    4. Test Adapter Tado v0.3.0-x (PreRelease)
      HGlab @Thomas Braun last edited by
      Die ein HOTWATER device haben, werden es wissen 😉
      Für die Interessierten - Es ist ein Tado-Device mit dem man die Warmwasseraufbereitung (Warmwasser = Hot Water) steuern kann. Du kannst ja mal mit deinem Wasserkocher versuchen zu duschen - wenn das klappt kannst dir ja überlegen ob du Tado nachrüstest 😛
        reeze @HGlab last edited by
        @hglab melde mich gerne, ich habe seit kurzen folgendes Problem:
        tado.0
        	2022-01-17 11:15:15.388	debug	state tado.0.114914.Rooms.0.setting.temperature.celsius changed: 65 (ack = false)
        tado.0
        	2022-01-17 11:15:15.388	debug	State change detected from different source than adapter
        tado.0
        	2022-01-17 11:15:15.387	error	Issue at setZoneOverlay: 'Error: Request failed with status code 422'. Based on config {"setting":{"type":"HOT_WATER","power":"ON"},"termination":{"typeSkillBasedApp":"MANUAL","durationInSeconds":null}}
        tado.0
        	2022-01-17 11:15:15.387	debug	API called with {"setting":{"type":"HOT_WATER","power":"ON"},"termination":{"typeSkillBasedApp":"MANUAL","durationInSeconds":null}}
        tado.0
        	2022-01-17 11:15:15.387	error	Error: Request failed with status code 422 with response {"errors":[{"code":"setting.notSupported","title":"temperature required"}]}
        tado.0
        	2022-01-17 11:15:15.236	debug	750ms queuing done [timer:'1149140']. API will be caled.
        tado.0
        	2022-01-17 11:15:14.461	debug	poolApiCall() entered for '114914/0'
        tado.0
        	2022-01-17 11:15:14.461	debug	Temperature changed for room '0' in home '114914' to '65'
        tado.0
        	2022-01-17 11:15:14.461	debug	VerticalSwing is: NOT_AVAILABLE
        tado.0
        	2022-01-17 11:15:14.461	debug	HorizontalSwing is: NOT_AVAILABLE
        tado.0
        	2022-01-17 11:15:14.461	debug	FanLevel is: NOT_AVAILABLE
        tado.0
        	2022-01-17 11:15:14.461	debug	FanSpeed is: NOT_AVAILABLE
        tado.0
        	2022-01-17 11:15:14.461	debug	Mode is: NOT_AVAILABLE
        tado.0
        	2022-01-17 11:15:14.461	debug	NextTimeBlockStart exists: true
        tado.0
        	2022-01-17 11:15:14.461	debug	DurationInSeconds is: 1800
        tado.0
        	2022-01-17 11:15:14.461	debug	Execution mode (typeSkillBasedApp) is: MANUAL
        tado.0
        	2022-01-17 11:15:14.461	debug	Temperature is: 65
        tado.0
        	2022-01-17 11:15:14.461	debug	Power is: OFF
        tado.0
        	2022-01-17 11:15:14.460	debug	Type is: HOT_WATER
        tado.0
        	2022-01-17 11:15:14.457	debug	Attribute 'tado.0.114914.Rooms.0.setting.temperature.celsius' changed. 'celsius' will be checked.
        tado.0
        	2022-01-17 11:15:14.457	debug	GETS INTERESSTING!!!
        Ich denke wir haben da schon mal vor einem halben Jahr dran rumgebastelt 🙂
          HGlab @reeze last edited by
          @reeze
          Hallo! Welche Adapter-Version nutzt du?
          Kannst du mir bitte mal unterhalb deines HOT_WATER Devices die Datenpunkte zu "Capabilities" in einen Screenshot packen? Danke!
            @hglab
            0.3.13
              @reeze
              Versuch es mal mit der 0.3.14-alpha.5
              Da sollte es bereits klappen
                @hglab
                ja klappt, danke
                  @reeze 👍
                    A Former User last edited by
                    ich meine, dass ich auch diesen Adapter für mein Tado habe.
                    Hab ich das nun richtig verstanden, dann ich bei einem Internetausfall, aber die Heizung nicht weiter steuern kann? Ich habe das Gefühl, dass mit der Brücke das ganze über den Online Dienst läuft. Ähnlich wie beim Nuki.
                    Bedeutet dies, wenn die Cloud in einigen Jahren ausgeschalter wird, oder durch den baldigen Börsengang von tado verändert wird, wir über ioBroker das dann nicht mehr verwenden können?
                    Oder hab ich das Tado Ding einfach nur falsch eingebunden? Hat es auch diretk ZigBee? Also muss ich das anders über die Deconz Antenne einbinden?
                    Ich hab auch die Ikea Schalter und keine Ikea Brücke.
                    Versteht ihr was ich meine?
                      @paul-ol sagte in Test Adapter Tado v0.3.0-x (PreRelease):
                      Nein, ist kein Zigbee.
                        pfahlenbauer @Thomas Braun last edited by
                        Ich bekomme neuerdings die folgende Fehlermeldung im Log (kommt alle paar Minuten). Kann da jemand helfen:
                        tado.0
                        2022-02-25 11:21:46.793	error	Disconnected from Tado cloud service ..., retry in 30 seconds !
                        tado.0
                        2022-02-25 11:21:46.791	error	Error in data refresh at step DoMobileDevices: Error: Client network socket disconnected before secure TLS connection was established
                        tado.0
                        2022-02-25 11:21:46.790	error	Error: Client network socket disconnected before secure TLS connection was established
                          K_o_bold @pfahlenbauer last edited by
                          Seit ein paar Tagen bekomme ich regelmäßig folgende errors:
                          tado.0
                          2022-09-21 20:20:31.681	info	Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
                          tado.0
                          2022-09-21 20:20:25.232	info	Connected to Tado cloud, initialyzing...
                          tado.0
                          2022-09-21 20:19:54.801	error	Disconnected from Tado cloud service ..., retry in 30 seconds !
                          tado.0
                          2022-09-21 20:19:54.796	error	Error in data refresh at step login: Error: Login failed! Please verify Username and Password
                          Nach kurzer Zeit verbindet sich der Adapter wieder mit der Tado Cloud und alles ist ok.
                          Hat jemand das gleiche Verhalten?
                          Adapter Version: 0.4.0
                          Thomas Braun H 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @K_o_bold last edited by
                            @k_o_bold
                            Das hatte ich eine zeitlang mit einer bestimmten Version von nodejs.
                            Wie bist du da aufgestellt?
                              K_o_bold @Thomas Braun last edited by
                              @thomas-braun ,
                              danke für die Rückmeldung. Hier meine Version...
                              node.js: 16.16.0
                              js-controller: 4.0.23
                                HGlab @K_o_bold last edited by
                                @k_o_bold
                                meiner Meinung nach liegt das an den Tado-Servern
                                  JayBa last edited by
                                  Kann man den Raumluftkomfort, ähnlich wie in der App, abgreifen? Also nicht die Einzelwerte sonder "zu warm", "feucht" etc. als schnelle Indikation.
                                  tado test v0.3.0
                                  10
                                  67
                                  5555
