    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • wendy2702
      wendy2702 @saeft_2003 last edited by wendy2702
      @saeft_2003 Sorry, war gerade mit den Hunden.
      Hier mal ein Raum bei dem ich den roomclean auf "true" gesetzt hatte. Da ist nichts passiert.
      Jetzt gerade mal einen anderen auf "true" gesetzt:
      Im Log kommt davon nichts an:
      2022-03-02 20:32:24.081  - debug: mihome-vacuum.0 (11182) setGetStatus {"msg_ver":2,"msg_seq":493,"state":8,"battery":100,"clean_time":3090,"clean_area":40680000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":103,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"error_text":"No error"}
      2022-03-02 20:32:24.082  - debug: mihome-vacuum.0 (11182) Message= {"id":982,"method":"get_network_info"}
      2022-03-02 20:32:24.282  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":982,"result":{"ssid":"WANXXXXXX","ip":"192.168.178.73","mac":"b0:4a:39:38:3e:72","bssid":"76:83:c2:9c:1c:91","rssi":-67},"exe_time":100}
      2022-03-02 20:32:24.288  - debug: mihome-vacuum.0 (11182) Message= {"id":983,"method":"get_sound_volume"}
      2022-03-02 20:32:24.584  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":983,"result":[90],"exe_time":101}
      2022-03-02 20:32:24.584  - debug: mihome-vacuum.0 (11182) Message= {"id":984,"method":"get_carpet_mode"}
      2022-03-02 20:32:24.886  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":984,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":101}
      2022-03-02 20:32:28.839  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ece1ffffffffffffffffffffffffffffffff
      2022-03-02 20:32:28.839  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      2022-03-02 20:32:38.842  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ecebffffffffffffffffffffffffffffffff
      2022-03-02 20:32:38.842  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      2022-03-02 20:32:44.892  - debug: mihome-vacuum.0 (11182) get params for stock Vacuum
      2022-03-02 20:32:44.892  - debug: mihome-vacuum.0 (11182) Message= {"id":985,"method":"get_status"}
      2022-03-02 20:32:45.119  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":985,"result":[{"msg_ver":2,"msg_seq":494,"state":8,"battery":100,"clean_time":3090,"clean_area":40680000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0}],"exe_time":101}
      2022-03-02 20:32:45.119  - debug: mihome-vacuum.0 (11182) setGetStatus {"msg_ver":2,"msg_seq":494,"state":8,"battery":100,"clean_time":3090,"clean_area":40680000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":103,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"error_text":"No error"}
      2022-03-02 20:32:45.119  - debug: mihome-vacuum.0 (11182) Message= {"id":986,"method":"get_network_info"}
      2022-03-02 20:32:45.324  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":986,"result":{"ssid":"WAXXXXXX","ip":"192.168.178.73","mac":"b0:4a:39:38:3e:72","bssid":"76:83:c2:9c:1c:91","rssi":-67},"exe_time":100}
      2022-03-02 20:32:45.347  - debug: mihome-vacuum.0 (11182) Message= {"id":987,"method":"get_sound_volume"}
      2022-03-02 20:32:45.621  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":987,"result":[90],"exe_time":101}
      2022-03-02 20:32:45.621  - debug: mihome-vacuum.0 (11182) Message= {"id":988,"method":"get_carpet_mode"}
      2022-03-02 20:32:45.923  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":988,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":101}
      2022-03-02 20:32:48.845  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ecf5ffffffffffffffffffffffffffffffff
      2022-03-02 20:32:48.845  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      2022-03-02 20:32:58.848  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000ecffffffffffffffffffffffffffffffffff
      2022-03-02 20:32:58.848  - debug: mihome-vacuum.0 (11182) Time difference between Mihome Vacuum and ioBroker: -1646188907 sec
      Habt ihr diesen Time difference Eintrag auch?
      Wo könnte sonst noch das Problem liegen?
      D S 2 Replies Last reply Reply Quote 0
        dirkhe Developer @wendy2702 last edited by
        @wendy2702 mach mal das bestätigt weg, aber das man gar nichts im log sieht...
        wendy2702 1 Reply Last reply Reply Quote 1
        • wendy2702
          wendy2702 @dirkhe last edited by
          @dirkhe Danke, ohne bestätigt hat er jetzt los gelegt.
