    4. Test PV Forecast Adapter
      PatrickWalther Developer last edited by
      Test PV Forecast Adapter 0.2.5
      Veröffentlichungsdatum 01.03.2022
      Github Link https://github.com/iobroker-community-adapters/ioBroker.pvforecast
      Guten Tag,
      seit gestern gibt es die neue Version und der Adapter ist in der Iobroker community(bitte beachtet den neuen Link). Der Antrag für die offizielle Liste ist gestellt.
      Patrick
      Diginix 1 Reply Last reply Reply Quote 1
      • Diginix
        Diginix last edited by Diginix
        @Meistertr
        Heute morgen 1 Uhr hatte ich folgende Fehler im Log:
        2022-03-02 01:00:03.720 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.00:30:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.724 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.01:00:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.725 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.01:30:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.725 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.02:00:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.725 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.02:30:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.726 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.03:00:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.726 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.03:30:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.726 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.04:00:00" has no existing object, this might lead to an error in future versions
        2022-03-02 01:00:03.727 - warn: pvforecast.0 (1873535) State "pvforecast.0.1.everyhour_kw.04:30:00" has no existing object, this might lead to an error in future versions
        Die gleichen Meldungen kamen gestern nach der Erstinst. von 0.2.5. Da könnte ich es verstehen, aber täglich sollte das doch nicht passieren?
        Unterhalb von pvforecast.0.1.everyhour_kw fängt es aber auch erst mit 5 Uhr an.
        Meistertr 2 Replies Last reply Reply Quote 0
        • Meistertr
          Meistertr Developer @Diginix last edited by
          @diginix i will fix 😊
            bastian-m last edited by bastian-m
            Vielen Dank an euch für die stetige Weiterentwicklung dieses Adapters.
            Ich habe einen neuen Feature-Request bei Github eingetragen.
            Ich bastle seit längerer zeit an einer prognosebasierten Verbrauchssteuerung, das Grundkonzept funktioniert mittlerweile. Was dafür aber bisher fehlt: Die Aufteilung von everyhour_kw auf zwei Ordner für "today" und "tomorrow".
            Mein Script kann bisher an Hand der Prognosedaten in "everyhour_kw" für einen Verbraucher von dem die Laufzeit und die Leistungsaufnahme übergeben werden entscheiden, zu welcher Uhrzeit der Verbraucher am optimalsten gestartet wird um einen möglichst hohen Eigenverbrauch zu erzielen. Das möchte ich gerne ausbauen, indem ich z.B. für bestimmte Verbraucher entscheide, ob ich sie z.B. mit geringer Leistung kontinuierlich die Nacht durchlaufen lasse, oder Nachts ausschalte und dann am Folgetag bei viel Sonne mit höherer Leistung ein paar Stunden laufen lasse. Konkretes Anwendungsbeispiel ist meine Wärmepumpe für Heizung/Warmwasser.
            Ich glaube, so ganz viel Arbeit wäre die Erweiterung des Adapters nicht, oder?
            Liebe Grüße,
            Bastian
            Meistertr 1 Reply Last reply Reply Quote 0
            • Meistertr
              Meistertr Developer @bastian-m last edited by
              @bastian-m das wäre möglich, aber im scipt würde ich sowieso den json datenpunkt nutzen weil er einfacher zu verarbeiten ist als die Objekte
              • Meistertr
                @diginix fixed on git
                • Diginix
                  Diginix @PatrickWalther last edited by
                  @patrickwalther sagte in Test PV Forecast Adapter:
                  Guten Tag,
                  Patrick
                  Bitte auch den Link im OP auf den offiziellen umstellen.
                    PatrickWalther Developer @Diginix last edited by
                    @diginix was meinst du mit OP?
                    Erster Beitrag wurde geändert
                    • Diginix
                      Opening Post. Passt. Danke!
