    4. Update Javascript auf 5.2.21 - Fehler im Log
    • Basti97
      Basti97 Most Active last edited by
      Bei mir ist leider der Javascript Adapter von meinen Slave kaputt gegangen. Ich glaube ich muss die SD Karte mal wechseln.
      Welche Pakete muss ich nun nachinstallieren und wie?
      host.Media04
      	2022-03-04 18:48:34.078	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Media04
      	2022-03-04 18:48:34.077	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      host.Media04
      	2022-03-04 18:48:34.076	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.Media04
      	2022-03-04 18:48:34.077	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.Media04
      	2022-03-04 18:48:34.076	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.Media04
      	2022-03-04 18:48:34.074	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.Media04
      	2022-03-04 18:48:34.074	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.Media04
      	2022-03-04 18:48:34.073	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.Media04
      	2022-03-04 18:48:34.072	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.Media04
      	2022-03-04 18:48:34.073	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
      host.Media04
      	2022-03-04 18:48:34.072	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.Media04
      	2022-03-04 18:48:34.071	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.Media04
      	2022-03-04 18:48:34.070	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.Media04
      	2022-03-04 18:48:34.071	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.Media04
      	2022-03-04 18:48:34.069	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
      host.Media04
      	2022-03-04 18:48:34.068	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.Media04
      	2022-03-04 18:48:34.067	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.Media04
      	2022-03-04 18:48:34.067	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.Media04
      	2022-03-04 18:48:34.066	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.Media04
      	2022-03-04 18:48:34.065	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.Media04
      	2022-03-04 18:48:34.064	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
      host.Media04
      	2022-03-04 18:48:34.063	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
      host.Media04
      	2022-03-04 18:48:34.062	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
      host.Media04
      	2022-03-04 18:48:34.061	error	Caught by controller[0]:
      • Basti97
        Basti97 Most Active @apollon77 last edited by
        @apollon77 said in Update Javascript auf 5.2.21 - Fehler im Log:
        @basti97 Ein Issue wegen was willst du auf machen?
        Das der Fehler behoben wird. 🙂
          apollon77 @Basti97 last edited by
          @basti97 welcher Fehler? Wenn npm das als error loggt landet es als error im log. Ist „as designed”
            @basti97 Puhh. Kommt das auch wenn alle Skripte dort gestoppt sind? Sonst reinstalliere mal den JavaScript Adapter selbst.
            Basti97 2 Replies Last reply Reply Quote 0
            • Basti97
              Basti97 Most Active @apollon77 last edited by Basti97
              @apollon77 Der Adapter lässt sich gar nicht erst starten die Meldung kommt sobald ich ihn starten möchte. Bei den Java Adapter steht als Verbrauch 0MB
              Ich glaube ich muss bei meinem Slave doch langsam die SD wechseln.
              • Basti97
                @apollon77 noch vergessen das kommt noch zuvor
                Das ist das komplette Log
                host.Media04
                	2022-03-04 23:53:43.832	info	Restart adapter system.adapter.javascript.1 because enabled
                host.Media04
                	2022-03-04 23:53:43.832	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.Media04
                	2022-03-04 23:53:43.831	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                host.Media04
                	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                host.Media04
                	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                host.Media04
                	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                host.Media04
                	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                host.Media04
                	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                host.Media04
                	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                host.Media04
                	2022-03-04 23:53:43.829	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                host.Media04
                	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                host.Media04
                	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                host.Media04
                	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                host.Media04
                	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                host.Media04
                	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                host.Media04
                	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                host.Media04
                	2022-03-04 23:53:43.827	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                host.Media04
                	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                host.Media04
                	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                host.Media04
                	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                host.Media04
                	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                host.Media04
                	2022-03-04 23:53:43.825	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                host.Media04
                	2022-03-04 23:53:43.825	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                host.Media04
                	2022-03-04 23:53:43.825	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                host.Media04
                	2022-03-04 23:53:43.824	error	Caught by controller[0]:
                host.Media04
                	2022-03-04 23:53:43.821	error	Caught by controller[0]: return getR�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&return splitChildren(node.getChildren(), function (_a) {
                host.Media04
                	2022-03-04 23:53:43.820	error	Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:139366
                  @basti97 ja Adapter s add m besten löschen und neu installieren und vorher as Karte tauschen
                  • Basti97
                    @apollon77 Danke werde ich morgen mal machen.
                    • Basti97
                      @apollon77
                      Ich habe auf dem Slave nun das hier eingegeben.
                      pi@Media04:~ $ iobroker del javascript.1
                      Delete adapter "javascript.1"
                      host.Media04 Counted 1 instances of javascript.1
                      host.Media04 Counted 2 channels of javascript.1
                      host.Media04 Counted 6 states of javascript.1
                      host.Media04 Counted 14 states of system.adapter.javascript.1
                      host.Media04 Counted 4 states (system.adapter.javascript.1.*) from states
                      host.Media04 Deleting 23 object(s).
                      host.Media04 Deleting 4 state(s).
                      pi@Media04:~ $ iobroker install javascript.1
                      adapter "javascript" already installed. Use "upgrade" to upgrade to a newer version.
