    4. js-controller 4.0.x jetzt für alle User im STABLE!
      TDCroPower @apollon77 last edited by
      @apollon77 danke habe es eben auch im Issue bei git gelesen.
      Leider fehlt der Hinweis auf das Verzeichnis in der Log Nachricht, wobei "adapter directory" es eigentlich sagt.
      Naja, jetzt hat es funktioniert...
      root@helios64:/opt/iobroker# cd node_modules/iobroker.ble/
      root@helios64:/opt/iobroker/node_modules/iobroker.ble# npm install -- production
      npm WARN deprecated request@2.12.0: request has been deprecated, see https://github.com/request/request/issues/3142
      > deasync@0.1.24 install /opt/iobroker/node_modules/iobroker.ble/node_modules/deasync
      > node ./build.js
      make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/deasync/build'
        CXX(target) Release/obj.target/deasync/src/deasync.o
        SOLINK_MODULE(target) Release/obj.target/deasync.node
        COPY Release/deasync.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/deasync/build'
      Installed in `/opt/iobroker/node_modules/iobroker.ble/node_modules/deasync/bin/linux-arm64-node-14/deasync.node`
      > usb@1.9.2 install /opt/iobroker/node_modules/iobroker.ble/node_modules/usb
      > node-gyp-build
      make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
        CC(target) Release/obj.target/libusb/libusb/libusb/core.o
        CC(target) Release/obj.target/libusb/libusb/libusb/descriptor.o
        CC(target) Release/obj.target/libusb/libusb/libusb/hotplug.o
        CC(target) Release/obj.target/libusb/libusb/libusb/io.o
        CC(target) Release/obj.target/libusb/libusb/libusb/strerror.o
        CC(target) Release/obj.target/libusb/libusb/libusb/sync.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/poll_posix.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/threads_posix.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_usbfs.o
        CC(target) Release/obj.target/libusb/libusb/libusb/os/linux_udev.o
        AR(target) Release/obj.target/usb.a
        COPY Release/usb.a
        CXX(target) Release/obj.target/usb_bindings/src/node_usb.o
      ../src/node_usb.cc: In function ‘Napi::Value SetDebugLevel(const Napi::CallbackInfo&)’:
      ../src/node_usb.cc:118:71: warning: ‘void libusb_set_debug(libusb_context*, int)’ is deprecated: Use libusb_set_option instead [-Wdeprecated-declarations]
        118 |  libusb_set_debug(usb_context, info[0].As<Napi::Number>().Int32Value());
      In file included from ../src/node_usb.h:11,
                       from ../src/node_usb.cc:1:
      ../libusb/libusb/libusb.h:1325:18: note: declared here
       1325 | void LIBUSB_CALL libusb_set_debug(libusb_context *ctx, int level);
        CXX(target) Release/obj.target/usb_bindings/src/device.o
        CXX(target) Release/obj.target/usb_bindings/src/transfer.o
        SOLINK_MODULE(target) Release/obj.target/usb_bindings.node
        COPY Release/usb_bindings.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/usb/build'
      > @abandonware/bluetooth-hci-socket@0.5.3-8 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! install response status 404 Not Found on https://github.com/abandonware/node-bluetooth-hci-socket/releases/download/0.5.3-8/bluetooth_hci_socket-0.5.3-8-node-v83-linux-arm64.tar.gz
      node-pre-gyp WARN Pre-built binaries not installable for @abandonware/bluetooth-hci-socket@0.5.3-8 and node@14.18.2 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/abandonware/node-bluetooth-hci-socket/releases/download/0.5.3-8/bluetooth_hci_socket-0.5.3-8-node-v83-linux-arm64.tar.gz
      make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/build'
        CXX(target) Release/obj.target/bluetooth_hci_socket/src/BluetoothHciSocket.o
      In file included from /opt/iobroker/.cache/node-gyp/14.18.2/include/node/node_buffer.h:25,
                       from ../src/BluetoothHciSocket.cpp:7:
      /opt/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        787 |       (node::addon_register_func) (regfunc),                          \
      /opt/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
        821 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/BluetoothHciSocket.cpp:635:1: note: in expansion of macro ‘NODE_MODULE’
        635 | NODE_MODULE(binding, BluetoothHciSocket::Init);
      ../src/BluetoothHciSocket.cpp: In member function ‘int BluetoothHciSocket::kernelDisconnectWorkArounds(int, char*)’:
      ../src/BluetoothHciSocket.cpp:401:1: warning: control reaches end of non-void function [-Wreturn-type]
        401 | }
        SOLINK_MODULE(target) Release/obj.target/bluetooth_hci_socket.node
        COPY Release/bluetooth_hci_socket.node
        COPY /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node