                        bastian-m @Meistertr last edited by
                        @meistertr Wenn ich ernsthaft programmieren könnte bestimmt. 😉 Vielleicht hättet ihr trotzdem Lust das einzubauen, vielleicht ist es ja auch für andere in irgendeiner Form von Nutzen. Dürfte im Adaptercode ja nicht vieeeel mehr als ein bisschen Copy-Paste sein, oder?
                        Patrick habe ich schonmal was gespendet, dir fehlt noch ein Donate-Link in deinem Github-Profil!
                        • Diginix
                          Diginix @bastian-m last edited by
                          @bastian-m Wie machst du denn jetzt den ganzen Vergleich in deinem Skript mit einer (unbekannten) Menge an Objekten?
                          • BananaJoe
                            BananaJoe Most Active last edited by
                            Frage zu e-Charts: Das bedingt das save to influxdv genutzt wird oder wie kann ich mir das vorstellen?
                            Oder besser gesagt; kann mir das bitte jemand noch mal für ... stellen wir uns vor ich wäre 8 Jahre alt ... erklären?
                            • Bernd 0
                              Bernd 0 last edited by
                              erstmal vielen Dank @Meistertr für die Weiterentwicklung des Adapters.
                              Ich habe die Daten in der Vis dargestellt und was ich nicht ganz verstehe ist, dass ich bei Solcast meinen Power-Output über den Tag sehe. Maximal kann meine Anlage 9Kw und das Diagramm zeigt das sehr schön.
                              Die Daten, die ich vom Adapter erhalte kann ich nicht wirklich interpretieren.
                              Habe ich eine falsche Einstellung getätigt? Habe ich einen Denkfehler?
                              Es müssten doch eigentlich die gleichen Daten vom Adapter wie von der Solcast Page kommen, oder?
                              Danke und VG
                              • Bernd 0
                                @bernd-0 Habe meinen "Fehler" gefunden. Ich habe den Azimuth von Solcast übernommen. Für den Adapter wird er aber anders berechnet.
                                • Diginix
                                  @Meistertr Da nun von solcast nur einmal 1 Uhr am Tag abgerufen wird, ist der Vorhersagewert für tomorrow im Laufe des Tages doch recht "veraltet". Wäre es denkbar/machbar nur diesen über den Tag verteilt noch weiter zu aktualisieren?
                                  Oder ändert sich da bei solcast eh nichts bis zum Beginn des eigentlichen Tages?
                                  Auf der solcast Seite bekomme ich über die API nur die Stundenwerte, aber habe nicht gefunden wo man den Gesamt Ertrag für heute und morgen sehen kann. Aktuell ist der Wert für morgen doch recht hoch und ich denke dass er heute im Laufe des Tages sicher schon nach unten korrigiert wäre, so denn die solcast API das hergibt.
                                  Edit: Habe mir eben nochmal die Werte mit der vom Adapter verwendeten URL von solcast für morgen geholt und summiert und da kommt weiterhin der selbe Wert heraus wie der von 1 Uhr heute morgen. Also wird bei solcast tomorrow im Laufe des Tages anscheinend nicht weiter verfeinert sondert bleibt über den Tag fix.
                                  • BananaJoe
                                    @PatrickWalther
                                    So, es ist vollbracht. Zwar durch die Brust ins Auge, aber es läuft (nebenbei habe ich aber wieder einmal viel gelernt).
                                    Ich habe nun die Vorhersage erfolgreich mit dem SQL-Adapter (und einer MySQL-Datenbank) und dem echarts-Adapter als Anzeige zum laufen bekommen:
                                    gelb ist meine echte Tagesleistung, rot die aus diesem Adapter (auch wenn ich hier Äpfel mit Birnen vergleiche, gelb sind W und rot Wh, daran mache ich mich als nächstes).
                                    Als Vorrausetzung nehme ich einen installierten und funktionsfähigen SQL-Adapter an.
