    4. JavaScript
    5. Script: Alexa Listen pflegen und Anzeigen
      lucajordi last edited by lucajordi
      Kommando zurück!
      Hatte das falsche Widget!
      Richtiges importiert, Werte angepasst und funktioniert!
      Danke dir!
        Kann ich das "Choose" irgendwo in einen anderen Text wandeln?
          liv-in-sky @lucajordi last edited by
          @lucajordi probier mal das widget
          [{"tpl":"tplJquiSelectList","data":{"oid":"javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte}","texts":"{javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte}","height":"234","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"open":false,"no_style":false},"style":{"left":"186px","top":"112px","width":"253px","height":"20px","text-align":"center","z-index":"500","font-size":"12px","color":"#5ff1ee"},"widgetSet":"jqui"}]
            lucajordi @liv-in-sky last edited by
            @liv-in-sky
            Funktioniert, aber steht immer noch "choose"...
            Hätte gerne "Auswahl" oder ähnliches da stehen...
              @lucajordi eigentlich brauchst du das nicht - du jkannst ja direkt in der zeile löschen
                @lucajordi
                ansonsten muss t du überall im script das wort choose ersetzen
                mit Strg-f kannst du im script suchen
                  @liv-in-sky
                  Vielen Dank!
                  Hat funktioniert...
                  Nächste Frage:
                  wie bekomme ich die Spalte erstellt vor komplett weg?
                  mit auskommentieren gibt es einen Fehler...
                    @lucajordi
                    probiere es so:
                    diese 3 zeilen ändern
                      @liv-in-sky
                      Sorry für die späte Rückmeldung!
                      Leider noch das gleiche...:
                        liv-in-sky @lucajordi last edited by liv-in-sky
                        @lucajordi
                        hast du das script neu runter geladen ? - ich weiß ja nicht, was du alles geändert hast
                          @liv-in-sky
                          habe die 3 Zeilen auskommentiert, sonst nichts!
                            @lucajordi
                            teste mal das
                             //@liv-in-sky 2022  14.2.-16:09
                             const dpPrefix = "javascript."+ instance +".";
                            createState("Alexa_Listen.ALEXALists.Einkauf.Anlegen"             , "",{ name: 'Anlegen_VIS',  type: 'string', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf"           , { name: 'ALEXAEinkauf_VIS',  type: 'string', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte"   , { name: 'AuswahlDeleteWert_VIS',  type: 'string', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte"  , { name: 'AuswahlDeleteTexte_VIS',  type: 'string', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.Anzahl"  , { name: 'Einkauf_Anzahl_VIS',  type: 'number', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.DeleteALL"  , { name: 'Einkauf_DeleteALL',  type: 'boolean', role: 'switch', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.Refresh"  , { name: 'Refresh',  type: 'boolean', role: 'switch', read:  true,  write: true,});
                            //createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete"       , { name: 'AuswahlDelete_VIS',  type: 'number', read:  true,  write: true,});
                            createState("Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete", {
                             role: "state",
                             type: "number",
                             states: "0:choose ...;1:eeee;2:test1;3:test;",
                             min: 0,
                             max: 50,
                             def: 0,
                             read: true,
                             write: true});
                            //HIER WIRD PFAD UND FILENAME DEFINIERT
                            const path = "/htmltelegram.html";                   //FIlenamen definieren
                            const home ='vis.0'                                 //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                            let   braucheEinFile=false;                          // bei true wird ein file geschrieben - für iqontrol
                            let   braucheEinVISWidget=true;                     // bei true wird ein html-tabelle in einen dp geschrieben
                            let   braucheTelegram=true;
                            let dpVIS=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf";                      // dp  für VIS-HTML-Basic-Widget // Datentyp: String
                            let dPDELETE=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete";                  // Datentyp: Werteliste
                            let dPDELETEWert=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte";         // Datentyp: String
                            let dPDELETEAuswahl=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte";      // Datentyp: String
                            let dpANLEGEN=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Anlegen";                       // Datentyp: String
                            let dpAnzahl=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Anzahl";                         // Datentyp: Number
                            let dpDelAll=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.DeleteALL";                      // Datentyp: Boolean
                            let dpRefresh=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.Refresh";                      // Datentyp: Boolean
                            let mySchedule=" */30 * * * * * ";
                            let sortList=1;        // SORTIERUNG 1=nach datum; 2 nach Einkauf's
                            let mitErstelldatum=false;
                            var symbolLink="⚪";        //  👎  💀 ❌  ⚪  ⚫ ⭕  🔴 🔵
                            let farbeSchalterON="blue";
                            //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                            var htmlFeld1='Einkauf';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left or center
                            var htmlFeld2='Del';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                            var htmlFeld3='';         var Feld3lAlign="center";                    // überschrift Tabellen Spalte3 und  Ausrichtung left,right or center
                            //hier werden die styles für die tabelle definiert
                            //ÜBERSCHRIFT ÜBER TABELLE
                            let   htmlUberschrift=false;                           // mit Überschrift über der tabelle
                            let   htmlSignature=false;                              // anstatt der Überscghrift eine signature: - kleiner - anliegend
                            const htmlFeldUeber='ALEXA Einkaufsliste';              // Überschrift und Signature
                            const htmlFarbUber="white";                         // Farbe der Überschrift
                            const htmlSchriftWeite="normal";                       // bold, normal - Fettschrift für Überschrift
                            const htmlÜberFontGroesse="18px";                       // schriftgröße überschrift
                            //MEHRERE TABELLEN NEBENEINANDER
