      WeiserWolf @simatec last edited by WeiserWolf
      @simatec
      Ich hoffe ich habe das richtig gemacht mit dem Log:)
      So wie ich das sehe, werden die Daten berechnet, aber irgendwie fehlt mir die Auslösung.
      Anbei auch nochmal die aktuellen Einstellungen als JSON.
      LOG.txt
      system.adapter.shuttercontrol.0.json
      2022-02-28 08:00:00.004 - debug: shuttercontrol.0 (28987) calculate astrodata ...
      2022-02-28 08:00:00.004 - debug: shuttercontrol.0 (28987) Sun Azimut: 109.7°
      2022-02-28 08:00:00.005 - debug: shuttercontrol.0 (28987) Sun Elevation: 4.9°
      2022-02-28 08:00:00.055 - info: shuttercontrol.0 (28987) Children Up #22 Set ID: Office value: 100%
      2022-02-28 08:00:00.063 - debug: shuttercontrol.0 (28987) last automatic Action for Office: up_ChidrenTime
      2022-02-28 08:00:00.063 - debug: shuttercontrol.0 (28987) shutterUpChildren #2 Office old height: 0% new height: 100%
      2022-02-28 08:00:01.066 - debug: shuttercontrol.0 (28987) save current height after State Check: 0% from Office
      2022-02-28 08:00:01.066 - debug: shuttercontrol.0 (28987) Shutter Office was moved manually to: 0% while window was open - prevent trigger from driving back
      2022-02-28 08:00:19.593 - debug: shuttercontrol.0 (28987) Shutter state changed: Office old value = 0 new value = 100
      2022-02-28 08:00:19.595 - debug: shuttercontrol.0 (28987) Office Updated trigger action to Manu_Mode to prevent moving after window close
      2022-02-28 08:00:19.596 - debug: shuttercontrol.0 (28987) Office drived manually to 100. Old value = 0. New value = 100
      2022-02-28 08:00:20.599 - debug: shuttercontrol.0 (28987) save current height after State Check: 100% from Office
      2022-02-28 08:00:20.600 - debug: shuttercontrol.0 (28987) Shutter Office was moved manually to: 100% while window was open - prevent trigger from driving back
      2022-02-28 08:05:00.004 - debug: shuttercontrol.0 (28987) calculate astrodata ...
      2022-02-28 08:05:00.005 - debug: shuttercontrol.0 (28987) Sun Azimut: 110.7°
      Hier noch mal ein Ausschnitt von heute morgen, die zeitliche Auslösung hat funktioniert
      • simatec
        simatec Developer Most Active @WeiserWolf last edited by
        @weiserwolf Mehr war im Log nicht drin?
          @simatec Von anderen Adaptern ja, aber ich habe nur nach diesem gefiltert. 🤷‍♂️
          Vielleicht baue ich einfach wieder einen Gurt ein, das krieg selbst ich Vollpfosten hin 😂 😂
          • simatec
            @weiserwolf
            Das bekommen wir schon hin.
            Zeige mal bitte die Objekte des Rollladens.
            Sun, up und Down
              Ich zeige einfach mal alle 🙂
              • simatec
                @weiserwolf Da dein Rollladen State auf "none" Steht und du wie ich es gesehen habe shellys verwendest, solltest du die Überprüfung der Rollläden nach x Sekunden aktivieren.
                  @simatec Ja ist aktuell ein Shelly mit dem ich noch rumspiele, der war über...
                  Aber verdammte Axt das hatte ich angeklickt, 100%ig, aber dann wohl nicht auf speichern gedrückt 🤷‍♂️
                  Habe es noch einmal aktiviert und gespeichert, mal schauen was morgen passiert 🙂
                  • simatec
                    @weiserwolf shellys schwanken während der Fahrt mit dem State etwas. Darum muss nach Ende der Fahrt von Shuttercontrol der Status noch einmal geprüft werden.
                    Ist leider ne doof Eigenschaft von den Shellys.
                    Habe aber gelesen, dass man dies wohl in der Config beheben kann.
