese Veröffentlichung einzuwenden hat, möge er jetzt sprechen oder auf ewig schweigen.
                                      E amg_666 2 Replies Last reply Reply Quote 5
                                        Einstein67 @Thomas Braun last edited by
                                        @thomas-braun Jetzt hast du dich als "Standesbeamter" geoutet 😉
                                        • amg_666
                                          amg_666 @Thomas Braun last edited by
                                          @thomas-braun Also bei so ner Ansage schweige ich lieber 🙂
                                          Gruß von meinem sehr ruhigen 4.0.15 Controller
                                          • O
                                            oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
                                            @apollon77
                                            Kürzlich hatte ein anderer Entwickler in einem anderen Thread den 3.3.22 als "ALT" bezeichnet...
                                            Scheint also soweit zu sein...
                                            747
                                            171774