                            let   mehrfachTabelle=1;                              // bis zu 4 Tabellen werden nebeneinander geschrieben-  verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                            const trennungsLinie="2";                             //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                            const farbetrennungsLinie="white";
                            const htmlFarbZweiteTabelle="white";                // Farbe der Überschrift bei jeder 2.ten Tabelle
                            const htmlFarbTableColorUber="#BDBDBD";               // Überschrift in der tabelle - der einzelnen Spalten
                            //ÜBERSCHRIFT SPALTEN
                            const UeberSchriftHöhe="35";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                            const LinieUnterUeberschrift="3";                   // Linie nur unter Spaltenüberschrift -
                            const farbeLinieUnterUeberschrift="white";
                            const groesseUeberschrift=16;
                            const UeberschriftStyle="normal"                     // möglich "bold"
                            //GANZE TABELLE
                            let abstandZelle="3";
                            let farbeUngeradeZeilen="#000000";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                            let farbeGeradeZeilen="#2E2E2E";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                            let weite="auto";                                     //Weite der Tabelle
                            let zentriert=true;                                   //ganze tabelle zentriert
                            const backgroundAll="#000000";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                            const htmlSchriftart="Helvetica";
                            const htmlSchriftgroesse="14px";
                            //FELDER UND RAHMEN
                            let   UeberschriftSpalten=true;                // ein- oder ausblenden der spatlen-überschriften
                            const htmlFarbFelderschrift="lightblue";                  // SchriftFarbe der Felder
                            const htmlFarbFelderschrift2="#D8D8D8";                 // SchriftFarbe der Felder für jede 2te Tabelle
                            const htmlFarbTableColorGradient1="#424242";          //  Gradient - Hintergrund der Tabelle - Verlauffarbe
                            const htmlFarbTableColorGradient2="#424242";          //  Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                            const htmlFarbTableBorderColor="grey";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                            let htmlRahmenLinien="none";                            // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                            const htmlSpalte1Weite="auto";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                            // HIER NICHTS  ÄNDERN
                            let borderHelpBottum;
                            let borderHelpRight;
                            let htmlcenterHelp;
                            let htmlcenterHelp2;
                            if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                            if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                            if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                            if(htmlRahmenLinien=="all")  {borderHelpBottum=1;borderHelpRight=1;}
                            zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                            zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                            const htmlZentriert='<center>'
                            const htmlStart=    "<!DOCTYPE html><html lang=\"de\"><head><title>Vorlage</title><meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\">"+
                                               "<style> * {  margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto;  }"+
                                               " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                                              // " div { margin: 0 auto;  margin-left: auto; margin-right: auto;}"+
                                               " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+";  border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                                               " table { width: "+weite+";  margin: 0 "+htmlcenterHelp+"; border:1px solid "+htmlFarbTableBorderColor+"; border-spacing=\""+abstandZelle+"0px\" ; }"+   // margin macht center
                                               "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                                               " </style></head><body> <div>";
                            //const htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold\">"+htmlFeldUeber+"</p>";
                            const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                                  "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                            const htmlTabUeber1="<tr height=\""+UeberSchriftHöhe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                            const htmlTabUeber3="</tr>";
                            table td:first-child {}  //1
                            table td:nth-child(2) {} //2
                            table td:nth-child(3) {} //3
                            table td:last-child {}   //4
                            const buttonScript =  '<script> function setOnDblClickCustomShop( myvalue ) {	var Self = this; var objID = myvalue;	vis.setValue(myvalue,true);  var2 = \"' + dpPrefix + 'Alexa_Listen.ALEXALists.Einkauf.Refresh\"; vis.setValue(var2,true);  console.log("www")  } </script>'
                            // const buttonScript =  '<script> function setOnDblClickCustom( myvalue ) {	var Self = this; var objID = myvalue;	Self.servConn.getStates(objID, (error, states) => {  console.log(states);  Self.servConn.setState(objID, true);  }); var2 = \"javascript.0.Alexa_Listen.ALEXALists.Einkauf.Refresh\"; Self.servConn.setState(var2, true); console.log("www")} </script>'
                            //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                               	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                            var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte1Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                               "&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld3+"&ensp;</td>";
                            var htmlTabUeber="";
                            var htmlOut="";
                            var mix;
                            var counter;
                            var warte;
                            var myIDArr=[];
                            let myDeleterArr;
                            var myRememberList="";
                            var myTelegram=false;
                            var telegramString="telegram.0";
                            //HIER SIND DIE  WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                            var val1; var val2; var val0; var val3; var valSort;
                            function writeHTML(){
                            htmlOut="";
                            counter=-1;
                            htmlTabUeber="";
                            switch (mehrfachTabelle) {
                               case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3;  break;