                                    Außerdem habt Ihr den pvforecast Adapter konfiguriert und am laufen so das es einen Datenpunkt mit der Vorhersage gibt. Meine Lösung nutzt den Datenpunkt JSONTable der Anlage. Meine Anlage heißt 600W und der Datenpunkt also
                                    pvforecast.0.600W.JSONTable
                                    Schritt 1: Datenpunkt erstellen, konfigurieren und initialisieren
                                    Es braucht einen Datenpunkt der Daten hält, ich habe hier diesen erstellt:
                                    0_userdata.0.Solaranlage.pvforecast
                                    Als Typ Number bzw. Nummer
                                    Dann habe ich ich SQL für den Datenpunkt eingeschaltet:
                                    Entprellzeit auf 0 da die Daten in einem rutsch geschrieben werden
                                    Nun ist es wichtig im Objekte Explorer dort einmal einen Wert von Hand reinzuschreiben, z.B. eine 42:
                                    Erst dann ist der Datenpunkt in der SQL-Datenbank auch angelegt. Das hat mich die ersten bestimmt 20 Minuten nerven gekostet bis ich darauf gekommen bin. Solange funktioniert nämlich das SendTo noch nicht.
                                    Schritt 2: Das Blockly Skript
                                    Ja ja, ich dachte ich könnte das mal eben mit Blockly zusammenklicken statt es direkt in JavaScript zu schreiben. Mach ich vielleicht noch. Nun ist es Blockly mit 3 JavaScript Funktionen weil der SendTo Block einfach nicht zu überreden war das ganze vernünftig zu senden.
                                    Im Spoiler der Blockly-Export
                                     <variables>
                                       <variable id="xr?C%:}F%HR,+baC%W8n">x</variable>
                                       <variable id="d/.bOP=7VlC5/[+=8g/u">myVAL</variable>
                                       <variable id="SL$d6/`ClO6iqfefh5LN">myTS</variable>
                                       <variable id="B$n_|Lt?V?dltG$1=%U!">JSONTable</variable>
                                       <variable id="zqSSt1.lPBrP!prtJp:[">JSONListe</variable>
                                       <variable id="[,noZ+!#R([v)Vli[JAC">counter</variable>
                                       <variable id="9[xS=sH).DKBS8oGN@cs">i</variable>
                                       <variable id="tkH#qcE=H5/_7~OttW5(">tempDatum</variable>
                                       <variable id="f=MX5bxXCe`#`$z~HXcG">tempLeistung</variable>
                                     </variables>
                                     <block type="procedures_defcustomreturn" id="f5+e$i!@hdFdP7[JA1^`" x="288" y="-212">
                                       <mutation statements="false">
                                         <arg name="x" varid="xr?C%:}F%HR,+baC%W8n"></arg>
                                       </mutation>
                                       <field name="NAME">ReplaceHyphen</field>
                                       <field name="SCRIPT">cmV0dXJuIHgucmVwbGFjZSgiLy0vZyIsIi4iKTs=</field>
                                     <block type="procedures_defcustomnoreturn" id="W?BjTQs!pguWw4HPwT)p" x="287" y="-162">
                                         <arg name="myVAL" varid="d/.bOP=7VlC5/[+=8g/u"></arg>
                                         <arg name="myTS" varid="SL$d6/`ClO6iqfefh5LN"></arg>
                                       </mutation>
                                       <field name="NAME">SendTo_SQL_storeState</field>