        TOUCH Release/obj.target/action_after_build.stamp
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/bluetooth-hci-socket/build'
      > @abandonware/noble@1.9.2-15 install /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
        SOLINK_MODULE(target) Release/obj.target/noble.node
        COPY Release/noble.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noble/build'
      > core-js@2.6.12 postinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/core-js
      > node -e "try{require('./postinstall')}catch(e){}"
      Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
      The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
      > https://opencollective.com/core-js
      > https://www.patreon.com/zloirock
      Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
      > parcel-bundler@1.12.5 postinstall /opt/iobroker/node_modules/iobroker.ble/node_modules/parcel-bundler
      > node -e "console.log('\u001b[35m\u001b[1mLove Parcel? You can now donate to our open collective:\u001b[22m\u001b[39m\n > \u001b[34mhttps://opencollective.com/parcel/donate\u001b[0m')"
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/glob-watcher/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/@parcel/watcher/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      + production@0.0.2
      added 1489 packages from 1205 contributors in 146.424s
      109 packages are looking for funding
        run `npm fund` for details
      .. danach nur noch den Adapter neustarten und er ist wieder Grün!
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      ? apollon77 2 Replies Last reply Reply Quote 1
        A Former User @TDCroPower last edited by
        @tdcropower
        mit root geht es mit nodejs nicht gut!
          apollon77 @TDCroPower last edited by
          @tdcropower Jupp. Jetzt am besten ein „iob fix“ hinterher und dann am besten nicht mehr mit root
            @apollon77 ihr habt Recht, im Docker Image gibt es noch einen iobroker user auf dem iobroker installiert wurde.
            iobroker@helios64:~$ ls -l
            total 1132
            drwxrwxr-x+   3 iobroker iobroker    4096 Feb 26 02:30 backups
            -rwxrwxrwx+   1 iobroker iobroker     233 Nov 23 16:15 INSTALLER_INFO.txt
            lrwxrwxrwx    1 iobroker iobroker      22 Nov 23 16:15 iob -> /opt/iobroker/iobroker
            -rwxr-xr-x+   1 iobroker iobroker     178 Feb 26 12:56 iobroker
            -rwxr-xr-x+   1 iobroker iobroker     178 Feb 26 12:40 iobroker.bak
            drwxrwxr-x+  10 iobroker iobroker    4096 Feb 26 14:20 iobroker-data
            drwxrwxr-x+   2 iobroker iobroker    4096 Feb 26 13:30 log
            drwxrwxr-x+ 621 iobroker iobroker   20480 Feb 26 12:51 node_modules
            -rw-rwxr--+   1 iobroker iobroker     864 Feb 26 12:39 package.json
            -rw-rwxr--+   1 iobroker iobroker 1098042 Feb 26 12:51 package-lock.json
            -rw-rwxr--+   1 iobroker iobroker    5693 Dez 23 01:16 reinstall.js
            Dann bleibt der default Portainer User root wieder weg.
              Etbron last edited by
              Ich habe gerade das Update nach Anleitung gemacht. Leider ist wohl ein Fehler aufgetreten, jetzt scheint mein ioBroker tot zu sein. Da ich Linux-mäßig leider Laie bin, fehlt mir jetzt ehrlich gesagt die Idee, wie ich am besten mit einer Reparatur anfangen kann.
              tlettschmidt@iobroker:~$ iob upgrade self
              Update js-controller from @3.3.22 to @4.0.15
              NPM version: 6.14.16
              npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
              In file included from ../../nan/nan.h:58,
                               from ../src/unix_dgram.cc:5:
              /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                793 |       (node::addon_register_func) (regfunc),                          \
              /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
              ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                404 | NODE_MODULE(unix_dgram, Initialize)
              Server Objects 127.0.0.1:41698 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
              Server States 127.0.0.1:56264 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
              Server Objects 127.0.0.1:41698 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
              Server States 127.0.0.1:56268 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
              Server Objects 127.0.0.1:41698 Error from InMemDB: Error: Unknown LUA script load
              Server Objects 127.0.0.1:41698 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
              Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
              Bin für jede Anregung und jeden Tipp dankbar.
