      Josh @simatec last edited by Josh
      @simatec @thomas-braun Habe die influx-cli nun über den Paketmanager im ioBroker Container installiert und den Pfad zur DB leer gelassen. Läuft jetzt bei mir.
      Vielen Dank für die Unterstützung.
        @apollon77 @simatec habe jetzt host auf info und bin mit backitup zum Test zurück auf 2.3.1 und anschließend wieder hoch auf 2.3.2
        downgrade
        2022-02-15 00:26:29.488 - info: host.IoBroker iobroker upgrade backitup@2.3.1
        2022-02-15 00:26:31.962 - info: host.IoBroker iobroker Update backitup from @2.3.2 to @2.3.1
        2022-02-15 00:26:32.036 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
        2022-02-15 00:26:32.218 - info: host.IoBroker "system.adapter.backitup.0" disabled
        2022-02-15 00:26:32.220 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-02-15 00:26:32.394 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
        2022-02-15 00:26:32.388 - info: backitup.0 (5928) Got terminate signal TERMINATE_YOURSELF
        2022-02-15 00:26:32.392 - info: backitup.0 (5928) cleaned everything up...
        2022-02-15 00:26:32.394 - info: backitup.0 (5928) terminating
        2022-02-15 00:26:32.395 - info: backitup.0 (5928) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-02-15 00:26:32.626 - info: host.IoBroker iobroker NPM version: 6.14.16Installing iobroker.backitup@2.3.1... (System call)
        2022-02-15 00:26:33.364 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-02-15 00:28:06.222 - info: host.IoBroker iobroker + iobroker.backitup@2.3.1updated 1 package in 92.668s
        2022-02-15 00:28:12.743 - info: host.IoBroker iobroker 154 packages are looking for funding run `npm fund` for details
        2022-02-15 00:28:12.824 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is started
        2022-02-15 00:28:13.015 - info: host.IoBroker "system.adapter.backitup.0" enabled
        2022-02-15 00:28:13.589 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 32195
        2022-02-15 00:28:13.591 - info: host.IoBroker iobroker Update "system.adapter.backitup.0"
        2022-02-15 00:28:13.802 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-02-15 00:28:13.965 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
        2022-02-15 00:28:14.061 - info: host.IoBroker iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
        2022-02-15 00:28:14.247 - info: host.IoBroker iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
        2022-02-15 00:28:14.259 - info: host.IoBroker iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
        2022-02-15 00:28:14.269 - info: host.IoBroker iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
        2022-02-15 00:28:14.279 - info: host.IoBroker iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
        2022-02-15 00:28:14.289 - info: host.IoBroker iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
        2022-02-15 00:28:14.299 - info: host.IoBroker iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
        2022-02-15 00:28:14.329 - info: host.IoBroker iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
        2022-02-15 00:28:14.386 - info: host.IoBroker iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
        2022-02-15 00:28:14.404 - info: host.IoBroker iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
        2022-02-15 00:28:14.421 - info: host.IoBroker iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        2022-02-15 00:28:15.064 - info: host.IoBroker stopInstance system.adapter.backitup.0 killing pid 32195
        2022-02-15 00:28:15.067 - info: backitup.0 (32195) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-02-15 00:28:15.524 - info: host.IoBroker iobroker exit 0
        2022-02-15 00:28:15.688 - warn: backitup.0 (32195) redis get system.adapter.backitup.0.alive, error - Connection is closed.
        2022-02-15 00:28:15.693 - warn: backitup.0 (32195) redis get system.adapter.backitup.0.sigKill, error - Connection is closed.
        2022-02-15 00:28:15.726 - warn: backitup.0 (32195) Did not add default (none) value on creation of backitup.0.info.ccuNextTime: Connection is closed.
        2022-02-15 00:28:15.731 - warn: backitup.0 (32195) Did not add default (none) value on creation of backitup.0.info.iobrokerNextTime: Connection is closed.
