    4. js-controller 4.0.x jetzt für alle User im STABLE!
      TDCroPower last edited by
      Update des js-controllers auf dem Docker Image von buanet ist durch, lediglich der rebuild vom BLE Adapter läuft bei 3 Versuchen nicht durch und im Log sieht man jetzt folgendes...
      host.helios64
      2022-02-26 12:48:17.793	info	Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.helios64
      2022-02-26 12:48:17.792	info	instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
      wenn ich den Befehl in der Konsole eingebe kommt folgendes...
      root@helios64:/opt/iobroker# npm install --production
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
      removed 3 packages and updated 1 package in 34.934s
      137 packages are looking for funding
        run `npm fund` for details
      was nun !?
      • andiko2
        andiko2 @tobrog last edited by
        @tobrog said in js-controller 4.0.x jetzt für alle User im STABLE!:
        adapter.getObjectList
        Dankeschön. Genau diese Info hat geholfen.
          apollon77 @TDCroPower last edited by
          @tdcropower Naja du solltest den "npm install" in einem bestimmten Verzeichnis ausführen - steht an sich in den Anweisungen im Log. Du hast es im iobroker "root" verzeichnis ausgeführt. Das hilft nicht, ja.
          Du musst es in /opt/iobroker/node_modules/iobroker.ble ausführen
          Und ja leider ist der BLE Adapter bze eine Library davon gerade nicht rebuild-fähig. Wir haben dort schon eine Änderung eingereicht, die ist aber noch nicht released.
            TDCroPower @apollon77 last edited by
            @apollon77 danke habe es eben auch im Issue bei git gelesen.
            Leider fehlt der Hinweis auf das Verzeichnis in der Log Nachricht, wobei "adapter directory" es eigentlich sagt.
            Naja, jetzt hat es funktioniert...
            root@helios64:/opt/iobroker# cd node_modules/iobroker.ble/
            root@helios64:/opt/iobroker/node_modules/iobroker.ble# npm install -- production
            npm WARN deprecated request@2.12.0: request has been deprecated, see https://github.com/request/request/issues/3142
            > deasync@0.1.24 install /opt/iobroker/node_modules/iobroker.ble/node_modules/deasync
            > node ./build.js
            make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/deasync/build'
              CXX(target) Release/obj.target/deasync/src/deasync.o
              SOLINK_MODULE(target) Release/obj.target/deasync.node
              COPY Release/deasync.node
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/deasync/build'
            Installed in `/opt/iobroker/node_modules/iobroker.ble/node_modules/deasync/bin/linux-arm64-node-14/deasync.node`
            > usb@1.9.2 install /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
            > node-gyp-build
            make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
              CC(target) Release/obj.target/libusb/libusb/libusb/core.o
              CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
              CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
              CC(target) Release/obj.target/libusb/libusb/libusb/io.o
              CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
              CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
              CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
              CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
              CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
              CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
              AR(target) Release/obj.target/usb.a
              COPY Release/usb.a
              CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
            ../src/node_usb.cc: In function ‘Napi::Value SetDebugLevel(const Napi::CallbackInfo&)’:
            ../src/node_usb.cc:118:71: warning: ‘void libusb_set_debug(libusb_context*, int)’ is deprecated: Use libusb_set_option instead [-Wdeprecated-declarations]
              118 |  libusb_set_debug(usb_context, info[0].As<Napi::Number>().Int32Value());
            In file included from ../src/node_usb.h:11,
                             from ../src/node_usb.cc:1:
            ../libusb/libusb/libusb.h:1325:18: note: declared here
             1325 | void LIBUSB_CALL libusb_set_debug(libusb_context *ctx, int level);
              CXX(target) Release/obj.target/usb_bindings/src/device.o
              CXX(target) Release/obj.target/usb_bindings/src/transfer.o
              SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
              COPY Release/usb_bindings.node
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
            > @abandonware/bluetooth-hci-socket@0.5.3-8 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
            > node-pre-gyp install --fallback-to-build
            node-pre-gyp ERR! install response status 404 Not Found on https://github.com/abandonware/node-bluetooth-hci-socket/releases/download/0.5.3-8/bluetooth_hci_socket-0.5.3-8-node-v83-linux-arm64.tar.gz
            node-pre-gyp WARN Pre-built binaries not installable for @abandonware/bluetooth-hci-socket@0.5.3-8 and node@14.18.2 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
            node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/abandonware/node-bluetooth-hci-socket/releases/download/0.5.3-8/bluetooth_hci_socket-0.5.3-8-node-v83-linux-arm64.tar.gz
            make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/build'
              CXX(target) Release/obj.target/bluetooth_hci_socket/src/BluetoothHciSocket.o
            In file included from /opt/iobroker/.cache/node-gyp/14.18.2/include/node/node_buffer.h:25,
                             from ../src/BluetoothHciSocket.cpp:7:
            /opt/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