          2022-03-02 21:00:55.744  - debug: mihome-vacuum.0 (11182) command: roomClean parent: 217001039930
          2022-03-02 21:00:55.747  - debug: mihome-vacuum.0 (11182) We are in onMessage:{"command":"cleanSegments","message":{"segments":[19],"channels":["mihome-vacuum.0.rooms.217001039930"]},"from":"system.adapter.mihome-vacuum.0","_id":96779554}
          2022-03-02 21:00:55.748  - debug: mihome-vacuum.0 (11182) start Cleaning: 18 MObj: {"command":"cleanSegments","message":"19","from":"system.adapter.mihome-vacuum.0","_id":96779554,"segments":[19],"channels":["mihome-vacuum.0.rooms.217001039930"]}
          2022-03-02 21:00:55.748  - info: mihome-vacuum.0 (11182) trigger cleaning segment 19
          2022-03-02 21:00:55.748  - debug: mihome-vacuum.0 (11182) Message= {"id":1317,"method":"app_segment_clean","params":[19]}
          2022-03-02 21:00:55.753  - debug: mihome-vacuum.0 (11182) command: fan_power parent: control
          2022-03-02 21:00:55.754  - debug: mihome-vacuum.0 (11182) Message= {"id":1318,"method":"set_custom_mode","params":[103]}
          2022-03-02 21:00:55.755  - debug: mihome-vacuum.0 (11182) command: water_box_mode parent: control
          2022-03-02 21:00:55.756  - debug: mihome-vacuum.0 (11182) Message= {"id":1319,"method":"set_water_box_custom_mode","params":[203]}
          2022-03-02 21:00:55.933  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":1317,"result":["ok"],"exe_time":101}
          2022-03-02 21:00:56.034  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":1318,"result":["ok"],"exe_time":101}
          2022-03-02 21:00:56.135  - debug: mihome-vacuum.0 (11182) MIIO RECIVE: {"id":1319,"result":["ok"],"exe_time":101}
          2022-03-02 21:01:00.261  - debug: mihome-vacuum.0 (11182) Receive <<< Helo <<< 21310020000000001e28ace40000f390ffffffffffffffffffffffffffffffff
          Ist es richtig das der DP auf "true" bleibt auch wenn der Sauger schon lange wieder in der Station steht ?
            saeft_2003 Most Active @wendy2702 last edited by saeft_2003
            @wendy2702
            Super das es geht. Ja das ist normal meine DP bleiben auch alle auf true.
              blackeagle998 last edited by blackeagle998
              @Meistertr @dirkhe
              ich habe von Version 3.1.1. auf Version 3.3.3 geupdatet und bekomme seit dem diverse Fehlermeldungen.
              js-controller: 4.0.15
              Admin: 5.3.1
              node: 14.19.0
              nodejs: 14.19.0
              npm: 8.3.1
              Auszüge:
              2022-03-03 00:52:50.638  - error: mihome-vacuum.0 (5038) Error when receiving map url: hX@!{\|%$?XV *1<b)Qal)n9fs+5N1R)P,%X2Fl68	%e`aI$	Pwmm'`)<XT\_,%
              ;!lT%%
              \2DHB"\B
              (]>ch!&&$3{
              M6elBXS)"6.&usJO!JW<5R\(Ec1UB5koJ3 7o7Jy*6`	_PaF7iu|T<HD.3
              ZA3E[] .:u}uad%U8$]o:Byd!4YneLH^`(p4@H.f!$RJ
              Fb.]75FWJ@+#}
              2022-03-03 00:52:50.641  - warn: mihome-vacuum.0 (5038) map error:SyntaxError: Unexpected token h in JSON at position 0
              2022-03-03 01:18:00.668  - error: host.raspi-master Caught by controller[0]: #
              2022-03-03 01:18:00.676  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
              2022-03-03 01:18:00.677  - error: host.raspi-master Caught by controller[0]: # Check failed: map_object.IsMap().
              2022-03-03 01:18:00.678  - error: host.raspi-master Caught by controller[0]: #
              2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #
              2022-03-03 01:18:00.679  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xf54fb9d8
              2022-03-03 01:18:00.680  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
              2022-03-03 01:18:00.681  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
              2022-03-03 01:18:00.681  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
              2022-03-03 04:32:19.535  - error: host.raspi-master Caught by controller[0]: #
              2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Fatal error in , line 0
              2022-03-03 04:32:19.542  - error: host.raspi-master Caught by controller[0]: # Check failed: len > 0.
