Solax WR zeigt teils keine aktuellen Daten in den Objekten
@simatec Ich habe jetzt mal bei Protokolle den Log heruntergeladen...
2022-02-28 22:00:40.896 - info: host.raspberrypi "system.adapter.solax.0" enabled 2022-02-28 22:00:40.969 - info: host.raspberrypi instance system.adapter.solax.0 started with pid 16308 2022-02-28 22:00:42.119 - debug: solax.0 (16308) Redis Objects: Use Redis connection: 127.0.0.1:9001 2022-02-28 22:00:42.156 - debug: solax.0 (16308) Objects client ready ... initialize now 2022-02-28 22:00:42.158 - debug: solax.0 (16308) Objects create System PubSub Client 2022-02-28 22:00:42.160 - debug: solax.0 (16308) Objects create User PubSub Client 2022-02-28 22:00:42.183 - debug: solax.0 (16308) Objects client initialize lua scripts 2022-02-28 22:00:42.189 - debug: solax.0 (16308) Objects connected to redis: 127.0.0.1:9001 2022-02-28 22:00:42.214 - debug: solax.0 (16308) Redis States: Use Redis connection: 127.0.0.1:9000 2022-02-28 22:00:42.223 - debug: solax.0 (16308) States create System PubSub Client 2022-02-28 22:00:42.224 - debug: solax.0 (16308) States create User PubSub Client 2022-02-28 22:00:42.237 - debug: solax.0 (16308) States connected to redis: 127.0.0.1:9000 2022-02-28 22:00:42.287 - debug: solax.0 (16308) Plugin sentry Initialize Plugin (enabled=true) 2022-02-28 22:00:42.641 - warn: solax.0 (16308) Object solax.0.suninfo.Altitude is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.642 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.646 - warn: solax.0 (16308) Object solax.0.suninfo.Altitude is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.646 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.656 - info: solax.0 (16308) State value to set for "solax.0.suninfo.Altitude" has to be type "number" but received type "string" 2022-02-28 22:00:42.663 - warn: solax.0 (16308) Object solax.0.suninfo.Azimut is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.663 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.666 - warn: solax.0 (16308) Object solax.0.suninfo.Azimut is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.667 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.673 - info: solax.0 (16308) State value to set for "solax.0.suninfo.Azimut" has to be type "number" but received type "string" 2022-02-28 22:00:42.679 - warn: solax.0 (16308) Object solax.0.history.yield_1_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.680 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.683 - warn: solax.0 (16308) Object solax.0.history.yield_1_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.683 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.733 - info: solax.0 (16308) State value to set for "solax.0.history.yield_1_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.739 - warn: solax.0 (16308) Object solax.0.history.yield_2_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.739 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.742 - warn: solax.0 (16308) Object solax.0.history.yield_2_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.743 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.749 - info: solax.0 (16308) State value to set for "solax.0.history.yield_2_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.755 - warn: solax.0 (16308) Object solax.0.history.yield_3_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.756 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.759 - warn: solax.0 (16308) Object solax.0.history.yield_3_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.759 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.768 - info: solax.0 (16308) State value to set for "solax.0.history.yield_3_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.774 - warn: solax.0 (16308) Object solax.0.history.yield_4_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.775 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.777 - warn: solax.0 (16308) Object solax.0.history.yield_4_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.778 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.784 - info: solax.0 (16308) State value to set for "solax.0.history.yield_4_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.790 - warn: solax.0 (16308) Object solax.0.history.yield_5_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.791 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.793 - warn: solax.0 (16308) Object solax.0.history.yield_5_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.794 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.843 - info: solax.0 (16308) State value to set for "solax.0.history.yield_5_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.849 - warn: solax.0 (16308) Object