    3. Einsteigerfragen
    4. Installation
    5. Raspi4 4GB --> Installation --> Cannot find module ...
      Hape1 @Thomas Braun last edited by Hape1
      ok, es sind über 11.000 Zeilen hier mal die letzten, in der Hoffnung, das es zu einer Fehlereingrenzung reicht --> wobei, welche Terminalapp wäre denn Deine Empfehlung?
      13764 info lifecycle iobroker.js-controller@4.0.15~install: Failed to exec install script
      13765 timing action:install Completed in 51938ms
      13766 verbose unlock done using /home/pi/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
      13767 timing stage:rollbackFailedOptional Completed in 952ms
      13768 timing stage:runTopLevelLifecycles Completed in 87075ms
      13769 silly saveTree iobroker.inst@3.0.0
      13769 silly saveTree ├─┬ iobroker.admin@5.3.1
      13769 silly saveTree │ ├─┬ @iobroker/adapter-core@2.6.0
      13769 silly saveTree │ │ └─┬ @types/iobroker@4.0.1
      13769 silly saveTree │ │   └── @types/node@17.0.21
      13769 silly saveTree │ ├─┬ axios@0.26.0
      13769 silly saveTree │ │ └── follow-redirects@1.14.9
      13769 silly saveTree │ ├─┬ body-parser@1.19.2
      13769 silly saveTree │ │ ├── bytes@3.1.2
      13769 silly saveTree │ │ ├── content-type@1.0.4
      13769 silly saveTree │ │ ├─┬ debug@2.6.9
      13769 silly saveTree │ │ │ └── ms@2.0.0
      13769 silly saveTree │ │ ├── depd@1.1.2
      13769 silly saveTree │ │ ├─┬ http-errors@1.8.1
      13769 silly saveTree │ │ │ ├── inherits@2.0.4
      13769 silly saveTree │ │ │ ├── setprototypeof@1.2.0
      13769 silly saveTree │ │ │ ├── statuses@1.5.0
      13769 silly saveTree │ │ │ └── toidentifier@1.0.1
      13769 silly saveTree │ │ ├─┬ iconv-lite@0.4.24
      13769 silly saveTree │ │ │ └── safer-buffer@2.1.2
      13769 silly saveTree │ │ ├─┬ on-finished@2.3.0
      13769 silly saveTree │ │ │ └── ee-first@1.1.1
      13769 silly saveTree │ │ ├── qs@6.9.7
      13769 silly saveTree │ │ ├─┬ raw-body@2.4.3
      13769 silly saveTree │ │ │ └── unpipe@1.0.0
      13769 silly saveTree │ │ └─┬ type-is@1.6.18
      13769 silly saveTree │ │   ├── media-typer@0.3.0
      13769 silly saveTree │ │   └─┬ mime-types@2.1.34
      13769 silly saveTree │ │     └── mime-db@1.51.0
      13769 silly saveTree │ ├─┬ compression@1.7.4
      13769 silly saveTree │ │ ├─┬ accepts@1.3.8
      13769 silly saveTree │ │ │ └── negotiator@0.6.3
      13769 silly saveTree │ │ ├── bytes@3.0.0
      13769 silly saveTree │ │ ├── compressible@2.0.18
      13769 silly saveTree │ │ ├── on-headers@1.0.2
      13769 silly saveTree │ │ ├── safe-buffer@5.1.2
      13769 silly saveTree │ │ └── vary@1.1.2
      13769 silly saveTree │ ├── connect-flash@0.1.1
      13769 silly saveTree │ ├─┬ cookie-parser@1.4.6
      13769 silly saveTree │ │ ├── cookie-signature@1.0.6
      13769 silly saveTree │ │ └── cookie@0.4.1
      13769 silly saveTree │ ├─┬ express-fileupload@1.3.1
      13769 silly saveTree │ │ └─┬ busboy@0.3.1
      13769 silly saveTree │ │   └─┬ dicer@0.3.0
      13769 silly saveTree │ │     └── streamsearch@0.1.2
      13769 silly saveTree │ ├─┬ express-session@1.17.2
      13769 silly saveTree │ │ ├── depd@2.0.0
      13769 silly saveTree │ │ ├── parseurl@1.3.3
      13769 silly saveTree │ │ ├── safe-buffer@5.2.1
      13769 silly saveTree │ │ └─┬ uid-safe@2.1.5
      13769 silly saveTree │ │   └── random-bytes@1.0.0
      13769 silly saveTree │ ├─┬ express@4.17.3
      13769 silly saveTree │ │ ├── array-flatten@1.1.1
      13769 silly saveTree │ │ ├─┬ content-disposition@0.5.4
      13769 silly saveTree │ │ │ └── safe-buffer@5.2.1
      13769 silly saveTree │ │ ├── cookie@0.4.2
      13769 silly saveTree │ │ ├── encodeurl@1.0.2
      13769 silly saveTree │ │ ├── escape-html@1.0.3
      13769 silly saveTree │ │ ├── etag@1.8.1
      13769 silly saveTree │ │ ├── finalhandler@1.1.2
      13769 silly saveTree │ │ ├── fresh@0.5.2
      13769 silly saveTree │ │ ├── merge-descriptors@1.0.1
      13769 silly saveTree │ │ ├── methods@1.1.2
      13769 silly saveTree │ │ ├── path-to-regexp@0.1.7
      13769 silly saveTree │ │ ├─┬ proxy-addr@2.0.7
      13769 silly saveTree │ │ │ ├── forwarded@0.2.0
      13769 silly saveTree │ │ │ └── ipaddr.js@1.9.1
      13769 silly saveTree │ │ ├── range-parser@1.2.1
      13769 silly saveTree │ │ ├─┬ send@0.17.2
      13769 silly saveTree │ │ │ ├── destroy@1.0.4
      13769 silly saveTree │ │ │ ├── mime@1.6.0
      13769 silly saveTree │ │ │ └── ms@2.1.3
      13769 silly saveTree │ │ ├── serve-static@1.14.2
      13769 silly saveTree │ │ └── utils-merge@1.0.1
      13769 silly saveTree │ ├─┬ passport-local@1.0.0
      13769 silly saveTree │ │ └── passport-strategy@1.0.0
      13769 silly saveTree │ ├─┬ passport@0.5.2
      13769 silly saveTree │ │ └── pause@0.0.1
      13769 silly saveTree │ ├─┬ semver@7.3.5
      13769 silly saveTree │ │ └─┬ lru-cache@6.0.0
      13769 silly saveTree │ │   └── yallist@4.0.0
      13769 silly saveTree │ └── ws@8.5.0
      13769 silly saveTree ├─┬ iobroker.backitup@2.3.3
      13769 silly saveTree │ ├─┬ @googleapis/drive@2.2.0
      13769 silly saveTree │ │ └─┬ googleapis-common@5.1.0
      13769 silly saveTree │ │   ├── extend@3.0.2
      13769 silly saveTree │ │   ├─┬ gaxios@4.3.2
      13769 silly saveTree │ │   │ ├─┬ abort-controller@3.0.0
      13769 silly saveTree │ │   │ │ └── event-target-shim@5.0.1
      13769 silly saveTree │ │   │ ├─┬ https-proxy-agent@5.0.0
      13769 silly saveTree │ │   │ │ ├─┬ agent-base@6.0.2
      13769 silly saveTree │ │   │ │ │ └─┬ debug@4.3.3
      13769 silly saveTree │ │   │ │ │   └── ms@2.1.2
      13769 silly saveTree │ │   │ │ └─┬ debug@4.3.3
      13769 silly saveTree │ │   │ │   └── ms@2.1.2
      13769 silly saveTree │ │   │ ├── is-stream@2.0.1
      13769 silly saveTree │ │   │ └─┬ node-fetch@2.6.7
      13769 silly saveTree │ │   │   └─┬ whatwg-url@5.0.0
      13769 silly saveTree │ │   │     ├── tr46@0.0.3
      13769 silly saveTree │ │   │     └── webidl-conversions@3.0.1
      13769 silly saveTree │ │   ├─┬ google-auth-library@7.14.0
      13769 silly saveTree │ │   │ ├── arrify@2.0.1
      13769 silly saveTree │ │   │ ├── base64-js@1.5.1
      13769 silly saveTree │ │   │ ├── ecdsa-sig-formatter@1.0.11
      13769 silly saveTree │ │   │ ├── fast-text-encoding@1.0.3
      13769 silly saveTree │ │   │ ├─┬ gcp-metadata@4.3.1
      13769 silly saveTree │ │   │ │ └─┬ json-bigint@1.0.0
      13769 silly saveTree │ │   │ │   └── bignumber.js@9.0.2
      13769 silly saveTree │ │   │ ├─┬ gtoken@5.3.2
      13769 silly saveTree │ │   │ │ ├─┬ google-p12-pem@3.1.3
      13769 silly saveTree │ │   │ │ │ └── node-forge@1.2.1
      13769 silly saveTree │ │   │ │ └─┬ jws@4.0.0
      13769 silly saveTree │ │   │ │   └─┬ jwa@2.0.0
      13769 silly saveTree │ │   │ │     └── buffer-equal-constant-time@1.0.1
      13769 silly saveTree │ │   │ └── jws@4.0.0
      13769 silly saveTree │ │   ├── url-template@2.0.8
      13769 silly saveTree │ │   └── uuid@8.3.2