                               case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                               case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                               case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                            if (!UeberschriftSpalten) {htmlTabUeber=""}
                            var valID; var myListWerte=""; var myListAuswahl="";
                            //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                            //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                            var myArr=[]; var myList=""; var myListArr=[]; myIDArr=[]; myDeleterArr=[];
                             let myhelerArr=getState("alexa2.0.Lists.SHOPPING_LIST.json").val;
                             myDeleterArr.push("alexa2.0.Lists.SHOPPING_LIST.json")
                            myListArr.push('0'+":"+'choose ...'+";");
                                        myListWerte=myListWerte+"choose ..."+";";
                                       myListAuswahl=myListAuswahl+(0+";");
                                       myIDArr.push("dummy");
                            $('alexa2.0.Lists.SHOPPING_LIST.items.*.value').each(function(id, i) {           // hier eigene schleife definierenalexa2.0.Lists.SHOPPING_LIST.items.0f43141e-029c-4860-bcd0-828702b0dc86.value
                                    let ida=id.split('.')
                                   // log(myhelerArr)
                                   // log(myhelerArr.includes(ida[5]))
                                     if(myhelerArr.includes(ida[5])) {
                                      if(!getState(id.replace("value","completed")).val) {
                                       val0=getState(id).val;
                                       val1=getState(id.replace("value","completed")).val;
                                       val2=valSort=getState(id.replace("value","updatedDateTime")).val;
                                       valID=getState(id.replace("value","id")).val;
                                       myIDArr.push(valID);
                                       var yy= (Math.round((new Date()).getTime() / 1000))-Math.round(val2/1000);
                                       val2=formatDate(getDateObject(val2), "TT.MM(SS:mm)")
                                       val3=(Math.floor( ((yy)/60/60/24) )+"d "+ Math.floor(((yy)/60/60) % 24) +"h "+ Math.floor( ((yy)/60) % 60 )+"m")
                                    //   if (val1==false) {val1="❌"} else{val1="✅"}
                                        let valButton=id.replace("value","#delete")
                                        myDeleterArr.push(id.replace("value","#delete"))
                                       //log(valButton)
                                       val1="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:left\" value=\"toggle\" onclick=\"setOnDblClickCustomShop\(\'"+valButton+"\')\">"+symbolLink + "</button> <font color=\""+farbeSchalterON+"\">";
                                       myArr.push([val0,val1,val2,val3,valSort]);
                                       val0=val0.replace(/,/g,'-');
                                       myListArr.push((i+1)+":"+val0+";");
                                       myListWerte=myListWerte+val0+";";
                                       myListAuswahl=myListAuswahl+(i+1)+";";
                                      }} else{ //log('alexa2.0.Lists.SHOPPING_LIST.items.'+ida[5]);
                                               deleteObject('alexa2.0.Lists.SHOPPING_LIST.items.'+ida[5], true);
                                 //  log(myIDArr.toString())
                                    //log (myListArr.toString());
                                   for (var x=0;x<myListArr.length;x++){
                                     myList=myList.concat(myListArr[x]);
                                    // log(myListArr[x]);
                                     //log(myList);
                                  // log("-----------myList : "+myList)
                                   if(myList!=myRememberList){
                                       myTelegram=true; //log("ist true")
                                       setStateDelayed(dPDELETEWert, myListAuswahl,500);
                                       setStateDelayed(dPDELETEAuswahl,  myListWerte,500);
                                     var timeout = setTimeout(function () {
                                       // var obj = getObject(dPDELETE);
                                        // log("11---"+myList);
                                       // obj.common.states=myList;
                                        myRememberList=myList;
                                        //log("22---"+myList);
                                       extendObject(dPDELETE, {common: {states: myList}});
                                     }, 400);
                             //SORT
                               if (sortList==1) {
                                             myArr.sort(function (alpha, beta) {
                                          if (alpha[4] > beta[4])
                                             return -1;
                                          if (beta[4] > alpha[4])
                                             return 1;
                                          return 0;
                                                } else
                                   {          myArr.sort(function (alpha, beta) {
                                          if (alpha[0].toUpperCase() > beta[0].toUpperCase())
                                             return 1;
                                          if (beta[0].toUpperCase() > alpha[0].toUpperCase())
                                             return -1;
                                          return 0;
                                                telegramString="";
                              for (var x=0 ; x<myArr.length ; x++) {
                                  counter++;
                                 //HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT - hat man oben 2 Felder definiert, braucht man hier 2 Werte
                                   val0=myArr[x][0];
                                   val1=myArr[x][1];
                                   var val2help=''//myArr[x][2]
                                   var val3help=''//myArr[x][3];
                                   if (mitErstelldatum) {val2=val3help+" am "+val2help;} else {val2=val3help}
                                   if (backgroundAll) {
                                      telegramString=telegramString+ myArr[x][0] + " - "+myArr[x][2] + '\n';   // "-"+ myArr[x][1]  +
                                    tabelleBind();
                            //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                                  tabelleFinish(); // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                            } // function ende
                            //MAIN:
                            schedule(mySchedule,  function () {
                              if(!getState(dpDelAll).val) writeHTML();
                                if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                }, 500);
                            writeHTML();
                             }, 2000);                                  //     <tdalign
                             function tabelleBind(){
                               //  counter=counter+mehrfachTabelle;