                    Hab aber keine zum testen da
                      @simatec Wenn es morgen läuft, schaue ich mal bei den Shelleys rein, was da so geht.
                      Das ist aber normal? Habe ich jetzt erstmalig im Log seit ich die Option aktiviert habe 😵
                      shuttercontrol.0
                      27253	2022-03-01 19:12:24.692	warn
                      This object will not be created in future versions. Please report this to the developer.
                      shuttercontrol.0
                      27253	2022-03-01 19:12:24.692	warn	Object shuttercontrol.0.info.Azimut
                      is invalid: Default value has to be type "number" but received type "string"
                      shuttercontrol.0
                      27253	2022-03-01 19:12:24.649	warn
                      shuttercontrol.0
                      27253	2022-03-01 19:12:24.649	warn	Object shuttercontrol.0.info.Elevation
                      • simatec
                        @weiserwolf
                        Ja das Warnungen, die in der nächsten Version gefixt werden
                          Futty last edited by
                          ich habe seit ein paar Tagen das Problem, dass die Zeiten für das hochfahren nicht mehr passen und ich kann mir nach längerem suchen leider immer noch nicht erklären an was es liegt...
                          Es wird einfach immer die späteste Zeit zum hochfahren verwendet.
                          Shuttercontrol v1.4.10
                          Node.js v14.18.2
                          js-controller v4.0.15
                          Objects - Control:
                          Objects - Info:
                          Zeit-Einstellungen - Einstellungen für den Wohnbereich
                          Extra-Einstellungen - Astro-Einstellung:
                          Log (Debug) nach Adapterstart:
                          Jemand eine Idee / ein Tipp?
                          Falls noch weitere Infos benötigt werden stelle ich diese gerne bereit.
                          Vielen Dank schon einmal!
                          Gruß Futty
                            Murphys234d @Futty last edited by Murphys234d
                            @futty Bei mir ist es anders, aber doch ähnlich.
                            Ich nutze feste Zeiten, aber auch diese funktionieren jetzt nicht mehr.
                            Denkt er es sei Wochenende oder Feiertag?
                            Version 1.4.10, node: v14.19.0, js-controller: 4.0.15
                            edit: Er denkt es sei Wochenende. Zumindest übernimmt er für den gezeigten Datenpunkt nur die Wochenendangabe. Datum und Uhrzeit auf der Infoseite des iobrokers stimmen.
                              Murphys234d @Murphys234d last edited by Murphys234d
                              @murphys234d said in Test Adapter shuttercontrol v1.4.x:
                              Habe gestern einmal die gewünschte Zeit beim Wochenende eingetragen und heute morgen sind sie zu dem Zeitpunkt wieder hochgefahren. "Fehler" sehe ich nur die gleichen warnings wie futty
                              edit: hab ein issue erstellt: https://github.com/simatec/ioBroker.shuttercontrol/issues/383
                              MurphysDr created this issue in simatec/ioBroker.shuttercontrol
                              closed Weekend time used innerweekly #383
                              • simatec
                                @murphys234d Bitte die Config als json posten.
                                Dein problem ist nicht reproduzierbar
                                  Futty @Murphys234d last edited by
                                  @murphys234d
                                  Ohne eine Änderung sind die Rollläden heute bei mir auch wieder korrekt hochgefahren.
                                  Ich beobachte es mal weiter. Vielleicht erkenne ich ein Muster.
                                    @futty Bei mir lag der Fehler vor dem Rechner, auch wenn ich mir erklären kann wann ich das umgestellt hätte.
                                    Wohnbereich (über den alle Fenster laufen) stand auf "Nur Zeit", statt "Zeit und Sonnenaufgang".
                                    In der Ansicht fehlt das "früheste Öffnen" und das war zeitlich hinter dem spätesten Öffnen eingestellt.
                                    Nochmal Danke @simatec für den schnellen, guten Support. Ein toller Adapter. Inzwischen hat er nur fast zu viele Features 😉
                                      Futty @Murphys234d last edited by Futty
                                      @murphys234d
                                      ich hab ja meine Einstellungen mit Bildern gepostet.