      13769 silly saveTree │ ├── axios@0.25.0
      13769 silly saveTree │ ├─┬ dropbox-v2-api@2.4.53
      13769 silly saveTree │ │ └─┬ request@2.88.2
      13769 silly saveTree │ │   ├── aws-sign2@0.7.0
      13769 silly saveTree │ │   ├── aws4@1.11.0
      13769 silly saveTree │ │   ├── caseless@0.12.0
      13769 silly saveTree │ │   ├─┬ combined-stream@1.0.8
      13769 silly saveTree │ │   │ └── delayed-stream@1.0.0
      13769 silly saveTree │ │   ├── forever-agent@0.6.1
      13769 silly saveTree │ │   ├─┬ form-data@2.3.3
      13769 silly saveTree │ │   │ └── asynckit@0.4.0
      13769 silly saveTree │ │   ├─┬ har-validator@5.1.5
      13769 silly saveTree │ │   │ ├─┬ ajv@6.12.6
      13769 silly saveTree │ │   │ │ ├── fast-deep-equal@3.1.3
      13769 silly saveTree │ │   │ │ ├── fast-json-stable-stringify@2.1.0
      13769 silly saveTree │ │   │ │ ├── json-schema-traverse@0.4.1
      13769 silly saveTree │ │   │ │ └─┬ uri-js@4.4.1
      13769 silly saveTree │ │   │ │   └── punycode@2.1.1
      13769 silly saveTree │ │   │ └── har-schema@2.0.0
      13769 silly saveTree │ │   ├─┬ http-signature@1.2.0
      13769 silly saveTree │ │   │ ├── assert-plus@1.0.0
      13769 silly saveTree │ │   │ ├─┬ jsprim@1.4.2
      13769 silly saveTree │ │   │ │ ├── extsprintf@1.3.0
      13769 silly saveTree │ │   │ │ ├── json-schema@0.4.0
      13769 silly saveTree │ │   │ │ └─┬ verror@1.10.0
      13769 silly saveTree │ │   │ │   └── core-util-is@1.0.2
      13769 silly saveTree │ │   │ └─┬ sshpk@1.17.0
      13769 silly saveTree │ │   │   ├── asn1@0.2.6
      13769 silly saveTree │ │   │   ├─┬ bcrypt-pbkdf@1.0.2
      13769 silly saveTree │ │   │   │ └── tweetnacl@0.14.5
      13769 silly saveTree │ │   │   ├── dashdash@1.14.1
      13769 silly saveTree │ │   │   ├─┬ ecc-jsbn@0.1.2
      13769 silly saveTree │ │   │   │ └── jsbn@0.1.1
      13769 silly saveTree │ │   │   ├── getpass@0.1.7
      13769 silly saveTree │ │   │   ├── jsbn@0.1.1
      13769 silly saveTree │ │   │   └── tweetnacl@0.14.5
      13769 silly saveTree │ │   ├── is-typedarray@1.0.0
      13769 silly saveTree │ │   ├── isstream@0.1.2
      13769 silly saveTree │ │   ├── json-stringify-safe@5.0.1
      13769 silly saveTree │ │   ├── oauth-sign@0.9.0
      13769 silly saveTree │ │   ├── performance-now@2.1.0
      13769 silly saveTree │ │   ├── qs@6.5.3
      13769 silly saveTree │ │   ├─┬ tough-cookie@2.5.0
      13769 silly saveTree │ │   │ └── psl@1.8.0
      13769 silly saveTree │ │   ├── tunnel-agent@0.6.0
      13769 silly saveTree │ │   └── uuid@3.4.0
      13769 silly saveTree │ ├─┬ fs-extra@10.0.1
      13769 silly saveTree │ │ ├── graceful-fs@4.2.9
      13769 silly saveTree │ │ ├─┬ jsonfile@6.1.0
      13769 silly saveTree │ │ │ └── universalify@2.0.0
      13769 silly saveTree │ │ └── universalify@2.0.0
      13769 silly saveTree │ ├─┬ ftp@0.3.10
      13769 silly saveTree │ │ ├─┬ readable-stream@1.1.14
      13769 silly saveTree │ │ │ ├── isarray@0.0.1
      13769 silly saveTree │ │ │ └── string_decoder@0.10.31
      13769 silly saveTree │ │ └── xregexp@2.0.0
      13769 silly saveTree │ ├── google-auth-library@7.14.0
      13769 silly saveTree │ ├─┬ node-schedule@2.1.0
      13769 silly saveTree │ │ ├─┬ cron-parser@3.5.0
      13769 silly saveTree │ │ │ ├─┬ is-nan@1.3.2
      13769 silly saveTree │ │ │ │ ├─┬ call-bind@1.0.2
      13769 silly saveTree │ │ │ │ │ ├── function-bind@1.1.1
      13769 silly saveTree │ │ │ │ │ └─┬ get-intrinsic@1.1.1
      13769 silly saveTree │ │ │ │ │   ├── has-symbols@1.0.2
      13769 silly saveTree │ │ │ │ │   └── has@1.0.3
      13769 silly saveTree │ │ │ │ └─┬ define-properties@1.1.3
      13769 silly saveTree │ │ │ │   └── object-keys@1.1.1
      13769 silly saveTree │ │ │ └── luxon@1.28.0
      13769 silly saveTree │ │ ├── long-timeout@0.1.1
      13769 silly saveTree │ │ └── sorted-array-functions@1.3.0
      13769 silly saveTree │ ├── node-wol@0.1.1
      13769 silly saveTree │ ├── request@2.88.2
      13769 silly saveTree │ ├─┬ tar-fs@2.1.1
      13769 silly saveTree │ │ ├── chownr@1.1.4
      13769 silly saveTree │ │ ├── mkdirp-classic@0.5.3
      13769 silly saveTree │ │ ├─┬ pump@3.0.0
      13769 silly saveTree │ │ │ ├─┬ end-of-stream@1.4.4
      13769 silly saveTree │ │ │ │ └─┬ once@1.4.0
      13769 silly saveTree │ │ │ │   └── wrappy@1.0.2
      13769 silly saveTree │ │ │ └── once@1.4.0
      13769 silly saveTree │ │ └─┬ tar-stream@2.2.0
      13769 silly saveTree │ │   ├─┬ bl@4.1.0
      13769 silly saveTree │ │   │ ├─┬ buffer@5.7.1
      13769 silly saveTree │ │   │ │ └── ieee754@1.2.1
      13769 silly saveTree │ │   │ └─┬ readable-stream@3.6.0
      13769 silly saveTree │ │   │   ├─┬ string_decoder@1.3.0
      13769 silly saveTree │ │   │   │ └── safe-buffer@5.2.1
      13769 silly saveTree │ │   │   └── util-deprecate@1.0.2
      13769 silly saveTree │ │   ├── fs-constants@1.0.0
      13769 silly saveTree │ │   └─┬ readable-stream@3.6.0
      13769 silly saveTree │ │     └─┬ string_decoder@1.3.0
      13769 silly saveTree │ │       └── safe-buffer@5.2.1
      13769 silly saveTree │ └─┬ webdav@4.8.0
      13769 silly saveTree │   ├── axios@0.24.0
      13769 silly saveTree │   ├── base-64@1.0.0
      13769 silly saveTree │   ├─┬ fast-xml-parser@3.21.1
      13769 silly saveTree │   │ └── strnum@1.0.5
      13769 silly saveTree │   ├── he@1.2.0
      13769 silly saveTree │   ├── hot-patcher@0.5.0
      13769 silly saveTree │   ├── layerr@0.1.2
      13769 silly saveTree │   ├─┬ md5@2.3.0
      13769 silly saveTree │   │ ├── charenc@0.0.2
      13769 silly saveTree │   │ ├── crypt@0.0.2
      13769 silly saveTree │   │ └── is-buffer@1.1.6
      13769 silly saveTree │   ├─┬ minimatch@3.1.2
      13769 silly saveTree │   │ └─┬ brace-expansion@1.1.11
      13769 silly saveTree │   │   ├── balanced-match@1.0.2
      13769 silly saveTree │   │   └── concat-map@0.0.1
      13769 silly saveTree │   ├── nested-property@4.0.0
      13769 silly saveTree │   ├── path-posix@1.0.0
      13769 silly saveTree │   ├── url-join@4.0.1
      13769 silly saveTree │   └─┬ url-parse@1.5.10
      13769 silly saveTree │     ├── querystringify@2.2.0
      13769 silly saveTree │     └── requires-port@1.0.0
      13769 silly saveTree ├─┬ iobroker.discovery@2.7.5
      13769 silly saveTree │ ├─┬ mdns-discovery@0.2.6
      13769 silly saveTree │ │ ├─┬ debug@2.2.0
      13769 silly saveTree │ │ │ └── ms@0.7.1
      13769 silly saveTree │ │ ├── dgram@1.0.1
      13769 silly saveTree │ │ └─┬ dns-packet@1.3.4
      13769 silly saveTree │ │   └── ip@1.1.5
      13769 silly saveTree │ ├── netmask@2.0.2
      13769 silly saveTree │ ├── node-mndp@0.0.3
      13769 silly saveTree │ ├─┬ node-ssdp@4.0.1
      13769 silly saveTree │ │ ├─┬ async@2.6.3
      13769 silly saveTree │ │ │ └── lodash@4.17.21
      13769 silly saveTree │ │ ├── bluebird@3.7.2
      13769 silly saveTree │ │ └─┬ debug@3.2.7