                                     case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}else
        {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                     case 2: if(counter%4==0){
                                                if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                           else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;
                                                  }else{
                                                            if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; }
                                                           else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} break;}
                                     case 3:if(counter%2==0)   {
                                                if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //Teil1 c=0
                                                           else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        "; \"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //Teil 2 c=1
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>";} //Teil 3 c=3
        } break;}else{
                                                if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";}
        } break;}
                                     case 4:  // counter=counter+8;
                                               if(counter%8==0)   {
                                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
                                                               else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}else{
                                               if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
                                                               else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut  = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
        } break;}
                                    } //switch ende
                            function tabelleFinish() {
                                   case 1:    break;
                                   case 2:
                                              if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                              break;
                                   case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                             if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                             if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                              break;
                                   case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                             if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                             if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                             if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                             break; }
                                     var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                                   var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                                    if (!htmlSignature) htmlUnter="";
                                      //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                                       var htmlOutVIS="";
                                     //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                                        if (htmlUberschrift)
                                            { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript ;
                                          } else {
                                           zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter+ buttonScript;
                              // log("bin raus aus tabelleBind");
                                       if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                             var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%;  text-align: center; \" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                              var htmlEnd="</table>"+htmlUnter+"</div></body>";
                             //mit oder ohne überschrift - zentriert oder links
                            htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                             //log(htmlOut);
                             setState(dpANLEGEN,"");
                             setState(dpAnzahl,(counter+1));
                             setState(dPDELETE,0);
                             if(myTelegram && braucheTelegram){
                                 //log("sende");
                                 myTelegram=false;
                                sendTo('telegram.0', {
                               text: (telegramString),
                               type: 'text'
                            telegramString="";
                            } // function ende
                            on({id: dPDELETE, ack: false, change: "ne"}, function (obj) {
                               let a=getState(dPDELETE).val;
                               if (a!=0){
                               let toDelete=myIDArr[getState(dPDELETE).val];
                               var stateHelp="alexa2.0.Lists.SHOPPING_LIST.items."+toDelete+".#delete"
                               setState(stateHelp,true);
                               writeHTML(); }, 4000);
                              // log("1+bin im on !!!+++!"+a+stateHelp)
                               on({id: dpANLEGEN, ack: false, change: "ne"}, function (obj) {
                                  // log(getState(dpANLEGEN).val+"----aa");
                                   if(getState(dpANLEGEN).val!="") {
                                setState("alexa2.0.Lists.SHOPPING_LIST.#New",getState(dpANLEGEN).val)
                               writeHTML(); }, 2000);
                                   on({id: dpRefresh, ack: false, change: "any"}, function (obj) {
                                   //log(getState(dpANLEGEN).val+"----refresh");
                                   var timeout2 = setTimeout(function () {
                                  on({id: myDeleterArr, ack: false, change: "any"}, function (obj) {
                                 on({id: dpDelAll, ack: false,val: true}, function (obj) {
                             let i;
                             for (i=0;i<myIDArr.length;i++) {//log("hier : "+myIDArr[i]);
                               if (myIDArr[i]!="dummy") {
                               let toDelete=myIDArr[i];
                                  setTimeout( function timer(){
                               log("Statehelp: "+stateHelp)
                               }, i*2500 );
                               log(i.toString())
                                    setState(dpDelAll,false);
                                    writeHTML(); }, (1+myIDArr.length)*1500);
                              // log(stateHelp)
                            }, 5000);
                              @liv-in-sky
                              Vielen Dank!
                              FUNKTIONIERT!
                              • BananaJoe
                                BananaJoe Most Active last edited by
                                Verdammt, da schau ich nur zufällig in diesen Artikel weil er unter den neuen, ungelesenen Stand .. und schon wieder 3h rumspielt bis alles lief wie ich wollte:
                                Und wieder viel über CSS gelernt ...
