    4. [Problem] HM-RPC-Adapter 1.4.5 läuft nicht richtig (on/off)
      Marcolotti last edited by
      Bei mir ebenso.
        Australier last edited by
        Kann ich ebenfalls bestätigen, bis auf "BIN-RPC" alle anderen RPC-Adapter auf GELB
          rascal last edited by
          gleiches Problem, bei mir schmiert deswegen sogar die occu ab 😞
            leo013 last edited by
            Bei mir ebenfalls, aber nur für die CUXD Einstellungen mit Bin-RPC
            host.raspberrypi 2017-04-22 08:06:08.431 info instance system.adapter.hm-rpc.0 terminated with code null ()
            host.raspberrypi 2017-04-22 08:06:08.429 warn instance system.adapter.hm-rpc.0 terminated due to SIGTERM
            host.raspberrypi 2017-04-22 08:06:08.389 info stopInstance system.adapter.hm-rpc.0 killing pid 24934
            host.raspberrypi 2017-04-22 08:06:08.388 info stopInstance system.adapter.hm-rpc.0
            host.raspberrypi 2017-04-22 08:06:08.387 info object change system.adapter.hm-rpc.0
            host.raspberrypi 2017-04-22 08:06:07.096 info instance system.adapter.hm-rpc.0 started with pid 24934
            hm-rpc.0 2017-04-22 08:06:04.599 info binrpc -> 192.168.123.170:2001 init ["xmlrpc_bin://192.168.123.37:2001",""]
            host.raspberrypi 2017-04-22 08:06:04.553 info stopInstance system.adapter.hm-rpc.0 killing pid 32296
            host.raspberrypi 2017-04-22 08:06:04.552 info stopInstance system.adapter.hm-rpc.0
            host.raspberrypi 2017-04-22 08:06:04.550 info object change system.adapter.hm-rpc.0
            host.raspberrypi 2017-04-22 08:05:22.355 info instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
            host.raspberrypi 2017-04-22 08:05:18.147 info instance system.adapter.hm-rpc.1 started with pid 24887
            host.raspberrypi 2017-04-22 08:05:15.545 info stopInstance system.adapter.hm-rpc.1 killing pid 23286
            host.raspberrypi 2017-04-22 08:05:15.542 info stopInstance system.adapter.hm-rpc.1
            hm-rpc.1 2017-04-22 08:05:15.564 info binrpc -> 192.168.123.170:8701 init ["xmlrpc_bin://192.168.123.37:8706",""]
            host.raspberrypi 2017-04-22 08:05:15.488 info object change system.adapter.hm-rpc.1
            hm-rpc.1 2017-04-22 08:02:33.468 error Socket error: Error: connect ECONNREFUSED 192.168.123.170:8701
            host.raspberrypi 2017-04-22 08:00:11.780 info instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
              apollon77 last edited by
              schaut mal die 1.4.6/Github-Version , Bluefox hat gerade nochmal an den Dependecies gedreht
                foxi last edited by
                ich kann die Probleme hier auch bestätigen. Nach 4 Monaten uptime habe ich iobroker(update) und die CCU2(Firmware) auf Aktuellen Stand gebracht. Im Ergebnis ist die CCU nicht Bedienbar gewesen - quasi abgewürgt. 😄 Hat lange gedauert bis ich auf iobroker und dem cuxd mit bin-rpc gekommen bin das da die Probleme her kommen. Also der hm-rpc0 läuft hier mit dem rfd (CCU) über bin-rpc und bekommt die Verbindungen - wenn auch mitunter etwas widerwillig.
                Der hm-rpc1 (cuxd) bekommt hier mit bin-rpc keine komplette Verbindung (Verbunden mit hm-rpc = falsch) Ich habe jetzt erstmal den hm-rpc mit cuxd komplett aus iobroker verband damit die ccu wenigstens läuft.
                Edit: Mit aus Github installieren habe ich mich noch nicht beschäftigt wie das funktioniert - ist das eine größere Baustelle 😉
                Beste Grüße vom Volker
                  Github simpel!
                  Unter Adapter ist das dritte Icon oben von Links so ein Katzenkopf. Tooltip drüber ist "Custom Install" oder so. Da drauf. Dort beim Tab "Von Github" einfach den Adapter wählen und los gehts.