      13769 silly saveTree │ │   └── ms@2.1.3
      13769 silly saveTree │ └─┬ serialport@9.2.8
      13769 silly saveTree │   ├─┬ @serialport/binding-mock@9.2.4
      13769 silly saveTree │   │ ├─┬ @serialport/binding-abstract@9.2.3
      13769 silly saveTree │   │ │ └─┬ debug@4.3.3
      13769 silly saveTree │   │ │   └── ms@2.1.2
      13769 silly saveTree │   │ └─┬ debug@4.3.3
      13769 silly saveTree │   │   └── ms@2.1.2
      13769 silly saveTree │   ├─┬ @serialport/bindings@9.2.8
      13769 silly saveTree │   │ ├─┬ @serialport/parser-readline@9.2.4
      13769 silly saveTree │   │ │ └── @serialport/parser-delimiter@9.2.4
      13769 silly saveTree │   │ ├─┬ bindings@1.5.0
      13769 silly saveTree │   │ │ └── file-uri-to-path@1.0.0
      13769 silly saveTree │   │ ├─┬ debug@4.3.3
      13769 silly saveTree │   │ ├── nan@2.15.0
      13769 silly saveTree │   │ └─┬ prebuild-install@7.0.1
      13769 silly saveTree │   │   ├── detect-libc@2.0.1
      13769 silly saveTree │   │   ├── expand-template@2.0.3
      13769 silly saveTree │   │   ├── github-from-package@0.0.0
      13769 silly saveTree │   │   ├── minimist@1.2.5
      13769 silly saveTree │   │   ├── napi-build-utils@1.0.2
      13769 silly saveTree │   │   ├── node-abi@3.8.0
      13769 silly saveTree │   │   ├─┬ npmlog@4.1.2
      13769 silly saveTree │   │   │ ├─┬ are-we-there-yet@1.1.7
      13769 silly saveTree │   │   │ │ ├── delegates@1.0.0
      13769 silly saveTree │   │   │ │ └─┬ readable-stream@2.3.7
      13769 silly saveTree │   │   │ │   ├── isarray@1.0.0
      13769 silly saveTree │   │   │ │   ├── process-nextick-args@2.0.1
      13769 silly saveTree │   │   │ │   └── string_decoder@1.1.1
      13769 silly saveTree │   │   │ ├── console-control-strings@1.1.0
      13769 silly saveTree │   │   │ ├─┬ gauge@2.7.4
      13769 silly saveTree │   │   │ │ ├── aproba@1.2.0
      13769 silly saveTree │   │   │ │ ├── has-unicode@2.0.1
      13769 silly saveTree │   │   │ │ ├── object-assign@4.1.1
      13769 silly saveTree │   │   │ │ ├── signal-exit@3.0.7
      13769 silly saveTree │   │   │ │ ├─┬ string-width@1.0.2
      13769 silly saveTree │   │   │ │ │ ├── code-point-at@1.1.0
      13769 silly saveTree │   │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
      13769 silly saveTree │   │   │ │ │ │ └── number-is-nan@1.0.1
      13769 silly saveTree │   │   │ │ │ └─┬ strip-ansi@3.0.1
      13769 silly saveTree │   │   │ │ │   └── ansi-regex@2.1.1
      13769 silly saveTree │   │   │ │ ├── strip-ansi@3.0.1
      13769 silly saveTree │   │   │ │ └── wide-align@1.1.5
      13769 silly saveTree │   │   │ └── set-blocking@2.0.0
      13769 silly saveTree │   │   ├─┬ rc@1.2.8
      13769 silly saveTree │   │   │ ├── deep-extend@0.6.0
      13769 silly saveTree │   │   │ ├── ini@1.3.8
      13769 silly saveTree │   │   │ └── strip-json-comments@2.0.1
      13769 silly saveTree │   │   └─┬ simple-get@4.0.1
      13769 silly saveTree │   │     ├─┬ decompress-response@6.0.0
      13769 silly saveTree │   │     │ └── mimic-response@3.1.0
      13769 silly saveTree │   │     └── simple-concat@1.0.1
      13769 silly saveTree │   ├── @serialport/parser-byte-length@9.2.4
      13769 silly saveTree │   ├── @serialport/parser-cctalk@9.2.4
      13769 silly saveTree │   ├── @serialport/parser-delimiter@9.2.4
      13769 silly saveTree │   ├── @serialport/parser-inter-byte-timeout@9.2.4
      13769 silly saveTree │   ├── @serialport/parser-readline@9.2.4
      13769 silly saveTree │   ├── @serialport/parser-ready@9.2.4
      13769 silly saveTree │   ├── @serialport/parser-regex@9.2.4
      13769 silly saveTree │   ├─┬ @serialport/stream@9.2.4
      13769 silly saveTree │   └─┬ debug@4.3.3
      13769 silly saveTree │     └── ms@2.1.2
      13769 silly saveTree └─┬ iobroker.js-controller@4.0.15
      13769 silly saveTree   ├─┬ @alcalzone/esbuild-register@2.5.1-1
      13769 silly saveTree   │ ├── esbuild@0.11.23
      13769 silly saveTree   │ └── jsonc-parser@3.0.0
      13769 silly saveTree   ├─┬ @iobroker/db-objects-file@4.0.15
      13769 silly saveTree   │ ├─┬ @iobroker/db-base@4.0.15
      13769 silly saveTree   │ │ ├─┬ @iobroker/js-controller-common@4.0.15
      13769 silly saveTree   │ │ │ ├─┬ @alcalzone/pak@0.7.0
      13769 silly saveTree   │ │ │ │ ├── axios@0.21.4
      13769 silly saveTree   │ │ │ │ ├─┬ execa@5.1.1
      13769 silly saveTree   │ │ │ │ │ ├─┬ cross-spawn@7.0.3
      13769 silly saveTree   │ │ │ │ │ │ ├── path-key@3.1.1
      13769 silly saveTree   │ │ │ │ │ │ ├─┬ shebang-command@2.0.0
      13769 silly saveTree   │ │ │ │ │ │ │ └── shebang-regex@3.0.0
      13769 silly saveTree   │ │ │ │ │ │ └─┬ which@2.0.2
      13769 silly saveTree   │ │ │ │ │ │   └── isexe@2.0.0
      13769 silly saveTree   │ │ │ │ │ ├── get-stream@6.0.1
      13769 silly saveTree   │ │ │ │ │ ├── human-signals@2.1.0
      13769 silly saveTree   │ │ │ │ │ ├── merge-stream@2.0.0
      13769 silly saveTree   │ │ │ │ │ ├── npm-run-path@4.0.1
      13769 silly saveTree   │ │ │ │ │ ├─┬ onetime@5.1.2
      13769 silly saveTree   │ │ │ │ │ │ └── mimic-fn@2.1.0
      13769 silly saveTree   │ │ │ │ │ └── strip-final-newline@2.0.0
      13769 silly saveTree   │ │ │ │ └─┬ fs-extra@9.1.0
      13769 silly saveTree   │ │ │ │   └── at-least-node@1.0.0
      13769 silly saveTree   │ │ │ ├─┬ @datalust/winston-seq@1.0.2
      13769 silly saveTree   │ │ │ │ ├── seq-logging@1.1.1
      13769 silly saveTree   │ │ │ │ └─┬ winston-transport@4.5.0
      13769 silly saveTree   │ │ │ │   ├─┬ logform@2.4.0
      13769 silly saveTree   │ │ │ │   │ ├── @colors/colors@1.5.0
      13769 silly saveTree   │ │ │ │   │ ├── fecha@4.2.1
      13769 silly saveTree   │ │ │ │   │ ├── ms@2.1.3
      13769 silly saveTree   │ │ │ │   │ ├── safe-stable-stringify@2.3.1
      13769 silly saveTree   │ │ │ │   │ └── triple-beam@1.3.0
      13769 silly saveTree   │ │ │ │   ├─┬ readable-stream@3.6.0
      13769 silly saveTree   │ │ │ │   │ └─┬ string_decoder@1.3.0
      13769 silly saveTree   │ │ │ │   │   └── safe-buffer@5.2.1
      13769 silly saveTree   │ │ │ │   └── triple-beam@1.3.0
      13769 silly saveTree   │ │ │ ├── ci-info@3.3.0
      13769 silly saveTree   │ │ │ ├── deep-clone@3.0.3
      13769 silly saveTree   │ │ │ ├─┬ event-stream@4.0.1
      13769 silly saveTree   │ │ │ │ ├── duplexer@0.1.2
      13769 silly saveTree   │ │ │ │ ├── from@0.1.7
      13769 silly saveTree   │ │ │ │ ├── map-stream@0.0.7
      13769 silly saveTree   │ │ │ │ ├─┬ pause-stream@0.0.11
      13769 silly saveTree   │ │ │ │ │ └── through@2.3.8
      13769 silly saveTree   │ │ │ │ ├── split@1.0.1
      13769 silly saveTree   │ │ │ │ ├── stream-combiner@0.2.2
      13769 silly saveTree   │ │ │ │ └── through@2.3.8
      13769 silly saveTree   │ │ │ ├─┬ jsonwebtoken@8.5.1
      13769 silly saveTree   │ │ │ │ ├─┬ jws@3.2.2
      13769 silly saveTree   │ │ │ │ │ └── jwa@1.4.1
      13769 silly saveTree   │ │ │ │ ├── lodash.includes@4.3.0