                                @liv-in-sky Danke für die reduzierte "Nur Einkaufsliste mit 2 Spalten" Version
                                  lucajordi @BananaJoe last edited by
                                  Wie kann ich den dem grünen Haken ein "enter" mitgeben?
                                  Würde gerne den neuen Artikel eingeben und mit dem grünen Haken eintragen
                                    @lucajordi einfach enter magst du nicht ?
                                      @lucajordi
                                      wenn der haken von dir ist, mußt du mit jquery arbeiten - sonst wäre der haken und das input feld nicht miteiander verbunden
                                      ich glaube,es gibt ein inputfeld mit so einer bestätigung als widget
                                      • BananaJoe
                                        @liv-in-sky Ich habe mal rumgepfuscht und die "Nur Einkaufsliste mit 2 Spalten" Version so erweitert das diese zusätzlich auch ein JSON erzeugt.
                                        So kann ich wie gewohnt das vis-inventwo - JSON Table Widget nutzen.
                                        Alle von mir dafür geänderten Zeilen habe ich jeweils mit // Start Change by BananaJoe und // End Change by BananaJoe gekennzeichnet.
                                        Letztendlich habe einen neuen Datenpunkt hinzugefügt, den Code der das rote X erzeugt so Escaped das man ihn in einen JSON packen kann und schreibe halt zusätzlich den JSON Datenpunkt:
                                        createState("Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf-JSON", { name: 'ALEXAEinkauf_VIS_JSON',  type: 'string', read:  true,  write: true,});
                                        role: "state",
                                        type: "number",
                                        min: 0,
                                        max: 50,
                                        def: 0,
                                        read: true,
                                        write: true});
                                        let   braucheTelegram=false;
                                        let dpVIS_JSON=dpPrefix+"Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf-JSON";                 // dp  für VIS-inventwo-JSON-Table // Datentyp: String
                                        var symbolLink="❌";        //  👎  💀 ❌  ⚪  ⚫ ⭕  🔴 🔵
                                        var htmlFeld1='Artikel';       var Feld1lAlign="left";                     // überschrift Tabellen Spalte1 und  Ausrichtung left or center
                                        var htmlFeld2='Löschen';        var Feld2lAlign="center";                      // überschrift Tabellen Spalte2 und  Ausrichtung left,right or center
                                        const htmlFarbTableColorUber="#76D2F4";               // Überschrift in der tabelle - der einzelnen Spalten
                                        const UeberschriftenHoehe="10px";                          //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                                        const farbeLinieUnterUeberschrift="#000000";
                                        const groesseUeberschrift=45;
                                        //GANZE TABELLE
                                        let farbeUngeradeZeilen="none";                     //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                        let farbeGeradeZeilen="#00aa00";                        //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                                        const backgroundAll="#333333";                        //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                                        const htmlSchriftart="Oxanium";
                                        const htmlSchriftgroesse="45px";
                                        //FELDER UND RAHMEN
                                        let   UeberschriftSpalten=false;                // ein- oder ausblenden der spatlen-überschriften
                                        const htmlFarbFelderschrift="#eeece1";                  // SchriftFarbe der Felder
                                        const htmlFarbFelderschrift2="#eeece1";                 // SchriftFarbe der Felder für jede 2te Tabelle
                                        const htmlFarbTableBorderColor="#000000";             // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                                        const htmlSpalte1Weite="1154px";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                        const htmlSpalte2Weite="312px";                   //  Weite der ersten beiden  Spalten oder z.b. 115px
                                        let htmlcenterHelp;
                                                          "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte2Weite+"}"+
                                        //const htmlTabStyle= "<table bordercolor=\""+htmlFarbTableBorderColor+"\" border=\"2px\" cellspacing=\""+abstandZelle+"\" cellpadding=\""+abstandZelle+"\" width=\""+weite+"\" rules=\""+htmlRahmenLinien+"\" style=\"color:"+htmlFarbFelderschrift+";  font-size:"+htmlSchriftgroesse+
                                        //                      "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");\">";
                                                             "; font-family:"+htmlSchriftart+";\">";
