    • O
      oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
      @simatec
      Hat leider nichts gebracht.
      # iobroker upload backitup
      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      # iobroker start backitup.0
      The adapter "backitup.0" was started.
      • simatec
        simatec Developer Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13 Hab es versucht mal nachzustellen. Da gibt es anscheind noch einen kleine GUI Bug.
        Mache mal folgendes.
        Öffne die Config ... Wenn Redis aktiviert ist, dann sollte der Speicher Button aktiv sein.
        Speichere mal und öffne die Config im Anschluss erneut.
        Dann sollte das richtige redis Menü da sein.
        Werde die GUI in der nächsten Version fixen
        O 2 Replies Last reply Reply Quote 1
        • O
          oFbEQnpoLKKl6mbY5e13 @simatec last edited by
          @simatec
          Perfekt!
          • O
            oFbEQnpoLKKl6mbY5e13 @simatec last edited by oFbEQnpoLKKl6mbY5e13
            @simatec
            Jetzt nicht wahnsinnig werden, aber da kann man ja nur einen Redis konfigurieren. Bei mir laufen aber für States und Objects separate Redis-Server...
            • simatec
              @ofbeqnpolkkl6mby5e13 Dann brauchst du ne zweite Instanz, die Du als Slave konfigurierst und die Backitup.0 als Master.
              Backitup.1 als Slave und dort das Redis Backup für den zweiten Server aktivieren.
              Die Instanz backitup.1 wird dann nur für das backup gestartet und im Anschluss wieder gestoppt
              • O
                @simatec
                Vielen Dank! Das werde ich probieren.
                Mal eine andere Frage:
                Wie funktioniert die ursprüngliche Backup Variante genau?
                Wenn ich meine zwei Ordner für die dump.rdb von States und Objects jeweils nach /var/lib/redis/states und /var/lib/redis/objects im iobroker-Container mounte und als Pfad fürs Backup /var/lib/redis angebe, wird dann rekursiv alles unter /var/lib/redis gebackupt?
                • simatec
                  @ofbeqnpolkkl6mby5e13 Wird so nicht funktionieren, da für docker kein lokales Backup erstellt wird.
                  Hier wird direkt mit redis-cli gearbeitet
                  • O
                    @simatec
                    Ach so, danke für die Auskunft! 👍
                    Wäre vielleicht noch eine Backup-Variante, dass man beliebige Ordner angeben kann. Backitup packt einfach alles in ein tar.gz.
                    • simatec
                      @ofbeqnpolkkl6mby5e13 Kannst du mit dem History Backup so machen
                      • O
                        @simatec
                        Okay.
                        Hätte ich redis-cli vorher installieren müssen?
                        [DEBUG] [redis] - Start Redis Backup ...
                        [DEBUG] [redis] - Created redistmp directory
                        [ERROR] [redis] - Error: Command failed: redis-cli -u 'redis://:@192.168.0.205:6379' --rdb /opt/iobroker/backups/redistmp/dump.rdb
                        /bin/sh: 1: redis-cli: not found
                        • simatec
                          simatec Developer Most Active @oFbEQnpoLKKl6mbY5e13 last edited by simatec
                          @ofbeqnpolkkl6mby5e13 ja redis-cli wird benötigt
                          • O
                            @simatec
                            Alles klar!
                            • simatec
                              @ofbeqnpolkkl6mby5e13 Sorry hab ich in der Doku vergessen ...
                              • O
                                @simatec
                                Packt @andre das zukünftig mit in den Container?
                                [DEBUG] [redis] - Try deleting the old redis tmp directory: "/opt/iobroker/backups/redistmp"
                                [DEBUG] [redis] - old redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
                                [DEBUG] [redis] - Created new redistmp directory
                                [DEBUG] [redis] - Packed 18MB so far...
                                [DEBUG] [redis] - Packed 64MB so far...
                                [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis-remote_2022_02_26-22_22_45_backupiobroker.tar.gz
                                [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
                                [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
                                [DEBUG] [redis] - done
                                • simatec
                                  @ofbeqnpolkkl6mby5e13 Muss ich mal mit ihm reden ...
                                  haselchen 1 Reply Last reply Reply Quote 1
                                  • O
                                    @simatec sagte in Test Adapter Backitup v2.3.x:
                                    Das hat einwandfrei so funktioniert. 👍
                                    • haselchen
                                      haselchen Most Active @simatec last edited by
                                      @simatec
                                      Ich habe eine Synology als MASTER und einen Pi als Slave.
                                      Hab gerade deinen Adapter installiert.
                                      Ich kann hier bei der Eingabe keinen Slave auswählen und wenn ich speichere gibt es eine Warnmeldung im Log.
                                      backitup.0	2022-03-03 19:56:11.965	warn	(2887) undefined is not running. The slave backup for this instance is not possible
                                      • simatec
                                        simatec Developer Most Active @haselchen last edited by
                                        @haselchen Hast du denn eine Instanz von Backitup auf dem Slave installiert?
                                        • haselchen
                                          @simatec
                                          Ich denke ich müsste auf die Frage wohl mit JA antworten 🙂
                                          Nein, das habe ich bisher nicht gemacht.
                                          Ich dachte , dass der Adapter aus den Tiefen des Iobroker Ordners die Infos des Slaves bezieht.
                                          Dann hole ich das nach und werde berichten......
                                          simatec amg_666 2 Replies Last reply Reply Quote 0
                                          • simatec
                                            @haselchen Naja klar kann ich Slaves in den iobroker Strukturen ermitteln, aber was macht das denn für einen Sinn, wenn keine Instanz auf dem Slave läuft 😬
                                            170
                                            2780
                                            2379837