        2022-02-15 00:28:16.000 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-02-15 00:28:17.216 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 32206
        2022-02-15 00:28:21.396 - info: backitup.0 (32206) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.9
        2022-02-15 00:28:21.585 - info: backitup.0 (32206) [iobroker] backup was activated at 05:30 every 1 day(s)
        upgrade
        2022-02-15 00:32:00.792 - info: host.IoBroker iobroker upgrade backitup@2.3.2
        2022-02-15 00:32:04.180 - info: host.IoBroker iobroker Update backitup from @2.3.1 to @2.3.2
        2022-02-15 00:32:04.376 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is stopped.
        2022-02-15 00:32:04.654 - info: host.IoBroker "system.adapter.backitup.0" disabled
        2022-02-15 00:32:04.656 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-02-15 00:32:04.829 - info: backitup.0 (32206) Got terminate signal TERMINATE_YOURSELF
        2022-02-15 00:32:04.831 - info: backitup.0 (32206) cleaned everything up...
        2022-02-15 00:32:04.832 - info: backitup.0 (32206) terminating
        2022-02-15 00:32:04.835 - info: backitup.0 (32206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-02-15 00:32:04.858 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
        2022-02-15 00:32:05.139 - info: host.IoBroker iobroker NPM version: 6.14.16
        2022-02-15 00:32:05.143 - info: host.IoBroker iobroker Installing iobroker.backitup@2.3.2... (System call)
        2022-02-15 00:32:06.102 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-02-15 00:32:09.971 - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-02-15 00:33:14.507 - info: host.IoBroker iobroker + iobroker.backitup@2.3.2updated 1 package in 68.184s
        2022-02-15 00:33:20.581 - info: host.IoBroker iobroker 154 packages are looking for funding run `npm fund` for details
        2022-02-15 00:33:20.647 - info: host.IoBroker iobroker host.IoBroker Adapter "system.adapter.backitup.0" is started
        2022-02-15 00:33:20.854 - info: host.IoBroker "system.adapter.backitup.0" enabled
        2022-02-15 00:33:21.515 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 1538
        2022-02-15 00:33:21.534 - info: host.IoBroker iobroker Update "system.adapter.backitup.0"
        2022-02-15 00:33:21.773 - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
        2022-02-15 00:33:21.806 - info: host.IoBroker iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
        2022-02-15 00:33:21.893 - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
        2022-02-15 00:33:22.160 - info: host.IoBroker iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
        2022-02-15 00:33:22.170 - info: host.IoBroker iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
        2022-02-15 00:33:22.179 - info: host.IoBroker iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
        2022-02-15 00:33:22.189 - info: host.IoBroker iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
        2022-02-15 00:33:22.201 - info: host.IoBroker iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
        2022-02-15 00:33:22.212 - info: host.IoBroker iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
        2022-02-15 00:33:22.223 - info: host.IoBroker iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
        2022-02-15 00:33:22.232 - info: host.IoBroker iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
        2022-02-15 00:33:22.241 - info: host.IoBroker iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
        2022-02-15 00:33:22.251 - info: host.IoBroker iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        2022-02-15 00:33:22.920 - info: host.IoBroker stopInstance system.adapter.backitup.0 killing pid 1538
        2022-02-15 00:33:22.923 - info: backitup.0 (1538) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-02-15 00:33:23.354 - info: host.IoBroker iobroker exit 0
        2022-02-15 00:33:23.468 - warn: backitup.0 (1538) Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
        2022-02-15 00:33:23.472 - warn: backitup.0 (1538) Unable to subscribe to meta namespace "meta." changes: Connection is closed.
        2022-02-15 00:33:23.475 - warn: backitup.0 (1538) redis get system.adapter.backitup.0.alive, error - Connection is closed.
        2022-02-15 00:33:23.477 - warn: backitup.0 (1538) redis get system.adapter.backitup.0.sigKill, error - Connection is closed.
