    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Sneaker75 @tombox last edited by Sneaker75
      @tombox Ich habe auf 0.0.10 aktualisiert, aber das hat es viel schlimmer gemacht. Nach einiger Zeit verabschiedet sich die Instanz und geht auf Rot. Version 0.0.8 lief ohne Probleme bis auf den Fehler bei Hermes, nachdem die Sendung aus der Liste geflogen ist.
      2022-03-02 18:10:01.542 - error: parcel.0 (15551) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-03-02 18:10:01.543 - error: parcel.0 (15551) unhandled promise rejection: Cannot read property 'toLocaleLowerCase' of undefined
      2022-03-02 18:10:01.545 - error: parcel.0 (15551) TypeError: Cannot read property 'toLocaleLowerCase' of undefined
      at Parcel.inDeliveryCheck (/opt/iobroker/node_modules/iobroker.parcel/main.js:1291:35)
      at /opt/iobroker/node_modules/iobroker.parcel/main.js:1211:50
      at Array.map ()
      at Parcel.mergeProviderJson (/opt/iobroker/node_modules/iobroker.parcel/main.js:1209:50)
      at /opt/iobroker/node_modules/iobroker.parcel/main.js:1106:30
      at async Parcel.updateProvider (/opt/iobroker/node_modules/iobroker.parcel/main.js:1041:17)
      at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.parcel/main.js:111:17)
      2022-03-02 18:10:01.545 - error: parcel.0 (15551) Cannot read property 'toLocaleLowerCase' of undefined
      2022-03-02 18:10:01.550 - info: parcel.0 (15551) terminating
      2022-03-02 18:10:01.557 - warn: parcel.0 (15551) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-03-02 18:10:02.180 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.224 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.225 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.226 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.227 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.228 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.229 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.231 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.317 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.318 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.320 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.321 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.322 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.323 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.324 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.326 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.327 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.328 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.330 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.331 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.332 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.333 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.512 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.514 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.516 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.521 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.522 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.523 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.541 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.543 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.544 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.547 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.549 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.563 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.564 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.565 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.566 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.567 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.568 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.569 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.570 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.571 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.572 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.573 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.574 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.575 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.576 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.577 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.578 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.579 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.580 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.581 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.582 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.583 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.584 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.585 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.586 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.587 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.588 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.589 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.590 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.591 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.592 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.593 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.594 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.595 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.596 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.597 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.598 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.599 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.600 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.601 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.602 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.603 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.604 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.605 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.606 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.607 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.608 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.611 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.612 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.613 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.614 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.615 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.616 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.617 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.618 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.619 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.620 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.621 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.622 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.623 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.630 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.631 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.635 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.636 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.637 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.638 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.639 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.640 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.641 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.642 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.646 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.648 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.649 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.652 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.653 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.654 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.655 - error: parcel.0 (15551) Error: DB closed
      2022-03-02 18:10:02.785 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory05.id: Connection is closed.
      2022-03-02 18:10:02.791 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.791 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory05.date: Connection is closed.
      2022-03-02 18:10:02.792 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.792 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory05.message: Connection is closed.
      2022-03-02 18:10:02.793 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.793 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory06.id: Connection is closed.
      2022-03-02 18:10:02.794 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.794 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory06.date: Connection is closed.
      2022-03-02 18:10:02.800 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.800 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory06.message: Connection is closed.
      2022-03-02 18:10:02.801 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.801 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory07.id: Connection is closed.
      2022-03-02 18:10:02.802 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.803 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory07.date: Connection is closed.
      2022-03-02 18:10:02.808 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.808 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory07.message: Connection is closed.
      2022-03-02 18:10:02.809 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.809 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory08.id: Connection is closed.
      2022-03-02 18:10:02.810 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.811 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory08.date: Connection is closed.
      2022-03-02 18:10:02.811 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.817 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory08.message: Connection is closed.
      2022-03-02 18:10:02.817 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.818 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory09.id: Connection is closed.
      2022-03-02 18:10:02.818 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.819 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory09.date: Connection is closed.
      2022-03-02 18:10:02.820 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.820 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory09.message: Connection is closed.
      2022-03-02 18:10:02.821 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.826 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.firstname: Connection is closed.
      2022-03-02 18:10:02.827 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.827 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.lastname: Connection is closed.
      2022-03-02 18:10:02.828 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.828 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.street: Connection is closed.
      2022-03-02 18:10:02.829 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.834 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.postalCode: Connection is closed.
