    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Solax WR zeigt teils keine aktuellen Daten in den Objekten
      Chris999 @wendy2702 last edited by
      @wendy2702 So..nochmal...
      Was muss ich jetzt genau in Putty eingeben?
      Ich logge mich doch erst auf dem Pi ein...oder?
      Da kann er aber mit dem Kommando nichts anfangen
        Chris999 @simatec last edited by wendy2702
        @simatec Ich habe jetzt mal bei Protokolle den Log heruntergeladen...
        2022-02-28 22:00:40.896 - info: host.raspberrypi "system.adapter.solax.0" enabled
        2022-02-28 22:00:40.969 - info: host.raspberrypi instance system.adapter.solax.0 started with pid 16308
        2022-02-28 22:00:42.119 - debug: solax.0 (16308) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2022-02-28 22:00:42.156 - debug: solax.0 (16308) Objects client ready ... initialize now
        2022-02-28 22:00:42.158 - debug: solax.0 (16308) Objects create System PubSub Client
        2022-02-28 22:00:42.160 - debug: solax.0 (16308) Objects create User PubSub Client
        2022-02-28 22:00:42.183 - debug: solax.0 (16308) Objects client initialize lua scripts
        2022-02-28 22:00:42.189 - debug: solax.0 (16308) Objects connected to redis: 127.0.0.1:9001
        2022-02-28 22:00:42.214 - debug: solax.0 (16308) Redis States: Use Redis connection: 127.0.0.1:9000
        2022-02-28 22:00:42.223 - debug: solax.0 (16308) States create System PubSub Client
        2022-02-28 22:00:42.224 - debug: solax.0 (16308) States create User PubSub Client
        2022-02-28 22:00:42.237 - debug: solax.0 (16308) States connected to redis: 127.0.0.1:9000
        2022-02-28 22:00:42.287 - debug: solax.0 (16308) Plugin sentry Initialize Plugin (enabled=true)
        2022-02-28 22:00:42.641 - warn: solax.0 (16308) Object solax.0.suninfo.Altitude is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.642 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.646 - warn: solax.0 (16308) Object solax.0.suninfo.Altitude is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.646 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.656 - info: solax.0 (16308) State value to set for "solax.0.suninfo.Altitude" has to be type "number" but received type "string"
        2022-02-28 22:00:42.663 - warn: solax.0 (16308) Object solax.0.suninfo.Azimut is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.663 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.666 - warn: solax.0 (16308) Object solax.0.suninfo.Azimut is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.667 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.673 - info: solax.0 (16308) State value to set for "solax.0.suninfo.Azimut" has to be type "number" but received type "string"
        2022-02-28 22:00:42.679 - warn: solax.0 (16308) Object solax.0.history.yield_1_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.680 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.683 - warn: solax.0 (16308) Object solax.0.history.yield_1_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.683 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.733 - info: solax.0 (16308) State value to set for "solax.0.history.yield_1_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.739 - warn: solax.0 (16308) Object solax.0.history.yield_2_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.739 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.742 - warn: solax.0 (16308) Object solax.0.history.yield_2_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.743 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.749 - info: solax.0 (16308) State value to set for "solax.0.history.yield_2_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.755 - warn: solax.0 (16308) Object solax.0.history.yield_3_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.756 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.759 - warn: solax.0 (16308) Object solax.0.history.yield_3_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.759 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.768 - info: solax.0 (16308) State value to set for "solax.0.history.yield_3_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.774 - warn: solax.0 (16308) Object solax.0.history.yield_4_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.775 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.777 - warn: solax.0 (16308) Object solax.0.history.yield_4_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.778 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.784 - info: solax.0 (16308) State value to set for "solax.0.history.yield_4_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.790 - warn: solax.0 (16308) Object solax.0.history.yield_5_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.791 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.793 - warn: solax.0 (16308) Object solax.0.history.yield_5_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.794 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.843 - info: solax.0 (16308) State value to set for "solax.0.history.yield_5_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.849 - warn: solax.0 (16308) Object solax.0.history.yield_6_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.849 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.852 - warn: solax.0 (16308) Object solax.0.history.yield_6_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.852 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.859 - info: solax.0 (16308) State value to set for "solax.0.history.yield_6_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.865 - warn: solax.0 (16308) Object solax.0.history.yield_7_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.865 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.868 - warn: solax.0 (16308) Object solax.0.history.yield_7_days_ago is invalid: Default value has to be type "number" but received type "string"
        2022-02-28 22:00:42.869 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.876 - info: solax.0 (16308) State value to set for "solax.0.history.yield_7_days_ago" has to be type "number" but received type "string"
        2022-02-28 22:00:42.891 - warn: solax.0 (16308) Object solax.0.info.success is invalid: Default value has to be type "boolean" but received type "string"
        2022-02-28 22:00:42.892 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.894 - warn: solax.0 (16308) Object solax.0.info.success is invalid: Default value has to be type "boolean" but received type "string"
        2022-02-28 22:00:42.895 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer.