        2022-02-15 00:33:23.483 - error: backitup.0 (1538) backitup.0 invalid config
        2022-02-15 00:33:23.739 - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-02-15 00:33:25.172 - info: host.IoBroker instance system.adapter.backitup.0 started with pid 1550
        2022-02-15 00:33:29.116 - info: backitup.0 (1550) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.9
        2022-02-15 00:33:29.236 - info: backitup.0 (1550) [iobroker] backup was activated at 05:30 every 1 day(s)
          apollon77 @crunchip last edited by apollon77
          @crunchip alles klar. Hab ne Idee. Das Info log war glaube ich Sehr hilfreich 😉
          Info: Der Backitup wird gestioppt beim update, dann aber direkt nach dem npm update neu gestartet , dann kommt der "upload" schritt vom Update und der startet dann nochmal neu ... das ist bei dir zu schnell. AN Sich sollte der eine start auch später sein. Sollte bald (laufe heute/heute abend) in der 4.0.10 vom controller gefixt sein
          • simatec
            simatec Developer Most Active last edited by simatec
            Ab sofort steht die Version 2.3.3 auf Github und in kürze auch im latest zur Verfügung.
            Changelog
            2.3.3 (2022-02-17)
            • (simatec) small GUI fixes
            • (simatec) Docker restore tunning
            • simatec
              Ab sofort steht die Version 2.3.4 auf Github und in Kürze auch im latest zur Verfügung.
              Changelog
              2.3.4 (2022-02-26)
              • (simatec) Redis Remote Backup for Docker added
              • (simatec) Docu updated
              Des Weiteren wurde die Doku für die Version 2.3.x aktualisiert.
              Bitte bei Einrichtungsproblemen die Doku lesen.
              Deutsche Dokumentation
              Englische Dokumentation
              amg_666 O 2 Replies Last reply Reply Quote 0
              • amg_666
                amg_666 @simatec last edited by
                @simatec sieht gut aus bei mir. iob nuc mit proxmox und debian 10 plus ein slave auf Raspi (beides iob 4.0.15) , update lief durch, danach manuelles backup lief durch. Er gibtz ein warning, dass auf dem Slave was nicht vorhanden ist, das liegt aber höchstwahrscheinlich an irgendeinem Problem des Slaves bzw seiner Instanzen und nicht am Adapter.
                Ich poste mal den Log zur Info. Der Error connect EHOSTUNREACH 192.168.2.20:21 kommt weil das NAS nicht online war.
                backitup.0
                	2022-02-26 16:30:45.681	debug	slave backups are completed
                backitup.0
                	2022-02-26 16:30:45.681	warn	undefined is not running. The slave backup for this instance is not possible
                backitup.0
                	2022-02-26 16:30:44.674	debug	Slave backup from Backitup-Master is started ...
                backitup.0
                	2022-02-26 16:30:44.673	debug	[iobroker] exec: done
                backitup.0
                	2022-02-26 16:30:44.372	debug	[iobroker/historyJSON] done
                backitup.0
                	2022-02-26 16:30:44.371	debug	[iobroker/historyJSON] new history json values created
                backitup.0
                	2022-02-26 16:30:44.215	debug	[iobroker/historyHTML] done
                backitup.0
                	2022-02-26 16:30:44.215	debug	[iobroker/historyHTML] new history html values created
                backitup.0
                	2022-02-26 16:30:43.442	debug	[iobroker/clean] done
                backitup.0
                	2022-02-26 16:30:42.686	debug	[iobroker/ftp] done
                backitup.0
                	2022-02-26 16:30:42.670	debug	[iobroker/ftp] Send javascripts_2022_02_26-16_30_37_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:30:42.547	debug	[iobroker/ftp] Send zigbee.0_2022_02_26-16_30_37_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:30:39.369	debug	[iobroker/ftp] Send historyDB_2022_02_26-16_29_57_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:30:38.391	debug	[iobroker/ftp] Send iobroker_2022_02_26-16_29_43_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:30:38.391	debug	[iobroker/ftp] FTP connected.
