    3. Einsteigerfragen
    4. Installation
    5. Admin nicht erreichbar
    • K. K. 1
      K. K. 1 @Thomas Braun last edited by
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ iobroker start admin
      pi@raspberrypi:/opt/iobroker $ sudo -u -H iobroker iobroker install admin@5.3.1
      sudo: Unbekannter Benutzer: -H
      sudo: Audit-Plugin sudoers_audit konnte nicht initialisiert werden
        Thomas Braun Most Active @K. K. 1 last edited by
        @k-k-1 Sorry, Blödsinn von mir.
        Besser:
        K. K. 1 1 Reply Last reply Reply Quote 0
        • K. K. 1
          pi@raspberrypi:/opt/iobroker $ iobroker install admin@5.3.1
          adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
            @k-k-1
            iobroker upgrade admin@5.3.1
            • K. K. 1
              Would you like to upgrade admin from @0.0.0 to @5.3.1 now? [(y)es, (n)o]: y
              Update admin from @0.0.0 to @5.3.1
              host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
              NPM version: 8.1.2
              npm install iobroker.admin@5.3.1 --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! code ENOTEMPTY
              npm ERR! syscall rename
              npm ERR! path /opt/iobroker/node_modules/accepts
              npm ERR! dest /opt/iobroker/node_modules/.accepts-rBwU1CL7
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/accepts' -> '/opt/iobroker/node_modules/.accepts-rBwU1CL7'
              npm ERR!     /home/iobroker/.npm/_logs/2022-02-27T17_35_39_508Z-debug.log
              host.raspberrypi Cannot install iobroker.admin@5.3.1: 217
              crunchip Thomas Braun 3 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @K. K. 1 last edited by
                @k-k-1 sagte in Admin nicht erreichbar:
                NPM version: 8.1.2
                wie kommst du dazu?
                  @k-k-1
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  K. K. 1 2 Replies Last reply Reply Quote 0
                  • K. K. 1
                    K. K. 1 @crunchip last edited by
                    @crunchip
                    Hab ich nicht bewusst gemacht ...
                    • K. K. 1
                      @thomas-braun said in Admin nicht erreichbar:
                      da passiert nichts
                      • K. K. 1
                        doch jetzt
                        pi@raspberrypi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.13.2
                        v16.13.2
                        8.1.2
                        pi
                        /opt/iobroker
                        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                          @k-k-1 ok passt
                            @k-k-1 Da fehlt was in der Ausgabe.
                            • K. K. 1
                              wenn ich es nochmal starte kommt jetzt folgendes
                              pi@raspberrypi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                              ln: die symbolische Verkn▒pfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                              pi@raspberrypi:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs~
                              ln: Ziel 'npm': Datei oder Verzeichnis nicht gefunden
                              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                probier doch mal den Adapter zu deinstallieren und danach neu installieren
                                iobroker del admin
                                iobroker add admin
                                  @k-k-1
                                  Dem ersten Befehl brauchst du nicht mehr. Nur die zweite Befehlskette nochmal vorllständig.
                                    @k-k-1 du hast beide Befehle in einer zeile, ausserdem hast du ei ~ am Ende
                                    • K. K. 1
                                      @crunchip said in Admin nicht erreichbar:
                                      so jetzt aber
                                      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.13.2
                                      v16.13.2
                                      8.1.2
                                      pi
                                      /home/pi
                                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Paketlisten werden gelesen… Fertig
                                      Abhängigkeitsbaum wird aufgebaut… Fertig
                                      Statusinformationen werden eingelesen… Fertig
                                      Aktualisierung für 12 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                      nodejs:
                                        Installiert:           16.13.2-deb-1nodesource1
                                        Installationskandidat: 16.14.0-deb-1nodesource1
                                        Versionstabelle:
                                           16.14.0-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                       *** 16.13.2-deb-1nodesource1 100
                                              100 /var/lib/dpkg/status
                                           12.22.5~dfsg-2~11u1 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      • K. K. 1
                                        @crunchip
                                        Ist der Fehler kritisch?
                                        pi@raspberrypi:/opt/iobroker $ iobroker del admin
                                        Delete adapter "admin"
                                        host.raspberrypi Counted 1 instances of admin
                                        host.raspberrypi Counted 2 meta of admin
                                        host.raspberrypi Counted 1 adapter for admin
                                        host.raspberrypi Counted 1 channels of admin
                                        host.raspberrypi Counted 9 states of admin
                                        host.raspberrypi Counted 16 states of system.adapter.admin
                                        host.raspberrypi Counted 9 states (io.admin.*) from states
                                        host.raspberrypi Counted 19 states (system.adapter.admin.*) from states
                                        host.raspberrypi Counted 1 objects of admin
                                        host.raspberrypi file admin deleted
                                        host.raspberrypi file admin.admin deleted
                                        host.raspberrypi object admin deleted
                                        host.raspberrypi object admin.admin deleted
                                        host.raspberrypi Deleting 31 object(s).
                                        host.raspberrypi Deleting 28 state(s).
                                        Error deleting adapter admin from disk: Error: Cannot find module 'iobroker.admin/io-package.json'
                                        Require stack:
                                        - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js
                                        - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                        You might have to delete it yourself!
                                        • K. K. 1
                                          @crunchip
                                          Muss ich da vorher noch irgend etwas löschen?
                                          pi@raspberrypi:/opt/iobroker $ iobroker add admin
                                          host.raspberrypi install adapter admin
                                          NPM version: 8.1.2
                                          npm ERR! errno -39
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-02-27T18_25_44_118Z-debug.log
                                            @k-k-1
                                            Zuerst würde ich eine Etage tiefer klar Schiff machen:
                                            iobroker stop
                                            sudo apt update
                                            sudo apt full-upgrade
                                            sudo reboot
                                            1906