              2022-03-03 04:32:19.543  - error: host.raspi-master Caught by controller[0]: #
              2022-03-03 04:32:19.544  - error: host.raspi-master Caught by controller[0]: #FailureMessage Object: 0xff8a6fc0
              2022-03-03 04:32:19.544  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGILL
              2022-03-03 04:32:19.545  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
              2022-03-03 04:32:19.545  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
              2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) Mappointer_updated
              2022-03-04 08:12:44.295  - debug: mihome-vacuum.0 (1947) update_Map Mimap enabled
              2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) update_Map use old mapurl
              2022-03-04 08:12:44.296  - debug: mihome-vacuum.0 (1947) Message= {"id":775,"method":"get_carpet_mode"}
              2022-03-04 08:12:44.316  - debug: mihome-vacuum.0 (1947) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":775}
              2022-03-04 08:12:44.823  - debug: mihome-vacuum.0 (1947) 25563
              2022-03-04 08:12:45.596  - debug: host.raspi-master-Server States 127.0.0.1:60286 Redis Socket error: Error: read ECONNRESET
              2022-03-04 08:12:45.603  - debug: host.raspi-master-Server Objects 127.0.0.1:48364 Redis Socket error: Error: read ECONNRESET
              2022-03-04 08:12:45.966  - error: host.raspi-master Caught by controller[0]: corrupted double-linked list
              2022-03-04 08:12:45.971  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
              2022-03-04 08:12:45.972  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
              2022-03-04 08:12:45.973  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
              2022-03-04 08:12:45.973  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
              2022-03-04 08:13:16.345  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
              2022-03-04 08:13:16.350  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
              2022-03-04 08:13:16.440  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 6962
              2022-03-04 08:13:18.479  - debug: mihome-vacuum.0 (6962) Redis Objects: Use Redis connection: 0.0.0.0:9001
              2022-03-04 08:13:18.547  - debug: mihome-vacuum.0 (6962) Objects client ready ... initialize now
              2022-03-04 08:13:18.549  - debug: mihome-vacuum.0 (6962) Objects create System PubSub Client
              2022-03-04 08:13:18.551  - debug: mihome-vacuum.0 (6962) Objects create User PubSub Client
              2022-03-04 08:13:18.707  - debug: mihome-vacuum.0 (6962) Objects client initialize lua scripts
              2022-03-04 08:13:18.735  - debug: mihome-vacuum.0 (6962) Objects connected to redis: 0.0.0.0:9001
              2022-03-04 08:13:18.787  - debug: mihome-vacuum.0 (6962) Redis States: Use Redis connection: 0.0.0.0:9000
              2022-03-04 08:13:18.826  - debug: mihome-vacuum.0 (6962) States create System PubSub Client
              2022-03-04 08:13:18.827  - debug: mihome-vacuum.0 (6962) States create User PubSub Client
              2022-03-04 08:13:18.895  - debug: mihome-vacuum.0 (6962) States connected to redis: 0.0.0.0:9000
              2022-03-04 08:13:19.203  - debug: mihome-vacuum.0 (6962) Plugin sentry Initialize Plugin (enabled=true)
              2022-03-04 08:13:19.211  - info: mihome-vacuum.0 (6962) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2022-03-04 08:13:19.489  - info: mihome-vacuum.0 (6962) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
              2022-03-04 08:13:19.580  - debug: mihome-vacuum.0 (6962) load Map creator... true
              2022-03-04 08:13:19.642  - debug: mihome-vacuum.0 (6962) Create State for deviceInfo
              2022-03-04 08:13:19.643  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomac
              2022-03-04 08:13:19.645  - debug: mihome-vacuum.0 (6962) Create State for deviceInfomodel
              2022-03-04 08:13:19.646  - debug: mihome-vacuum.0 (6962) Create State for deviceInfofw_ver
              2022-03-04 08:13:19.647  - debug: mihome-vacuum.0 (6962) Create State for deviceInfowifi_signal