      2022-03-02 18:10:02.837 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.838 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.city: Connection is closed.
      2022-03-02 18:10:02.842 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.842 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.country: Connection is closed.
      2022-03-02 18:10:02.848 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.849 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.sender.lastname: Connection is closed.
      2022-03-02 18:10:02.849 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.850 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.deliveryDate: Connection is closed.
      2022-03-02 18:10:02.850 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.851 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.deliveryTimeTo: Connection is closed.
      2022-03-02 18:10:02.852 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.852 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.deliveryTimeFrom: Connection is closed.
      2022-03-02 18:10:02.853 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.853 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.specialService: Connection is closed.
      2022-03-02 18:10:02.854 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.854 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory01.id: Connection is closed.
      2022-03-02 18:10:02.855 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory01.date: Connection is closed.
      2022-03-02 18:10:02.855 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.856 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory01.message: Connection is closed.
      2022-03-02 18:10:02.856 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.857 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory02.id: Connection is closed.
      2022-03-02 18:10:02.857 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.858 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory02.date: Connection is closed.
      2022-03-02 18:10:02.859 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.860 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory02.message: Connection is closed.
      2022-03-02 18:10:02.860 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.861 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory03.id: Connection is closed.
      2022-03-02 18:10:02.861 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.861 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory03.date: Connection is closed.
      2022-03-02 18:10:02.862 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.862 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory03.message: Connection is closed.
      2022-03-02 18:10:02.865 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory04.id: Connection is closed.
      2022-03-02 18:10:02.865 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.866 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory04.date: Connection is closed.
      2022-03-02 18:10:02.866 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.867 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory04.message: Connection is closed.
      2022-03-02 18:10:02.868 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.868 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory05.id: Connection is closed.
      2022-03-02 18:10:02.869 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.869 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory05.date: Connection is closed.
      2022-03-02 18:10:02.870 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.870 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory05.message: Connection is closed.
      2022-03-02 18:10:02.871 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.871 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory06.id: Connection is closed.
      2022-03-02 18:10:02.872 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.873 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory06.date: Connection is closed.
      2022-03-02 18:10:02.874 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.874 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory06.message: Connection is closed.
      2022-03-02 18:10:02.875 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.875 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory07.id: Connection is closed.
      2022-03-02 18:10:02.876 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.877 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory07.date: Connection is closed.
      2022-03-02 18:10:02.877 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.878 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory07.message: Connection is closed.
      2022-03-02 18:10:02.878 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.879 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory08.id: Connection is closed.
      2022-03-02 18:10:02.879 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.880 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory08.date: Connection is closed.
      2022-03-02 18:10:02.880 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.880 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory08.message: Connection is closed.
      2022-03-02 18:10:02.881 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.882 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory09.id: Connection is closed.
      2022-03-02 18:10:02.882 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.882 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory09.date: Connection is closed.
      2022-03-02 18:10:02.883 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.883 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory09.message: Connection is closed.
      2022-03-02 18:10:02.884 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.884 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory10.id: Connection is closed.
      2022-03-02 18:10:02.885 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.886 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory10.date: Connection is closed.
      2022-03-02 18:10:02.886 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.887 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory10.message: Connection is closed.
      2022-03-02 18:10:02.887 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.887 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.firstname: Connection is closed.
      2022-03-02 18:10:02.894 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.895 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.lastname: Connection is closed.
      2022-03-02 18:10:02.895 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.896 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.street: Connection is closed.
      2022-03-02 18:10:02.896 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.897 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.postalCode: Connection is closed.
      2022-03-02 18:10:02.897 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.897 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.city: Connection is closed.
      2022-03-02 18:10:02.898 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.898 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.country: Connection is closed.
      2022-03-02 18:10:02.899 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.899 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.sender.lastname: Connection is closed.
      2022-03-02 18:10:02.900 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.deliveryDate: Connection is closed.
      2022-03-02 18:10:02.900 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.901 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.deliveryTimeTo: Connection is closed.
      2022-03-02 18:10:02.901 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.902 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.deliveryTimeFrom: Connection is closed.
      2022-03-02 18:10:02.902 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.903 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.specialService: Connection is closed.
      2022-03-02 18:10:02.904 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.905 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory01.id: Connection is closed.
      2022-03-02 18:10:02.905 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.906 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory01.date: Connection is closed.