                backitup.0
                	2022-02-26 16:30:38.024	debug	[iobroker/javascripts] done
                backitup.0
                	2022-02-26 16:30:38.023	debug	[iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2022_02_26-16_30_37_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:30:38.018	debug	[iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                backitup.0
                	2022-02-26 16:30:38.002	debug	[iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
                backitup.0
                	2022-02-26 16:30:37.841	debug	[iobroker/javascripts] found Script: Anzeige_initialisieren_(setstate)
                backitup.0
                	2022-02-26 16:30:37.840	debug	[iobroker/javascripts] found Script: Anzeige_initialisieren_(Exec)
                backitup.0
                	2022-02-26 16:30:37.840	debug	[iobroker/javascripts] found Script: zigbee_watchdog
                backitup.0
                	2022-02-26 16:30:37.840	debug	[iobroker/javascripts] found Script: Tasmota_Watchdog
                backitup.0
                	2022-02-26 16:30:37.840	debug	[iobroker/javascripts] found Script: tasmota_devices
                backitup.0
                	2022-02-26 16:30:37.839	debug	[iobroker/javascripts] found Script: Statusanzeige_initialisieren
                backitup.0
                	2022-02-26 16:30:37.839	debug	[iobroker/javascripts] found Script: Backup-Tabelle
                backitup.0
                	2022-02-26 16:30:37.839	debug	[iobroker/javascripts] found Script: Anwesenheitssimulation
                backitup.0
                	2022-02-26 16:30:37.838	debug	[iobroker/javascripts] found Script: Pflanzenanzucht
                backitup.0
                	2022-02-26 16:30:37.838	debug	[iobroker/javascripts] found Script: Opplo_Switch_Schlafzimmer
                backitup.0
                	2022-02-26 16:30:37.838	debug	[iobroker/javascripts] found Script: Tradfri_Andreas
                backitup.0
                	2022-02-26 16:30:37.837	debug	[iobroker/javascripts] found Script: Tradfri_Doro
                backitup.0
                	2022-02-26 16:30:37.836	debug	[iobroker/javascripts] found Script: Tradfri_Garten
                backitup.0
                	2022-02-26 16:30:37.836	debug	[iobroker/javascripts] found Script: Tradfri_Nils
                backitup.0
                	2022-02-26 16:30:37.836	debug	[iobroker/javascripts] found Script: Opplo_Switch_Garten
                backitup.0
                	2022-02-26 16:30:37.835	debug	[iobroker/javascripts] found Script: Opplo_Switch_Wohnzimmer
                backitup.0
                	2022-02-26 16:30:37.835	debug	[iobroker/javascripts] found Script: Bild_an_Telegram
                backitup.0
                	2022-02-26 16:30:37.835	debug	[iobroker/javascripts] found Script: Begruessung
                backitup.0
                	2022-02-26 16:30:37.834	debug	[iobroker/javascripts] found Script: Statusansagen
                backitup.0
                	2022-02-26 16:30:37.834	debug	[iobroker/javascripts] found Script: zigbee_test
                backitup.0
                	2022-02-26 16:30:37.834	debug	[iobroker/javascripts] found Script: RF_433_Bridge
                backitup.0
                	2022-02-26 16:30:37.833	debug	[iobroker/javascripts] found Script: Radar_Ein
                backitup.0
                	2022-02-26 16:30:37.833	debug	[iobroker/javascripts] found Script: Fenstercheck_Nils
                backitup.0
                	2022-02-26 16:30:37.833	debug	[iobroker/javascripts] found Script: Fenstercheck_Garten
                backitup.0
                	2022-02-26 16:30:37.832	debug	[iobroker/javascripts] found Script: Klingel
                backitup.0
                	2022-02-26 16:30:37.831	debug	[iobroker/javascripts] found Script: Das_Sonoff_Skript
                backitup.0
                	2022-02-26 16:30:37.831	debug	[iobroker/javascripts] found Script: Abzugshaube
                backitup.0
                	2022-02-26 16:30:37.831	debug	[iobroker/javascripts] found Script: Skript_1
                backitup.0
                	2022-02-26 16:30:37.830	debug	[iobroker/javascripts] found Script: Skript_1
                backitup.0
                	2022-02-26 16:30:37.830	debug	[iobroker/javascripts] found Script: Wetter_Check_Rolladen
                backitup.0
                	2022-02-26 16:30:37.830	debug	[iobroker/javascripts] found Script: Urlaub_ermitteln
                backitup.0
                	2022-02-26 16:30:37.829	debug	[iobroker/javascripts] found Script: Summe_Impfungen
                backitup.0
                	2022-02-26 16:30:37.829	debug	[iobroker/javascripts] found Script: BT_Anwesenheit_tr-64
                backitup.0
                	2022-02-26 16:30:37.829	debug	[iobroker/javascripts] found Script: Wii_u
                backitup.0
                	2022-02-26 16:30:37.828	debug	[iobroker/javascripts] found Script: WakeOnLan
