    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      guergen @DJMarc75 last edited by guergen
      Ich habe grade ein update eingespielt, seither geht hier gar nix mehr mit parcel...
      Bin grade bis zur Version 0.0.3 zurück.
      js-controller: 4.0.15
      node.js: 14.19.0
      npm: 6.14.16
      parcel: 0.0.8
      Fehlermeldung ist:
      host.iob | 2022-02-25 16:53:57.858 | error | instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iob | 2022-02-25 16:53:57.858 | error | Caught by controller[0]: }
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:101:18)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:974:19)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]: was compiled against a different Node.js version using
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
      host.iob | 2022-02-25 16:53:57.857 | error | Caught by controller[0]:                  ^
      host.iob | 2022-02-25 16:53:57.856 | error | Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
      host.iob | 2022-02-25 16:53:57.856 | error | Caught by controller[0]: internal/modules/cjs/loader.js:1144
      Thomas Braun T 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @guergen last edited by Thomas Braun
        @guergen sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
        Von was auf was?
        canvas.node muss offenbar neugebaut werden.
          tombox @guergen last edited by
          @guergen ja ein paket hat leider ein rebuild problem
          /opt/iobroker
          npm install canvas
          • Christoph1337
            Christoph1337 @DJMarc75 last edited by
            @djmarc75 super Idee!
            • DJMarc75
              @tombox
              eben entdeckt im Log - betrifft wieder Hermes
              parcel.0
              	2022-02-25 17:19:07.166	error	TypeError: Cannot create property 'id' on string '['
                tombox @DJMarc75 last edited by
                @djmarc75 Installier mal die letzte version dann sollte mehr log vorhanden sein
                Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @tombox last edited by
                  @tombox
                  Wann wird eigentlich der DP 'indelivery' wieder genullt?
                  Im Moment hab ich da eine erfolgreiche Lieferung von Amazon von heute drin.
                    tombox @Thomas Braun last edited by
                    @thomas-braun wenn der status keiner der strings enthält
                    "in zustellung") ||
                    "zustellung heute") ||
                    "heute zugestell") ||
                    "wird zugestellt") ||
                    "zustellfahrzeug")
                    • DJMarc75
                      DJMarc75 @tombox last edited by DJMarc75
                      @tombox said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      parcel.0
                      	2022-02-26 05:44:03.526	error	{"code":501,"message":"Ungültiges Authentifizierungstoken im HTTP Header."}
                      parcel.0
                      	2022-02-26 05:44:03.525	error	Error: Request failed with status code 403
                      parcel.0
                      	2022-02-26 05:44:03.523	error	https://mobile-api.myhermes.de/mobile-api-web/v2/shipments
                      andere Meldungen kamen bisher nicht
                        Tschaeens @tombox last edited by
                        @tombox
                        Ich würde gern bei DHL Briefankündigung das base64 image per Synology Chat verschicken. Wie kann ich das base64 in ein jpg nach iobroker holen? Vielleicht hast du eine Idee?
                        Lieben Gruß
                          guergen @Thomas Braun last edited by guergen
                          @thomas-braun natürlich den parcel-Adapter von 0.0.7 auf 0.0.8.
                          Nach dem update (vermutlich) auf die neuste canva-Version, ich glaube ich hatte was von 2.9 irgendwas im Augenwinkel, geht es jetzt wieder
                          • DJMarc75
                            DJMarc75 last edited by DJMarc75
                            jetzt eben folgende Fehler im LOG gesehen....