                      Und danach über den Reiter Adapter nochmal neuinstalliert. Beim starten des Adapters kommt wieder diese Fehlermeldung.
                      host.Media04
                      	2022-03-06 12:24:11.686	info	Restart adapter system.adapter.javascript.1 because enabled
                      host.Media04
                      	2022-03-06 12:24:11.685	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.Media04
                      	2022-03-06 12:24:11.684	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                      host.Media04
                      	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.Media04
                      	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.Media04
                      	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                      host.Media04
                      	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.Media04
                      	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                      host.Media04
                      	2022-03-06 12:24:11.680	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                      host.Media04
                      	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                      host.Media04
                      	2022-03-06 12:24:11.680	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                      host.Media04
                      	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.Media04
                      	2022-03-06 12:24:11.678	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.Media04
                      	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.Media04
                      	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                      host.Media04
                      	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                      host.Media04
                      	2022-03-06 12:24:11.676	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                      host.Media04
                      	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.Media04
                      	2022-03-06 12:24:11.676	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                      host.Media04
                      	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.Media04
                      	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                      host.Media04
                      	2022-03-06 12:24:11.673	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                      host.Media04
                      	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.Media04
                      	2022-03-06 12:24:11.673	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                      host.Media04
                      	2022-03-06 12:24:11.672	error	Caught by controller[0]:
                      Aber trotzdem funktioniert es nicht.
                        @basti97 Naja du must wenn javascript komplett entfernen nicht nur instanz 1 ... Die Skripte werden an sich nicht gelöscht, also iob del javascript (vorher backup sicherheitshalber)
                        Alternativ kannst du vorher ein ´cd /opt/iobrokerundnpm i iobroker.javasscript` versuchen obs hilft
                        Basti97 1 Reply Last reply Reply Quote 0
                        • Basti97
                          @apollon77 Ich habe aber auf meinem Master noch zwei Javascript Instanzen laufen. Nicht das sie mit gelöscht werden.
                          Wenn ich den Master herunterfahre und das iobroker del javascript ausführe kommt das hier.
                          Oder soll ich das mal als sudo probieren.
                          No connection to databases possible ...
                          Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @Basti97 last edited by
                            @basti97 sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                            Nein, iobroker nie mit sudo beackern.
                            • Basti97
                              Basti97 Most Active @Thomas Braun last edited by
                              @thomas-braun ok also führe ich auf den Slave mal das hier aus?
                              bleiben die andere Instanzen unberührt oder soll ich den Master herunterfahren.
                                @basti97 dann mach lieber das mit npm install ... zu dem "no connection to db": Welcher controller? Welche db?
                                • Basti97
                                  @apollon77
                                      Plattform: linux
                                      Betriebssystem: linux
                                      Architektur: arm
                                      CPUs: 4
                                      Geschwindigkeit: 600 MHz
                                      Modell: ARMv7 Processor rev 4 (v7l)
                                      RAM: 922.8 MB
                                      System-Betriebszeit: 1 T. 22:21:40
                                      Node.js: v14.19.0
                                      NPM: 6.14.16
                                      Datenträgergröße: 14.5 GB
                                      freier Festplattenspeicher: 4.9 GB
                                      Adapter-Anzahl: 400
                                      Betriebszeit: 04:10:41
                                      Aktive Instanzen: 4
                                      Pfad: /opt/iobroker/
                                      JS Controller: 3.3.2
                                  Javascript Adapter hat die Version 5.2.21
                                  Brauchst du noch mehr infos?
                                  • Basti97
                                    @apollon77 sollte ich das ausführen? Weil irgendwie ging es nicht.
                                    pi@Media04:~ $ cd /opt/iobrokerundnpm i iobroker.javasscript
                                    -bash: cd: Zu viele Argumente.
                                    pi@Media04:~ $ cd /opt/iobroker undnpm i iobroker.javasscript
                                      Thomas Braun Most Active @Basti97 last edited by Thomas Braun
                                      Das soll so lauten:
                                      cd /opt/iobroker/
                                      • Basti97
                                        Das kommt raus
                                        pi@Media04:/opt/iobroker $  npm i iobroker.javasscript
                                        npm ERR! code E404
                                        npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.javasscript - N        ot found
                                        npm ERR! 404
                                        npm ERR! 404  'iobroker.javasscript@latest' is not in the npm registry.
                                        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                                        npm ERR! 404
                                        npm ERR! 404 Note that you can also install from a
                                        npm ERR! 404 tarball, folder, http url, or git url.
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-03-06T16_02_24_230Z-debug.log
                                          @basti97
                                          Da ist ein s zu viel.
                                          npm i iobroker.javascript
                                          • Basti97
                                            @thomas-braun said in Update Javascript auf 5.2.21 - Fehler im Log:
                                            Super vielen Dank das hat funktoniert ich bin glücklich.
                                            Das kam im übrigen.
                                            pi@Media04:/opt/iobroker $ npm i iobroker.javascript
                                            npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                            > iobroker.javascript@5.3.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
                                            > node ./install/installTypings.js
                                            Installing NodeJS typings...
                                            latest @types: 17, installed node: 14
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                            + iobroker.javascript@5.3.1
                                            added 3 packages from 3 contributors, removed 3 packages and updated 6 packages in 377.051s
                                            90 packages are looking for funding
                                              run `npm fund` for details
                                            3692
