    4. Update Javascript auf 5.2.21 - Fehler im Log
    • Basti97
      Basti97 Most Active @apollon77 last edited by Basti97
      @apollon77 Der Adapter lässt sich gar nicht erst starten die Meldung kommt sobald ich ihn starten möchte. Bei den Java Adapter steht als Verbrauch 0MB
      Ich glaube ich muss bei meinem Slave doch langsam die SD wechseln.
      • Basti97
        @apollon77 noch vergessen das kommt noch zuvor
        Das ist das komplette Log
        host.Media04
        	2022-03-04 23:53:43.832	info	Restart adapter system.adapter.javascript.1 because enabled
        host.Media04
        	2022-03-04 23:53:43.832	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.Media04
        	2022-03-04 23:53:43.831	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
        host.Media04
        	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        host.Media04
        	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        host.Media04
        	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
        host.Media04
        	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        host.Media04
        	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
        host.Media04
        	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
        host.Media04
        	2022-03-04 23:53:43.829	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
        host.Media04
        	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
        host.Media04
        	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        host.Media04
        	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
        host.Media04
        	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        host.Media04
        	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
        host.Media04
        	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
        host.Media04
        	2022-03-04 23:53:43.827	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
        host.Media04
        	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
        host.Media04
        	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
        host.Media04
        	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
        host.Media04
        	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
        host.Media04
        	2022-03-04 23:53:43.825	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
        host.Media04
        	2022-03-04 23:53:43.825	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
        host.Media04
        	2022-03-04 23:53:43.825	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
        host.Media04
        	2022-03-04 23:53:43.824	error	Caught by controller[0]:
        host.Media04
        	2022-03-04 23:53:43.821	error	Caught by controller[0]: return getR�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&return splitChildren(node.getChildren(), function (_a) {
        host.Media04
        	2022-03-04 23:53:43.820	error	Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:139366
          apollon77 @Basti97 last edited by
          @basti97 ja Adapter s add m besten löschen und neu installieren und vorher as Karte tauschen
          Basti97 2 Replies Last reply Reply Quote 0
          • Basti97
            @apollon77 Danke werde ich morgen mal machen.
            • Basti97
              @apollon77
              Ich habe auf dem Slave nun das hier eingegeben.
              pi@Media04:~ $ iobroker del javascript.1
              Delete adapter "javascript.1"
              host.Media04 Counted 1 instances of javascript.1
              host.Media04 Counted 2 channels of javascript.1
              host.Media04 Counted 6 states of javascript.1
              host.Media04 Counted 14 states of system.adapter.javascript.1
              host.Media04 Counted 4 states (system.adapter.javascript.1.*) from states
              host.Media04 Deleting 23 object(s).
              host.Media04 Deleting 4 state(s).
              pi@Media04:~ $ iobroker install javascript.1
              adapter "javascript" already installed. Use "upgrade" to upgrade to a newer version.
              Und danach über den Reiter Adapter nochmal neuinstalliert. Beim starten des Adapters kommt wieder diese Fehlermeldung.
              host.Media04
              	2022-03-06 12:24:11.686	info	Restart adapter system.adapter.javascript.1 because enabled
              host.Media04
              	2022-03-06 12:24:11.685	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.Media04
              	2022-03-06 12:24:11.684	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
              host.Media04
              	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
              host.Media04
              	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
              host.Media04
              	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
              host.Media04
              	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
              host.Media04
              	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
              host.Media04
              	2022-03-06 12:24:11.680	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
              host.Media04
              	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
              host.Media04
              	2022-03-06 12:24:11.680	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
              host.Media04
              	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
              host.Media04
              	2022-03-06 12:24:11.678	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
              host.Media04
              	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
              host.Media04
              	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
              host.Media04
              	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
              host.Media04
              	2022-03-06 12:24:11.676	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
              host.Media04
              	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
              host.Media04
              	2022-03-06 12:24:11.676	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
              host.Media04
              	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
              host.Media04
              	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
              host.Media04
              	2022-03-06 12:24:11.673	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
              host.Media04
              	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
              host.Media04
              	2022-03-06 12:24:11.673	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
              host.Media04
              	2022-03-06 12:24:11.672	error	Caught by controller[0]:
              Aber trotzdem funktioniert es nicht.