                            parcel.0
                            	2022-02-26 14:45:46.429	error	{"httpCode":"404","httpMessage":"Not Found","moreInformation":"The requested URL was not found on this server"}
                            parcel.0
                            	2022-02-26 14:45:46.428	error	Error: Request failed with status code 404
                            parcel.0
                            	2022-02-26 14:45:46.427	error	https://onlinetools.ups.com/mychoice/v1/shipments/details/AddressToken?loc=de_DE
                            parcel.0
                            	2022-02-26 14:35:49.044	error	[ { "shipmentId" : "H1025380036636802050", "type" : "IN_MANUALLY", "description" : "Kissenbezug", "creationDate" : "24.02.2022", "lastModified" : "2022-02-25T11:29:05.000+01:00", "lastStatusId" : "5", "lastStatusMessage" : "Die Sendung wurde zugestellt. ", "lastStatusDate" : "25.02.2022", "receiver" : { }, "sender" : { "lastname" : "Amazon (POZ2)" }, "deliveryForecast" : { "deliveryDate" : "25.02.2022", "deliveryTimeTo" : "13:15", "deliveryTimeFrom" : "10:15", "specialService" : false }, "statusHistory" : [ { "id" : "90-1-4", "date" : "2022-02-25T11:29:05+01:00", "message" : "Die Sendung wurde zugestellt. " }, { "id" : "50-1-3", "date" : "2022-02-25T07:20:18+01:00", "message" : "Die Sendung befindet sich in der Zustellung." }, { "id" : "45-5-3", "date" : "2022-02-25T00:34:57+01:00", "message" : "Die Sendung ist im Hermes Verteilzentrum LC Bad Rappenau (2367) eingetroffen." }, { "id" : "30-0-6", "date" : "2022-02-25T00:34:57+01:00", "message" : "Die Sendung wurde im Hermes Logistikzentrum sortiert." }, { "id" : "30-0-6", "date" : "2022-02-24T12:20:55+01:00", "message" : "Die Sendung wurde im Hermes Logistikzentrum sortiert." }, { "id" : "0-0-0", "date" : "2022-02-24T04:53:04+01:00", "message" : "Die Sendung wurde Hermes elektronisch angekündigt." } ], "bookable" : { } }, { "shipmentId" : "H1026150003886201050", "type" : "IN_MANUALLY", "description" : "Stichsäge", "creationDate" : "23.02.2022", "lastModified" : "2022-02-24T12:00:57.000+01:00", "lastStatusId" : "5", "lastStatusMessage" : "Die Sendung wurde zugestellt. ", "lastStatusDate" : "24.02.2022", "receiver" : { }, "sender" : { "lastname" : "Amazon Flat (VEVI)" }, "deliveryForecast" : { "deliveryDate" : "24.02.2022", "deliveryTimeTo" : "13:20", "deliveryTimeFrom" : "10:20", "specialService" : false }, "statusHistory" : [ { "id" : "90-1-4", "date" : "2022-02-24T12:00:57+01:00", "message" : "Die Sendung wurde zugestellt. " }, { "id" : "50-1-3", "date" : "2022-02-24T07:19:10+01:00", "message" : "Die Sendung befindet sich in der Zustellung." }, { "id" : "45-5-3", "date" : "2022-02-24T01:16:44+01:00", "message" : "Die Sendung ist im Hermes Verteilzentrum LC Bad Rappenau (2367) eingetroffen." }, { "id" : "30-0-6", "date" : "2022-02-24T01:16:44+01:00", "message" : "Die Sendung wurde im Hermes Logistikzentrum sortiert." }, { "id" : "30-0-6", "date" : "2022-02-23T15:46:12+01:00", "message" : "Die Sendung wurde im Hermes Logistikzentrum sortiert." }, { "id" : "0-0-0", "date" : "2022-02-23T14:54:05+01:00", "message" : "Die Sendung wurde Hermes elektronisch angekündigt." } ], "bookable" : { } }, { "shipmentId" : "H1022590109235201050", "type" : "IN_MANUALLY", "description" : "Meine Sendung", "creationDate" : "07.01.2022", "lastModified" : "2022-01-08T17:00:58.000+01:00", "lastStatusId" : "5", "lastStatusMessage" : "Die Sendung wurde zugestellt. ", "lastStatusDate" : "08.01.2022", "receiver" : { }, "sender" : { "lastname" : "Amazon DI (DTM8)" }, "deliveryForecast" : { "deliveryDate" : "08.01.2022", "deliveryTimeTo" : null, "deliveryTimeFrom" : null, "specialService" : false }, "statusHistory" : [ { "id" : "90-1-4", "date" : "2022-01-08T17:00:58+01:00", "message" : "Die Sendung wurde zugestellt. " }, { "id" : "50-1-2", "date" : "2022-01-08T10:15:12+01:00", "message" : "Die Sendung befindet sich in der Zustellung." }, { "id" : "45-5-3", "date" : "2022-01-08T01:03:29+01:00", "message"
                            parcel.0
                            	2022-02-26 14:35:49.037	error	TypeError: Cannot create property 'id' on string '['
                            edit: bei UPS scheint es wohl momentan Probleme zu geben, daher die Meldung im LOG Zeile 1 bis 6 ignorieren !