      13769 silly saveTree   │ │ │ │ ├── lodash.isboolean@3.0.3
      13769 silly saveTree   │ │ │ │ ├── lodash.isinteger@4.0.4
      13769 silly saveTree   │ │ │ │ ├── lodash.isnumber@3.0.3
      13769 silly saveTree   │ │ │ │ ├── lodash.isplainobject@4.0.6
      13769 silly saveTree   │ │ │ │ ├── lodash.isstring@4.0.1
      13769 silly saveTree   │ │ │ │ ├── lodash.once@4.1.1
      13769 silly saveTree   │ │ │ │ ├── ms@2.1.3
      13769 silly saveTree   │ │ │ │ └── semver@5.7.1
      13769 silly saveTree   │ │ │ ├─┬ node.extend@2.0.2
      13769 silly saveTree   │ │ │ │ └── is@3.3.0
      13769 silly saveTree   │ │ │ ├── promisify-child-process@4.1.1
      13769 silly saveTree   │ │ │ ├── readline@1.3.0
      13769 silly saveTree   │ │ │ ├─┬ winston-daily-rotate-file@4.6.1
      13769 silly saveTree   │ │ │ │ ├─┬ file-stream-rotator@0.6.1
      13769 silly saveTree   │ │ │ │ │ └── moment@2.29.1
      13769 silly saveTree   │ │ │ │ └── object-hash@2.2.0
      13769 silly saveTree   │ │ │ ├─┬ winston-syslog@2.5.0
      13769 silly saveTree   │ │ │ │ ├── glossy@0.1.7
      13769 silly saveTree   │ │ │ │ └── unix-dgram@2.0.4
      13769 silly saveTree   │ │ │ └─┬ winston@3.6.0
      13769 silly saveTree   │ │ │   ├─┬ @dabh/diagnostics@2.0.3
      13769 silly saveTree   │ │ │   │ ├─┬ colorspace@1.1.4
      13769 silly saveTree   │ │ │   │ │ ├─┬ color@3.2.1
      13769 silly saveTree   │ │ │   │ │ │ ├─┬ color-convert@1.9.3
      13769 silly saveTree   │ │ │   │ │ │ │ └── color-name@1.1.3
      13769 silly saveTree   │ │ │   │ │ │ └─┬ color-string@1.9.0
      13769 silly saveTree   │ │ │   │ │ │   └─┬ simple-swizzle@0.2.2
      13769 silly saveTree   │ │ │   │ │ │     └── is-arrayish@0.3.2
      13769 silly saveTree   │ │ │   │ │ └── text-hex@1.0.0
      13769 silly saveTree   │ │ │   │ ├── enabled@2.0.0
      13769 silly saveTree   │ │ │   │ └── kuler@2.0.0
      13769 silly saveTree   │ │ │   ├── async@3.2.3
      13769 silly saveTree   │ │ │   ├─┬ one-time@1.0.0
      13769 silly saveTree   │ │ │   │ └── fn.name@1.1.0
      13769 silly saveTree   │ │ │   ├─┬ readable-stream@3.6.0
      13769 silly saveTree   │ │ │   │ └─┬ string_decoder@1.3.0
      13769 silly saveTree   │ │ │   └── stack-trace@0.0.10
      13769 silly saveTree   │ │ ├── deep-clone@3.0.3
      13769 silly saveTree   │ │ └── respjs@4.2.0
      13769 silly saveTree   │ ├─┬ @iobroker/db-objects-redis@4.0.15
      13769 silly saveTree   │ │ └─┬ ioredis@4.28.5
      13769 silly saveTree   │ │   ├── cluster-key-slot@1.1.0
      13769 silly saveTree   │ │   ├── denque@1.5.1
      13769 silly saveTree   │ │   ├── lodash.defaults@4.2.0
      13769 silly saveTree   │ │   ├── lodash.flatten@4.4.0
      13769 silly saveTree   │ │   ├── lodash.isarguments@3.1.0
      13769 silly saveTree   │ │   ├── p-map@2.1.0
      13769 silly saveTree   │ │   ├── redis-commands@1.7.0
      13769 silly saveTree   │ │   ├── redis-errors@1.2.0
      13769 silly saveTree   │ │   ├── redis-parser@3.0.0
      13769 silly saveTree   │ │   └── standard-as-callback@2.1.0
      13769 silly saveTree   │ └── deep-clone@3.0.3
      13769 silly saveTree   ├─┬ @iobroker/db-objects-jsonl@4.0.15
      13769 silly saveTree   │ └─┬ @alcalzone/jsonl-db@2.5.1
      13769 silly saveTree   │   ├─┬ alcalzone-shared@4.0.1
      13769 silly saveTree   │   └─┬ proper-lockfile@4.1.2
      13769 silly saveTree   │     └── retry@0.12.0
      13769 silly saveTree   ├── @iobroker/db-objects-redis@4.0.15
      13769 silly saveTree   ├─┬ @iobroker/db-states-file@4.0.15
      13769 silly saveTree   │ └── @iobroker/db-states-redis@4.0.15
      13769 silly saveTree   ├── @iobroker/db-states-jsonl@4.0.15
      13769 silly saveTree   ├── @iobroker/db-states-redis@4.0.15
      13769 silly saveTree   ├─┬ @iobroker/js-controller-adapter@4.0.15
      13769 silly saveTree   │ ├── @iobroker/plugin-base@1.2.1
      13769 silly saveTree   │ ├─┬ @iobroker/plugin-sentry@1.2.0
      13769 silly saveTree   │ │ ├─┬ @sentry/integrations@6.18.0
      13769 silly saveTree   │ │ │ ├── @sentry/types@6.18.0
      13769 silly saveTree   │ │ │ ├─┬ @sentry/utils@6.18.0
      13769 silly saveTree   │ │ │ │ └── tslib@1.14.1
      13769 silly saveTree   │ │ │ ├─┬ localforage@1.10.0
      13769 silly saveTree   │ │ │ │ └─┬ lie@3.1.1
      13769 silly saveTree   │ │ │ │   └── immediate@3.0.6
      13769 silly saveTree   │ │ │ └── tslib@1.14.1
      13769 silly saveTree   │ │ ├─┬ @sentry/node@6.18.0
      13769 silly saveTree   │ │ │ ├─┬ @sentry/core@6.18.0
      13769 silly saveTree   │ │ │ │ ├── @sentry/hub@6.18.0
      13769 silly saveTree   │ │ │ │ └── @sentry/minimal@6.18.0
      13769 silly saveTree   │ │ │ ├── @sentry/hub@6.18.0
      13769 silly saveTree   │ │ │ ├── @sentry/tracing@6.18.0
      13769 silly saveTree   │ │ │ └── lru_map@0.3.3
      13769 silly saveTree   │ │ └─┬ source-map-support@0.5.21
      13769 silly saveTree   │ │   ├── buffer-from@1.1.2
      13769 silly saveTree   │ │   └── source-map@0.6.1
      13769 silly saveTree   │ └─┬ pidusage@3.0.0
      13769 silly saveTree   │   └── safe-buffer@5.2.1
      13769 silly saveTree   ├─┬ @iobroker/js-controller-cli@4.0.15
      13769 silly saveTree   │ ├─┬ @iobroker/js-controller-common-db@4.0.15
      13769 silly saveTree   │ │ └─┬ winston-seq-updated@1.0.4
      13769 silly saveTree   │ │   └── seq-logging@0.4.6
      13769 silly saveTree   │ ├─┬ chokidar@3.5.3
      13769 silly saveTree   │ │ ├─┬ anymatch@3.1.2
      13769 silly saveTree   │ │ │ ├── normalize-path@3.0.0
      13769 silly saveTree   │ │ │ └── picomatch@2.3.1
      13769 silly saveTree   │ │ ├─┬ braces@3.0.2
      13769 silly saveTree   │ │ │ └─┬ fill-range@7.0.1
      13769 silly saveTree   │ │ │   └─┬ to-regex-range@5.0.1
      13769 silly saveTree   │ │ │     └── is-number@7.0.0
      13769 silly saveTree   │ │ ├── fsevents@2.3.2
      13769 silly saveTree   │ │ ├─┬ glob-parent@5.1.2
      13769 silly saveTree   │ │ │ └─┬ is-glob@4.0.3
      13769 silly saveTree   │ │ │   └── is-extglob@2.1.1
      13769 silly saveTree   │ │ ├─┬ is-binary-path@2.1.0
      13769 silly saveTree   │ │ │ └── binary-extensions@2.2.0
      13769 silly saveTree   │ │ ├── is-glob@4.0.3
      13769 silly saveTree   │ │ ├── normalize-path@3.0.0
      13769 silly saveTree   │ │ └── readdirp@3.6.0
      13769 silly saveTree   │ ├── daemonize2@0.4.2
      13769 silly saveTree   │ ├─┬ debug@4.3.3
      13769 silly saveTree   │ └── readline-sync@1.4.10
      13769 silly saveTree   ├── @iobroker/js-controller-common-db@4.0.15
      13769 silly saveTree   ├── @iobroker/js-controller-common@4.0.15
      13769 silly saveTree   ├── @iobroker/plugin-base@1.2.1
      13769 silly saveTree   ├── @iobroker/plugin-sentry@1.2.0
      13769 silly saveTree   ├── axios@0.24.0
      13769 silly saveTree   ├── daemonize2@0.4.2
      13769 silly saveTree   ├─┬ debug@4.3.3
      13769 silly saveTree   ├─┬ decache@4.6.1
      13769 silly saveTree   │ └── callsite@1.0.0