      2022-03-02 18:10:02.906 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.907 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory01.message: Connection is closed.
      2022-03-02 18:10:02.907 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.907 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory02.id: Connection is closed.
      2022-03-02 18:10:02.908 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.908 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory02.date: Connection is closed.
      2022-03-02 18:10:02.909 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory02.message: Connection is closed.
      2022-03-02 18:10:02.909 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.910 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory03.id: Connection is closed.
      2022-03-02 18:10:02.910 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.911 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory03.date: Connection is closed.
      2022-03-02 18:10:02.911 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.911 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory03.message: Connection is closed.
      2022-03-02 18:10:02.912 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.912 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory04.id: Connection is closed.
      2022-03-02 18:10:02.915 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.916 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory04.date: Connection is closed.
      2022-03-02 18:10:02.916 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.917 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory04.message: Connection is closed.
      2022-03-02 18:10:02.917 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.918 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory05.id: Connection is closed.
      2022-03-02 18:10:02.918 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.918 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory05.date: Connection is closed.
      2022-03-02 18:10:02.919 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.919 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory05.message: Connection is closed.
      2022-03-02 18:10:02.920 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.920 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory06.id: Connection is closed.
      2022-03-02 18:10:02.921 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.921 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory06.date: Connection is closed.
      2022-03-02 18:10:02.922 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.922 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory06.message: Connection is closed.
      2022-03-02 18:10:02.923 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.923 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.receiver.firstname: Connection is closed.
      2022-03-02 18:10:02.924 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.924 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.receiver.lastname: Connection is closed.
      2022-03-02 18:10:02.925 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.receiver.street: Connection is closed.
      2022-03-02 18:10:02.925 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.926 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.receiver.postalCode: Connection is closed.
      2022-03-02 18:10:02.927 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.927 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.receiver.city: Connection is closed.
      2022-03-02 18:10:02.928 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.928 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.receiver.country: Connection is closed.
      2022-03-02 18:10:02.929 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.930 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.sender.lastname: Connection is closed.
      2022-03-02 18:10:02.930 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.931 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.deliveryForecast.deliveryDate: Connection is closed.
      2022-03-02 18:10:02.931 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.932 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.deliveryForecast.deliveryTimeTo: Connection is closed.
      2022-03-02 18:10:02.932 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.933 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.deliveryForecast.deliveryTimeFrom: Connection is closed.
      2022-03-02 18:10:02.933 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.934 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.deliveryForecast.specialService: Connection is closed.
      2022-03-02 18:10:02.934 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.934 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory01.id: Connection is closed.
      2022-03-02 18:10:02.935 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.935 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory01.date: Connection is closed.
      2022-03-02 18:10:02.936 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.936 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory01.message: Connection is closed.
      2022-03-02 18:10:02.937 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.938 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory02.id: Connection is closed.
      2022-03-02 18:10:02.942 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.942 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory02.date: Connection is closed.
      2022-03-02 18:10:02.943 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.943 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory02.message: Connection is closed.
      2022-03-02 18:10:02.944 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.944 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory03.id: Connection is closed.
      2022-03-02 18:10:02.945 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.945 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory03.date: Connection is closed.
      2022-03-02 18:10:02.946 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.947 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory03.message: Connection is closed.
      2022-03-02 18:10:02.947 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.948 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory04.id: Connection is closed.
      2022-03-02 18:10:02.948 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.949 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory04.date: Connection is closed.
      2022-03-02 18:10:02.950 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.950 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen01.statusHistory04.message: Connection is closed.
      2022-03-02 18:10:02.951 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.951 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory07.id: Connection is closed.
      2022-03-02 18:10:02.952 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.952 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory07.date: Connection is closed.
      2022-03-02 18:10:02.953 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.953 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory07.message: Connection is closed.
      2022-03-02 18:10:02.954 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.954 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory08.id: Connection is closed.
      2022-03-02 18:10:02.955 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.956 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory08.date: Connection is closed.
      2022-03-02 18:10:02.956 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.957 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory08.message: Connection is closed.
      2022-03-02 18:10:02.957 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.958 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory09.id: Connection is closed.
      2022-03-02 18:10:02.958 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.958 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory09.date: Connection is closed.
      2022-03-02 18:10:02.959 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:02.961 - warn: parcel.0 (15551) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory09.message: Connection is closed.
