    4. JavaScript
    5. Homematic - HmIP-eTRV-B - Ventilsteuerung
      Homoran Global Moderator Administrators @Wurzeldoktor last edited by
      @wurzeldoktor sagte in Homematic - HmIP-eTRV-B - Ventilsteuerung:
      meine instanzen sind alle am aktuellen stable stand
      bitte nicht als kleine Briefmarke, sondern als Text in Code-tags
        Wurzeldoktor @Homoran last edited by
        @homoran sagte in Homematic - HmIP-eTRV-B - Ventilsteuerung:
        Linux iobroker 4.19.0-18-amd64 #1 SMP Debian 4.19.208-1 (2021-09-29) x86_64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Sun Feb 27 12:14:04 2022 from 192.168.0.64
        daniel@iobroker:~$ Rega: 3.0.35
        -bash: Rega:: Kommando nicht gefunden.
        daniel@iobroker:~$ iobroker update -i
        Used repository: Stable (default)
        Adapter    "admin"        : 5.3.1    , installed 5.3.1
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "backitup"     : 2.3.3    , installed 2.3.3
        Adapter    "cloud"        : 4.1.0    , installed 4.1.0
        Adapter    "device-reminder": 1.2.9  , installed 1.2.9
        Adapter    "devices"      : 1.0.9    , installed 1.0.9
        Adapter    "discovery"    : 2.7.5    , installed 2.7.5
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fullybrowser" : 2.0.10   , installed 2.0.10
        Adapter    "hm-rega"      : 3.0.35   , installed 3.0.35
        Adapter    "hm-rpc"       : 1.15.0   , installed 1.15.0
        Adapter    "ical"         : 1.11.4   , installed 1.11.4
        Adapter    "influxdb"     : 1.9.5    , installed 1.9.5
        Adapter    "info"         : 1.9.8    , installed 1.9.8
        Adapter    "iot"          : 1.8.24   , installed 1.8.24
        Adapter    "javascript"   : 5.2.21   , installed 5.2.21
        Controller "js-controller": 4.0.15   , installed 4.0.15
        Adapter    "linux-control": 1.1.3    , installed 1.1.3
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "openweathermap": 0.1.0   , installed 0.1.0
        Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
        Adapter    "ping"         : 1.5.0    , installed 1.5.0
        Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
        Adapter    "ring"         : 1.2.8    , installed 1.2.8
        Adapter    "roomba"       : 1.1.4    , installed 1.1.4
        Adapter    "scenes"       : 2.3.8    , installed 2.3.8
        Adapter    "shuttercontrol": 1.4.10  , installed 1.4.10
        Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
        Adapter    "socketio"     : 3.1.5    , installed 3.1.5
        Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
        Adapter    "telegram"     : 1.11.1   , installed 1.11.1
        Adapter    "text2command" : 2.1.1    , installed 2.1.1
        Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
        Adapter    "trashschedule": 1.4.1    , installed 1.4.1
        Adapter    "vis"          : 1.4.5    , installed 1.4.5
        Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
        Adapter    "vis-inventwo" : 3.2.8    , installed 3.2.8
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "web"          : 3.4.16   , installed 3.4.16
        Adapter    "whatsapp-cmb" : 0.1.6    , installed 0.1.6
        Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
        daniel@iobroker:~$
          wurde gemacht - keine Änderung.
          hast du danach neu eingelesen?
            Wurzeldoktor @Homoran last edited by Wurzeldoktor
            ja wurde ja so gefordert 🙂
            bleibt bei 0.00-1.01%
            seit dem letzten HM Adapter Update fehlen mir auch die Namen der von mir in der CCU hinterlegten Geräte..
              sollte es eigentlich nicht.
              Ich habe diese Ventile nicht, kann das nicht testen.
              Vielleicht kann @foxriver76 etwas dazu sagen.
                Habe nun sogar die Instanz gestoppt - den Objektdatenbaum gelöscht - wieder aktiviert und neu eingelesen.
                gleichbleibend.
                bei den HM Geräten hab ich das Problem auch nicht....
                da sind 0 - 0%
                100- 100%
                  Homoran Global Moderator Administrators @Wurzeldoktor last edited by Homoran
                  da sind 0 - 0%
                  100- 100%
                  so soll das bei HmIP auch sein, ist es bei mir auch.
                  Ist doch Blödsinn wenn du nur von 0-1% Steuern kannst und das dann auf 0-0.01 im HM umgerechnet wird
                  W dslraser 2 Replies Last reply Reply Quote 0
                    war auch meine Meinung dazu!
                    Finde das auch auf der CCU nen Schwachsinn - aber gsd bin ich ja nur Endnutzer und leider wurden die HM Geräte aufgelassen...
                    jedoch kommen mir glaub ich keine weiteren IP Geräte ins haus 😕 eher wieder normale Schalter
                      was?
                      0-1 ist das sogenannte "Dezimalprozent", das ist vollkommen in Ordnung, wenn es konsequent umgestezt wird.
                      der "normale User" kommt halt besser mit 0 - 100 klar, also übersetzt ioBroker dies.
