    4. eBus Adapter Vaillant
      Cino @Hiltex last edited by
      @hiltex said in eBus Adapter Vaillant:
      Mit solchen Sachen wir HcPumpStarts kann ich persönlich nicht viel anfangen
      Sag das nicht. Mit den ganzen Werten kann man sich förmlich ein Diagnosetool bauen über VIS.
        Cino last edited by
        Sind alle Werte in der Config eigentlich abrufbar? Hab mir einige ausgesucht und kriege Fehler.
        ebus.0
        2022-02-26 21:36:02.162	error	sent read -f -c Durchfluss FlowRate , received ERR: element not found for {"circuit":"Durchfluss","name":"FlowRate","parameter":""}
        ebus.0
        2022-02-26 21:36:02.159	error	sent read -f -c Gebläsedrehzahl FanSpeed , received ERR: element not found for {"circuit":"Gebläsedrehzahl","name":"FanSpeed","parameter":""}
        ebus.0
        2022-02-26 21:36:02.156	error	sent read -f -c Rücklauf expertlevel_ReturnTemp , received ERR: element not found for {"circuit":"Rücklauf","name":"expertlevel_ReturnTemp","parameter":""}
        ebus.0
        2022-02-26 21:36:02.153	error	sent read -f -c Pumpe1 CirPump , received ERR: element not found for {"circuit":"Pumpe1","name":"CirPump","parameter":""}
        ebus.0
        2022-02-26 21:36:02.150	error	sent read -f -c Wasserdruck WaterPressure , received ERR: element not found for {"circuit":"Wasserdruck","name":"WaterPressure","parameter":""}
        ebus.0
        2022-02-26 21:36:02.148	error	sent read -f -c Pumpe Hc1PumpStatus , received ERR: element not found for {"circuit":"Pumpe","name":"Hc1PumpStatus","parameter":""}
        ebus.0
        2022-02-26 21:36:02.144	error	sent read -f -c HK1Vorlauf Hc1FlowTemp , received ERR: element not found for {"circuit":"HK1Vorlauf","name":"Hc1FlowTemp","parameter":""}
        ebus.0
        2022-02-26 21:36:02.141	error	sent read -f -c HK1Vorlaufsoll Hc1ActualFlowTempDesired , received ERR: element not found for {"circuit":"HK1Vorlaufsoll","name":"Hc1ActualFlowTempDesired","parameter":""}
        Hiltex 1 Reply Last reply Reply Quote 0
        • Hiltex
          Hiltex @Cino last edited by
          @cino auch das ist abhängig von deiner ganz speziellen Konfiguration. Bei mir gibt es auch einige Werte, die nicht vorhanden sind und deshalb einen Fehler produzieren
            @hiltex gibt jetzt aber auch keine Möglichkeit mal alles zu pollen und dann zu gucken was ein Wert zurückgibt?
            • Hiltex
              @cino kommt ganz darauf an, was du als Unterbau benutzt. Der Hauptteil meiner Automatisierung läuft über Loxone und LoxBerry. Dessen ebus-Plugin hat eine Schaltfläche „Read all“. Das ist natürlich sehr bequem.
              Bei ioBroker fällt mir nichts anderes ein, als alle Werte manuell einzutragen und das dann mal laufen zu lassen
                Cino last edited by
                So läuft jetzt alles bei mir. Werte kann ich fast alles lesen und was interessant ist habe ich mir rausgepickt.
                Wie schaltet ihr den Heizbetrieb aus? Mein Gedanke ist das VRC700 in der Visu nachzubauen. Den Heizmodus und die Soll Raumtemperatur.
                Hat das schon einer? Was ich rausgelesen habe ist, das viele Probleme haben weil der 700er die Werte über den Bus wieder überschreibt.
                  DaniB last edited by
                  ich habe mich nun seit mehreren Tagen durch dieses Forum gelesen und habe so ziemlich alles versucht meine Vaillant Wärmepumpe über eBus auszulesen. Bisher nur mit mäßigem Erfolg.