                                        const htmlTabUeber1="<tr height=\""+UeberschriftenHoehe+"\" style=\"color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ;  border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" \">";
                                        var jsonString = "[";
                                          	var htmlTabUeber2="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte2Weite+" align="+Feld2lAlign+">&ensp;"+htmlFeld2+"&ensp;</td><td  align="+Feld3lAlign+">&ensp;"+htmlFeld3+"&ensp;</td>";
                                        var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld1+"&ensp;</td><td width="+htmlSpalte2Weite+"  align="+Feld2lAlign+" style=\"color:"+htmlFarbZweiteTabelle+"\">&ensp;"+htmlFeld2+
                                        var htmlOut="";
                                        var mix;
                                        var counter;
                                        var warte;
                                        var myIDArr=[];
                                        let myDeleterArr;
                                        htmlOut="";
                                        counter=-1;
                                        htmlTabUeber="";
                                              // log(myhelerArr)
                                                  //log(valButton)
                                                  val1JSON="<button style\=\"border:none\; background-color\:transparent\; color\:white\; font\-size\:1em\; text\-align:center\" value=\"toggle\" onclick=\"setOnDblClickCustomShop\(\'"+valButton+"\')\">"+symbolLink + "</button> <font color=\""+farbeSchalterON+"\">";
                                                //log(myList);
                                                }, 400);
                                        //SORT
                                          if (sortList==1) {
                                                        return -1;
                                                        return 1;
                                                     return 0;
                                                           } else
                                                        return 1;
                                                        return -1;
                                                     return 0;
                                                           telegramString="";
                                           jsonString = "["
                                             counter++;
                                              val0=myArr[x][0];
                                              val1=myArr[x][1];
                                               tabelleBind();
                                        } // function ende
                                        //MAIN:
                                           }, 500);
                                        writeHTML();
                                               let valJSON = val1JSON.replace(/"/g, '\\"');
                                               let myArtikel = val0.replace(/(^|\s)\S/g, l => l.toUpperCase());
                                               jsonString = jsonString + '{"Artikel":"' + myArtikel + '","Delete":"' + valJSON + '"},'
        {  htmlOut=htmlOut+"<tr bgcolor=rgba(69,136,24,0.5)><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td></tr>"; break;}
                                                             }else{
        if(counter%2==0)  {htmlOut = htmlOut+"<tr ><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        } break;}else{
                                                           if(counter%3==0 )  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        } break;}
                                                          if(counter%8==0)   {
        } break;}else{
                                                          if(counter%4==0)  {htmlOut = htmlOut+"<tr><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
        } break;}
                                               } //switch ende
                                              case 1:    break;
                                              case 2:
                                                         break;
                                                         break;
                                                        break; }
                                                  var htmlOutVIS="";
                                                     } else {
                                                   jsonString = jsonString.slice(0, -1);
                                                   jsonString = jsonString + ']';
                                                   setState(dpVIS_JSON, jsonString);
                                                   //Ende Change by BananaJoe
                                        //log(htmlOut);
                                            //log("sende");
                                            myTelegram=false;
                                          type: 'text'
                                        telegramString="";
                                        } // function ende
                                          if (a!=0){
                                        on({id: "javascript.0.echos.Alexa_Einkaufsliste.JSON_uncompleted", ack: false, change: "any"}, function (obj) {