                backitup.0
                	2022-02-26 16:30:37.828	debug	[iobroker/javascripts] found Script: Velux_abends_zu
                backitup.0
                	2022-02-26 16:30:37.827	debug	[iobroker/javascripts] found Script: TV
                backitup.0
                	2022-02-26 16:30:37.826	debug	[iobroker/javascripts] found Script: Summe_Stromverbrauch
                backitup.0
                	2022-02-26 16:30:37.826	debug	[iobroker/javascripts] found Script: Statusanzeige_gross
                backitup.0
                	2022-02-26 16:30:37.825	debug	[iobroker/javascripts] found Script: Pflanzencheck
                backitup.0
                backitup.0
                	2022-02-26 16:30:37.825	debug	[iobroker/javascripts] found Script: Frostwächter_Gartenhaus
                backitup.0
                	2022-02-26 16:30:37.824	debug	[iobroker/javascripts] found Script: BluRay
                backitup.0
                	2022-02-26 16:30:37.824	debug	[iobroker/javascripts] found Script: BT_Anwesenheit_Radar2
                backitup.0
                	2022-02-26 16:30:37.824	debug	[iobroker/javascripts] found Script: Astroabfrage
                backitup.0
                	2022-02-26 16:30:37.823	debug	[iobroker/javascripts] found Script: Velux_nach_Sonnenuntergang_schliessen
                backitup.0
                	2022-02-26 16:30:37.823	debug	[iobroker/javascripts] found Script: Velux_nach_Sonnenaufgang_öffnen
                backitup.0
                	2022-02-26 16:30:37.822	debug	[iobroker/javascripts] found Script: Velux_Nils_auf
                backitup.0
                	2022-02-26 16:30:37.821	debug	[iobroker/javascripts] found Script: Restart_klf200
                backitup.0
                	2022-02-26 16:30:37.821	debug	[iobroker/javascripts] found Script: Alle_Velux_öffnen
                backitup.0
                	2022-02-26 16:30:37.821	debug	[iobroker/javascripts] found Script: Alle_Velux_schliessen
                backitup.0
                	2022-02-26 16:30:37.820	debug	[iobroker/javascripts] found Script: velux_list_all_nodes
                backitup.0
                	2022-02-26 16:30:37.820	debug	[iobroker/javascripts] found Script: Velux_Nils_Zu
                backitup.0
                	2022-02-26 16:30:37.819	debug	[iobroker/javascripts] found Script: Velux_Martina_rechts_zu
                backitup.0
                	2022-02-26 16:30:37.819	debug	[iobroker/javascripts] found Script: Velux_Martina_rechts_auf
                backitup.0
                	2022-02-26 16:30:37.819	debug	[iobroker/javascripts] found Script: Velux_Martina_links_zu
                backitup.0
                	2022-02-26 16:30:37.818	debug	[iobroker/javascripts] found Script: Velux_Martina_links_auf
                backitup.0
                	2022-02-26 16:30:37.818	debug	[iobroker/javascripts] found Script: Test_Fritzbox_Filter
                backitup.0
                	2022-02-26 16:30:37.817	debug	[iobroker/javascripts] found Script: TV_Internet
                backitup.0
                	2022-02-26 16:30:37.816	debug	[iobroker/javascripts] found Script: Statusanzeige_2
                backitup.0
                backitup.0
                	2022-02-26 16:30:37.815	debug	[iobroker/javascripts] found Script: Telefonliste_(TR-64)
                backitup.0
                	2022-02-26 16:30:37.815	debug	[iobroker/javascripts] found Script: LG_Telefontest
                backitup.0
                	2022-02-26 16:30:37.814	debug	[iobroker/javascripts] found Script: Weihnachtsbeleuchtung_aussen
                backitup.0
                	2022-02-26 16:30:37.814	debug	[iobroker/javascripts] found Script: Weihnachtsbeleuchtung_Wintergarten_links
                backitup.0
                	2022-02-26 16:30:37.813	debug	[iobroker/javascripts] found Script: Weihnachtsbaum_(Gosund_SP1-3)
                backitup.0
                	2022-02-26 16:30:37.813	debug	[iobroker/javascripts] found Script: Schuhschrank
                backitup.0
                	2022-02-26 16:30:37.812	debug	[iobroker/javascripts] found Script: Schrank_Keller
                backitup.0
                	2022-02-26 16:30:37.811	debug	[iobroker/javascripts] found Script: Legolampe
                backitup.0
                	2022-02-26 16:30:37.622	debug	[iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                backitup.0
                	2022-02-26 16:30:37.018	debug	[iobroker/zigbee] done
                backitup.0
                	2022-02-26 16:30:37.017	debug	[iobroker/zigbee] found zigbee database: zigbee.0
                backitup.0
                	2022-02-26 16:30:36.860	debug	[iobroker/historyDB] done
                backitup.0
                	2022-02-26 16:30:36.835	debug	[iobroker/historyDB] Backup created: /opt/iobroker/backups/historyDB_2022_02_26-16_29_57_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:30:27.648	debug	[iobroker/historyDB] Packed 35MB so far...