                  Meine Konstellation:
                  • Esera eBus-Adapter USB und Esera eBus-Adapter Ethernet (beides Vorhanden, die Ergebnisse sind die selben)
                  • Vaillant Split WP Außeneinheit
                  • Hydraulikstation mit VRC 700
                  • VR71
                  • AllStor Pufferspeicher
                  • Trinkwasserstation VWZ
                  • Recovair, hängt hinter dem V32
                  Frischer Raspberry Image mit eBus Daemon installiert.
                  Wie zu sehen, habe ich bereits mehrere Möglichkeiten der config ausprobiert.
                  Was mir auffiel ist (was schon der ein oder andere Nutzer auch gesagt hat) nur beim aus und wieder einschalten der Anlage, sendet diese die Kennung.
                  Mein Vorgehen:
                  • ebusd service starten
                  • Anlage Stromlos und wieder einschalten
                  Habe bereits die Dateien lokal abgelegt und den Pfad angepasst. Kein anderes Ergebnis. Potentiometer blink fröhlich. Ein verstellen bewirkt nur den Abbruch der Kommunikation.
                  Die Config: /etc/default/ebusd
                  EBUSD_OPTS="--scanconfig=full --accesslevel=* -d /dev/ttyUSB1 --httpport=8889 -p 8888 --latency=100000 -l /var/log/ebusd.log --htmlpath=/var/ebusd/html">
                  ebusctl i:
                  pi@raspberrypi:/etc/ebusd $ ebusctl i
                  version: ebusd 22.1.v22.1
                  device: /dev/ttyUSB1
                  access: *
                  signal: acquired
                  symbol rate: 78
                  max symbol rate: 179
                  min arbitration micros: 366
                  max arbitration micros: 482
                  min symbol latency: 3
                  max symbol latency: 3
                  reconnects: 0
                  masters: 7
                  conditional: 15
                  poll: 0
                  update: 8
                  address 00: master #1
                  address 03: master #11
                  address 08: slave #11, scanned "MF=Vaillant;ID=HMU00;SW=0517;HW=5103"
                  address 0a: slave, scanned "MF=Vaillant;ID=PMW01;SW=0206;HW=8302", loaded "vaillant/0a.pmw.hwc.csv"
                  address 10: master #2
                  address 12: slave
                  address 13: master #12
                  address 15: slave #2, scanned "MF=Vaillant;ID=70000;SW=0614;HW=6903"
                  address 18: slave #12, scanned "MF=Vaillant;ID=V32;SW=0117;HW=9802"
                  address 26: slave, scanned "MF=Vaillant;ID=VR_71;SW=0104;HW=0503"
                  address 31: master #8, ebusd
                  address 36: slave #8, ebusd
                  address 71: master #9
                  address 76: slave #9, scanned "MF=Vaillant;ID=VWZ00;SW=0522;HW=5103"
                  address f7: master #20
                  address fc: slave #20, scanned "MF=Vaillant;ID=PMW01;SW=0206;HW=8302"
                  Log:
                  Ist angehängt
                  Log.txt
                  Es läuft eigentlich immer auf das selbe hinaus. Erfindet genau eine CSV. Dies ist jedoch unterschiedlich. Manchmal findet aer auch die CSV der VR71. Aber immer nur eine.
                  Ich bin echt ratlos und kann mir kein Reim drauf machen.
                  Kann vielleicht jemand helfen?
                  Grüße Dani
                  MassiveAttack C 2 Replies Last reply Reply Quote 0
                  • MassiveAttack
                    MassiveAttack @DaniB last edited by
                    @danib
                    Mein tipp, nimm einen anderen adapter, vorzugsweise die eigenentwicklung von ebusd. Hatte mit dem esera auch immer probleme.
                    Sonst scheint mir alles richtig zu sein
                      A Former User @MassiveAttack last edited by
                      @massiveattack
                      Leider ein klitzekleines Problem.
                      Gibts nicht ....
                      Wer weiß wann die Jungs wieder liefern können.
                      Ich stehe schon, gefühlt, ewig auf der Warteliste.
                        DaniB @Guest last edited by
                        @dreistein genau das ist auch mein Problem. Stehe ebenfalls auf der Warteliste.