      2022-03-02 18:10:02.962 - warn: parcel.0 (15551) get state error: Connection is closed.
      2022-03-02 18:10:03.061 - info: parcel.0 (15551) terminating with timeout
      2022-03-02 18:10:04.728 - error: host.raspberrypi4-iob instance system.adapter.parcel.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-03-02 18:10:04.729 - info: host.raspberrypi4-iob Restart adapter system.adapter.parcel.0 because enabled
      2022-03-02 18:10:34.791 - info: host.raspberrypi4-iob instance system.adapter.parcel.0 started with pid 32708
      2022-03-02 18:10:38.606 - info: parcel.0 (32708) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.parcel, node: v12.22.10, js-controller: 3.3.22
      2022-03-02 18:10:38.728 - info: parcel.0 (32708) Login to DHL
      2022-03-02 18:10:39.385 - info: parcel.0 (32708) Login to DHL successful
      2022-03-02 18:10:39.408 - info: parcel.0 (32708) Login to DPD
      2022-03-02 18:10:42.332 - info: parcel.0 (32708) Login to DPD successful
      2022-03-02 18:10:42.339 - info: parcel.0 (32708) Login to T17 User
      2022-03-02 18:10:43.200 - info: parcel.0 (32708) Login to T17 User successful
      2022-03-02 18:10:44.245 - info: parcel.0 (32708) Login to Amazon
      2022-03-02 18:10:47.605 - info: parcel.0 (32708) Login to Amazon successful
      2022-03-02 18:10:47.617 - info: parcel.0 (32708) Login to GLS
      2022-03-02 18:10:48.070 - info: parcel.0 (32708) Login to GLS successful
      2022-03-02 18:10:48.077 - info: parcel.0 (32708) Login to UPS
      2022-03-02 18:10:48.944 - info: parcel.0 (32708) Login to UPS successful
      2022-03-02 18:10:49.505 - info: parcel.0 (32708) Login to Hermes
      2022-03-02 18:10:49.910 - info: parcel.0 (32708) Login to Hermes successful
      2022-03-02 18:11:14.201 - error: parcel.0 (32708) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-03-02 18:11:14.202 - error: parcel.0 (32708) unhandled promise rejection: Cannot read property 'toLocaleLowerCase' of undefined
      2022-03-02 18:11:14.203 - error: parcel.0 (32708) TypeError: Cannot read property 'toLocaleLowerCase' of undefined
      at Array.map ()
      at async Parcel.onReady (/opt/iobroker/node_modules/iobroker.parcel/main.js:108:13)
      2022-03-02 18:11:14.204 - error: parcel.0 (32708) Cannot read property 'toLocaleLowerCase' of undefined
      2022-03-02 18:11:14.208 - info: parcel.0 (32708) terminating
      2022-03-02 18:11:14.209 - warn: parcel.0 (32708) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-03-02 18:11:14.865 - warn: parcel.0 (32708) get state error: DB closed
      2022-03-02 18:11:14.903 - warn: parcel.0 (32708) get state error: Connection is closed.
      2022-03-02 18:11:14.904 - warn: parcel.0 (32708) get state error: Connection is closed.
      2022-03-02 18:11:14.905 - warn: parcel.0 (32708) get state error: Connection is closed.
      2022-03-02 18:11:14.906 - warn: parcel.0 (32708) get state error: Connection is closed.
      2022-03-02 18:11:14.907 - warn: parcel.0 (32708) get state error: Connection is closed.