                                      Scheint meiner Meinung nach zu passen.
                                      Und laut den objects passt es nicht. Morgen ist Wochenende und die Rollos gehen normal hoch...
                                      anbei mal meine .json
                                        Android51 last edited by
                                        Ich habe gestern den Adapter auf die neuste Version aktualisiert. Seitdem fahren die Rolläden nicht mehr. Es wird im Protokoll alles korrekt protokolliert, jeder Rolladen sei angeblich gefahren, aber tatsächlich fährt nichts.
                                        Die Rolladen können manuell noch über den Rolladen-Adapter angesteuert werden. Finde irgendwie das Problem nicht. Könnt ihr mir helfen?
                                        • simatec
                                          simatec Developer Most Active @Android51 last edited by
                                          @android51 Bitte Debuglog und Konfiguration als JSON posten
                                            steimi last edited by
                                            Ich habe für einige Rollladen einen Sensor zur Erkennung ob das Fenster gekippt ist. Dies funktioniert auch, wenn die Fenster nach dem Schliessen gekippt werden. Wie muss / kann ich Shuttercontrol konfigurieren, damit er die Rolladen beim Schliessen nicht ganz nach unten fährt wenn die Fenster schon gekippt sind? er soll dort gleich die Position für das gekippte fenster anfahren.
                                              "_id": "system.adapter.shuttercontrol.0",
                                              "common": {
                                                "name": "shuttercontrol",
                                                "version": "1.4.11",
                                                "title": "shuttercontrol",
                                                "authors": [
                                                  "simatec <nais@gmx.net>"
                                                "keywords": [
                                                  "ioBroker",
                                                  "Smart Home",
                                                  "home automation",
                                                  "Rollladen",
                                                  "Jalousie",
                                                  "Rollladensteuerung"
                                                "license": "MIT",
                                                "platform": "Javascript/Node.js",
                                                "main": "main.js",
                                                "icon": "shuttercontrol.png",
                                                "enabled": true,
                                                "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.shuttercontrol/master/admin/shuttercontrol.png",
                                                "readme": "https://github.com/simatec/ioBroker.shuttercontrol/blob/master/README.md",
                                                "loglevel": "warn",
                                                "mode": "daemon",
                                                "type": "climate-control",
                                                "compact": true,
                                                "materialize": true,
                                                "installedVersion": "1.4.11",
                                                "host": "iobroker-01",
                                                "stopBeforeUpdate": true,
                                                "dependencies": [
                                                    "admin": ">=3.0.0"
                                                "installedFrom": "iobroker.shuttercontrol@1.4.11",
                                                "plugins": {
                                                  "sentry": {
                                                    "dsn": "https://5f58df7167d846e3a90bae5414d4fc09@sentry.iobroker.net/62"
                                                "contributors": [
                                                  "Rene G. <info@rg-engineering.eu>"
                                                "connectionType": "local",
                                                "dataSource": "push",
                                                "adminUI": {
                                                  "config": "materialize"
                                              "native": {
                                                "livingAutomatic": "livingSunriseSunset",
                                                "W_shutterDownLiving": "21:45",
                                                "W_shutterUpLivingMin": "05:30",
                                                "W_shutterUpLivingMax": "07:00",
                                                "driveDelayUpLiving": "1",
                                                "WE_shutterDownLiving": "22:00",
                                                "WE_shutterUpLivingMin": "07:00",
                                                "WE_shutterUpLivingMax": "07:30",
                                                "sleepAutomatic": "sleepSunriseSunset",
                                                "W_shutterDownSleep": "21:30",
                                                "W_shutterUpSleepMin": "06:00",
                                                "W_shutterUpSleepMax": "07:00",
                                                "driveDelayUpSleep": "1",
                                                "WE_shutterDownSleep": "22:00",
                                                "WE_shutterUpSleepMin": "07:00",
                                                "WE_shutterUpSleepMax": "07:30",
                                                "childrenAutomatic": "childrenSunriseSunset",
                                                "W_shutterDownChildren": "19:00",
                                                "W_shutterUpChildrenMin": "05:50",
                                                "W_shutterUpChildrenMax": "07:30",
                                                "driveDelayUpChildren": "1",
                                                "WE_shutterDownChildren": "20:00",
                                                "WE_shutterUpChildrenMin": "07:30",
                                                "WE_shutterUpChildrenMax": "08:00",
                                                "latitude": "",
                                                "longitude": "",
                                                "sunProtEndElevation": "15",
                                                "astroDelayUp": "-20",