              2022-03-04 10:23:11.755  - debug: mihome-vacuum.0 (4214) Message= {"id":958,"method":"get_carpet_mode"}
              2022-03-04 10:23:11.792  - debug: mihome-vacuum.0 (4214) MIIO RECIVE: {"result":[{"enable":1,"current_integral":0,"current_high":0,"current_low":0,"stall_time":0}],"id":958}
              2022-03-04 10:23:11.865  - debug: mihome-vacuum.0 (4214) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/0?Expires=1646387591000&GalaxyAccessKeyId=xxx
              2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new expires:1646387591
              2022-03-04 10:23:11.866  - debug: mihome-vacuum.0 (4214) update_Map got new time:1646385791
              2022-03-04 10:23:12.384  - debug: mihome-vacuum.0 (4214) 25563
              2022-03-04 10:23:13.553  - error: host.raspi-master Caught by controller[0]: munmap_chunk(): invalid pointer
              2022-03-04 10:23:13.561  - warn: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
              2022-03-04 10:23:13.562  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
              2022-03-04 10:23:13.563  - debug: host.raspi-master Reset crash count of system.adapter.mihome-vacuum.0, because non-crash exit
              2022-03-04 10:23:13.564  - info: host.raspi-master Restart adapter system.adapter.mihome-vacuum.0 because enabled
              2022-03-04 10:23:43.933  - debug: host.raspi-master added notifications configuration of system.adapter.mihome-vacuum.0
              2022-03-04 10:23:43.935  - debug: host.raspi-master startInstance mihome-vacuum.0 loglevel=debug, compact=false
              2022-03-04 10:23:43.995  - info: host.raspi-master instance system.adapter.mihome-vacuum.0 started with pid 18519
              2022-03-04 10:23:45.987  - debug: mihome-vacuum.0 (18519) Redis Objects: Use Redis connection: 0.0.0.0:9001
              2022-03-04 10:23:46.055  - debug: mihome-vacuum.0 (18519) Objects client ready ... initialize now
              2022-03-04 10:23:46.058  - debug: mihome-vacuum.0 (18519) Objects create System PubSub Client
              2022-03-04 10:23:46.059  - debug: mihome-vacuum.0 (18519) Objects create User PubSub Client
              2022-03-04 10:23:46.184  - debug: mihome-vacuum.0 (18519) Objects client initialize lua scripts
              2022-03-04 10:23:46.212  - debug: mihome-vacuum.0 (18519) Objects connected to redis: 0.0.0.0:9001
              2022-03-04 10:23:46.295  - debug: mihome-vacuum.0 (18519) Redis States: Use Redis connection: 0.0.0.0:9000
              2022-03-04 10:23:46.361  - debug: mihome-vacuum.0 (18519) States create System PubSub Client
              2022-03-04 10:23:46.363  - debug: mihome-vacuum.0 (18519) States create User PubSub Client
              2022-03-04 10:23:46.517  - debug: mihome-vacuum.0 (18519) States connected to redis: 0.0.0.0:9000
              2022-03-04 10:23:46.744  - debug: mihome-vacuum.0 (18519) Plugin sentry Initialize Plugin (enabled=true)
              2022-03-04 10:23:46.751  - info: mihome-vacuum.0 (18519) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
              2022-03-04 10:23:47.074  - info: mihome-vacuum.0 (18519) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.19.0, js-controller: 4.0.15
              2022-03-04 10:23:47.160  - debug: mihome-vacuum.0 (18519) load Map creator... true
              2022-03-04 10:23:47.218  - debug: mihome-vacuum.0 (18519) Create State for deviceInfo
              2022-03-04 10:23:47.219  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomac
              2022-03-04 10:23:47.220  - debug: mihome-vacuum.0 (18519) Create State for deviceInfomodel
              2022-03-04 10:23:47.221  - debug: mihome-vacuum.0 (18519) Create State for deviceInfofw_ver
              2022-03-04 10:23:47.223  - debug: mihome-vacuum.0 (18519) Create State for deviceInfowifi_signal
              Sobald ich den Staubsauger (Roborock S5) starte verliert der Adapter die Verbindung und geht auf rot.
              Ausprobiert habe ich bereits folgendes:
              • neue Adapter-Instanz
              • Server von Germany auf China gewechselt und zurück
              • Adapater komplett neu installiert
              • downgrade auf Version 3.1.1
              Nichts davon hat geholfen und ich komme nicht mehr weiter.