      13769 silly saveTree   ├── deep-clone@3.0.3
      13769 silly saveTree   ├─┬ diskusage@1.1.3
      13769 silly saveTree   │ └── es6-promise@4.2.8
      13769 silly saveTree   ├─┬ greenlock-express@4.0.3
      13769 silly saveTree   │ ├─┬ @root/greenlock-express@4.0.4
      13769 silly saveTree   │ │ ├─┬ @root/greenlock@4.0.5
      13769 silly saveTree   │ │ │ ├─┬ @greenlock/manager@3.1.0
      13769 silly saveTree   │ │ │ │ └─┬ greenlock-manager-fs@3.1.1
      13769 silly saveTree   │ │ │ │   ├── @root/mkdirp@1.0.0
      13769 silly saveTree   │ │ │ │   └── safe-replace@1.1.0
      13769 silly saveTree   │ │ │ ├─┬ @root/acme@3.1.0
      13769 silly saveTree   │ │ │ │ ├─┬ @root/csr@0.8.1
      13769 silly saveTree   │ │ │ │ │ ├─┬ @root/asn1@1.0.0
      13769 silly saveTree   │ │ │ │ │ │ └── @root/encoding@1.0.1
      13769 silly saveTree   │ │ │ │ │ ├── @root/pem@1.0.4
      13769 silly saveTree   │ │ │ │ │ └── @root/x509@0.7.2
      13769 silly saveTree   │ │ │ │ ├── @root/encoding@1.0.1
      13769 silly saveTree   │ │ │ │ ├── @root/keypairs@0.10.3
      13769 silly saveTree   │ │ │ │ ├── @root/pem@1.0.4
      13769 silly saveTree   │ │ │ │ ├── @root/request@1.8.1
      13769 silly saveTree   │ │ │ │ └── @root/x509@0.7.2
      13769 silly saveTree   │ │ │ ├── @root/csr@0.8.1
      13769 silly saveTree   │ │ │ ├── @root/keypairs@0.10.3
      13769 silly saveTree   │ │ │ ├── @root/mkdirp@1.0.0
      13769 silly saveTree   │ │ │ ├── @root/request@1.8.1
      13769 silly saveTree   │ │ │ ├── acme-http-01-standalone@3.0.5
      13769 silly saveTree   │ │ │ ├── cert-info@1.5.1
      13769 silly saveTree   │ │ │ ├── greenlock-store-fs@3.2.2
      13769 silly saveTree   │ │ │ └── safe-replace@1.1.0
      13769 silly saveTree   │ │ └── redirect-https@1.3.1
      13769 silly saveTree   │ ├── @root/greenlock@4.0.5
      13769 silly saveTree   │ └── redirect-https@1.3.1
      13769 silly saveTree   ├─┬ greenlock@4.0.4
      13769 silly saveTree   │ └── @root/keypairs@0.9.0
      13769 silly saveTree   ├── jsonwebtoken@8.5.1
      13769 silly saveTree   ├─┬ jszip@3.7.1
      13769 silly saveTree   │ ├── lie@3.3.0
      13769 silly saveTree   │ ├── pako@1.0.11
      13769 silly saveTree   │ ├─┬ readable-stream@2.3.7
      13769 silly saveTree   │ │ ├── isarray@1.0.0
      13769 silly saveTree   │ │ └── string_decoder@1.1.1
      13769 silly saveTree   │ └── set-immediate-shim@1.0.1
      13769 silly saveTree   ├─┬ le-acme-core@2.1.4
      13769 silly saveTree   │ └─┬ rsa-compat@1.9.4
      13769 silly saveTree   │   ├─┬ keypairs@1.2.14
      13769 silly saveTree   │   │ ├── eckles@1.4.1
      13769 silly saveTree   │   │ └── rasha@1.2.5
      13769 silly saveTree   │   ├── node-forge@0.7.6
      13769 silly saveTree   │   └── ursa-optional@0.9.10
      13769 silly saveTree   ├── le-challenge-fs@2.0.9
      13769 silly saveTree   ├── le-sni-auto@2.1.9
      13769 silly saveTree   ├─┬ loadavg-windows@1.1.1
      13769 silly saveTree   │ └── weak-daemon@1.0.3
      13769 silly saveTree   ├── mime@3.0.0
      13769 silly saveTree   ├── pidusage@3.0.0
      13769 silly saveTree   ├── promisify-child-process@4.1.1
      13769 silly saveTree   ├─┬ prompt@1.2.2
      13769 silly saveTree   │ ├── async@0.9.2
      13769 silly saveTree   │ ├─┬ read@1.0.7
      13769 silly saveTree   │ │ └── mute-stream@0.0.8
      13769 silly saveTree   │ ├── revalidator@0.1.8
      13769 silly saveTree   │ └─┬ winston@2.4.5
      13769 silly saveTree   │   ├── async@1.0.0
      13769 silly saveTree   │   ├── colors@1.0.3
      13769 silly saveTree   │   ├── cycle@1.0.3
      13769 silly saveTree   │   └── eyes@0.1.8
      13769 silly saveTree   ├── readline-sync@1.4.10
      13769 silly saveTree   ├─┬ tar@6.1.11
      13769 silly saveTree   │ ├── chownr@2.0.0
      13769 silly saveTree   │ ├─┬ fs-minipass@2.1.0
      13769 silly saveTree   │ │ └── minipass@3.1.6
      13769 silly saveTree   │ ├── minipass@3.1.6
      13769 silly saveTree   │ ├── minizlib@2.1.2
      13769 silly saveTree   │ └── mkdirp@1.0.4
      13769 silly saveTree   └─┬ yargs@17.3.1
      13769 silly saveTree     ├─┬ cliui@7.0.4
      13769 silly saveTree     │ ├─┬ string-width@4.2.3
      13769 silly saveTree     │ │ ├── emoji-regex@8.0.0
      13769 silly saveTree     │ │ ├── is-fullwidth-code-point@3.0.0
      13769 silly saveTree     │ │ └─┬ strip-ansi@6.0.1
      13769 silly saveTree     │ │   └── ansi-regex@5.0.1
      13769 silly saveTree     │ ├── strip-ansi@6.0.1
      13769 silly saveTree     │ └─┬ wrap-ansi@7.0.0
      13769 silly saveTree     │   ├─┬ ansi-styles@4.3.0
      13769 silly saveTree     │   │ └─┬ color-convert@2.0.1
      13769 silly saveTree     │   │   └── color-name@1.1.4
      13769 silly saveTree     │   └── strip-ansi@6.0.1
      13769 silly saveTree     ├── escalade@3.1.1
      13769 silly saveTree     ├── get-caller-file@2.0.5
      13769 silly saveTree     ├── require-directory@2.1.1
      13769 silly saveTree     ├─┬ string-width@4.2.3
      13769 silly saveTree     │ ├── is-fullwidth-code-point@3.0.0
      13769 silly saveTree     │ └─┬ strip-ansi@6.0.1
      13769 silly saveTree     │   └── ansi-regex@5.0.1
      13769 silly saveTree     ├── y18n@5.0.8
      13769 silly saveTree     └── yargs-parser@21.0.0
      13770 warn optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      13771 warn notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      13772 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid OS:    darwin
      13772 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Valid Arch:  any
      13772 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual OS:   linux
      13772 verbose notsup SKIPPING OPTIONAL DEPENDENCY: Actual Arch: arm
      13773 verbose stack Error: iobroker.js-controller@4.0.15 install: `node iobroker.js setup first`
      13773 verbose stack Exit status 22
      13773 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13773 verbose stack     at EventEmitter.emit (events.js:400:28)
      13773 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13773 verbose stack     at ChildProcess.emit (events.js:400:28)
      13773 verbose stack     at maybeClose (internal/child_process.js:1058:16)
      13773 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
      13774 verbose pkgid iobroker.js-controller@4.0.15
      13775 verbose cwd /opt/iobroker
      13776 verbose Linux 5.10.92-v7l+
      13777 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "--production" "--loglevel" "error" "--unsafe-perm"
      13778 verbose node v14.19.0
      13779 verbose npm  v6.14.16
      13780 error code ELIFECYCLE
      13781 error errno 22
      13782 error iobroker.js-controller@4.0.15 install: `node iobroker.js setup first`
      13782 error Exit status 22
      13783 error Failed at the iobroker.js-controller@4.0.15 install script.
      13783 error This is probably not a problem with npm. There is likely additional logging output above.
