    4. iQontrol Vis Support Thread
    • V
      vepman @dslraser last edited by
      @dslraser
      Homematic TFK:
        "from": "system.adapter.hm-rega.0",
        "user": "system.user.admin",
        "ts": 1641840969210,
        "common": {
          "name": "TFK_Wz_re",
          "icon": "/icons/16_hm-sec-sc_thumb.png"
        "native": {
          "ADDRESS": "KEQ1100000",
          "FIRMWARE": "2.4",
          "INTERFACE": "PEQ1841917",
          "PARENT": "",
          "TYPE": "HM-Sec-SC-2",
          "FLAGS": 1,
          "RF_ADDRESS": 2411964,
          "ROAMING": 0,
          "RX_MODE": 12,
          "UPDATABLE": 0,
          "VERSION": 16,
          "CHILDREN": [
            "KEQ1100000:0",
            "KEQ1100000:1"
          "PARAMSETS": [
            "MASTER"
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
        "_id": "hm-rpc.0.KEQ1100000",
        "type": "device"
      • dslraser
        dslraser Forum Testing Most Active @vepman last edited by
        @vepman sagte in iQontrol Vis Support Thread:
        Der DP aus rpc ist der den ich sehen möchte.
        hm-rpc.0.KEQ1100000
        • V
          @dslraser
          Sorry, falsch kopiert:
            "type": "state",
            "common": {
              "name": "TFK_Wz_re:1.STATE",
              "def": false,
              "type": "boolean",
              "read": true,
              "write": false,
              "role": "sensor.window",
              "custom": {
                "iqontrol.0": {
                  "enabled": true,
                  "readonly": false,
                  "invert": false,
                  "confirm": false,
                  "pincode": "",
                  "unit": "",
                  "unit_zero": "",
                  "unit_one": "",
                  "min": "",
                  "max": "",
                  "step": "",
                  "roundDigits": 2,
                  "timeFormat": "x",
                  "timeDisplayFormat": "dddd, DD.MM.YYYY HH:mm:ss",
                  "timeDisplayDontShowDistance": false,
                  "type": "boolean",
                  "targetValueId": "",
                  "states": {
                    "true": "auf",
                    "false": "zu"
                  "statesAddInput": false,
                  "statesAddInputCaption": "Enter other value...",
                  "showOnlyTargetValues": false
            "native": {
              "CONTROL": "DOOR_SENSOR.STATE",
              "DEFAULT": false,
              "FLAGS": 1,
              "ID": "STATE",
              "MAX": true,
              "MIN": false,
              "OPERATIONS": 5,
              "TAB_ORDER": 0,
              "TYPE": "BOOL",
              "UNIT": ""
            "ts": 1641840969291,
            "_id": "hm-rpc.0.KEQ1100000.1.STATE",
            "acl": {
              "object": 1636,
              "state": 1636,
          • dslraser
            "readonly": false,
            hm, sieht eigentlich alles richtig aus...
            Bis auf das hier vielleicht in den custom "readonly": false, (vielleicht mal den Haken setzen.)
            • V
              @dslraser
              Haken gesetzt, aber keine Änderung.
              • dslraser
                dslraser Forum Testing Most Active @vepman last edited by dslraser
                @dslraser
                gerade mal bei mir probiert (nur meine TFK habe 0 und 1) bei mir funktioniert es genau so...
                 "type": "state",
                 "common": {
                   "name": "Wohnzimmertür.STATE",
                   "def": 0,
                   "type": "number",
                   "read": true,
                   "write": false,
                   "min": 0,
                   "max": 1,
                   "states": {
                     "0": "CLOSED",
                     "1": "OPEN"
                   "role": "value.window",
                   "custom": {
                     "iqontrol.0": {
                       "enabled": true,
                       "readonly": true,
                       "invert": false,
                       "confirm": false,
                       "pincode": "",
                       "unit": "",
                       "unit_zero": "",
                       "unit_one": "",
                       "min": 0,
                       "max": 1,
                       "step": "",
                       "roundDigits": 2,
                       "timeFormat": "x",
                       "type": "number",
                       "role": "",
                       "states": {
                         "0": "zu",
                         "1": "auf"
                 "native": {
                   "MIN": "CLOSED",
                   "UNIT": "\"\"",
                   "OPERATIONS": 5,
                   "MAX": "OPEN",
                   "FLAGS": 1,
                   "ID": "STATE",
                   "TAB_ORDER": 0,
                   "TYPE": "ENUM",
                   "DEFAULT": "CLOSED",
                   "VALUE_LIST": [
                     "CLOSED",
                     "OPEN"
                 "ts": 1644135050211,
                 "_id": "hm-rpc.0.0000D569A39178.1.STATE",
                 "acl": {
                   "object": 1636,
                   "state": 1636,
                ohne custom
                EDIT:
                hier habe ich nichts eingestellt
                Jetzt habe ich auch als Gerät Fenster ausprobiert, geht auch.
                V 1 Reply Last reply Reply Quote 1
                • V
                  @dslraser
                  Habe mal interessehalber auch auf Type "number" umgestellt und "0" und "1" benutzt,
                  ergab aber auch keine Änderung.