                backitup.0
                	2022-02-26 16:30:17.655	debug	[iobroker/historyDB] Packed 22MB so far...
                backitup.0
                	2022-02-26 16:30:07.642	debug	[iobroker/historyDB] Packed 10MB so far...
                backitup.0
                	2022-02-26 16:29:57.638	debug	[iobroker/historyDB] compress from historyDB started ...
                backitup.0
                	2022-02-26 16:29:56.884	debug	[iobroker/iobroker] done
                backitup.0
                	2022-02-26 16:29:55.792	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2022_02_26-16_29_43_backupiobroker.tar.gz
                backitup.0
                	2022-02-26 16:29:49.026	debug	[iobroker/iobroker] host.iobroker 18601 objects saved
                backitup.0
                	2022-02-26 16:29:47.846	debug	[iobroker/iobroker] host.iobroker 16532 states saved
                backitup.0
                	2022-02-26 16:29:43.602	debug	Backup has started ...
                backitup.0
                	2022-02-26 16:29:39.353	debug	telegram-instance:
                backitup.0
                	2022-02-26 16:28:46.671	debug	No backup file was found
                backitup.0
                	2022-02-26 16:28:44.669	error	Error: connect EHOSTUNREACH 192.168.2.20:21
                backitup.0
                	2022-02-26 16:28:41.504	info	[ccu] backup was activated at 01:30 every 3 day(s)
                backitup.0
                	2022-02-26 16:28:41.449	info	[iobroker] backup was activated at 02:00 every 1 day(s)
                backitup.0
                	2022-02-26 16:28:41.413	debug	Backitup has recognized a linux system
                backitup.0
                	2022-02-26 16:28:41.378	info	starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 4.0.15
                backitup.0
                	2022-02-26 16:28:40.712	debug	Plugin sentry Initialize Plugin (enabled=true)
                backitup.0
                	2022-02-26 16:28:40.431	debug	States connected to redis: 0.0.0.0:9000
                backitup.0
                	2022-02-26 16:28:40.342	debug	States create User PubSub Client
                backitup.0
                	2022-02-26 16:28:40.341	debug	States create System PubSub Client
                backitup.0
                	2022-02-26 16:28:40.289	debug	Redis States: Use Redis connection: 0.0.0.0:9000
                backitup.0
                	2022-02-26 16:28:40.235	debug	Objects connected to redis: 0.0.0.0:9001
                backitup.0
                	2022-02-26 16:28:40.226	debug	Objects client initialize lua scripts
                backitup.0
                	2022-02-26 16:28:40.094	debug	Objects create User PubSub Client
                backitup.0
                	2022-02-26 16:28:40.093	debug	Objects create System PubSub Client
                backitup.0
                	2022-02-26 16:28:40.090	debug	Objects client ready ... initialize now
                backitup.0
                	2022-02-26 16:28:40.002	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
                backitup.0
                	2022-02-26 16:27:29.638	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                backitup.0
                	2022-02-26 16:27:29.638	debug	Plugin sentry destroyed
                backitup.0
                	2022-02-26 16:27:29.637	info	terminating
                backitup.0
                	2022-02-26 16:27:29.636	info	cleaned everything up...
                backitup.0
                	2022-02-26 16:27:29.635	info	Got terminate signal TERMINATE_YOURSELF
                • O
                  oFbEQnpoLKKl6mbY5e13 @simatec last edited by oFbEQnpoLKKl6mbY5e13
                  @simatec sagte in Test Adapter Backitup v2.3.x:
                  Habe ich mir gerade angesehen. Da kann man nur einen Pfad konfigurieren.