      13784 verbose exit [ 22, true ]
      code_texpi@raspberrypi4:~ $ cd /opt/iobroker
      pi@raspberrypi4:/opt/iobroker $ iobroker stop
      pi@raspberrypi4:/opt/iobroker $ npm install iobroker.js-controller
      > iobroker.js-controller@4.0.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
        CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      In file included from ../../nan/nan.h:58,
                       from ../src/unix_dgram.cc:5:
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        793 |       (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
        404 | NODE_MODULE(unix_dgram, Initialize)
        SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
        COPY Release/unix_dgram.node
      make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
        CXX(target) Release/obj.target/diskusage/src/main.o
                       from ../src/main.cpp:3:
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
         42 | NODE_MODULE(diskusage, Init)
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
      > iobroker.js-controller@4.0.15 install /opt/iobroker/node_modules/iobroker.js-controller
       Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
       Cannot read system.config: null (OK when migrating or restoring)
      No connection to databases possible ...
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 22
      npm ERR! iobroker.js-controller@4.0.15 install: `node iobroker.js setup first`
      npm ERR! Exit status 22
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.15 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2022-02-26T22_28_45_404Z-debug.log
      pi@raspberrypi4:/opt/iobroker $ iobroker setup
      internal/modules/cjs/loader.js:905
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
          at Function.Module._load (internal/modules/cjs/loader.js:746:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi4:/opt/iobroker $ iobroker add admin
        throw err;
        requireStack: []
      t
        Hape1 last edited by
        pi@raspberrypi4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.0
        v14.19.0
        8.5.2
        pi
        /home/pi
        OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:3 https://download.docker.com/linux/raspbian bullseye InRelease
        OK:4 https://repos.influxdata.com/debian bullseye InRelease
        OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
        Paketlisten werden gelesen… Fertig
        Abhängigkeitsbaum wird aufgebaut… Fertig
        Statusinformationen werden eingelesen… Fertig
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           14.19.0-deb-1nodesource1
          Installationskandidat: 14.19.0-deb-1nodesource1
          Versionstabelle:
         *** 14.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.5~dfsg-2~11u1 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        pi@raspberrypi4:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm ERR! code 24
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
        npm ERR!  Cannot read system.config: null (OK when migrating or restoring)
        npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
        npm ERR!     /home/iobroker/.npm/_logs/2022-02-27T12_21_20_675Z-debug-0.log
        pi@raspberrypi4:/opt/iobroker $ iobroker fix
        library: loaded
        Library version=2022-02-10
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          Thomas Braun Most Active @Hape1 last edited by
          @hape1 sagte in Raspi4 4GB --> Installation --> Cannot find module ...:
          npm 8.5.2 ist nicht die für nodejs@14 vorgesehene Version. Installier node 14.19.0 nochmal sauber neu.
            Mir gelingt das deinstallieren von node nicht:
            pi@raspberrypi4:~ $ sudo apt-get purge nodejs
            Die folgenden Pakete werden ENTFERNT:
              nodejs*
            0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
            Nach dieser Operation werden 117 MB Plattenplatz freigegeben.
            Möchten Sie fortfahren? [J/n] j
            (Lese Datenbank ... 69365 Dateien und Verzeichnisse sind derzeit installiert.)
            Entfernen von nodejs (14.19.0-deb-1nodesource1) ...
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/docs« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/emoji-regex« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/brace-expansion« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/normalize-package-data« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/minizlib« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/infer-owner« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/chownr« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ip-regex« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/abbrev« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/supports-color« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/debug/node_modules/ms« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/debug/src« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/has-unicode« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ssri« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/concat-map« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/readdir-scoped-modules« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/humanize-ms« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/promzard« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/yallist« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/is-cidr« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/libnpmhook« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/hosted-git-info« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/asap« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/glob« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ini« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/graceful-fs« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/dezalgo« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-registry-fetch« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-profile« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/smart-buffer« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/chalk« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/retry« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/tiny-relative-date« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/function-bind« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/write-file-atomic« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/color-convert« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/util-deprecate« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/http-proxy-agent« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/is-typedarray« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/aproba« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/opener« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