                            • haselchen
                              haselchen Most Active @DJMarc75 last edited by
                              @tombox
                              Hab mich jetzt auch mal an deinen hammergeilen Adapter gewagt 🙂
                              Fetter Daumen hoch dafür!!
                              Little Question.
                              Ich habe mal mit Amazon angefangen.
                              Dort steht nun heute bestellt.....
                              Wie bekomme ich das Bestelldatum ?
                              Möchte das zusammengeklöppelt in der VIS abbilden.
                              • DJMarc75
                                DJMarc75 @haselchen last edited by
                                @haselchen said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                Das Bestelldatum wird von Amazon als solches (noch?) nicht in den Adapter übertragen.
                                Im Moment würden nur Hilfsvariablen (eigene Datenpunkte) in Verbindung mit Blocklys helfen.
                                • haselchen
                                  haselchen Most Active @DJMarc75 last edited by haselchen
                                  @djmarc75
                                  Danke für die Info!
                                  ich tue mich ein wenig schwer mit der Visualisierung von DHL.
                                  Dort wird leider nicht so schön alles aufgeführt wie bei Amazon.
                                  Wie bekomme ich das Bestellte in einen Datenpunkt?
                                  Und die Prognose für die Zustellung?
                                  DJMarc75 T 2 Replies Last reply Reply Quote 0
                                  • DJMarc75
                                    @haselchen
                                    bei DHL wird es nur sehr viel detailierter im Adapter dargestellt. Das macht es halt komplizierter bei der Darstellung in VIS. Ich habe so einige Blocklys schreiben müssen um dies in meiner VIS einigermaßen vernünftig darstellen zu können.
                                    Da der Adapter aber noch in der Testphase ist macht es wenig Sinn eine "finale" VIS mit Blocklys zu erstellen. Ich bin jeden Tag am Tüffteln 😰
                                      tombox @haselchen last edited by tombox
                                      @haselchen Amazon hat jetzt noch detailierte Information erstmal schauen ob man daraus was ableiten kann aber man kann jetzt exakter sagen ob das paket delivered ist. Ein Bestelldatum sehe ich direkt nicht
                                      haselchen 1 Reply Last reply Reply Quote 1
                                      • haselchen
                                        haselchen Most Active @tombox last edited by
                                        @tombox
                                        Hab gerade nen Knoten in der Birne.
                                        Wie kriege ich das hin das ich das Bestelldatum als Datenpunkt bekomme ?
                                        @DJMarc75
                                        Magst du zeigen wie Du die DHL Infos bzw Sendungsverfolgung realisiert hast?
                                        T DJMarc75 2 Replies Last reply Reply Quote 0
                                          @haselchen Bisher ist das nicht drin warum brauchst du das genau?
                                          • haselchen
                                            @tombox
                                            Verständnishalber.
                                            Bei mir steht , heute bestellt , Zustellung Donnerstag.
                                            Dadurch weiß ich aber nicht welcher Tag „heute“ ist/war.
                                            Die Bestellung war am 25.02.
                                            Das Wort Heute steht heute auch noch drin.
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            525740