                                       <field name="SCRIPT">Ly8gVW5kIHdlcnQgZXJzdGVsbGVuIHdpZSBnZXBsYW50DQpzZW5kVG8oInNxbC4wIiwgInN0b3JlU3RhdGUiLCB7DQogICAgImlkIjogJzBfdXNlcmRhdGEuMC5Tb2xhcmFubGFnZS5wdmZvcmVjYXN0JywNCiAgICAic3RhdGUiOiB7IA0KICAgICAgICAidmFsIjogbXlWQUwsIA0KICAgICAgICAidHMiOiBteVRTLA0KICAgICAgICAiYWNrIjogdHJ1ZQ0KICAgIH0NCn0sIGFzeW5jIGZ1bmN0aW9uIChyZXN1bHQpIHsNCiAgICBjb25zb2xlLmxvZyhyZXN1bHQpOw0KfSk7</field>
                                     <block type="procedures_defcustomnoreturn" id="m.]d6DR4hIR|rhM`P3KU" x="288" y="-112">
                                       <mutation statements="false"></mutation>
                                       <field name="NAME">SendTo_SQL_deleteAll</field>
                                       <field name="SCRIPT">Ly8gQWxsZXMgbMO2c2NoZW4NCnNlbmRUbygic3FsLjAiLCAiZGVsZXRlQWxsIiwgew0KICAgICJpZCI6ICcwX3VzZXJkYXRhLjAuU29sYXJhbmxhZ2UucHZmb3JlY2FzdCcsDQp9LCBhc3luYyBmdW5jdGlvbiAocmVzdWx0KSB7DQogICAgICBjb25zb2xlLmxvZyhyZXN1bHQpOw0KfSk7DQo=</field>
                                     <block type="comment" id="emF90N[xA].w:e$0a5`A" x="288" y="-62">
                                       <field name="COMMENT">Trigger auf den Datenpunkt JSONTable der</field>
                                         <block type="comment" id="v|g5R@PBSlfR{}gqtWR1">
                                           <field name="COMMENT">gewünschten Anlage</field>
                                             <block type="on_ext" id="2}81gNSPn48mxt-C32N3">
                                               <value name="OID0">
                                                 <shadow type="field_oid" id="$fUC/kgh^7[pBZjds,[N">
                                                 <block type="text" id="Q~[~L7`?jff9w0!|{R!~">
                                                   <field name="TEXT">pvforecast.0.600W.JSONTable</field>
                                                 <block type="comment" id="xipk,Q4m/$Zbq(9xP]N;">
                                                   <field name="COMMENT">Den JSON in eine Variable als Objekt holen</field>
                                                     <block type="variables_set" id="9le8nB_}E+{=^zh:Futa" disabled="true">
                                                       <field name="VAR" id="B$n_|Lt?V?dltG$1=%U!">JSONTable</field>
                                                         <block type="convert_json2object" id="C^`)6e!W4atd.!+{(i`D">
                                                             <block type="get_value_var" id="CX?q]Gc8j[Ks2F4.yc=c">
                                                               <value name="OID">
        <shadow type="text" id="Y:eexHcUNi5aP`=sh5_;">
        <field name="TEXT"></field>
        <block type="text" id="2yV92%k{c@aR$t@FV|VK">
                                                         <block type="variables_set" id="y:J|yOI69aKr_]e}X})q">
                                                             <block type="on_source" id="GDRdyJ%YUi4U{P:xhe%L">
                                                             <block type="comment" id="78{/(q^zo:Vm3)}YeMKs">
                                                               <field name="COMMENT">Den JSON nochmal als Liste</field>
        <block type="variables_set" id="$C:;|F_ENe?Kc{f9E*tE" disabled="true">
        <field name="VAR" id="zqSSt1.lPBrP!prtJp:[">JSONListe</field>
        <block type="lists_split" id=":4[[9BsVwSu-#SFS/qp#">
        <mutation mode="SPLIT"></mutation>
        <field name="MODE">SPLIT</field>
        <value name="INPUT">
        <block type="get_value_var" id="k${_LxJlQ~Jc%^8mQ;J3">
        <value name="OID">
        <shadow type="text">
        <block type="text" id="@(LLEO9DcZC_107PY7e;">
        <value name="DELIM">
        <shadow type="text" id="_=ir)--C~K.5!,@3!%@4">
        <field name="TEXT">},</field>
        <block type="variables_set" id="KTHIaej{MV5TTxsehu:h">
        <block type="lists_split" id="`#[tp]8]y!L^LEp8OL)J">