                    WolleGee last edited by
                    Hallo
                    bei mir hat das Update auf die 1.4.6 auch keine Verbesserung gebracht. Der hm.rpc.0 (rfd) springt von grün auf Gelb, der hm.rpc.1 (hmip) ist auf grün. Im Log steht folgendes:
                    hm-rpc.0	2017-04-22 11:39:28.695	info	binrpc -> 150 devices
                    hm-rpc.0	2017-04-22 11:39:28.684	info	binrpc <- listDevices ["hm-rpc.0"]
                    hm-rpc.0	2017-04-22 11:39:28.669	info	binrpc <- system.listMethods ["hm-rpc.0"]
                    hm-rpc.0	2017-04-22 11:39:28.370	info	binrpc -> 150 devices
                    hm-rpc.0	2017-04-22 11:39:28.359	info	binrpc <- listDevices ["hm-rpc.0"]
                    hm-rpc.0	2017-04-22 11:39:28.345	info	binrpc <- system.listMethods ["hm-rpc.0"]
                    und das fortlaufend… Die CCU reagiert seitdem auch sehr träge
                    Wolle
                      foxi last edited by
                      hier läuft es jetzt mit der 1.4.6 - Fettes Danke an Bluefox
                      ! hm-rpc.1 2017-04-22 11:53:10.704 info Connected
                      ! hm-rpc.1 2017-04-22 11:53:10.698 info new CUxD devices/channels after filter: 0
                      ! hm-rpc.1 2017-04-22 11:53:10.683 info binrpc -> listDevices 18
                      ! hm-rpc.1 2017-04-22 11:53:10.029 info binrpc client is trying to connect to 192.168.178.28:8701 with ["xmlrpc_bin://192.168.178.23:8701","hm-rpc.1"]
                      ! hm-rpc.1 2017-04-22 11:53:10.026 info binrpc server is trying to listen on 192.168.178.23:8701
                      ! hm-rpc.1 2017-04-22 11:53:09.780 info starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v4.2.6
                      Gruß vom Volker
                      • BBTown
                        BBTown last edited by
                        Auch von meiner Seite die Bestätigung, dass sowohl mit der hm.rpc Version 1.4.5 als auch mit der 1.4.6 der Adapter Schwierigkeiten macht.
                        Ich nutze 2 Instanzen vom hm.rpc (einmal wireless, einmal wired).
                        Mit der 1.4.5 konnte nur der wireless (hm.rpc.0) gestartet werden, der wired (hm.rpc.1) blieb rot.
                        Mit der Version 1.4.6 gehen beide Instanzen auf grün, wechseln dann jedoch rhytmisch wieder auf rot.
                        Anbei mein Log hierzu:
                          Dieses Verhalten kann ich bestätigen.
                          Das Problem:
                          Beim Update (genau gesagt davor) wurde der laufende Prozess nicht gekillt)
                          Nach dem Update sollte er wieder gestartet werden, statt dessen wurde er zum zweiten mal gestartet
                          Die Lösung:
                          Die Instanz stoppen und die dann noch laufende zusätzliche Instanz über die Konsole killen und anschließend die hm-rpc (im admin) wieder starten.
                          Das Vorgehen:
                          über die Konsole mit
                          cd /opt/iobroker
                          sudo iobroker stop hm-rpc.0
                          ggf. auch weitere Instanzen
                          dann die PID des noch laufenden Prozesses herausbekommen mit:
                          ps -A | grep io
                          irgendwo steht dann noch z.B. ein
                          20234 ? 00:05:30 io.hm-rpc.0
                          Anschließend diesen Prozess killen
                          sudo kill -9 20243
                          Dies ggf. mit weiteren Instanzen ebenfalls durchführen.
                          Dann wieder mit
                          sudo iobroker start hm-rpc.0
                          die Instanz starten, alternativ über den Reiter Instanzen im Admin
                          Viel Erfolg
                          Rainer
                          • BBTown
                            Moin Rainer,
                            Deine Anleitung war Perfekt!! 😄
                            Bei mir waren es insgesamt 6 hm-rpc Prozesse die noch liefen :shock:
                            Nun macht es einen guten Eindruck und die v.1.4.6 scheint wieder zu machen was sie soll
                            Vielen Dank für deine superschnelle Hilfe und ein erholsames Wochenende.
                              Auch von mir ein Danke!
                              Alles wieder in Ordnung!
                              Bei mir liefen 8 Prozesse! Jetzt muss ich nur noch meine Wemos updaten.
                              Wolfgang
                                Semenchkare last edited by
                                auch bei mir wieder alles im grünen Bereich!
                                Herzlichen Dank!