        2022-02-28 22:00:42.901 - info: solax.0 (16308) State value to set for "solax.0.info.success" has to be type "boolean" but received type "string"
        2022-02-28 22:00:42.963 - info: solax.0 (16308) starting. Version 0.3.7 in /opt/iobroker/node_modules/iobroker.solax, node: v14.19.0, js-controller: 4.0.15
        2022-02-28 22:00:42.989 - debug: solax.0 (16308) Solax is started
        2022-02-28 22:00:43.010 - debug: solax.0 (16308) System longitude: 9.205442731944252 System latitude: 52.80312946030813
        2022-02-28 22:00:43.011 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:00:43.012 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:00:43.013 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:00:43.013 - debug: solax.0 (16308) current local Time: 22:00
        2022-02-28 22:00:43.015 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:00:43.015 - debug: solax.0 (16308) Sun Altitude: -35.1°
        2022-02-28 22:00:43.015 - debug: solax.0 (16308) Sun Azimut: 310.5°
        2022-02-28 22:00:43.157 - debug: solax.0 (16308) Request Interval: 1 minute(s)
        2022-02-28 22:00:43.398 - debug: solax.0 (16308) API Request successfully completed
        2022-02-28 22:00:45.473 - debug: solax.0 (16308) solaxRequest: {"success":true,"exception":"Query success!","result":{"inverterSN":"H3UE10H1011006","sn":"SWFFTM5RNN","acpower":196,"yieldtoday":34.4,"yieldtotal":4904.1,"feedinpower":-30,"feedinenergy":7436.06,"consumeenergy":1127.73,"soc":68,"inverterType":"5","inverterStatus":"102","uploadTime":"2022-02-28 21:59:11","batPower":-212}}
        2022-02-28 22:01:43.159 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:01:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:01:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:01:43.164 - debug: solax.0 (16308) current local Time: 22:01
        2022-02-28 22:01:43.165 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:01:43.166 - debug: solax.0 (16308) Sun Altitude: -35.2°
        2022-02-28 22:01:43.167 - debug: solax.0 (16308) Sun Azimut: 310.8°
        2022-02-28 22:01:43.191 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:02:43.160 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:02:43.161 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:02:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:02:43.162 - debug: solax.0 (16308) current local Time: 22:02
        2022-02-28 22:02:43.163 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:02:43.164 - debug: solax.0 (16308) Sun Altitude: -35.3°
        2022-02-28 22:02:43.164 - debug: solax.0 (16308) Sun Azimut: 311.1°
        2022-02-28 22:02:43.188 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:03:43.160 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:03:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:03:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:03:43.163 - debug: solax.0 (16308) current local Time: 22:03
        2022-02-28 22:03:43.164 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:03:43.165 - debug: solax.0 (16308) Sun Altitude: -35.5°
        2022-02-28 22:03:43.165 - debug: solax.0 (16308) Sun Azimut: 311.3°
        2022-02-28 22:03:43.183 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:04:43.160 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:04:43.161 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:04:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:04:43.163 - debug: solax.0 (16308) current local Time: 22:04
        2022-02-28 22:04:43.163 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:04:43.164 - debug: solax.0 (16308) Sun Altitude: -35.6°
        2022-02-28 22:04:43.165 - debug: solax.0 (16308) Sun Azimut: 311.6°
        2022-02-28 22:04:43.181 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:05:43.160 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:05:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:05:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:05:43.164 - debug: solax.0 (16308) current local Time: 22:05
        2022-02-28 22:05:43.165 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:05:43.166 - debug: solax.0 (16308) Sun Altitude: -35.7°
        2022-02-28 22:05:43.167 - debug: solax.0 (16308) Sun Azimut: 311.9°
        2022-02-28 22:05:43.189 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:06:43.161 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:06:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:06:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:06:43.163 - debug: solax.0 (16308) current local Time: 22:06
        2022-02-28 22:06:43.164 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:06:43.164 - debug: solax.0 (16308) Sun Altitude: -35.8°
        2022-02-28 22:06:43.165 - debug: solax.0 (16308) Sun Azimut: 312.2°
        2022-02-28 22:06:43.187 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:07:43.161 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:07:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:07:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:07:43.164 - debug: solax.0 (16308) current local Time: 22:07
        2022-02-28 22:07:43.165 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:07:43.166 - debug: solax.0 (16308) Sun Altitude: -35.9°
        2022-02-28 22:07:43.166 - debug: solax.0 (16308) Sun Azimut: 312.4°
        2022-02-28 22:07:43.189 - debug: solax.0 (16308) is Night: true
        2022-02-28 22:08:43.161 - debug: solax.0 (16308) nightCalc started ...