                  Danach ioBroker neu gestartet, half aber nicht.
                  Verstehe ich nicht, warum das auf einmal nicht mehr geht.
                  JLeg s.bormann 2 Replies Last reply Reply Quote 0
                  • JLeg
                    JLeg @vepman last edited by
                    @vepman hast du die ‚gerätespezifischen Optionen‘ immer noch wie oben gezeigt gesetzt? Das dürfte so nicht funktionieren, da müssten true/false, also die ‚echten‘ Werte rein…
                    • s.bormann
                      s.bormann Most Active @vepman last edited by
                      @dslraser
                      Probier mal die role zu ändern. Bei sensor.window nutzt iQontrol recht spezifische Settings.
                      • V
                        vepman @s.bormann last edited by vepman
                        @s-bormann
                        Ja, habe mal die role auf "light" (Schalter) geändert und sofort wurde wie gewünscht mit "auf" und "zu" reagiert.
                        sensor.window ist wohl der Übeltäter. 👍
                        Kann man irgendwie ein "workaround" anwenden?
                        • dslraser
                          dslraser Forum Testing Most Active @JLeg last edited by
                          @jleg sagte in iQontrol Vis Support Thread:
                          @vepman
                          hast Du fas gelesen ? (und wieder raus genommen ?)
                          • V
                            vepman @dslraser last edited by vepman
                            @dslraser @jleg
                            Habe gerade mal true und false reingeschrieben und probiert: keine Änderung.
                            true und false wieder rausgenommen: auch keine Änderung.
                            Einzig wenn ich die role auf Schalter(light) ändere, geht es sofort. 🙄
                            Nebenbei bemerkt, habe ich eine Liste mit den Fenstern, da klappt es. Ist ja aber auch ein Widget. 😊
                            • dslraser
                              @vepman
                              bei mir ist die role value.window und es funktioniert. (kannst ja mal einen alias erstellen und damit mal testen)
                              • V
                                @dslraser
                                Hab mal mit alias ein Fenster erstellt und getestet, leider der gleiche Fehler.
                                Bei mir bleibt im alias auch sensor.window, welchen ich dann manuell auf value.window geändert hatte. Auch das ging nicht.
                                • dslraser
                                  @dslraser
                                  das ist alles seltsam…
                                  die role bei Dir sollte aber passen
                                  https://www.iobroker.net/#de/documentation/basics/roles.md
                                  @s-bormann
                                  Dann kann ich auch nicht weiter helfen, aber Sebastian nochmal ?
                                  V O 2 Replies Last reply Reply Quote 1
                                  • V
                                    @dslraser
                                    Trotzdem Danke für deine Mühe.
                                    Werde wohl von Kacheln auf Liste umschwenken.
                                    Die Fensterliste mit Kacheln war noch eine Relikt aus dem Anfang von iQontrol. 😁
                                      martinschm @vepman last edited by
                                      ich habe die Entwicklungen rund um iQontrol in letzter Zeit leider nicht mehr so aktiv verfolgen können wie früher. Ist es (mittlerweile) möglich, das man InfoA/B bei den schmalen Kacheln vertikal zentriert anzeigt?
                                      Sprich, das hier das Wort "Zuhause" nicht am unteren Rand klebt sondern weiter oben steht?
                                      Und ist es möglich bei InfoA/B einfach einen String als Beschriftung einzugeben, ohne ein State zu verlinken in dem der String als Wert steht?
                                      • O
                                        Opa75+ @dslraser last edited by
                                        @dslraser Bildschirmfoto 2022-03-05 um 10.19.07.png Bildschirmfoto 2022-03-05 um 10.18.14.png Bildschirmfoto 2022-03-05 um 10.17.33.png Bildschirmfoto 2022-03-05 um 10.16.27.png Bildschirmfoto 2022-03-05 um 10.07.16.png Bildschirmfoto 2022-03-05 um 10.06.24.png Ich habe versucht genau nach der Anleitung die Fensterliste zu erstellen.
                                        Leider bekomme ich nur den Rahmen mit Titel: Fensterleiste angezeigt! =>keine Fensterdaten "geöffnet oder geschlossen". Da ich die Anleitung bei der Erstellung des Widgets 2xgeprüft habe, glaube ich das der Fehler bei der Erstellung der Listen im Alias liegt. Anbei Fotos mit der Bitte um Prüfung.
                                        Besten Dank im Voraus
                                        O dslraser 2 Replies Last reply Reply Quote 0
                                        • O
                                          Opa75+ @Opa75+ last edited by
                                          @opa75 Nachtrag: Überschriften habe ich noch nicht begonnen!
                                          • dslraser
                                            dslraser Forum Testing Most Active @Opa75+ last edited by
                                            @opa75
                                            In der „Anleitung“ im Wiki siehst Du auch den RAW eines meiner alias. Diese alias sind vom type number und haben eine Werteliste (states). Ich verwende auch HMIP Geräte, aber über den rpc Adapter.
                                            Du nutzt anscheinend den HMIP Adapter über einen Access-Point…?(dieser liefert andere Datenpunkte)
                                            android app vis how-to ios app iqontrol mobile ui vis
                                            125
                                            1518
                                            644948