                                                "astroDelayDown": "25",
                                                "driveDelayUpAstro": "1",
                                                "SummerStart": "01.03.",
                                                "SummerEnd": "30.09.",
                                                "XMasStart": "01.12.",
                                                "XMasEnd": "06.01.",
                                                "publicHolidays": true,
                                                "publicHolInstance": "feiertage.0",
                                                "HolidayDP": "ical.0.events.0.today.Urlaub",
                                                "lightsensorDown": "400",
                                                "lightsensorUp": "500",
                                                "lightsensorUpDown": "alias.0.Wetter.Outdoor.Beleuchtungsstaerke",
                                                "schoolfree": false,
                                                "schoolfreeInstance": "",
                                                "schoolfreeDP": "",
                                                "schoolfreeChildrenArea": true,
                                                "schoolfreeSleepArea": false,
                                                "schoolfreeLivingArea": false,
                                                "LateAllDown": false,
                                                "LateAllDownTime": "22:15",
                                                "betweenPositionTime": "22:00",
                                                "noGoTime": "0",
                                                "currentShutterState": false,
                                                "currentShutterStateTime": "60",
                                                "triggerAutoSleep": "",
                                                "triggerAutoLiving": "",
                                                "triggerAutoChildren": "",
                                                "alarmWind1Level": "100",
                                                "alarmWind1": "",
                                                "alarmWind2Level": "100",
                                                "alarmWind2": "",
                                                "alarmRainLevel": "100",
                                                "alarmRain": "",
                                                "alarmFrostLevel": "80",
                                                "alarmFrost": "",
                                                "alarmFireLevel": "100",
                                                "alarmFire": "",
                                                "events": [
                                                    "enabled": true,
                                                    "shutterName": "SV_Kueche_F1_Rollo_Wert",
                                                    "name": "hm-rega.0.1391",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "typeDown": "living",
                                                    "type": "outside temperature and direction",
                                                    "heightDownSun": "30",
                                                    "direction": "110",
                                                    "directionRange": "50",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "outsideTempSensor": "0_userdata.0.Wetter_Klima.var_weather_temperature_sun_gleitend",
                                                    "tempOutside": "40",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "triggerState": "true",
                                                    "triggerStateTilted": "",
                                                    "triggerDrive": "100",
                                                    "triggerDriveTildet": "",
                                                    "triggerChange": "off",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "hysteresisOutside": "15",
                                                    "hysteresisInside": "5",
                                                    "hysteresisLight": "5",
                                                    "currentAction": "",
                                                    "currentHeight": "",
                                                    "oldHeight": "",
                                                    "firstCompleteUp": "",
                                                    "triggerHeight": "",
                                                    "LateDown": false,
                                                    "inSummerNotDown": false,
                                                    "KeepSunProtect": false,
                                                    "triggerAction": "",
                                                    "driveAfterClose": false,
                                                    "useXmasLevel": false,
                                                    "XmasLevel": "",
                                                    "betweenPosition": false,
                                                    "betweenPositionLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "sunProtectEndDely": "",
                                                    "sunProtectEndtimerid": "",
                                                    "enableAlarmWind1": false,
                                                    "enableAlarmWind2": false,
                                                    "enableAlarmRain": false,
                                                    "enableAlarmFrost": false,
                                                    "enableAlarmFire": false,
                                                    "alarmTriggerAction": "",
                                                    "alarmTriggerLevel": "",
                                                    "lastAutoAction": ""
                                                    "enabled": true,
                                                    "shutterName": "SV_Kueche_F2_Rollo_Wert",
                                                    "name": "hm-rega.0.1393",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "heightDownSun": "35",
                                                    "direction": "200",
                                                    "directionRange": "75",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "KeepSunProtect": true,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_WZ_F1_Rollo_Wert",
                                                    "name": "hm-rega.0.1395",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "direction": "200",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_WZ_F2_Rollo_Wert",