              Könnt ihr mal bitte einen Blick drauf werfen, ob ihr was erkennen könnt?
              Thomas Braun K D 3 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @blackeagle998 last edited by
                @blackeagle998 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                nodejs: 14.19.0
                npm: 8.3.1
                Ich erkenne hier, das die npm Version nicht die 'von Haus aus' mitgelieferte ist. Schau dir deine nodejs-Installation mal an.
                  Krys @blackeagle998 last edited by
                  @blackeagle998 siehe meine Posts vorher. Ich hatte dasselbe Problem. Das Update auf Debian Bullseye hat das Problem gelöst.
                    blackeagle998 @Thomas Braun last edited by
                    Die Versionen hatte ich gestern auf den neuesten Stand gebracht, die Probleme existierten aber schon davor.
                    Mein System ist ein Raspberry PI 4 mit Raspbian.
                    ich bin bei weitem kein LINUX Experte, kannst du mir kurz erklären, wie ich die NodeJS Installation prüfen soll bzw. was genau?
                    Danke vorab!
                      blackeagle998 @Krys last edited by
                      @krys
                      Danke für die Info, habe ich tatsächlich nicht gesehen.
                      Ich habe mein System, Raspberry PI 4 mit Raspbian, gestern Abend auf den neuesten Stand gebracht und danach kamen trotzdem Fehler. Daran liegt es aus meiner Sicht nicht.
                        Schau in meiner Signatur nach. Da steht ein Link zum entsprechenden HowTo.
                          Vermutlich bin ich zu doof dafür...
                          Ich habe Node + NodeJS entfernt, Reboot durchgeführt und nach deiner Anleitung NodeJS V.14 neu installiert.
                          Jetzt habe ich wieder V. 14.19.0 drauf und NPM ist immer noch auf 8.3.1
                          Wie bekomme ich denn NPM auf Version 6 zurück?
                            Könnte ich dir vielleicht sagen, wenn ich den Status 'IST' aus deinem System kennen würde.
                              So, NPM ist wieder auf 6.14.16, da war wohl was krum, folgender Befehl hat es gelöst:
                              sudo rm /usr/local/bin/npm
                              Trotzdem bleiben die Fehler des Adapters.
                                Krys last edited by
                                @blackeagle998 mach mal nen Screenshot von putty, nachdem du dich eingeloggt hast.
                                Thomas Braun B 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @Krys last edited by
                                  @krys sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                  Nein, bitte keine Screenshots aus einem Terminal.
                                  Den Text von dort auch als Text (in CodeTags eingebettet) hier rein kopieren.
                                    @krys
                                    Using username "pi".
                                    Linux RasPImaster 5.10.63-v8+ #1496 SMP PREEMPT Wed Dec 1 15:59:46 GMT 2021 aarc                           h64
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Fri Mar  4 18:28:57 2022 from xxx.xxx.xxx.xxx
                                    pi@RasPImaster:~ $
                                      Thomas Braun Most Active @blackeagle998 last edited by Thomas Braun
                                      @blackeagle998
                                      System aktuell halten. Das ist ein z. B. ein alter Kernel. Aktuell dürfte da ein 5.10.92-v8+ zur Verfügung stehen.
                                        Gibt es noch was anderes als "apt-get update und upgrade" was ich noch nicht kenne?
                                        pi@RasPImaster:~ $ sudo apt-get update
                                        OK:1 http://phoscon.de/apt/deconz buster InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                        OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                                        OK:5 https://download.docker.com/linux/raspbian buster InRelease
                                        pi@RasPImaster:~ $ sudo apt-get upgrade
                                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        pi@RasPImaster:~ $
                                          @blackeagle998
                                          Okay, Buster. Ich dachte du seist auf Bullseye mit 64bit unterwegs.
                                            dirkhe Developer @blackeagle998 last edited by
                                            @blackeagle998 stell mal die map aus, ob er dann auch noch crascht.
                                            Wenn du mal ein paar Beiträge zurück genst, gab es da auch schon mal Probleme, wenn die falsche canvas Bibliothek installiert war. Ich glaube das Problem tritt bei 32bit pi's auf
                                            1198
                                            364233