      2022-03-02 18:11:15.160 - error: host.raspberrypi4-iob instance system.adapter.parcel.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-03-02 18:11:15.161 - info: host.raspberrypi4-iob Restart adapter system.adapter.parcel.0 because enabled
      2022-03-02 18:11:45.221 - info: host.raspberrypi4-iob instance system.adapter.parcel.0 started with pid 1361
      2022-03-02 18:11:49.346 - info: parcel.0 (1361) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.parcel, node: v12.22.10, js-controller: 3.3.22
      2022-03-02 18:11:49.435 - info: parcel.0 (1361) Login to DHL
      2022-03-02 18:11:50.018 - info: parcel.0 (1361) Login to DHL successful
      2022-03-02 18:11:50.048 - info: parcel.0 (1361) Login to DPD
      2022-03-02 18:11:52.891 - info: parcel.0 (1361) Login to DPD successful
      2022-03-02 18:11:57.325 - info: parcel.0 (1361) Login to T17 User
      2022-03-02 18:11:57.619 - info: parcel.0 (1361) Login to T17 User successful
      2022-03-02 18:11:58.118 - info: parcel.0 (1361) Login to Amazon
      2022-03-02 18:12:01.538 - info: parcel.0 (1361) Login to Amazon successful
      2022-03-02 18:12:01.546 - info: parcel.0 (1361) Login to GLS
      2022-03-02 18:12:02.012 - info: parcel.0 (1361) Login to GLS successful
      2022-03-02 18:12:02.019 - info: parcel.0 (1361) Login to UPS
      2022-03-02 18:12:02.794 - info: parcel.0 (1361) Login to UPS successful
      2022-03-02 18:12:03.425 - info: parcel.0 (1361) Login to Hermes
      2022-03-02 18:12:03.813 - info: parcel.0 (1361) Login to Hermes successful
      2022-03-02 18:13:06.092 - error: parcel.0 (1361) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-03-02 18:13:06.093 - error: parcel.0 (1361) unhandled promise rejection: Cannot read property 'toLocaleLowerCase' of undefined
      2022-03-02 18:13:06.095 - error: parcel.0 (1361) TypeError: Cannot read property 'toLocaleLowerCase' of undefined
      at Array.map ()
      2022-03-02 18:13:06.096 - error: parcel.0 (1361) Cannot read property 'toLocaleLowerCase' of undefined
      2022-03-02 18:13:06.101 - info: parcel.0 (1361) terminating
      2022-03-02 18:13:06.103 - warn: parcel.0 (1361) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-03-02 18:13:06.652 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.653 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.654 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.657 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.658 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.659 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.660 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.661 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.662 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.663 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.664 - warn: parcel.0 (1361) get state error: DB closed
      2022-03-02 18:13:06.793 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.795 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.796 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.797 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.798 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.836 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.951 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.952 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.953 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.954 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.956 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.957 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.959 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.961 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.962 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.963 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.969 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.970 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.973 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.980 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.981 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.982 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:06.983 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.029 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.firstname: Connection is closed.
      2022-03-02 18:13:07.030 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.030 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.lastname: Connection is closed.
      2022-03-02 18:13:07.031 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.032 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.street: Connection is closed.
      2022-03-02 18:13:07.032 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.033 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.postalCode: Connection is closed.
      2022-03-02 18:13:07.034 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.035 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.city: Connection is closed.
      2022-03-02 18:13:07.035 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.036 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.receiver.country: Connection is closed.
      2022-03-02 18:13:07.037 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.037 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.sender.lastname: Connection is closed.
      2022-03-02 18:13:07.038 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.039 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.deliveryDate: Connection is closed.
      2022-03-02 18:13:07.040 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.040 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.deliveryTimeTo: Connection is closed.
      2022-03-02 18:13:07.041 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.041 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.deliveryTimeFrom: Connection is closed.
      2022-03-02 18:13:07.042 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.043 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.deliveryForecast.specialService: Connection is closed.
      2022-03-02 18:13:07.044 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.044 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory01.id: Connection is closed.
      2022-03-02 18:13:07.045 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.046 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory01.date: Connection is closed.
      2022-03-02 18:13:07.046 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.047 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory01.message: Connection is closed.
      2022-03-02 18:13:07.048 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.048 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory02.id: Connection is closed.
      2022-03-02 18:13:07.049 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.050 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory02.date: Connection is closed.
      2022-03-02 18:13:07.051 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.052 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory02.message: Connection is closed.
      2022-03-02 18:13:07.053 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.054 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory03.id: Connection is closed.
      2022-03-02 18:13:07.054 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.055 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory03.date: Connection is closed.
      2022-03-02 18:13:07.056 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.056 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory03.message: Connection is closed.
      2022-03-02 18:13:07.057 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.058 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory04.id: Connection is closed.
      2022-03-02 18:13:07.058 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.059 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory04.date: Connection is closed.
      2022-03-02 18:13:07.060 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.060 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory04.message: Connection is closed.
      2022-03-02 18:13:07.061 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.062 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory05.id: Connection is closed.
      2022-03-02 18:13:07.062 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.063 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory05.date: Connection is closed.
      2022-03-02 18:13:07.064 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.065 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory05.message: Connection is closed.
      2022-03-02 18:13:07.065 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.066 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory06.id: Connection is closed.
      2022-03-02 18:13:07.066 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.067 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory06.date: Connection is closed.