                                                    "name": "hm-rega.0.1397",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "heightDownSun": "15",
                                                    "direction": "290",
                                                    "directionRange": "90",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_WZ_F3_Rollo_Wert",
                                                    "name": "hm-rega.0.1399",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "heightDownSun": "25",
                                                    "direction": "245",
                                                    "directionRange": "55",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_WZ_F4_Rollo_Wert",
                                                    "name": "hm-rega.0.1401",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "type": "off",
                                                    "heightDownSun": "40",
                                                    "direction": "290",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_WZ_F5_Rollo_Wert",
                                                    "name": "hm-rega.0.1403",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "direction": "335",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_WZ_F6_Rollo_Wert",
                                                    "name": "hm-rega.0.1405",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "direction": "290",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_Bad_F1_Rollo_Wert",
                                                    "name": "hm-rega.0.1407",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "direction": "20",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "SV_HWR_F1_Rollo_Wert",
                                                    "name": "hm-rega.0.1409",
                                                    "triggerID": "",
                                                    "typeUp": "living",
                                                    "direction": "20",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "",
                                                    "trigDelyUp": "",
                                                    "trigDelyDown": "",
                                                    "enabled": true,
                                                    "shutterName": "Kinderzimmer_1_F1",
                                                    "name": "homepilot20.0.Actuator.1-14234511.Position_inverted",
                                                    "triggerID": "hm-rpc.0.00109BE9A07A30.1.STATE",
                                                    "typeUp": "children",
                                                    "typeDown": "children",
                                                    "heightDownSun": "20",
                                                    "direction": "200",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "triggerState": "0",
                                                    "triggerStateTilted": "1",
                                                    "triggerDriveTildet": "20",
                                                    "triggerChange": "upDown",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "0",
                                                    "betweenPositionLevel": "50",
                                                    "trigDelyUp": "0",
                                                    "trigDelyDown": "0",
                                                    "sunProtectEndDely": "0",
                                                    "enabled": true,
                                                    "shutterName": "Kinderzimmer_2_F1",
                                                    "name": "homepilot20.0.Actuator.4-14234511.Position_inverted",
                                                    "triggerID": "",
                                                    "direction": "200",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "triggerState": "none",
                                                    "triggerStateTilted": "none",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "0",
                                                    "trigDelyUp": "0",
                                                    "enabled": true,
                                                    "shutterName": "Kinderzimmer_2_F2",
                                                    "name": "homepilot20.0.Actuator.5-14234511.Position_inverted",
                                                    "triggerID": "hm-rpc.0.00109BE9A071DA.1.STATE",
                                                    "direction": "290",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "0",
                                                    "trigDelyUp": "0",
                                                    "enabled": true,
                                                    "shutterName": "Kinderzimmer_3_F1",
                                                    "name": "homepilot20.0.Actuator.2-14234511.Position_inverted",
                                                    "triggerID": "hm-rpc.0.00109BE9A072F4.1.STATE",
                                                    "direction": "290",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "0",
                                                    "trigDelyUp": "0",
                                                    "enabled": true,
                                                    "shutterName": "Kinderzimmer_3_F2",
                                                    "name": "homepilot20.0.Actuator.3-14234511.Position_inverted",
                                                    "triggerID": "",
                                                    "direction": "20",
                                                    "tempInside": "23",
                                                    "tempSensor": "",
                                                    "lightSensor": "",
                                                    "valueLight": "15",
                                                    "heightUp": "100",
                                                    "heightDown": "0",
                                                    "triggerDriveTildet": "50",
                                                    "elevation": "8",
                                                    "autoDrive": "off",
                                                    "oldHeight": "",
                                                    "LateDown": false,
                                                    "XmasLevel": "0",
                                                    "trigDelyUp": "0",
                                            332
                                            7408
                                            10575276