                        Hab das ganz auch schon mit nem docker container laufen. Es gibt auch Anleitungen dazu, aber das will einfach nicht laufen....
                        MassiveAttack 1 Reply Last reply Reply Quote 0
                        • MassiveAttack
                          @danib @Dreistein
                          ah ok, wusste ich nicht.
                          bei meinem esera adapter konnte ich auch immer nur ein csv laden, und musste mich dafür stunden spielen, damit das funktioniert.
                          mit dem ebusd adapter funktioniert das binnen sekunden, und es werden auch mehrere csv's geladen.
                          du kannst dich noch mit der latency spielen, wobei das nur mäßigen erfolg verspricht
                            DaniB @MassiveAttack last edited by
                            @massiveattack
                            Will auch haben.... 😞
                            Aber so wie es momentan aussieht wird das dieses Jahr nix mehr. Vielleicht bringt ja die neue MyVaillant App die ja demnächst kommen soll etwas mehr Erfolg in Verbindung mit nem aktualisierten Vaillant Adapter in ioBroker.
                            Ich spiel jetzt noch etwas mit der Latency, verspreche mir da aber nicht wirklich was von....
                            Danke schonmal!
                            • MassiveAttack
                              @danib
                              gutes gelingen 🙂
                                Cino @DaniB last edited by
                                @danib Deine Gerätschaften werden alle erkannt. Es wird bis auf die lokale pmw aber keine csv geladen.
                                Deine Config bitte wieder auf web stellen.
                                  DaniB @Cino last edited by
                                  @cino die Config ist doch bereits auf Web gestellt worden. Wenn nichts angegeben wurde dann holt er sie doch aus dem Web. Und eine zieht er ja korrekt.
                                    @danib
                                    So sieht eine Config mit Web aus
                                    EBUSD_OPTS="--configpath=http://ebusd.eu/config/ -d /dev/ttyUSB0 -p 8888  --latency=30000 --receivetimeout=80000 -l /var/log/ebusd.log  --scanconfig=full  --httpport=8889 --htmlpath=/var/ebusd/html"
                                      @cino es bleibt eben bei der gleichen Ausgabe. Er findet nur eine Config. Auch mit der Config aus dem Netz.
                                      Hab auch die Latency auf 100000 hoch gestellt. Leider der höchste Wert.
                                      • Hiltex
                                        Hiltex @DaniB last edited by
                                        @danib Ich nutze den Esera ebus Koppler schon seit einigen Jahren und bei mir ist das so:
                                        Läuft alles und ich schalte die Theme aus und wieder ein, dann kommt nichts mehr. Starte ich den Raspberry mit ebusd neu, wird keine einzige CSV gefunden.
                                        Folgendes Vorgehen funktioniert jedoch immer:
                                        Therme aus, ebusd stoppen, Koppler stromlos.
                                        Therme an, kurz warten, Koppler an, kurz warten, ebusd starten, etwas länger warten, ebusd stoppen, kurz warten, ebusd starten, etwas länger warten, läuft.
                                        Wenn die Therme nicht aus war und nur das Raspi neugestartet wurde, reicht es ebusd einmal neuzustarten. Manchmal zweimal.
                                        Ist ein wenig umständlich, aber läuft dann über Monate einwandfrei.
                                        Wenn alle Stricke reißen hilft der Support von Esera auch gerne. Der ist echt super freundlich, kompetent und nimmst sich wirklich Zeit dafür.
                                        Vielleicht hilft dir das ja weiter.
                                          DaniB @Hiltex last edited by
                                          @hiltex
                                          Dann hab ich jetzt was zu tun.
                                          Kurze Frage noch,
                                          1. Was bedeutet bei dir "kurz warten" und "etwas länger warten"? 😂
                                          2. Nutzt du den ETH oder USB Koppler?
                                          • Hiltex
                                            @danib ich habe die Ethernet-Variante.
                                            Kurz heißt 10-20 Sekunden
                                            Lang heißt 60 Sekunden
                                            Das ist auch nur gefühlt, hab’s nie nachgemessen
                                            ebus ebus adapter error erste schritte problem
                                            49
                                            388
                                            101835