      2022-03-02 18:13:07.067 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.068 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory06.message: Connection is closed.
      2022-03-02 18:13:07.068 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.069 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory07.id: Connection is closed.
      2022-03-02 18:13:07.069 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.070 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory07.date: Connection is closed.
      2022-03-02 18:13:07.070 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.071 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory07.message: Connection is closed.
      2022-03-02 18:13:07.071 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.072 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory08.id: Connection is closed.
      2022-03-02 18:13:07.072 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.073 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory08.date: Connection is closed.
      2022-03-02 18:13:07.074 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.074 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory08.message: Connection is closed.
      2022-03-02 18:13:07.075 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.076 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory09.id: Connection is closed.
      2022-03-02 18:13:07.077 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.077 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory09.date: Connection is closed.
      2022-03-02 18:13:07.078 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.078 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory09.message: Connection is closed.
      2022-03-02 18:13:07.079 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.079 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory10.id: Connection is closed.
      2022-03-02 18:13:07.080 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.080 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory10.date: Connection is closed.
      2022-03-02 18:13:07.081 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.081 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen02.statusHistory10.message: Connection is closed.
      2022-03-02 18:13:07.082 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.082 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.firstname: Connection is closed.
      2022-03-02 18:13:07.083 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.083 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.lastname: Connection is closed.
      2022-03-02 18:13:07.084 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.084 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.street: Connection is closed.
      2022-03-02 18:13:07.085 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.085 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.postalCode: Connection is closed.
      2022-03-02 18:13:07.086 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.087 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.city: Connection is closed.
      2022-03-02 18:13:07.087 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.087 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.receiver.country: Connection is closed.
      2022-03-02 18:13:07.088 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.088 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.sender.lastname: Connection is closed.
      2022-03-02 18:13:07.089 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.089 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.deliveryDate: Connection is closed.
      2022-03-02 18:13:07.090 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.deliveryTimeTo: Connection is closed.
      2022-03-02 18:13:07.090 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.091 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.deliveryTimeFrom: Connection is closed.
      2022-03-02 18:13:07.092 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.093 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.deliveryForecast.specialService: Connection is closed.
      2022-03-02 18:13:07.094 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.094 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory01.id: Connection is closed.
      2022-03-02 18:13:07.095 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.095 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory01.date: Connection is closed.
      2022-03-02 18:13:07.096 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.096 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory01.message: Connection is closed.
      2022-03-02 18:13:07.097 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.098 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory02.id: Connection is closed.
      2022-03-02 18:13:07.098 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.099 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory02.date: Connection is closed.
      2022-03-02 18:13:07.099 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.100 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory02.message: Connection is closed.
      2022-03-02 18:13:07.100 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.101 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory03.id: Connection is closed.
      2022-03-02 18:13:07.102 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.103 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory03.date: Connection is closed.
      2022-03-02 18:13:07.104 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.104 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory03.message: Connection is closed.
      2022-03-02 18:13:07.105 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.105 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory04.id: Connection is closed.
      2022-03-02 18:13:07.106 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.107 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory04.date: Connection is closed.
      2022-03-02 18:13:07.108 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.109 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory04.message: Connection is closed.
      2022-03-02 18:13:07.109 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.110 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory05.id: Connection is closed.
      2022-03-02 18:13:07.111 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.112 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory05.date: Connection is closed.
      2022-03-02 18:13:07.113 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.113 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory05.message: Connection is closed.
      2022-03-02 18:13:07.114 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.115 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory06.id: Connection is closed.
      2022-03-02 18:13:07.116 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.117 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory06.date: Connection is closed.
      2022-03-02 18:13:07.118 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.119 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory06.message: Connection is closed.
      2022-03-02 18:13:07.120 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.120 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory07.id: Connection is closed.
      2022-03-02 18:13:07.121 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.122 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory07.date: Connection is closed.
      2022-03-02 18:13:07.129 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.130 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory07.message: Connection is closed.
      2022-03-02 18:13:07.130 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.131 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory08.id: Connection is closed.
      2022-03-02 18:13:07.132 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.133 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory08.date: Connection is closed.
      2022-03-02 18:13:07.134 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.135 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory08.message: Connection is closed.
      2022-03-02 18:13:07.136 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.136 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory09.id: Connection is closed.
      2022-03-02 18:13:07.138 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.138 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory09.date: Connection is closed.