              787 |       (node::addon_register_func) (regfunc),                          \
            /opt/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
              821 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/BluetoothHciSocket.cpp:635:1: note: in expansion of macro ‘NODE_MODULE’
              635 | NODE_MODULE(binding, BluetoothHciSocket::Init);
            ../src/BluetoothHciSocket.cpp: In member function ‘int BluetoothHciSocket::kernelDisconnectWorkArounds(int, char*)’:
            ../src/BluetoothHciSocket.cpp:401:1: warning: control reaches end of non-void function [-Wreturn-type]
              401 | }
              SOLINK_MODULE(target) Release/obj.target/bluetooth_hci_socket.node
              COPY Release/bluetooth_hci_socket.node
              COPY /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node
              TOUCH Release/obj.target/action_after_build.stamp
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/build'
            > @abandonware/noble@1.9.2-15 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
            > node-gyp rebuild
            make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
              SOLINK_MODULE(target) Release/obj.target/noble.node
              COPY Release/noble.node
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
            > core-js@2.6.12 postinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/core-js
            > node -e "try{require('./postinstall')}catch(e){}"
            Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
            The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
            > https://opencollective.com/core-js
            > https://www.patreon.com/zloirock
            Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
            > parcel-bundler@1.12.5 postinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/parcel-bundler
            > node -e "console.log('\u001b[35m\u001b[1mLove Parcel? You can now donate to our open collective:\u001b[22m\u001b[39m\n > \u001b[34mhttps://opencollective.com/parcel/donate\u001b[0m')"
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/@parcel/watcher/node_modules/fsevents):
            + production@0.0.2
            added 1489 packages from 1205 contributors in 146.424s
            109 packages are looking for funding
            .. danach nur noch den Adapter neustarten und er ist wieder Grün!
            mikeal created this issue in request/request
            open Request’s Past, Present and Future #3142
            ? apollon77 2 Replies Last reply Reply Quote 1
              A Former User @TDCroPower last edited by
              @tdcropower
              mit root geht es mit nodejs nicht gut!
                @tdcropower Jupp. Jetzt am besten ein „iob fix“ hinterher und dann am besten nicht mehr mit root
                  @apollon77 ihr habt Recht, im Docker Image gibt es noch einen iobroker user auf dem iobroker installiert wurde.
                  iobroker@helios64:~$ ls -l
                  total 1132
                  drwxrwxr-x+   3 iobroker iobroker    4096 Feb 26 02:30 backups
                  -rwxrwxrwx+   1 iobroker iobroker     233 Nov 23 16:15 INSTALLER_INFO.txt
                  lrwxrwxrwx    1 iobroker iobroker      22 Nov 23 16:15 iob -> /opt/iobroker/iobroker
                  -rwxr-xr-x+   1 iobroker iobroker     178 Feb 26 12:56 iobroker
                  -rwxr-xr-x+   1 iobroker iobroker     178 Feb 26 12:40 iobroker.bak
                  drwxrwxr-x+  10 iobroker iobroker    4096 Feb 26 14:20 iobroker-data
                  drwxrwxr-x+   2 iobroker iobroker    4096 Feb 26 13:30 log
                  drwxrwxr-x+ 621 iobroker iobroker   20480 Feb 26 12:51 node_modules
                  -rw-rwxr--+   1 iobroker iobroker     864 Feb 26 12:39 package.json
                  -rw-rwxr--+   1 iobroker iobroker 1098042 Feb 26 12:51 package-lock.json
                  -rw-rwxr--+   1 iobroker iobroker    5693 Dez 23 01:16 reinstall.js
                  Dann bleibt der default Portainer User root wieder weg.
                    Etbron last edited by
                    Ich habe gerade das Update nach Anleitung gemacht. Leider ist wohl ein Fehler aufgetreten, jetzt scheint mein ioBroker tot zu sein. Da ich Linux-mäßig leider Laie bin, fehlt mir jetzt ehrlich gesagt die Idee, wie ich am besten mit einer Reparatur anfangen kann.
                    tlettschmidt@iobroker:~$ iob upgrade self
                    Update js-controller from @3.3.22 to @4.0.15
                    NPM version: 6.14.16
                    npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                    In file included from ../../nan/nan.h:58,
                                     from ../src/unix_dgram.cc:5:
                    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                      793 |       (node::addon_register_func) (regfunc),                          \
                    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                      827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                      404 | NODE_MODULE(unix_dgram, Initialize)
                    Server Objects 127.0.0.1:41698 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                    Server States 127.0.0.1:56264 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                    Server Objects 127.0.0.1:41698 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                    Server States 127.0.0.1:56268 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                    Server Objects 127.0.0.1:41698 Error from InMemDB: Error: Unknown LUA script load
                    Server Objects 127.0.0.1:41698 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                    Bin für jede Anregung und jeden Tipp dankbar.