        2022-02-28 22:08:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14
        2022-02-28 22:08:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00
        2022-02-28 22:08:43.164 - debug: solax.0 (16308) current local Time: 22:08
        2022-02-28 22:08:43.165 - debug: solax.0 (16308) calculate astrodata ...
        2022-02-28 22:08:43.165 - debug: solax.0 (16308) Sun Altitude: -36°
        2022-02-28 22:08:43.166 - debug: solax.0 (16308) Sun Azimut: 312.7°
        2022-02-28 22:08:43.196 - debug: solax.0 (16308) is Night: true
        Mod Edit: log in Code Tags gesetzt
        wendy2702 simatec 2 Replies Last reply Reply Quote 0
        • wendy2702
          wendy2702 @Chris999 last edited by
          @chris999 Hast du den Adapter mal gestoppt, alle Objekte gelöscht und Adapter neu gestartet?
          Ist das log von nach dieser Aktion?
          • simatec
            simatec Developer Most Active @Chris999 last edited by
            @chris999 sagte in Solax WR zeigt teils keine aktuellen Daten in den Objekten:
            is Night: true
            In der Nacht holt er keine daten.
            Wenn gewünscht, kann ich das konfigurierbar machen
              @wendy2702 Ja...gestoppt, gelöscht und neu gestartet. Dann den log gezogen
                Chris999 @simatec last edited by Chris999
                @simatec Er holt tagsüber auch nicht alle Daten
                Aktuell ist:
                acpower vom 1.3. 07:24
                batpower vom 1.3. 19:16
                consumeenergy vom 1.3. 19:16
                feedinenergy vom 1.3. 19:16
                feedinpower vom 28.2. 22:00
                soc vom 1.3. 19:16
                Aktuelle Uhrzeit ist 20:05
                ist schon seltsam, dass er so unterschiedlich die Daten holt...oder nicht holt..
                zumindest soc wäre auch nachts interessant.
                Aber am wichtigsten für mich ist feedinpower, um meine Klimaanlagen bedarfsgerecht schalten zu können.
                Bekommen wir das irgendwie hin?
                • simatec
                  @chris999 Das hört sich sehr komisch an.
                  Hab meine Anlage gerade mal auf Cloud umgestellt und alle Daten kommen im 5 Minuten Intervall.
                  Mache mal folgendes.
                  Hole dir mal die Daten parallel zur Abfrage über den browser und vergleiche diese mal.
                  Somit können wir ausschließen, ob das Problem beim adapter oder bei deiner Cloudabfrage liegt.
                  https://www.eu.solaxcloud.com:9443/proxy/api/getRealtimeInfo.do?tokenId=XXXXXXXXXXXXXXXXXXXXX&sn=XXXXXXXX
                    @simatec Habe ich jetzt gerade mal gemacht.
                    Da passen die Werte genau. Der Adapter zieht die bei mir aber aus der Cloud..oder?
                    Kann ich das umstellen, dass er die Werte direkt vom WR bekommt?
                    • simatec
                      @chris999 Das sind die Daten aus der Cloud.
                      Zeige mir mal bitte die Ausgabe im Browser und die Werte im Adapter.
                      Welche Version vom Solax Adapter ist installiert?
                        @simatec
                        Werte im Browser:
                        success true
                        exception "Query success!"
                        result
                        inverterSN "H3UE10H1011006"
                        sn "SWFFTM5RNN"
                        acpower 1164
                        yieldtoday 1.1
                        yieldtotal 4962.7
                        feedinpower -18
                        feedinenergy 7517.11
                        consumeenergy 1140.14
                        feedinpowerM2 0
                        soc 52
                        peps1 0
                        peps2 0
                        peps3 0
                        inverterType "5"
                        inverterStatus "102"
                        uploadTime "2022-03-03 08:54:31"
                        batPower 1406
                        powerdc1 299
                        powerdc2 2259
                        powerdc3 null
                        powerdc4 null
                        Installierte Adapterversion ist 0.3.7
                        EDIT: Werte weichen etwas ab, da wohl nicht exakt zeitgleich erfasst
                        • simatec
                          Das ist nicht relevant, da die daten in der Cloud nur alle 5 Minuten aktualisiert werden.