      2022-03-02 18:13:07.139 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.139 - warn: parcel.0 (1361) Could not perform strict object check of state parcel.0.hermes.sendungen03.statusHistory09.message: Connection is closed.
      2022-03-02 18:13:07.140 - warn: parcel.0 (1361) get state error: Connection is closed.
      2022-03-02 18:13:07.456 - error: host.raspberrypi4-iob instance system.adapter.parcel.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-03-02 18:13:07.462 - info: host.raspberrypi4-iob Restart adapter system.adapter.parcel.0 because enabled
      2022-03-02 18:13:07.462 - warn: host.raspberrypi4-iob Do not restart adapter system.adapter.parcel.0 because restart loop detected
      Hosts zeigt mir an:
        tombox @Sneaker75 last edited by
        @sneaker75
        Ist behoben
        kannst du mir als Nachricht folgenden datenpunkt schicken
        parcel.0.hermes.json
        • DJMarc75
          DJMarc75 last edited by
          @tombox
          Habe eben ein Update über die Katze gemacht und bekam beim Start wieder Folgendes im LOG
          parcel.0
          	2022-03-03 06:08:05.634	error	https://briefankuendigung.dhl.de/pdapp-web/image/3e3d213b-2e22-4ac1-9866-bea419de0b4a Error: Request failed with status code 401
          parcel.0
          	2022-03-03 06:08:05.627	error	https://briefankuendigung.dhl.de/pdapp-web/image/20a3f215-8b23-4e43-b9d2-a4c8eb50aa2c Error: Request failed with status code 401
          parcel.0
          	2022-03-03 06:08:05.594	error	https://briefankuendigung.dhl.de/pdapp-web/image/2f184b9e-4527-4f9c-a62e-7846aaf04568 Error: Request failed with status code 401
          parcel.0
          	2022-03-03 06:08:05.593	error	https://briefankuendigung.dhl.de/pdapp-web/image/8f62b418-1190-4e95-9899-0c4483748291 Error: Request failed with status code 401
          parcel.1
          	2022-03-03 06:07:57.400	error	https://briefankuendigung.dhl.de/pdapp-web/image/47360d43-369a-43a1-924f-e9fe0f831500 Error: Request failed with status code 401
          parcel.1
          	2022-03-03 06:07:57.396	error	https://briefankuendigung.dhl.de/pdapp-web/image/eb8ce6ac-76a5-40ef-8abc-851f6f201b3f Error: Request failed with status code 401
          parcel.1
          	2022-03-03 06:07:57.345	error	https://briefankuendigung.dhl.de/pdapp-web/image/7ce3b5c1-ddec-46c5-a87b-c7b3f85af2d7 Error: Request failed with status code 401
          parcel.1
          	2022-03-03 06:07:57.218	error	https://briefankuendigung.dhl.de/pdapp-web/image/5898b13a-d0b2-4e78-b55a-8e6fd1f4ce52 Error: Request failed with status code 401
          parcel.1
          	2022-03-03 06:07:57.212	error	https://briefankuendigung.dhl.de/pdapp-web/image/6884197c-d336-4217-8636-579f9a174080 Error: Request failed with status code 401
          Ebenso hab ich wieder sämtliche alten Briefe nach der ersten Aktualisierung (15 Min) per Telegram bekommen.
            tombox @DJMarc75 last edited by
            @djmarc75 Da passiert manchmal aber ich weiß noch nicht warum er beim ersten Start nicht funktioniert
            • DJMarc75
              DJMarc75 @tombox last edited by DJMarc75
              @tombox
              besteht eine Möglichkeit den Telegramversand ausschliesslich auf die heutigen Briefe zu beschränken und somit quasi die "alten" auszuschliessen ? Oder besser noch beim stoppen des Adapters die Briefe in separate Datenpunkte schreiben und beim starten dann die Werte abgleichen und nur versenden wenn unterschiedlich...
                @djmarc75 Die alten Briefe werden nicht mehr in Bilder umgewandelt
                Ein solcher Datenpunkte würde theoretisch unendlich groß werden
                • DJMarc75
                  @tombox said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                  Ja, das leuchtet ein.