solax.0.history.yield_6_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.849 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.852 - warn: solax.0 (16308) Object solax.0.history.yield_6_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.852 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.859 - info: solax.0 (16308) State value to set for "solax.0.history.yield_6_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.865 - warn: solax.0 (16308) Object solax.0.history.yield_7_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.865 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.868 - warn: solax.0 (16308) Object solax.0.history.yield_7_days_ago is invalid: Default value has to be type "number" but received type "string" 2022-02-28 22:00:42.869 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.876 - info: solax.0 (16308) State value to set for "solax.0.history.yield_7_days_ago" has to be type "number" but received type "string" 2022-02-28 22:00:42.891 - warn: solax.0 (16308) Object solax.0.info.success is invalid: Default value has to be type "boolean" but received type "string" 2022-02-28 22:00:42.892 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.894 - warn: solax.0 (16308) Object solax.0.info.success is invalid: Default value has to be type "boolean" but received type "string" 2022-02-28 22:00:42.895 - warn: solax.0 (16308) This object will not be created in future versions. Please report this to the developer. 2022-02-28 22:00:42.901 - info: solax.0 (16308) State value to set for "solax.0.info.success" has to be type "boolean" but received type "string" 2022-02-28 22:00:42.963 - info: solax.0 (16308) starting. Version 0.3.7 in /opt/iobroker/node_modules/iobroker.solax, node: v14.19.0, js-controller: 4.0.15 2022-02-28 22:00:42.989 - debug: solax.0 (16308) Solax is started 2022-02-28 22:00:43.010 - debug: solax.0 (16308) System longitude: 9.205442731944252 System latitude: 52.80312946030813 2022-02-28 22:00:43.011 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:00:43.012 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:00:43.013 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:00:43.013 - debug: solax.0 (16308) current local Time: 22:00 2022-02-28 22:00:43.015 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:00:43.015 - debug: solax.0 (16308) Sun Altitude: -35.1° 2022-02-28 22:00:43.015 - debug: solax.0 (16308) Sun Azimut: 310.5° 2022-02-28 22:00:43.157 - debug: solax.0 (16308) Request Interval: 1 minute(s) 2022-02-28 22:00:43.398 - debug: solax.0 (16308) API Request successfully completed 2022-02-28 22:00:45.473 - debug: solax.0 (16308) solaxRequest: {"success":true,"exception":"Query success!","result":{"inverterSN":"H3UE10H1011006","sn":"SWFFTM5RNN","acpower":196,"yieldtoday":34.4,"yieldtotal":4904.1,"feedinpower":-30,"feedinenergy":7436.06,"consumeenergy":1127.73,"soc":68,"inverterType":"5","inverterStatus":"102","uploadTime":"2022-02-28 21:59:11","batPower":-212}} 2022-02-28 22:01:43.159 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:01:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:01:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:01:43.164 - debug: solax.0 (16308) current local Time: 22:01 2022-02-28 22:01:43.165 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:01:43.166 - debug: solax.0 (16308) Sun Altitude: -35.2° 2022-02-28 22:01:43.167 - debug: solax.0 (16308) Sun Azimut: 310.8° 2022-02-28 22:01:43.191 - debug: solax.0 (16308) is Night: true 2022-02-28 22:02:43.160 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:02:43.161 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:02:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:02:43.162 - debug: solax.0 (16308) current local Time: 22:02 2022-02-28 22:02:43.163 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:02:43.164 - debug: solax.0 (16308) Sun Altitude: -35.3° 2022-02-28 22:02:43.164 - debug: solax.0 (16308) Sun Azimut: 311.1° 2022-02-28 22:02:43.188 - debug: solax.0 (16308) is Night: true 2022-02-28 22:03:43.160 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:03:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:03:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:03:43.163 - debug: solax.0 (16308) current local Time: 22:03 2022-02-28 22:03:43.164 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:03:43.165 - debug: solax.0 (16308) Sun Altitude: -35.5° 2022-02-28 22:03:43.165 - debug: solax.0 (16308) Sun Azimut: 311.3° 2022-02-28 22:03:43.183 - debug: solax.0 (16308) is Night: true 2022-02-28 22:04:43.160 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:04:43.161 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:04:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:04:43.163 - debug: solax.0 (16308) current local Time: 22:04 2022-02-28 22:04:43.163 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:04:43.164 - debug: solax.0 (16308) Sun Altitude: -35.6° 2022-02-28 22:04:43.165 - debug: solax.0 (16308) Sun Azimut: 311.6° 2022-02-28 22:04:43.181 - debug: solax.0 (16308) is Night: true 2022-02-28 22:05:43.160 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:05:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:05:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:05:43.164 - debug: solax.0 (16308) current local Time: 22:05 2022-02-28 22:05:43.165 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:05:43.166 - debug: solax.0 (16308) Sun Altitude: -35.7° 2022-02-28 22:05:43.167 - debug: solax.0 (16308) Sun Azimut: 311.9° 2022-02-28 22:05:43.189 - debug: solax.0 (16308) is Night: true 2022-02-28 22:06:43.161 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:06:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:06:43.162 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:06:43.163 - debug: solax.0 (16308) current local Time: 22:06 2022-02-28 22:06:43.164 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:06:43.164 - debug: solax.0 (16308) Sun Altitude: -35.8° 2022-02-28 22:06:43.165 - debug: solax.0 (16308) Sun Azimut: 312.2° 2022-02-28 22:06:43.187 - debug: solax.0 (16308) is Night: true 2022-02-28 22:07:43.161 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:07:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:07:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:07:43.164 - debug: solax.0 (16308) current local Time: 22:07 2022-02-28 22:07:43.165 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:07:43.166 - debug: solax.0 (16308) Sun Altitude: -35.9° 2022-02-28 22:07:43.166 - debug: solax.0 (16308) Sun Azimut: 312.4° 2022-02-28 22:07:43.189 - debug: solax.0 (16308) is Night: true 2022-02-28 22:08:43.161 - debug: solax.0 (16308) nightCalc started ... 2022-02-28 22:08:43.162 - debug: solax.0 (16308) nauticalDusk: 19:14 2022-02-28 22:08:43.163 - debug: solax.0 (16308) nauticalDawn: 06:00 2022-02-28 22:08:43.164 - debug: solax.0 (16308) current local Time: 22:08 2022-02-28 22:08:43.165 - debug: solax.0 (16308) calculate astrodata ... 2022-02-28 22:08:43.165 - debug: solax.0 (16308) Sun Altitude: -36° 2022-02-28 22:08:43.166 - debug: solax.0 (16308) Sun Azimut: 312.7° 2022-02-28 22:08:43.196 - debug: solax.0 (16308) is Night: trueMod Edit: log in Code Tags gesetzt
@chris999 Hast du den Adapter mal gestoppt, alle Objekte gelöscht und Adapter neu gestartet?
Ist das log von nach dieser Aktion?
@chris999 sagte in Solax WR zeigt teils keine aktuellen Daten in den Objekten:
is Night: true
In der Nacht holt er keine daten.
Wenn gewünscht, kann ich das konfigurierbar machen -
@wendy2702 Ja...gestoppt, gelöscht und neu gestartet. Dann den log gezogen
@simatec Er holt tagsüber auch nicht alle Daten
Aktuell ist:
acpower vom 1.3. 07:24
batpower vom 1.3. 19:16
consumeenergy vom 1.3. 19:16
feedinenergy vom 1.3. 19:16
feedinpower vom 28.2. 22:00
soc vom 1.3. 19:16Aktuelle Uhrzeit ist 20:05
ist schon seltsam, dass er so unterschiedlich die Daten holt...oder nicht holt..
zumindest soc wäre auch nachts interessant.
Aber am wichtigsten für mich ist feedinpower, um meine Klimaanlagen bedarfsgerecht schalten zu können.Bekommen wir das irgendwie hin?
@chris999 Das hört sich sehr komisch an.
Hab meine Anlage gerade mal auf Cloud umgestellt und alle Daten kommen im 5 Minuten Intervall.Mache mal folgendes.
Hole dir mal die Daten parallel zur Abfrage über den browser und vergleiche diese mal.
Somit können wir ausschließen, ob das Problem beim adapter oder bei deiner Cloudabfrage liegt. -
@simatec Habe ich jetzt gerade mal gemacht.
Da passen die Werte genau. Der Adapter zieht die bei mir aber aus der Cloud..oder?
Kann ich das umstellen, dass er die Werte direkt vom WR bekommt? -
@chris999 Das sind die Daten aus der Cloud.
Zeige mir mal bitte die Ausgabe im Browser und die Werte im Adapter.Welche Version vom Solax Adapter ist installiert?
@simatec
Werte im Browser:success true
exception "Query success!"
result
inverterSN "H3UE10H1011006"
sn "SWFFTM5RNN"
acpower 1164
yieldtoday 1.1
yieldtotal 4962.7
feedinpower -18
feedinenergy 7517.11
consumeenergy 1140.14
feedinpowerM2 0
soc 52
peps1 0
peps2 0
peps3 0
inverterType "5"
inverterStatus "102"
uploadTime "2022-03-03 08:54:31"
batPower 1406
powerdc1 299
powerdc2 2259
powerdc3 null
powerdc4 null
Installierte Adapterversion ist 0.3.7
EDIT: Werte weichen etwas ab, da wohl nicht exakt zeitgleich erfasst
Das ist nicht relevant, da die daten in der Cloud nur alle 5 Minuten aktualisiert werden.