        <block type="on_source" id="c),q`)7dZyX)GtW;Oe0Y">
        <shadow type="text" id="koPJuBu/Hm/D7+[$DR$`">
        <field name="TEXT">},{</field>
        <block type="comment" id="_dDWRwqorhv|K4r20+CF">
        <field name="COMMENT">Zähler für die einzelnen Werte</field>
        <block type="variables_set" id="w[HNQFZ(pKC;(LonsppG">
        <field name="VAR" id="[,noZ+!#R([v)Vli[JAC">counter</field>
        <block type="math_number" id="$YD#)Z6].!0wU8:!IFY-">
        <field name="NUM">-1</field>
        <block type="comment" id="nON/.IM*.X5L7BSfqn.j">
        <field name="COMMENT">Vorherige Werte löschen</field>
        <block type="procedures_callcustomnoreturn" id="MjjlAd,#02dH9;[91A:e">
        <mutation name="SendTo_SQL_deleteAll"></mutation>
        <block type="comment" id="+UxP]UFX*K*Ay8@+.3D(">
        <field name="COMMENT">Kurz warten ...</field>
        <block type="timeouts_wait" id="b#[5BCU4#vD.+@RIgxwr">
        <field name="DELAY">2</field>
        <block type="comment" id="?qlG@bV1nj7K%h8?`S-h">
        <field name="COMMENT">Die Werte abarbeiten:</field>
        <block type="controls_forEach" id="sZ%NhNSxC10sAg@O]Kz6">
        <field name="VAR" id="9[xS=sH).DKBS8oGN@cs">i</field>
        <value name="LIST">
        <block type="variables_get" id="psB3RQ42dmHy[=aKrs!2">
        <statement name="DO">
        <block type="comment" id="0i?Xu2@hUv,g4?;i5Fhl">
        <field name="COMMENT">Wird beim ersten mal 0 sein</field>
        <block type="math_change" id="liet[5#L@~`I]t{8:/Es">
        <value name="DELTA">
        <shadow type="math_number" id="986qLvCF[J2VK^no0@Rp">
        <field name="NUM">1</field>
        <block type="comment" id="}fPI/Q;fVu7V-uYuX2I+">
        <field name="COMMENT">Wir arbeiten die Liste ab, nutzen aber das Objekt!</field>
        <block type="variables_set" id="^w);@i_kdtjWWf?c}BcO">
        <field name="VAR" id="tkH#qcE=H5/_7~OttW5(">tempDatum</field>
        <block type="get_attr" id="jTRbW_-wI4-}.!,5V(VJ">
        <value name="PATH">
        <shadow type="text" id="3r`W9/~ToEj{Abx:)agx">
        <block type="text_join" id="xoFmSb~Y+xnD;cvM|g;-">
        <value name="ADD0">
        <block type="variables_get" id="K9;4LQ$1S/`at#YY52.j">
        <value name="ADD1">
        <block type="text" id="Kkt8qVr.ykp~NV;@{Uas">
        <field name="TEXT">.Uhrzeit</field>
        <value name="OBJECT">
        <block type="variables_get" id="`-rw74I`kqylUWgeH*+(">
        <block type="comment" id="b?]P+H9BwqfkDRv$/:j(">
        <field name="COMMENT">Die - in . umwandeln</field>
        <block type="variables_set" id="k@v15A-cYpf/vbpRa;_z">
        <block type="procedures_callcustomreturn" id="p[kw(;yI)pXBjjzD#D)~">
        <mutation name="ReplaceHyphen">
        <arg name="x"></arg>
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="N)h=(1TR`.9#96=m?A0Y">
        <block type="comment" id="I-6Pjzc2in5fU|/L@xLT">
        <field name="COMMENT">In ein Datum-Objekt umwandeln</field>
        <block type="variables_set" id="FsILBORsaLrrazBi1L)J">
        <block type="convert_from_date" id="4bbw}ZJhpHe}e.*nJ0`M">
        <field name="OPTION">object</field>
        <block type="variables_get" id="RjC;=Ac;nPHFrHCNt$SG">
        <block type="comment" id="?/.AjS+{19mE_EhC6?{%">
        <field name="COMMENT">Die Leistung holen (hier in Wh statt kWh)</field>
        <block type="variables_set" id="7$e1=Z.||tt-}b}$`QUX">
        <field name="VAR" id="f=MX5bxXCe`#`$z~HXcG">tempLeistung</field>
        <block type="math_arithmetic" id="czVYE)d?^hj;sB8tQW%c" inline="false">
        <shadow type="math_number" id="QXXI#nb51thU(gYujO7l">
        <block type="get_attr" id="!p(Q2{*u/U@(LdLaWO;s">
        <value name="PATH">
        <block type="text_join" id="eO+Kc@J#5ncJexgCa;XG">
        <value name="ADD0">