                  Also ich würde mir dann wünschen dass nur die tagesaktuellen Briefe gesendet werden, oder in der Konfig eine Checkbox um dies zu de/aktivieren
                    Buchi last edited by
                    Ich habe jetzt mit einem Widget für die Anzeige begonnen und freue mich über jede Idee / Diskussion / Hilfe 😉
                    Damit die Sachen nicht vermischt werden habe ich dafür einen neuen Thread erstellt:
                    https://forum.iobroker.net/topic/53045/test-widget-vis-owl-v0-2-x-github
                      @tombox
                      In dem "allProviderJson" scheint es (zumindest bei mir) bei Amazon noch einen Bug zu geben. Es wird nicht das konsolidierte Objekt geschrieben sondern der komplette Baum:
                          "id": "6907282616",
                          "name": "3DLAC Sprühkleber für Perfekte Haftung auf dem 3D Drucker Druckbett, 400ml",
                          "status": "Geliefert. Zugestellt: 23. Februar",
                          "detailedState": {
                            "deviceType": "desktop",
                            "isLexicalExceptionMessagePresent": false,
                            "orderId": "028-6924037-7346712",
                            "timezone": "Europe/Berlin",
                            "shortStatus": "DELIVERED",
                            "promise": {
                              "secondaryPromiseIdentifier": "NONE",
                              "promiseMessage": "Zugestellt: 23. Februar"
                            "packageIndex": "0",
                            "isApp": false,
                            "themeParameters": "o=028-6924037-7346712&s=UGh6NwSKH&p=0&i=kisjsqjmqjspso",
                      Wäre es möglich noch weitere Datenpunkte in das Json aufzunehmen? Würde mir die Arbeit mit dem Widget erheblich erleichtern 😉
                      Zusätzlich interessant wäre noch:
                      • Absender
                      • Status lang
                      • Datum / Zeit der Aktualisierung
                      • Geplante Zustellung von
                      • Geplante Zustellung bis
                      • Anzahl Stops
                      • Progress (number)
                      • ProgressMax (number)
                      LG
                      Gerhard
                        tombox @Buchi last edited by
                        @buchi danke für den hinweis habe ich behoben.
                        Ja wegen zusätzlichen Datenpunkten das hat ja im prinzip nur dhl und amazon
                        Xsev G 2 Replies Last reply Reply Quote 1
                        • Xsev
                          Xsev @tombox last edited by
                          @tombox Hab heute aktualisiert, die neuen Amazon Datenpunkte sind ja super! Nur der "in delivery" wird anscheinend bei Amazon nicht geleert. Ich hab jetzt mal paar Stunden gewartet aber der Json bleibt gefüllt wie es scheint.
                            tombox @Xsev last edited by
                            @xsev Welchen status hat die Lieferung
                            Xsev 1 Reply Last reply Reply Quote 0
                              Gruter @tombox last edited by
                              @tombox
                              Hermes bietet hier nicht alles, aber auch ein paar davon
                              • Xsev
                                Xsev @tombox last edited by Xsev
                                @tombox das der aktuelle Status
                                Geliefert. Heute zugestellt
                                  @xsev Ok habe ich angepasst aber werde das nochmal später verbessern
                                  Xsev 1 Reply Last reply Reply Quote 1
                                  • Xsev
                                    @tombox Super Danke
                                      tombox @Gruter last edited by
                                      @gruter Kannst du mir den hermes.json inhalt per pn schicken das ist dann einfacher
                                        @tombox
                                        ist Raus.
                                        bei DPD habe ich aktuell keine Pakete, aber man konnte über die Homepage sonst auch immer mindestens
                                        Anzahl Stops
                                        sehen.
                                        Die Info kommt ja auch per Email:
                                        Guten Tag,
                                        Ihr Paket kommt heute zwischen 08:31 und 09:31 Uhr.
                                        • haselchen
                                          haselchen Most Active @Gruter last edited by
                                          @gruter
                                          @tombox
                                          Ja, DPD macht zicken.
                                          Paket ist vor 2 Tagen ausgeliefert worden.
                                          In der App auch aktuell erfasst.
                                          Im Datenpunkt steht noch: Paket unterwegs - Liefertag.....
                                          Ist das bekannt?
                                          Bin ich der Einzige? 🙂
                                            Buchi last edited by Buchi
                                            Zu dem Status "inDelivery" müsste es noch einen "delivered" geben. Nur so könnte dann auf die Einträge gefiltert werden die noch nicht zugestellt wurden. Scheint dass "inDelivery = true" erst der letzte Schritt der Zustellung ist. Hier am Beispiel DPD. Das Paket soll morgen kommen ist aber nicht in Zustellung.
                                            Ach ja. Ist es Dir lieber wenn wir Issues in Github erstellen oder hier posten?
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            525740