                  Zitat aus Doku:
                  "Ab Backitup Version 2.3.x ist es möglich ein Remote Backup für Redis zu erstellen. Hier müsst ihr euren Host und Port des entfernten Redis Servers angeben und die Login Daten eures Systems."
                  Bei mir ist da nichts, was ich konfigurieren könnte. Was mache ich falsch?
                  • simatec
                    simatec Developer Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
                    @ofbeqnpolkkl6mby5e13
                    Welche Dockerversion ist installiert? Backitup unterstützt die offizielle iobroker Dockerversion ab 5.2
                    cf564911-0b07-4104-9e85-b264bbaa95a3-Bildschirmfoto 2022-02-26 um 21.26.22.png Bildschirmfoto 2022-02-26 um 21.26.22.png
                    • O
                      @simatec
                      latest-v6 von Ende 2021.
                      • simatec
                        @ofbeqnpolkkl6mby5e13 Wie hast du installiert über Github oder latest?
                        Mach mal nochmal ein Upload
                        • O
                          @simatec
                          latest. Okay, probiere ich.
                          • O
                            oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
                            @simatec
                            Hat leider nichts gebracht.
                            # iobroker upload backitup
                            # iobroker start backitup.0
                            The adapter "backitup.0" was started.
                            • simatec
                              @ofbeqnpolkkl6mby5e13 Hab es versucht mal nachzustellen. Da gibt es anscheind noch einen kleine GUI Bug.
                              Mache mal folgendes.
                              Öffne die Config ... Wenn Redis aktiviert ist, dann sollte der Speicher Button aktiv sein.
                              Speichere mal und öffne die Config im Anschluss erneut.
                              Dann sollte das richtige redis Menü da sein.
                              Werde die GUI in der nächsten Version fixen
                              O 2 Replies Last reply Reply Quote 1
                              • O
                                @simatec
                                Perfekt!
                                • O
                                  @simatec
                                  Jetzt nicht wahnsinnig werden, aber da kann man ja nur einen Redis konfigurieren. Bei mir laufen aber für States und Objects separate Redis-Server...
                                  • simatec
                                    @ofbeqnpolkkl6mby5e13 Dann brauchst du ne zweite Instanz, die Du als Slave konfigurierst und die Backitup.0 als Master.
                                    Backitup.1 als Slave und dort das Redis Backup für den zweiten Server aktivieren.
                                    Die Instanz backitup.1 wird dann nur für das backup gestartet und im Anschluss wieder gestoppt
                                    • O
                                      @simatec
                                      Vielen Dank! Das werde ich probieren.
                                      Mal eine andere Frage:
                                      Wie funktioniert die ursprüngliche Backup Variante genau?
                                      Wenn ich meine zwei Ordner für die dump.rdb von States und Objects jeweils nach /var/lib/redis/states und /var/lib/redis/objects im iobroker-Container mounte und als Pfad fürs Backup /var/lib/redis angebe, wird dann rekursiv alles unter /var/lib/redis gebackupt?
                                      • simatec
                                        @ofbeqnpolkkl6mby5e13 Wird so nicht funktionieren, da für docker kein lokales Backup erstellt wird.
                                        Hier wird direkt mit redis-cli gearbeitet
                                        • O
                                          @simatec
                                          Ach so, danke für die Auskunft! 👍
                                          Wäre vielleicht noch eine Backup-Variante, dass man beliebige Ordner angeben kann. Backitup packt einfach alles in ein tar.gz.
                                          • simatec
                                            @ofbeqnpolkkl6mby5e13 Kannst du mit dem History Backup so machen
                                            170
                                            2780
                                            2344244