        <block type="variables_get" id="6h@/w;v+5fJ:2k^fRu$`">
        <value name="ADD1">
        <block type="text" id="u;lW,EMq1lo;0wl@^s~Z">
        <field name="TEXT">.Leistung</field>
        <block type="variables_get" id=":wC%m_*5#kUmjSCtRht*">
        <shadow type="math_number" id=".oUR!B4y8;}kLXv3HYVD">
        <field name="NUM">1000</field>
        <block type="comment" id=".r}c.6$[JDf=.|#00pZj">
        <field name="COMMENT">Und in die Datenbank schreiben</field>
        <block type="procedures_callcustomnoreturn" id="C,/_Emb0_,HXS0:;0?Cb">
        <mutation name="SendTo_SQL_storeState">
        <arg name="myVAL"></arg>
        <arg name="myTS"></arg>
        </mutation>
        <value name="ARG0">
        <block type="variables_get" id="ZX``,0~qVZ*H;d75IT!S">
        <value name="ARG1">
        <block type="variables_get" id="2rC,dvFPd3*_,1)EOdkN">
                                    Anpassen müsst Ihr:
                                    In der JavaScript-Funktion SendTo_SQL_storeState den Namen des Ziel-Datenpunktes:
                                    gelb markiert:
                                    Das gleiche in der JavaScript-Funktion SendTo_SQL_DeleteAll
                                    Und im Kopf den Quellpfad zu eurer Anlage:
                                    Und ob Ihr es in kWh oder Wh haben wollt:
                                    (die x 1000 entfernen oder durch 1 Ersetzen bei kWh)
                                    Wenn Ihr das Skript startet passiert erst einmal nichts. Erst wenn neue Daten reinkämen.
                                    Zum Testen könntet Ihr
                                    • Im Trigger von wurde geändert auf wurde aktualisiert ändern
                                    • den pvforecast Adapter einmal neu starten. Zumindest bei mir holt er dann sofort einmal neue Daten
                                    und schon hat er uns die Werte schön in die Datenbank geschrieben:
                                    MariaDB [iobroker]> select * from ts_number where id = '95';
                                    | id | ts            | val  | ack  | _from | q    |
                                    | 95 | 1646287082001 |    0 |    1 |     0 |    0 |
                                    | 95 | 1646288940000 |   29 |    1 |     0 |    0 |
                                    | 95 | 1646290802000 |  146 |    1 |     0 |    0 |
                                    | 95 | 1646294400000 |  247 |    1 |     0 |    0 |
                                    | 95 | 1646298000000 |  377 |    1 |     0 |    0 |
                                    | 95 | 1646301600000 |  422 |    1 |     0 |    0 |
                                    | 95 | 1646305200000 |  428 |    1 |     0 |    0 |
                                    | 95 | 1646308800000 |  383 |    1 |     0 |    0 |
                                    | 95 | 1646312400000 |  317 |    1 |     0 |    0 |
                                    | 95 | 1646316000000 |  222 |    1 |     0 |    0 |
                                    | 95 | 1646319600000 |  113 |    1 |     0 |    0 |
                                    | 95 | 1646323200000 |   34 |    1 |     0 |    0 |
                                    | 95 | 1646326800000 |    8 |    1 |     0 |    0 |
                                    | 95 | 1646327160000 |    2 |    1 |     0 |    0 |
                                    | 95 | 1646327460000 |    0 |    1 |     0 |    0 |
                                    | 95 | 1646373360000 |    0 |    1 |     0 |    0 |
                                    | 95 | 1646375280000 |   36 |    1 |     0 |    0 |
                                    | 95 | 1646377200000 |  180 |    1 |     0 |    0 |
                                    | 95 | 1646380800000 |  284 |    1 |     0 |    0 |