                      Etbron @Etbron last edited by
                      Schnappatmung hat sich ein wenig beruhigt. Ich habe ihn nochmal gestoppt, nochmal gestartet und scheinbar läuft er jetzt. Trotzdem wäre es schön, wenn sich jemand den Fehler anschauen würde und mir ein kurzes Feedback geben könnte, ob ich jetzt ein problem habe bzw. bekommen werde.
                        @tdcropower ok da bin ich ehrlich. Keine Ahnung. An sich sollte man nicht mit dem iobroker User arbeiten. @andre ?! Wie ist das bei Docker am besten?!
                          apollon77 @Etbron last edited by
                          @etbron das ist alles ok. Ließ doch mal gaaaaanz oben im ersten post. Da steht alles drin. Diese Meldungen sind erwartet gewesen und daher voll normal. Jaaaanz ruhig
                            Etbron @apollon77 last edited by
                            @apollon77 Danke. Die Ich hatte das Post gesehen - und hätte mir auch keine Sorgen gemacht, wenn der ioBroker nach dem Update direkt wieder erreichbar gewesen wäre. Vielen Dank für die schnelle Antwort und beruhigenden Worte 🙂
                              erfggi last edited by
                              Mein Update war erfolgreich auf dem Master (Proxmox VM) und auf dem Slave (RaspberryPi4 mit Deconz2 UsbStick) Läuft alles seit 4h ohne Probleme.
                              • Rene55
                                Rene55 last edited by
                                Mein ioBroker läuft als Docker-Container. Beim Aufruf des 'iob upgrade self' bekomme ich den Fehler 'sudo: unable to execute /usr/bin/node: Operation not permitted'. Gibt es für Docker-User hier was besonderes zu beachten?
                                Ben1983 apollon77 2 Replies Last reply Reply Quote 0
                                • Ben1983
                                  Ben1983 @Rene55 last edited by
                                  @rene55 mein iobroker läuft unter Windows.
                                  Muss mal hier wirklich den installer eine neue Instanz installieren lassen, oder lediglich in der console ein upgrade Self ausführen?
                                  Kann mir jemand beschreiben, wie ich das ubter Windows hoch ziehe? Stehe komplett im dunklen.
                                    apollon77 @Ben1983 last edited by
                                    @ben1983 zu Windows am besten im ersten post schauen. Da ist ein link zu einer Anleitung von @sigi234 … ggf dann dort bitte fragen.
                                      apollon77 @Rene55 last edited by
                                      @rene55 @andre an advice? Danke. An sich sollte das doch direkt tun….
                                      • Latzi
                                        Latzi @apollon77 last edited by
                                        @apollon77 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                        Du hast ne alte mongodb lib wohl von nem node-red. Liegt eher an nodejs 14+ als am Controller.
                                        @apollon77 ich bekomm die mongodb lib nicht weg, gibt es noch einen anderen Weg oder hab ich da was falsch gemacht?
                                        pi@Pi4-Server:/opt/iobroker $ npm uninstall mongodb
                                        npm ERR! code ELOOP
                                        npm ERR! syscall open
                                        npm ERR! path /opt/iobroker/node_modules/xml2js/package.json
                                        npm ERR! errno -40
                                        npm ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/xml2js/package.json'
                                        • Ben1983
                                          Ben1983 @apollon77 last edited by
                                          @apollon77 meine Frage bezieht sich ja auf die Anleitung.
                                          Verstehe die nicht.
                                          Da steht bei Update neu aufsetzen???
                                          Siggi habe ich im Discord angeschrieben.
                                            apollon77 @Latzi last edited by
                                            @latzi da meckert npm über andere komische Dinge in deinem node_modules. Du kannst das dir mal löschen was er anmeckert aber dann fehlt ein Paket. Wenn also danach ein Adapter nicht geht (bei dem Paket zb shelly u.a.) musst du den Adapter Dannie installieren. Da musst du mal googeln Bzw sollte man außerhalb diese threads diskutieren.
                                            501
                                            138347