                                  bei mir läuft seit den Updates die 2. Instanz (CUXD) nicht mehr richtig.
                                  Apr 23 11:12:07 homematic-ccu2 daemon.info cuxd[307]: INIT 'xmlrpc_bin://192.168.178.23:8701' ''
                                  Apr 23 11:12:12 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                                  Apr 23 11:12:12 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(listDevices) request
                                  Apr 23 11:12:19 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                                  Apr 23 11:12:19 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(listDevices) request
                                  Apr 23 11:13:49 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(ping) request
                                  Apr 23 11:14:23 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                                  Apr 23 11:15:09 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(init) request
                                  Apr 23 11:15:09 homematic-ccu2 daemon.warn cuxd[307]: process_rpc_request(192.168.178.23) - illegal XMLRPC(listDevices) request
                                  Ich habe den Tip von Rainer schon ausprobiert. Nichts.
                                  Gruß Marco
                                    Das ist auch kein Wunder, da cuxd nur bin-rpc versteht.
                                    Mit dem letzten fix des Adapters sollte das dann wieder gehen.
                                    Rainer
                                      robsdobs last edited by
                                      Ich hab auch Probleme mit CUXD.
                                      Meine Version ist die 1.4.6.
                                      Ich wollte die Kanäle neu einlesen, weil ich einige Datenpunkt umbenannt hatte (hieß mal LIGHT, jetzt GAS).
                                      Im WebUI soeht es folgendermaßen aus:
                                      Also unter Objekte hab ich das gelöscht und Geräte neu einlesen den haken rein:
                                      Wenn ich jetzt Speichere und den haken bei neu einlesen setze und speichere springt das erstmal ständig zwischen Connected und Disconnected hin und her:
                                      hm-rpc.2	2017-04-26 22:35:30.088	info	Disconnected
                                      hm-rpc.2	2017-0 4-26 22:35:30.088	info	Connected
                                      hm-rpc.2	2017-04-26 22:35:30.087	info	Connected
                                      hm-rpc.2	2017-04-26 22:35:14.878	info	Connected
                                      hm-rpc.2	2017-04-26 22:35:14.877	info	new CUxD devices/channels after filter: 0
                                      hm-rpc.2	2017-04-26 22:35:14.854	info	binrpc -> listDevices 125
                                      hm-rpc.2	2017-04-26 22:35:14.360	info	binrpc client is trying to connect to 192.168.178.205:8701 with ["xmlrpc_bin://192.168.178.220:8711","hm-rpc.2"]
                                      hm-rpc.2	2017-04-26 22:35:14.357	info	binrpc server is trying to listen on 192.168.178.220:8711
                                      hm-rpc.2	2017-04-26 22:35:13.249	info	starting. Version 1.4.6 in /media/1c31537f-0f75-428d-9228-7b54b469086c/programms/iobroker/node_modules/iobroker.hm-rpc, node: v4.8.2
                                      hm-rpc.2	2017-04-26 22:35:10.137	info	Disconnected
                                      hm-rpc.2	2017-04-26 22:35:10.133	info	binrpc -> 192.168.178.205:8701 init ["xmlrpc_bin://192.168.178.220:8711",""]
                                      hm-rpc.2	2017-04-26 22:35:06.628	info	Connected
                                      hm-rpc.2	2017-04-26 22:35:05.702	info	binrpc -> listDevices 125
                                      hm-rpc.2	2017-04-26 22:35:05.197	info	binrpc client is trying to connect to 192.168.178.205:8701 with ["xmlrpc_bin://192.168.178.220:8711","hm-rpc.2"]
                                      hm-rpc.2	2017-04-26 22:35:05.193	info	binrpc server is trying to listen on 192.168.178.220:8711
                                      hm-rpc.2	2017-04-26 22:35:04.048	info	starting. Version 1.4.6 in /media/1c31537f-0f75-428d-9228-7b54b469086c/programms/iobroker/node_modules/iobroker.hm-rpc, node: v4.8.2
                                      hm-rpc.2	2017-04-26 22:35:01.001	info	terminating
                                      hm-rpc.2	2017-04-26 22:35:00.979	info	Disconnected
                                      hm-rpc.2	2017-04-26 22:35:00.977	info	binrpc -> 192.168.178.205:8701 init ["xmlrpc_bin://192.168.178.220:8711",""]
                                      Die Datenpunte stimmen dann nicht (LIGHT anstelle GAS):
                                      18
                                      3272