                                    | 95 | 1646384400000 |  360 |    1 |     0 |    0 |
                                    | 95 | 1646388000000 |  401 |    1 |     0 |    0 |
                                    | 95 | 1646391600000 |  406 |    1 |     0 |    0 |
                                    | 95 | 1646395200000 |  372 |    1 |     0 |    0 |
                                    | 95 | 1646398800000 |  310 |    1 |     0 |    0 |
                                    | 95 | 1646402400000 |  218 |    1 |     0 |    0 |
                                    | 95 | 1646406000000 |  114 |    1 |     0 |    0 |
                                    | 95 | 1646409600000 |   35 |    1 |     0 |    0 |
                                    | 95 | 1646413200000 |    8 |    1 |     0 |    0 |
                                    | 95 | 1646413620000 |    2 |    1 |     0 |    0 |
                                    | 95 | 1646413980000 |    0 |    1 |     0 |    0 |
                                    30 rows in set (0.001 sec)
                                    Die kann man jetzt in echarts etc. verwenden.
                                    Woran ich noch verzweifle:
                                    // Alles löschen
                                    sendTo("sql.0", "deleteAll", {
                                        "id": '0_userdata.0.Solaranlage.pvforecast',
                                    }, async function (result) {
                                          console.log(result);
                                    Wie schaffe ich es auch den Wert von id als Variable zu übergeben?
                                    Daran habe ich nämlich 90% der Zeit gesessen. Zuerst habe ich es vergeblich mit dem Blockly-SendTo Block versucht (aber der hat es immer falsch formatiert gesendet) und dann wie ich die festen Werte durch Variablen ersetze.
                                    P sonnenschein 3 Replies Last reply Reply Quote 3
                                    • Meistertr
                                      @diginix schau ich mir heute mal an, ist mir auch schon aufgefallen, dass da irgendwas nicht stimmt
                                      • Diginix
                                        Diginix @Meistertr last edited by Diginix
                                        @meistertr Gestern war ab 1 Uhr die Prognose für heute 36 kWh, aber auch mit den solcast Werten von gestern Abend 20 Uhr ergab sich summiert 36 kWh für heute. Heute morgen 1 Uhr ist der Wert dann auf 26 kWh reduziert worden.
                                        Real erwarte ich heute keine 10 kWh. Die Prognose vom Plenticore Adapter waren gestern 7 Uhr schon nur 13 kWh für heute und heute 7 Uhr dann nur noch 8 kWh. Was auch immer @StrathCole da für wahnsinnige Formeln gebaut hat, sie passen für tomorrow deutlich besser.
                                        @bastian-m Mit derart daneben liegenden Vorhersagen für tomorrow ist eine Entscheidung ob ein Verbraucher heute oder besser morgen läuft komplett sinnlos. Die Werte für den aktuellen Tag mögen z.T. noch ok sein, aber mit denen des Folgetages braucht man nicht ins Rennen gehen.
                                        Edit: Für morgen sagt solcast 49 kWh und Strathcoles Berechnung 13 kWh.
                                          @diginix welche Formel? Hast du einen Link?
                                            PatrickWalther Developer @BananaJoe last edited by
                                            @bananajoe Vielleicht kann das ja @Meistertr einbinden.
                                            forecast photovoltaik
                                            113
                                            879
                                            280515