                Etbron @Etbron last edited by
                Schnappatmung hat sich ein wenig beruhigt. Ich habe ihn nochmal gestoppt, nochmal gestartet und scheinbar läuft er jetzt. Trotzdem wäre es schön, wenn sich jemand den Fehler anschauen würde und mir ein kurzes Feedback geben könnte, ob ich jetzt ein problem habe bzw. bekommen werde.
                  @tdcropower ok da bin ich ehrlich. Keine Ahnung. An sich sollte man nicht mit dem iobroker User arbeiten. @andre ?! Wie ist das bei Docker am besten?!
                    apollon77 @Etbron last edited by
                    @etbron das ist alles ok. Ließ doch mal gaaaaanz oben im ersten post. Da steht alles drin. Diese Meldungen sind erwartet gewesen und daher voll normal. Jaaaanz ruhig
                      Etbron @apollon77 last edited by
                      @apollon77 Danke. Die Ich hatte das Post gesehen - und hätte mir auch keine Sorgen gemacht, wenn der ioBroker nach dem Update direkt wieder erreichbar gewesen wäre. Vielen Dank für die schnelle Antwort und beruhigenden Worte 🙂
                        erfggi last edited by
                        Mein Update war erfolgreich auf dem Master (Proxmox VM) und auf dem Slave (RaspberryPi4 mit Deconz2 UsbStick) Läuft alles seit 4h ohne Probleme.
                        • Rene55
                          Rene55 last edited by
                          Mein ioBroker läuft als Docker-Container. Beim Aufruf des 'iob upgrade self' bekomme ich den Fehler 'sudo: unable to execute /usr/bin/node: Operation not permitted'. Gibt es für Docker-User hier was besonderes zu beachten?
                          Ben1983 apollon77 2 Replies Last reply Reply Quote 0
                          • Ben1983
                            Ben1983 @Rene55 last edited by
                            @rene55 mein iobroker läuft unter Windows.
                            Muss mal hier wirklich den installer eine neue Instanz installieren lassen, oder lediglich in der console ein upgrade Self ausführen?
                            Kann mir jemand beschreiben, wie ich das ubter Windows hoch ziehe? Stehe komplett im dunklen.
                              apollon77 @Ben1983 last edited by
                              @ben1983 zu Windows am besten im ersten post schauen. Da ist ein link zu einer Anleitung von @sigi234 … ggf dann dort bitte fragen.
                                apollon77 @Rene55 last edited by
                                @rene55 @andre an advice? Danke. An sich sollte das doch direkt tun….
                                • Latzi
                                  Latzi @apollon77 last edited by
                                  @apollon77 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                  Du hast ne alte mongodb lib wohl von nem node-red. Liegt eher an nodejs 14+ als am Controller.
                                  @apollon77 ich bekomm die mongodb lib nicht weg, gibt es noch einen anderen Weg oder hab ich da was falsch gemacht?
                                  pi@Pi4-Server:/opt/iobroker $ npm uninstall mongodb
                                  npm ERR! code ELOOP
                                  npm ERR! syscall open
                                  npm ERR! path /opt/iobroker/node_modules/xml2js/package.json
                                  npm ERR! errno -40
                                  npm ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/xml2js/package.json'
                                  • Ben1983
                                    Ben1983 @apollon77 last edited by
                                    @apollon77 meine Frage bezieht sich ja auf die Anleitung.
                                    Verstehe die nicht.
                                    Da steht bei Update neu aufsetzen???
                                    Siggi habe ich im Discord angeschrieben.
                                      apollon77 @Latzi last edited by
                                      @latzi da meckert npm über andere komische Dinge in deinem node_modules. Du kannst das dir mal löschen was er anmeckert aber dann fehlt ein Paket. Wenn also danach ein Adapter nicht geht (bei dem Paket zb shelly u.a.) musst du den Adapter Dannie installieren. Da musst du mal googeln Bzw sollte man außerhalb diese threads diskutieren.
                                        @ben1983 dann aber am besten im thread zu der Anleitung besprechen. So kann Siri die Anleitung verbessern.
                                        • Ben1983
                                          @apollon77 da kann man aber nicht antworten oder sonstiges, wenn man den Link zu der Anleitung öffnet.
                                          • Feuersturm
                                            Feuersturm @Ben1983 last edited by
                                            @ben1983 Dann einfach ein neues Thema eröffnen mit Bezug zu der Anleitung für Windows und deiner Fragestellung 🙂
                                            501
                                            138561