                @basti97 Naja du must wenn javascript komplett entfernen nicht nur instanz 1 ... Die Skripte werden an sich nicht gelöscht, also iob del javascript (vorher backup sicherheitshalber)
                Alternativ kannst du vorher ein ´cd /opt/iobrokerundnpm i iobroker.javasscript` versuchen obs hilft
                Basti97 1 Reply Last reply Reply Quote 0
                • Basti97
                  @apollon77 Ich habe aber auf meinem Master noch zwei Javascript Instanzen laufen. Nicht das sie mit gelöscht werden.
                  Wenn ich den Master herunterfahre und das iobroker del javascript ausführe kommt das hier.
                  Oder soll ich das mal als sudo probieren.
                  No connection to databases possible ...
                  Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @Basti97 last edited by
                    @basti97 sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                    Nein, iobroker nie mit sudo beackern.
                    • Basti97
                      Basti97 Most Active @Thomas Braun last edited by
                      @thomas-braun ok also führe ich auf den Slave mal das hier aus?
                      bleiben die andere Instanzen unberührt oder soll ich den Master herunterfahren.
                        @basti97 dann mach lieber das mit npm install ... zu dem "no connection to db": Welcher controller? Welche db?
                        • Basti97
                          @apollon77
                              Plattform: linux
                              Betriebssystem: linux
                              Architektur: arm
                              CPUs: 4
                              Geschwindigkeit: 600 MHz
                              Modell: ARMv7 Processor rev 4 (v7l)
                              RAM: 922.8 MB
                              System-Betriebszeit: 1 T. 22:21:40
                              Node.js: v14.19.0
                              NPM: 6.14.16
                              Datenträgergröße: 14.5 GB
                              freier Festplattenspeicher: 4.9 GB
                              Adapter-Anzahl: 400
                              Betriebszeit: 04:10:41
                              Aktive Instanzen: 4
                              Pfad: /opt/iobroker/
                              JS Controller: 3.3.2
                          Javascript Adapter hat die Version 5.2.21
                          Brauchst du noch mehr infos?
                          • Basti97
                            @apollon77 sollte ich das ausführen? Weil irgendwie ging es nicht.
                            pi@Media04:~ $ cd /opt/iobrokerundnpm i iobroker.javasscript
                            -bash: cd: Zu viele Argumente.
                            pi@Media04:~ $ cd /opt/iobroker undnpm i iobroker.javasscript
                              Thomas Braun Most Active @Basti97 last edited by Thomas Braun
                              Das soll so lauten:
                              cd /opt/iobroker/
                              • Basti97
                                Das kommt raus
                                pi@Media04:/opt/iobroker $  npm i iobroker.javasscript
                                npm ERR! code E404
                                npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.javasscript - N        ot found
                                npm ERR! 404
                                npm ERR! 404  'iobroker.javasscript@latest' is not in the npm registry.
                                npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                                npm ERR! 404
                                npm ERR! 404 Note that you can also install from a
                                npm ERR! 404 tarball, folder, http url, or git url.
                                npm ERR!     /home/iobroker/.npm/_logs/2022-03-06T16_02_24_230Z-debug.log
                                  @basti97
                                  Da ist ein s zu viel.
                                  npm i iobroker.javascript
                                  • Basti97
                                    Basti97 Most Active last edited by
                                    @thomas-braun said in Update Javascript auf 5.2.21 - Fehler im Log:
                                    Super vielen Dank das hat funktoniert ich bin glücklich.
                                    Das kam im übrigen.
                                    pi@Media04:/opt/iobroker $ npm i iobroker.javascript
                                    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                    > iobroker.javascript@5.3.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
                                    > node ./install/installTypings.js
                                    Installing NodeJS typings...
                                    latest @types: 17, installed node: 14
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                    + iobroker.javascript@5.3.1
                                    added 3 packages from 3 contributors, removed 3 packages and updated 6 packages in 377.051s
                                    90 packages are looking for funding
                                      run `npm fund` for details
                                      @basti97 uund hats was gebracht?
                                      • Basti97
                                        @apollon77 Ja der Adapter funktioniert wieder. Wenn man die Lösung weiß ist es einfach. Ich habe mir gleich den Lösungsweg gespeichert. 🙂
                                        Würde der Befehl npm i iobroker.javascript auch funktionieren wenn ein anderer Adapter kaputt wäre. Natürlich müsste ich dann javascript ersetzen.
                                          @basti97
                                          Eigentlich vermeidet man den Einsatz von npm auf direktem Weg.
                                          Besser:
                                          iobroker install ADAPTERNAME
                                            @basti97 ja und nein. Als pauschale Nummer nicht ganz so geeignet. Kommt immer darauf an
                                            3692