/safe-buffer« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/libnpmaccess« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-package-arg« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/clone« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/http-cache-semantics« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/spdx-expression-parse« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/agent-base« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/nopt« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/cli-columns« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/bin-links« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/init-package-json« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/stringify-package« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/validate-npm-package-license« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/cacache/lib/util« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ansicolors« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ansistyles« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-install-checks« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/has-flag« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/gauge/node_modules« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/lru-cache« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/spdx-correct« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/unique-filename« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/string-width/node_modules/ansi-regex« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/string-width/node_modules/strip-ansi« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ip« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/libnpmteam« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/inflight« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ignore-walk« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/path-is-absolute« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/iconv-lite/encodings« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/make-fetch-happen« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/safer-buffer« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/libnpmorg« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/mute-stream« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/isexe« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/rimraf« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/fs.realpath« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/libnpmpublish« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/text-table« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ansi-styles« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/node-gyp/.github/workflows« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/node-gyp/gyp« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/node-gyp/lib« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/semver/bin« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/delegates« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/once« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/wrappy« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/ms« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/socks-proxy-agent« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/encoding« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/fs-minipass« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/console-control-strings« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/colors« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/cidr-regex« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/err-code« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/balanced-match« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/readable-stream« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-audit-report/lib« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/libnpmsearch« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/https-proxy-agent« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/wide-align« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-packlist« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/cli-table3« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-pick-manifest« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/wcwidth« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npmlog« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/pacote/lib/util« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/promise-retry« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/unique-slug« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/debuglog« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/set-blocking« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/minimatch« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/are-we-there-yet« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/validate-npm-package-name« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/has« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/read« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/color-name« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/read-package-json« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/agentkeepalive/lib« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/which/bin« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/cmd-shim« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/signal-exit« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/columnify« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/inherits« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/socks/typings/common« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/archy« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-bundled« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/string_decoder« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/read-cmd-shim« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/tar/lib« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/defaults« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/qrcode-terminal« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/builtins« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/mkdirp« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/npm-user-validate« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/jsonparse« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/promise-inflight« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/node_modules/env-paths« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/man/man7« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/man/man5« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/man/man1« nicht leer, wird daher nicht gelöscht
            dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules/npm/lib/utils« nicht leer, wird daher nicht gelöscht
            Trigger für man-db (2.9.4-2) werden verarbeitet ...