                                               writeHTML();
                                           }, 4000);
                                             // on({id: dpRefresh, ack: false, change: "any"}, function (obj) {
                                              on({id: dpRefresh, ack: false, val:true }, function (obj) {
                                               setState("javascript.0.Alexa_Listen.ALEXALists.Einkauf.Refresh", false);
                                        let i;
                                          }, i*2500 );
                                          log(i.toString())
                                         // log(stateHelp)
                                        }, 5000);
                                        Mir ist natürlich nicht gelungen das Script mit in den JSON zu packen welches die Löschfunktion aufruft.
                                        Deshalb habe ich dieses direkt im Projekt unter Skriptehinterlegt:
                                        /* Alexa Einkaufsliste JSON */
                                            var Self = this;
                                            var2 = "javascript.0.Alexa_Listen.ALEXALists.Einkauf.Refresh";
                                        Das Widget dazu braucht die folgenden Einstellungen (sonst aktualisiert es irgendwie nicht ordentlich:
                                        Hier auch noch mal Export:
                                        [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"200","iTableRefreshRate":"1","iColCount":"2","iColShow1":"true","iTblTextAlign1":"left","iTblCellFormat1":"normal","iTblCellImageSize1":"200","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellThresholdsDp1":"","iTblCellThresholdsText1":"","iOpacityAll":"1","iTblRowEvenColor":"rgba(51, 51, 51, 0.3)","iTblRowUnevenColor":"rgba(69, 136, 24, 0.3)","iTblHeaderColor":"#333333","iRowSpacing":"10","iTblRowEvenTextColor":"#eeece1","iTblRowUnevenTextColor":"#eeece1","iTblHeaderTextColor":"#05e8ff","iBorderSize":"1","iBorderStyleLeft":"outset","iBorderStyleRight":"outset","iBorderStyleUp":"outset","iBorderStyleDown":"outset","iBorderColor":"#666666","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"javascript.0.Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf-JSON","iTblShowHead":true,"iHorScroll":false,"iColShow2":"true","iTblTextAlign2":"left","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellThresholdsDp2":"","iTblCellThresholdsText2":"","iColShow3":"true","iTblTextAlign3":"center","iTblCellFormat3":"normal","iTblCellImageSize3":"200","iTblCellBooleanCheckbox3":"false","iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellThresholdsDp3":"","iTblCellThresholdsText3":"","iColShow4":"true","iTblTextAlign4":"center","iTblCellFormat4":"normal","iTblCellImageSize4":"200","iTblCellBooleanCheckbox4":"false","iTblCellBooleanColorFalse4":"#ff0000","iTblCellBooleanColorTrue4":"#00ff00","iTblCellNumberDecimals4":"2","iTblCellNumberDecimalSeperator4":".","iTblCellNumberThousandSeperator4":",","iTblCellThresholdsDp4":"","iTblCellThresholdsText4":"","iColShow5":"true","iTblTextAlign5":"center","iTblCellFormat5":"normal","iTblCellImageSize5":"200","iTblCellBooleanCheckbox5":"false","iTblCellBooleanColorFalse5":"#ff0000","iTblCellBooleanColorTrue5":"#00ff00","iTblCellNumberDecimals5":"2","iTblCellNumberDecimalSeperator5":".","iTblCellNumberThousandSeperator5":",","iTblCellThresholdsDp5":"","iTblCellThresholdsText5":"","iColShow6":"true","iTblTextAlign6":"center","iTblCellFormat6":"normal","iTblCellImageSize6":"200","iTblCellBooleanCheckbox6":"false","iTblCellBooleanColorFalse6":"#ff0000","iTblCellBooleanColorTrue6":"#00ff00","iTblCellNumberDecimals6":"2","iTblCellNumberDecimalSeperator6":".","iTblCellNumberThousandSeperator6":",","iTblCellThresholdsDp6":"","iTblCellThresholdsText6":"","iColShow7":"true","iTblTextAlign7":"left","iTblCellFormat7":"normal","iTblCellImageSize7":"200","iTblCellBooleanCheckbox7":"false","iTblCellBooleanColorFalse7":"#ff0000","iTblCellBooleanColorTrue7":"#00ff00","iTblCellNumberDecimals7":"2","iTblCellNumberDecimalSeperator7":".","iTblCellNumberThousandSeperator7":",","iTblCellThresholdsDp7":"","iTblCellThresholdsText7":"","iColShow8":"true","iTblTextAlign8":"left","iTblCellFormat8":"normal","iTblCellImageSize8":"200","iTblCellBooleanCheckbox8":"false","iTblCellBooleanColorFalse8":"#ff0000","iTblCellBooleanColorTrue8":"#00ff00","iTblCellNumberDecimals8":"2","iTblCellNumberDecimalSeperator8":".","iTblCellNumberThousandSeperator8":",","iTblCellThresholdsDp8":"","iTblCellThresholdsText8":"","iColShow9":"true","iTblTextAlign9":"left","iTblCellFormat9":"normal","iTblCellImageSize9":"200","iTblCellBooleanCheckbox9":"false","iTblCellBooleanColorFalse9":"#ff0000","iTblCellBooleanColorTrue9":"#00ff00","iTblCellNumberDecimals9":"2","iTblCellNumberDecimalSeperator9":".","iTblCellNumberThousandSeperator9":",","iTblCellThresholdsDp9":"","iTblCellThresholdsText9":"","iColShow10":"true","iTblTextAlign10":"left","iTblCellFormat10":"normal","iTblCellImageSize10":"200","iTblCellBooleanCheckbox10":"false","iTblCellBooleanColorFalse10":"#ff0000","iTblCellBooleanColorTrue10":"#00ff00","iTblCellNumberDecimals10":"2","iTblCellNumberDecimalSeperator10":".","iTblCellNumberThousandSeperator10":",","iTblCellThresholdsDp10":"","iTblCellThresholdsText10":"","iColShow11":"true","iTblTextAlign11":"left","iTblCellFormat11":"normal","iTblCellImageSize11":"200","iTblCellBooleanCheckbox11":"false","iTblCellBooleanColorFalse11":"#ff0000","iTblCellBooleanColorTrue11":"#00ff00","iTblCellNumberDecimals11":"2","iTblCellNumberDecimalSeperator11":".","iTblCellNumberThousandSeperator11":",","iTblCellThresholdsDp11":"","iTblCellThresholdsText11":"","iColShow12":"true","iTblTextAlign12":"left","iTblCellFormat12":"normal","iTblCellImageSize12":"200","iTblCellBooleanCheckbox12":"false","iTblCellBooleanColorFalse12":"#ff0000","iTblCellBooleanColorTrue12":"#00ff00","iTblCellNumberDecimals12":"2","iTblCellNumberDecimalSeperator12":".","iTblCellNumberThousandSeperator12":",","iTblCellThresholdsDp12":"","iTblCellThresholdsText12":"","iColShow13":"true","iTblTextAlign13":"left","iTblCellFormat13":"normal","iTblCellImageSize13":"200","iTblCellBooleanCheckbox13":"false","iTblCellBooleanColorFalse13":"#ff0000","iTblCellBooleanColorTrue13":"#00ff00","iTblCellNumberDecimals13":"2","iTblCellNumberDecimalSeperator13":".","iTblCellNumberThousandSeperator13":",","iTblCellThresholdsDp13":"","iTblCellThresholdsText13":"","iColShow14":"true","iTblTextAlign14":"left","iTblCellFormat14":"normal","iTblCellImageSize14":"200","iTblCellBooleanCheckbox14":"false","iTblCellBooleanColorFalse14":"#ff0000","iTblCellBooleanColorTrue14":"#00ff00","iTblCellNumberDecimals14":"2","iTblCellNumberDecimalSeperator14":".","iTblCellNumberThousandSeperator14":",","iTblCellThresholdsDp14":"","iTblCellThresholdsText14":"","iColAttr1":"Artikel","iColName1":"Artikel","iColAttr2":"Delete","iColName2":"Löschen","iColAttr3":"caller","iColName3":"Rufnummer","iColAttr4":"sym","iColAttr5":"name","iColName4":" ","iColName5":"Name","iTblCellDatetimeFormat1":"dd.mm.yy HH:ii","iBorderRemoveDouble":false,"iTblFixedHead":true,"iVertScroll":true,"iColAttr6":"device","iColName6":"Telefoniegerät","iTblSortOrder":"asc","iTblHeadTextAlign1":"left","iTblHeadTextAlign2":"left","iTblHeadTextAlign3":"center","iTblHeadTextAlign4":"center","iTblHeadTextAlign5":"center","iTblHeadTextAlign6":"center"},"style":{"left":"0px","top":"0px","width":"1144px","height":"800px","z-index":"12","text-shadow":"1px 1px 0 #000000, 1px -1px 0 #000000, -1px 1px 0 #000000, -1px -1px 0 #000000, 1px 0px 0 #000000, 0px 1px 0 #000000, -1px 0px 0 #000000, 0px -1px 0 #000000, 1px 1px 4px #000000, 2px 2px 4px #000000","font-family":"Oxanium","font-size":"50px","overflow-x":"hidden","overflow-y":"scroll","text-align":"left"},"widgetSet":"vis-inventwo"}]
                                        Das ganze sieht dann so im Betrieb aus:
                                        Also eigentlich wie in meinem vorherigen Artikel. Nur eben als JSON Tabelle dargestellt. So könnte man die Formatierungen in der VIS / am Widget vornehmen und auch dort nach belieben Spalten ausblenden oder die Reihenfolge ändern. Nachteil ist das man dann das Skript extra unterbringen muss.
                                        Du hast ja jede Menge Skripte auf ähnlicher Basis geschrieben - eventuell lohnt es sich ebenfalls das ein oder andere zusätzlich als JSON auszugeben.
                                        • BananaJoe
                                          BananaJoe Most Active @liv-in-sky last edited by
                                          @liv-in-sky sagte in Script: Alexa Listen pflegen und Anzeigen:
                                          @lucajordi
                                          jepp, das jqui - ctrl - Input + Set-Button kann das. Mann kann auch Symbole reinkopieren (ich hab eines aus deinen Quelltexten genommen):
                                          jetzt bräuchte man einen grünen Haken zum kopieren 🙂 Woher hast du die Symbole aus dem Quelltext?
                                          liv-in-sky L 2 Replies Last reply Reply Quote 0
                                            liv-in-sky @BananaJoe last edited by
                                            @bananajoe
                                            es gibt bei allen meinen tabellen scripten eine zeile, in der man theoretisch das erzeugen de json-dp einbinden kann. genau an der stelle, an dem die tabelle die zeile erstellt
                                            einige scripte arbeiten sogar intern mit dem json-format
                                            eigentlich war geplant, dass andere die tabellen als vorlage nutzen und eigene tabellen erstellen - aber letztlich ist das etwas zu komplex
                                            ob man im inventwo eien delete button einbaue kann, weiß ich gerade nicht (ich glaube nicht) aber im material design table widget geht das
                                            man kann eigentlch die tabellen so definiern, dass sie geauso aussehen, wie die, die du zeigst - daher weiß ich gerade nicht, was du mir sagen/zeigen willst
                                            um nur noch das json zu bekommen, kann man denn mittelzeil herauskopieren - etwas angleichen und den ganzen html teil braucht man dann nicht mehr
                                            ps um zu verhinden, dass die user mit den internen scripten hantieren muss, wollte ich keine json erstellen - das anfängern zu erklären ist umständlich - durch das html widget , ist die sache in der vis erledigt - das sollte eigentlich ein vorteil sein
                                            javascript template
                                            29
                                            409
                                            78248
