    4. Fehler beim Backup
    • Neues Video auf YouTube
    Fehler beim Backup
      Thomas Braun Most Active @sebaboehm last edited by
      @sebaboehm Das ist ja auch der normale user, der verwendet wird.
      iobroker stop
      iobroker fix
      iobroker update -i
      iobroker upgrade
      iobroker start
      sagt jetzt?
        sebaboehm @Thomas Braun last edited by
        Fix läuft durch
        Update -I auf slave:
        No connection to databases possible ...
        Update -I auf Master:
        Used repository: Stable (default)
        hash unchanged, use cached sources
        update done
        Adapter "admin" : 5.3.1 , installed 5.3.1
        Adapter "alarm" : 3.0.5 , installed 3.0.5
        Adapter "alexa2" : 3.11.2 , installed 3.11.2
        Adapter "backitup" : 2.3.3 , installed 2.3.3
        Adapter "cloud" : 4.1.0 , installed 4.1.0
        Adapter "deconz" : 1.3.19 , installed 1.3.19
        Adapter "devices" : 1.0.9 , installed 1.0.9
        Adapter "discovery" : 2.7.5 , installed 2.7.5
        Adapter "dwd" : 2.7.7 , installed 2.7.7
        Adapter "email" : 1.0.10 , installed 1.0.10
        Adapter "harmony" : 1.2.2 , installed 1.2.2
        Adapter "history" : 1.10.5 , installed 1.10.5
        Adapter "hm-rega" : 3.0.35 , installed 3.0.35
        Adapter "hm-rpc" : 1.15.0 , installed 1.15.0
        Adapter "ical" : 1.11.4 , installed 1.11.4
        Adapter "info" : 1.9.8 , installed 1.9.8
        Adapter "iot" : 1.8.24 , installed 1.8.24
        Adapter "jarvis" : 3.0.11 , installed 3.0.11
        Adapter "javascript" : 5.2.21 , installed 5.2.21
        Controller "js-controller" : 4.0.15 , installed 3.3.22 [Updateable]
        Adapter "mihome" : 1.3.7 , installed 1.3.7
        Adapter "mihome-vacuum" : 3.3.1 , installed 3.3.1
        Adapter "mobile" : 1.0.1 , installed 1.0.1
        Adapter "pushover" : 2.0.5 , installed 2.0.5
        Adapter "ring" : 1.2.8 , installed 1.2.8
        Adapter "rpi2" : 1.3.1 , installed 1.3.1
        Adapter "samsung" : 0.2.9 , installed 0.2.9
        Adapter "scenes" : 2.3.8 , installed 2.3.8
        Adapter "simple-api" : 2.6.2 , installed 2.6.2
        Adapter "socketio" : 3.1.5 , installed 3.1.5
        Adapter "telegram" : 1.11.1 , installed 1.11.1
        Adapter "text2command" : 2.1.1 , installed 2.1.1
        Adapter "tr-064" : 4.2.15 , installed 4.2.15
        Adapter "trashschedule" : 1.4.1 , installed 1.4.1
        Adapter "vis" : 1.4.5 , installed 1.4.5
        Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
        Adapter "vis-hqwidgets" : 1.1.9 , installed 1.1.9
        Adapter "vis-timeandweather": 1.1.7 , installed 1.1.7
        Adapter "vw-connect" : 0.0.48 , installed 0.0.48
        Adapter "weatherunderground": 3.3.1 , installed 3.3.1
        Adapter "web" : 3.4.16 , installed 3.4.16
        Adapter "whatsapp-cmb" : 0.1.6 , installed 0.1.6
        Adapter "worx" : 1.5.5 , installed 1.5.5
        Adapter "zigbee" : 1.6.16 , installed 1.6.16
        pi@ioBroker-RasPi4-8GB:~ $
        ioBroker upgrade auf Slave:
        ioBroker Upgrade auf Master:
        All adapters are up to date
        Thomas Braun S 2 Replies Last reply Reply Quote 0
          @sebaboehm sagte in Fehler beim Backup:
          Richte den slave nochmal ein. Der kommt nicht an die Datenbank des Masters.
            sebaboehm @sebaboehm last edited by
            @sebaboehm said in Fehler beim Backup:
            Fix läuft durch
            Update -I auf Slave:
            update done
            ioBroker upgrade auf Master:
              @sebaboehm
              Bitte Aktionen in der Konsole vollständig (inkl. Eingabezeile und login prompt) in CodeTags posten.
                Ja, das habe ich bereis versucht.
                States und Objects sind in redis.
                Das Problem ist ja auch, das der Master an die auch nicht ran kommt.
                  @sebaboehm
                  iobroker status
                  auf beiden Systemen.
                    CodeTags?
                      Slave
                      Master
                        @sebaboehm
                        CodeTags machen so eine Ausgabe.
                          @thomas-braun wenn du mir sagst wie das geht, mache ich das gerne 🙂
                          S Thomas Braun 2 Replies Last reply Reply Quote 0
                            @sebaboehm ```
                            code_text
                            pi@ioBroker-RasPi4-8GB:~ $ iobroker start
                            pi@ioBroker-RasPi4-8GB:~ $ iobroker status
                            Objects type: file
                            States  type: file
                              @sebaboehm
                              ? Hab dir sogar bunte Bildchen gemacht.
                              Das gelb hinterlegte Icon anklicken. Text zwischen die Steuerzeichen kopieren, fertig.
                                ja sorry, hab es jetzt gesehen und verstanden 🙂
                                  Also nochmal:
                                  Master
                                  Objects type: file
                                  States  type: file
                                  Slave
                                  pi@ioBroker-RasPi-Slave-AiO:~ $ iobroker status
                                  At least one iobroker host is running.
                                  Objects type: file
                                  States  type: file
                                    @sebaboehm
                                    Nein, die sind jeweils in file/file
                                      das wäre mir neu. Irgendwas stimmt hier anscheinend nicht.
                                      Aber kann es damit zusammenhängen das sowohl der Master als auch der Slave da nicht ran kommt?
                                        @sebaboehm
                                        Kommen Sie schon. Sonst sähe die Meldung zu
                                        iobroker status
                                        anders aus.
                                        Ich vermute, da ist der MultiHost-Modus nicht richtig eingerichtet. Mach das doch nochmal.
                                          i@ioBroker-RasPi-Slave-AiO:~ $ sudo systemctl status redis-server
                                          ● redis-server.service - Advanced key-value store
                                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                             Active: active (running) since Sat 2022-02-26 10:52:29 CET; 5h 57min ago
                                               Docs: http://redis.io/documentation,
                                                     man:redis-server(1)
                                           Main PID: 607 (redis-server)
                                              Tasks: 4 (limit: 4915)
                                             CGroup: /system.slice/redis-server.service
                                                     └─607 /usr/bin/redis-server 127.0.0.1:6379
                                          Feb 26 10:52:28 ioBroker-RasPi-Slave-AiO systemd[1]: Starting Advanced key-value store...
                                          Feb 26 10:52:29 ioBroker-RasPi-Slave-AiO systemd[1]: redis-server.service: Can't open PID file /run/redis/redis-server.pid (yet?) after start:
                                          Feb 26 10:52:29 ioBroker-RasPi-Slave-AiO systemd[1]: Started Advanced key-value store.
                                            @sebaboehm
                                            Das der redis-Server läuft heißt ja nicht, dass er auch von ioBroker benutzt wird.
                                            1899