            pi@raspberrypi4:~ $
              Thomas Braun Most Active @Hape1 last edited by Thomas Braun
              @hape1
              Wer hat denn von purge gesprochen?
              sudo apt remove node*
              sudo apt remove nodejs*
              sudo apt update
              sudo apt install --reinstall nodejs
                danke, done --> und nun?
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.19.0
                v14.19.0
                6.14.16
                pi
                /home/pi
                OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                nodejs:
                 Versionstabelle:
                  Homoran Global Moderator Administrators @Hape1 last edited by
                  habe mich an die Anleitung gehalten,
                  an welche?
                  da scheint ja schon grundsätzlich einiges schief (gewesen??) zu sein
                  Spätestens mit npm v8 könnte die Verwaltung der notwendigen npm-Module sagen wir mal vorsichtig "iobroker inkompatibel" ausgeführt worden sein.
                  Wenn da jetzt nicht so vieles andere schon drauf wäre, würde ich zu einer Neuinstallation raten.
                  Aber vielleicht bekommen wir es noch hin, wenn wir wissen, was du genau gemacht hast
                    naja, ich habe von der iobroker-Seite die Kommandozeile kopiert und ausgeführt:
                    curl -sLf https://iobroker.net/install.sh | bash -
                    Dann kam es zu Fehlermeldungen:
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v14.19.0
                    v14.19.0
                    8.5.2
                    pi
                    /home/pi
                    nodejs:
                      Versionstabelle:
                    npm ERR! code 24
                    library: loaded
                    Es wäre mir auch egal alles auf dem System installierte wieder runterzuholen und neu zu installieren --> es ist ja noch gar nix in iobroker installiert --> wie auch, das Programm ist ja nicht über die ip:8081 erreichbar ...
                    Es wäre nett, wenn ihr mir sagt, wie alles wieder komplett deinstalliert und dann neu aufgesetzt wird.
                    Kann es vllt. auch damit zusammenhängen, das ja bereits auf der gleichen ip die Apps Portainer (Ports 9000 und 9443), AdGuard und Grafana mit telegraf auf dem Pi laufen ... ?
                      Homoran Global Moderator Administrators @Hape1 last edited by Homoran
                      war denn vorher schon eine nodejs Version drauf?
                      Der "Einzeiler" hätte sonst node v14 mit npm v6 installiert
                      Das dürfte man im log sehen.
                      Aber wenn der port 9000 vergeben ist kann die interne datenbank diesen nicht nutzen
                      Apps Portainer
                      hab ich das irgendwo überlesen, dass hier mit Containern gearbeitet wird?
                        Auf dem Port 9000 läuft auch die Datenbank, die du da natürlich nicht erreichen kannst, weil da schon der Portainer läuft.
                        Warum man auf den kleinen Pi auch noch einen Docker-Container knallt erschließt sich mir allerdings auch nicht.
                          Hape1 @Thomas Braun last edited by
                          also, in meinem Eingangspost steht, welche Apps auf dem Pi laufen ... Kann man den Port für die Datenbank von iobroker denn ändern?
                            Hab ich zwar auch gelesen, aber nicht realisiert was eine "App Portainer" sein sollte . Vom Port stand da aber schon mal gar nichts
                            Jetzt müsste ich den Thread aus den Einsteigerfragen verschieben, da so eine Konstellation nu wirklich keine Einsdeiger-Konfiguration ist.
                              @hape1 Ja, geht soweit ich weiß natürlich irgendwie.
                              Hab den Befehl aber nicht im Kopf.
                              Weil ich neugierig bin: Was veranlasst einen auf dem Pi mit Docker herumzukutschieren?
                                Das sollte auch nicht als Vorwurf rüberkommen, ich habe auch nicht realisiert, das iobroker auf Port 9000 horcht. Also, alles gut! Bliebe also die Frage, ob man den Port der ioBroker Datenbank ändern kann.
                                  Hape1 @Homoran last edited by Hape1
                                  Ok, ich konnte den Port 9000 vom Portainer ausschalten. iobroker ist nun auch installiert, aber es fehlt etwas:
                                  Linux raspberrypi4 5.10.92-v7l+ #1514 SMP Mon Jan 17 17:38:03 GMT 2022 armv7l
                                  The programs included with the Debian GNU/Linux system are free software;
                                  the exact distribution terms for each program are described in the
                                  individual files in /usr/share/doc/*/copyright.
                                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                  permitted by applicable law.
                                  Last login: Sun Feb 27 18:26:27 2022 from 192.168.1.161
                                  pi@raspberrypi4:~ $ iobroker start
                                  pi@raspberrypi4:/opt/iobroker $ cd /opt/iobroker
                                  pi@raspberrypi4:/opt/iobroker $ sudo iobroker stop
                                  pi@raspberrypi4:/opt/iobroker $ sudo iobroker update
                                    throw err;
                                    requireStack: []
                                  Habe nun versucht, den fehlenden js-Controller nachzuinstallieren. Es wird aber immer noch angemeckert, das der Port 9000 von einem anderen Server (was wohl der 9000er-Port von Portainer ist) verwendet wird:
                                   The DB port  9000 is occupied by something that is not a Redis protocol server. Please check other software running on this port or, if you use iobroker, make sure to update to js-controller 2.0 or higher!
                                    Vielen Dank für Eure Hilfe --> ich habe mich entschlossen das Thema iobroker auf dem Pi erstmal zurückzustellen. Sollte ich das Thema wieder aufgreifen, melde ich mich wieder.
                                      @hape1
                                      Was läuft denn da eigentlich in dem Docker?
                                        Um auf Deine Frage zu antworten: Zunächst Portainer, als umfangreiches Deployment-Tool für Container auf dem Docker, dann Grafana mit telegraf als Monitoring für den Pi und AdGuard als Nameserver um unerwünnschte Werbung zu blocken ... dat is et. 😊
                                          @hape1
                                          Würde ich alles direkt auf dem Pi ausführen und mir die Zwischenebene Docker sparen.
                                          2061