Mir sind aber die Daten in der Browserausgabe und die Daten im iobroker wichtig.Die muss ich vergleichen
D.h. Wenn der Adapter die Daten abgerufen hat, dann hole dir parallel die daten vom Browser
Und genau die benötige ich.Ein Tipp wäre noch, die aktuelle latest zu installieren und nach Anleitung den Expertenmodus aktivieren, den Wifi Stick auf die Firmwareversion laut Anleitung zu flashen und sekundengenaue Daten direkt und lokal ohne Cloud zu bekommen.
Wenn du weiterhin lieber die Cloud nutzen willst, dann mache trotzdem mal bitte ein Update des Adapters auf die aktuelle latest Version.
@simatec
Browser:
success true
result
sn "SWFFTM5RNN"
acpower 1407
yieldtoday 1.5
yieldtotal 4963.1
feedinpower -103
feedinenergy 7517.5
consumeenergy 1140.54
feedinpowerM2 0
soc 54
peps1 0
peps2 0
peps3 0
inverterType "5"
uploadTime "2022-03-03 09:09:31"
batPower 1295
powerdc1 329
powerdc2 2346
powerdc3 null
powerdc4 nulliobroker:
Wenn ich die Daten direkt vom Stick in ioBroker bekommen will...läuft die Cloud dann nicht mehr?
Das würde ich schon gerne weiter nutzen...sonst kann ich von unterwegs ja nicht mehr auf die Anlage zugreifen...Beim ioBroker wird die 0.3.7 als neueste Version angezeigt
@simatec Danke..werde ich mal machen.
Das ist für mich alle noch extremes Neuland. Aber ich gebe mein Bestes, diese Sachen zu lernen.Die Anleitung zum lokalen Abfragen hatte ich schon gelesen...aber gehofft, das nicht anwenden zu müssen
Danke schonmal für deine Geduld mit mir... mit 50 lernt man nicht mehr so schnell neue Dinge
@chris999 Die lokale Abfrage ist auch kein muss. Die Daten aus der Cloud sind im Grunde ausreichend.
Nachteil bei der Cloud ist halt, dass man vor Störungen in der Cloud nicht geschützt ist und der Abruf nur alle 5 Minuten passieren kann.Teste bitte erstmal die aktuelle Beta Version.
@simatec So.. ich hatte ja heute Vormittag die Beta Version geladen. Leider hat sich am Verhalten nichts geändert.
Ich habe dann die Firmware auf dem Stick auf die Version dowgraded, die du in der Doku hinterlegt hast und in den Experteneinstellungen auf Lokal gestellt.
In der Doku steht, die Firmware darf nicht höher, als 2.30.20 sein. Die hinterlegte Firmware ist allerding 2.33.20.
Ist das so korrekt?
Jedenfalls kommen jetzt gar keine Daten mehr rein. in den Objekten
Oder habe ich einen Fehler gemacht?
Der Adapter ist jedenfalls grün. -
@chris999
Ja in der Doku ist noch ein Schreibfehler. Ist mir auch gerade aufgefallen.
Die Firmware ist richtig.Zeige mal deine Einstellungen im Adapter und ein Screenshot des Webinterfaces vom Stick
@chris999 Die lokale IP (192.168.188.105) in den Adaptereinstellungen fehlt.
Des Weiteren musst du auch dein Passwort (Passwort des Wifi Sticks >>> Standard admin) in den Adaptereinstellungen setzen.
@simatec KopfaufTisch
Ich wusste, dass ich einen blöden Fehler gemacht habe...Jetzt funktioniert es!!
Vielen Dank für die Hilfe...jetzt kann ich mich daran setzen, ein Script zu erstellen.
@simatec Kann es sein, dass lokal keine Werte der Batterie ausgelesen werden?
Und wie du ja schon sagtest, werden Nachts ebenfalls keine Werte abgefragt. Um 20 Uhr war gestern schluss.
Kann man das noch irgendwie anpassen?
Ansonsten kommen jetzt schön die Werte rein... gefällt mir
