    3. Einsteigerfragen
    4. Installation
    5. Admin nicht erreichbar
      Thomas Braun Most Active @K. K. 1 last edited by
      @k-k-1 sagte in Admin nicht erreichbar:
      iobroker install admin
      Versuch mal
      sudo -u -H iobroker iobroker install admin@5.3.1
      K. K. 1 1 Reply Last reply Reply Quote 0
      • K. K. 1
        K. K. 1 @Thomas Braun last edited by
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ iobroker start admin
        pi@raspberrypi:/opt/iobroker $ sudo -u -H iobroker iobroker install admin@5.3.1
        sudo: Unbekannter Benutzer: -H
        sudo: Audit-Plugin sudoers_audit konnte nicht initialisiert werden
          @k-k-1 Sorry, Blödsinn von mir.
          Besser:
          • K. K. 1
            pi@raspberrypi:/opt/iobroker $ iobroker install admin@5.3.1
            adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
              @k-k-1
              iobroker upgrade admin@5.3.1
              • K. K. 1
                Would you like to upgrade admin from @0.0.0 to @5.3.1 now? [(y)es, (n)o]: y
                Update admin from @0.0.0 to @5.3.1
                host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                NPM version: 8.1.2
                npm install iobroker.admin@5.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/accepts
                npm ERR! dest /opt/iobroker/node_modules/.accepts-rBwU1CL7
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/accepts' -> '/opt/iobroker/node_modules/.accepts-rBwU1CL7'
                npm ERR!     /home/iobroker/.npm/_logs/2022-02-27T17_35_39_508Z-debug.log
                host.raspberrypi Cannot install iobroker.admin@5.3.1: 217
                crunchip Thomas Braun 3 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @K. K. 1 last edited by
                  NPM version: 8.1.2
                  wie kommst du dazu?
                    @k-k-1
                    sudo ln -s /usr/bin/node /usr/bin/nodejs
                    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    K. K. 1 2 Replies Last reply Reply Quote 0
                    • K. K. 1
                      K. K. 1 @crunchip last edited by
                      @crunchip
                      Hab ich nicht bewusst gemacht ...
                      • K. K. 1
                        @thomas-braun said in Admin nicht erreichbar:
                        da passiert nichts
                        • K. K. 1
                          doch jetzt
                          pi@raspberrypi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.13.2
                          v16.13.2
                          8.1.2
                          pi
                          /opt/iobroker
                          crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                            @k-k-1 ok passt
                              @k-k-1 Da fehlt was in der Ausgabe.
                              • K. K. 1
                                wenn ich es nochmal starte kommt jetzt folgendes
                                pi@raspberrypi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                ln: die symbolische Verkn▒pfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                pi@raspberrypi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs~
                                ln: Ziel 'npm': Datei oder Verzeichnis nicht gefunden
                                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                  probier doch mal den Adapter zu deinstallieren und danach neu installieren
                                  iobroker del admin
                                  iobroker add admin
                                    @k-k-1
                                    Dem ersten Befehl brauchst du nicht mehr. Nur die zweite Befehlskette nochmal vorllständig.
                                      @k-k-1 du hast beide Befehle in einer zeile, ausserdem hast du ei ~ am Ende
                                      • K. K. 1
                                        @crunchip said in Admin nicht erreichbar:
                                        so jetzt aber
                                        pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.13.2
                                        v16.13.2
                                        8.1.2
                                        pi
                                        /home/pi
                                        OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Paketlisten werden gelesen… Fertig
                                        Abhängigkeitsbaum wird aufgebaut… Fertig
                                        Statusinformationen werden eingelesen… Fertig
                                        Aktualisierung für 12 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                        nodejs:
                                          Installiert:           16.13.2-deb-1nodesource1
                                          Installationskandidat: 16.14.0-deb-1nodesource1
                                          Versionstabelle:
                                             16.14.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                         *** 16.13.2-deb-1nodesource1 100
                                                100 /var/lib/dpkg/status
                                             12.22.5~dfsg-2~11u1 500
                                                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                        • K. K. 1
                                          @crunchip
                                          Ist der Fehler kritisch?
                                          pi@raspberrypi:/opt/iobroker $ iobroker del admin
                                          Delete adapter "admin"
                                          host.raspberrypi Counted 1 instances of admin
                                          host.raspberrypi Counted 2 meta of admin
                                          host.raspberrypi Counted 1 adapter for admin
                                          host.raspberrypi Counted 1 channels of admin
                                          host.raspberrypi Counted 9 states of admin
                                          host.raspberrypi Counted 16 states of system.adapter.admin
                                          host.raspberrypi Counted 9 states (io.admin.*) from states
                                          host.raspberrypi Counted 19 states (system.adapter.admin.*) from states
                                          host.raspberrypi Counted 1 objects of admin
                                          host.raspberrypi file admin deleted
                                          host.raspberrypi file admin.admin deleted
                                          host.raspberrypi object admin deleted
                                          host.raspberrypi object admin.admin deleted
                                          host.raspberrypi Deleting 31 object(s).
                                          host.raspberrypi Deleting 28 state(s).
                                          Error deleting adapter admin from disk: Error: Cannot find module 'iobroker.admin/io-package.json'
                                          Require stack:
                                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js
                                          - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                          You might have to delete it yourself!
                                          • K. K. 1
                                            @crunchip
                                            Muss ich da vorher noch irgend etwas löschen?
                                            pi@raspberrypi:/opt/iobroker $ iobroker add admin
                                            host.raspberrypi install adapter admin
                                            NPM version: 8.1.2
                                            npm ERR! errno -39
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-02-27T18_25_44_118Z-debug.log
                                            1891