                          Mir sind aber die Daten in der Browserausgabe und die Daten im iobroker wichtig.
                          Die muss ich vergleichen
                          D.h. Wenn der Adapter die Daten abgerufen hat, dann hole dir parallel die daten vom Browser
                          Und genau die benötige ich.
                          Ein Tipp wäre noch, die aktuelle latest zu installieren und nach Anleitung den Expertenmodus aktivieren, den Wifi Stick auf die Firmwareversion laut Anleitung zu flashen und sekundengenaue Daten direkt und lokal ohne Cloud zu bekommen.
                          Wenn du weiterhin lieber die Cloud nutzen willst, dann mache trotzdem mal bitte ein Update des Adapters auf die aktuelle latest Version.
                            @simatec
                            Browser:
                            success true
                            result
                            sn "SWFFTM5RNN"
                            acpower 1407
                            yieldtoday 1.5
                            yieldtotal 4963.1
                            feedinpower -103
                            feedinenergy 7517.5
                            consumeenergy 1140.54
                            feedinpowerM2 0
                            soc 54
                            peps1 0
                            peps2 0
                            peps3 0
                            inverterType "5"
                            uploadTime "2022-03-03 09:09:31"
                            batPower 1295
                            powerdc1 329
                            powerdc2 2346
                            powerdc3 null
                            powerdc4 null
                            iobroker:
                            Wenn ich die Daten direkt vom Stick in ioBroker bekommen will...läuft die Cloud dann nicht mehr?
                            Das würde ich schon gerne weiter nutzen...sonst kann ich von unterwegs ja nicht mehr auf die Anlage zugreifen...
                            Beim ioBroker wird die 0.3.7 als neueste Version angezeigt
                            • simatec
                              @chris999 Du musst deine Repo von Stable auf Beta umstellen.
                              Die Cloud funktioniert auch mit lokaler Abfrage
                              Was du genau machen musst, um lokal abfragen zu können, steht in der Doku
                                @simatec Danke..werde ich mal machen.
                                Das ist für mich alle noch extremes Neuland. Aber ich gebe mein Bestes, diese Sachen zu lernen.
                                Die Anleitung zum lokalen Abfragen hatte ich schon gelesen...aber gehofft, das nicht anwenden zu müssen 😉
                                Danke schonmal für deine Geduld mit mir... mit 50 lernt man nicht mehr so schnell neue Dinge 😉
                                • simatec
                                  @chris999 Die lokale Abfrage ist auch kein muss. Die Daten aus der Cloud sind im Grunde ausreichend.
                                  Nachteil bei der Cloud ist halt, dass man vor Störungen in der Cloud nicht geschützt ist und der Abruf nur alle 5 Minuten passieren kann.
                                  Teste bitte erstmal die aktuelle Beta Version.
                                    @simatec So.. ich hatte ja heute Vormittag die Beta Version geladen. Leider hat sich am Verhalten nichts geändert.
                                    Ich habe dann die Firmware auf dem Stick auf die Version dowgraded, die du in der Doku hinterlegt hast und in den Experteneinstellungen auf Lokal gestellt.
                                    In der Doku steht, die Firmware darf nicht höher, als 2.30.20 sein. Die hinterlegte Firmware ist allerding 2.33.20.
                                    Ist das so korrekt?
                                    Jedenfalls kommen jetzt gar keine Daten mehr rein. in den Objekten
                                    Oder habe ich einen Fehler gemacht?
                                    Der Adapter ist jedenfalls grün.
                                    • simatec
                                      @chris999
                                      Ja in der Doku ist noch ein Schreibfehler. Ist mir auch gerade aufgefallen.
                                      Die Firmware ist richtig.
                                      Zeige mal deine Einstellungen im Adapter und ein Screenshot des Webinterfaces vom Stick
                                        • simatec
                                          @chris999 Die lokale IP (192.168.188.105) in den Adaptereinstellungen fehlt.
                                          Des Weiteren musst du auch dein Passwort (Passwort des Wifi Sticks >>> Standard admin) in den Adaptereinstellungen setzen.
                                          C 2 Replies Last reply Reply Quote 1
                                            @simatec KopfaufTisch
                                            Ich wusste, dass ich einen blöden Fehler gemacht habe...
                                            Jetzt funktioniert es!!
                                            Vielen Dank für die Hilfe...jetzt kann ich mich daran setzen, ein Script zu erstellen.
                                            5981