                      • dslraser
                        dslraser Forum Testing Most Active @Homoran last edited by dslraser
                        bei mir ist es nicht so
                          "type": "state",
                          "common": {
                            "name": "Heizkörperthermostat Wohnzimmer:1.LEVEL",
                            "role": "level",
                            "def": 0,
                            "type": "number",
                            "read": true,
                            "write": true,
                            "min": 0,
                            "max": 1.01,
                            "unit": "%"
                          "native": {
                            "MIN": 0,
                            "OPERATIONS": 7,
                            "MAX": 1.01,
                            "FLAGS": 1,
                            "ID": "LEVEL",
                            "TYPE": "FLOAT",
                            "DEFAULT": 0,
                            "CONTROL": "HEATING_CONTROL_HMIP.LEVEL",
                            "UNIT": "%"
                          "from": "system.adapter.hm-rega.0",
                          "user": "system.user.admin",
                          "ts": 1646144875302,
                          "_id": "hm-rpc.0.000A1709A1EB85.1.LEVEL",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                        RPC 1.15.8
                        Rega 3.0.37
                        Edit: bei mir sind es übrigens HmIP-eTRV-2
                        W Homoran 2 Replies Last reply Reply Quote 0
                          Wurzeldoktor @dslraser last edited by
                          @dslraser sagte in Homematic - HmIP-eTRV-B - Ventilsteuerung:
                            "type": "state",
                            "common": {
                              "role": "level",
                              "def": 0,
                              "type": "number",
                              "read": true,
                              "write": true,
                              "min": 0,
                              "max": 1.01,
                              "unit": "%"
                            "native": {
                              "MIN": 0,
                              "OPERATIONS": 7,
                              "MAX": 1.01,
                              "FLAGS": 1,
                              "ID": "LEVEL",
                              "TYPE": "FLOAT",
                              "DEFAULT": 0,
                              "UNIT": "%"
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          RPC 1.15.8
                          Rega 3.0.37
                          danke das es nicht nur bei mir so ist...
                          Komm mir schon etwas blöd vor 😧
                          • dslraser
                            dslraser Forum Testing Most Active @Wurzeldoktor last edited by
                            @wurzeldoktor
                            bei den Heizgruppen ist es übrigens genau so
                              "type": "state",
                              "common": {
                                "name": "Heizung Wohnzimmer.LEVEL",
                                "def": 0,
                                "type": "number",
                                "read": true,
                                "write": true,
                                "min": 0,
                                "max": 1.01,
                                "unit": "%",
                                "role": "level"
                              "native": {
                                "MIN": 0,
                                "OPERATIONS": 7,
                                "MAX": 1.01,
                                "FLAGS": 1,
                                "ID": "LEVEL",
                                "TYPE": "FLOAT",
                                "DEFAULT": 0,
                                "UNIT": "%"
                              "ts": 1637185619464,
                              "_id": "hm-rpc.2.INT0000014.1.LEVEL",
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                              Homoran Global Moderator Administrators @dslraser last edited by Homoran
                              dann muss da etwas passiert sein.
                              ich bekomme im Browser seit der Umstellung auf admin keine Obketdaten mehr angezeigt.
                              Habe mir diese unsichtbaren Daten jetzt herauskopiert
                                "type": "state",
                                "common": {
                                  "name": "Licht_WC:10.LEVEL",
                                  "def": 0,
                                  "type": "number",
                                  "read": true,
                                  "write": true,
                                  "min": 0,
                                  "max": 100,
                                  "unit": "%",
                                  "role": "level.dimmer"
                                "native": {
                                  "MIN": 0,
                                  "UNIT": "100%",
                                  "OPERATIONS": 7,
                                  "MAX": 1.01,
                                  "FLAGS": 1,
                                  "ID": "LEVEL",
                                  "TYPE": "FLOAT",
                                  "DEFAULT": 0,
                                  "CONTROL": "DIMMER.LEVEL"
                                "ts": 1642176220056,
                                "_id": "hm-rpc.1.001A58A9A27EC9.10.LEVEL",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              0-100
                              native 0- 1.0.1
                              dslraser W 2 Replies Last reply Reply Quote 0
                              • dslraser
                                ich habe bei mir am WE auf der Raspberrymatic ein Update gemacht
                                Aktuelle Firmwareversion: 3.61.7.20220226
                                Kann es daran liegen ?
                                Homoran W 2 Replies Last reply Reply Quote 0
                                  möchlich!
                                  würde mich nicht wundern
                                    Mal schauen ob ich irgendwann ne Lösung für den Spaß habe und mit den IP Dingern die gleichen Verhältnisse bekomme - wie mit den HM....
                                    Im Moment scheitere ich mit den IP Geräten einfach daran... (Hatte das Problem bereits mit einer 24v IP Schaltplatine - ausgetauscht auf eine HM und alles läuft!)
                                    • dslraser
                                      ich würde es nicht beschwören, aber ich meine das war bei mir noch nie anders...?
                                        Wurzeldoktor @dslraser last edited by Wurzeldoktor
                                        habe das ganze bereits vor dem Update versucht (Habe ich erst gestern gemacht...) und war das gleiche Problem.
                                        Kämpfe seit 5Tagen damit herum... sowohl auf der CCU mittels Programm, als auch im Broker..
                                        @Homoran
                                        EDIT: Achja - gleiches Skript läuft mit HM Thermostaten ohne Probleme allerdings mit 0 - 100%
                                          das würde ja passen.
                                          Wenn der Adapter davon ausgeht, dass die eingegeben Zahlen in ioB Prozente sind und durch 100 geteilt werden müssen um auf der CCU richtig zu funktionieren, kommt er mit werten nur zwischen 0 und 1 zu Ergebnissen die du nicht brauchen kannst.
                                          Du könntest ja mal spaßeshalber in den Objektdaten das max auf 100 setzen, ob es dann klappt.
                                          • dslraser
                                            übrigens….
                                            https://forum.iobroker.net/post/638859
                                            da war das auch schon so
                                            EDIT:
                                            https://github.com/ioBroker/ioBroker.hm-rpc/issues/337#issuecomment-849803344
                                            krobipd created this issue in ioBroker/ioBroker.hm-rpc
                                            closed HmIP-MP3P: Falsche Prozent beim Level Status #337
                                            2205
