    4. [Neuer Adapter] EuSec
    • Marko1974
      Marko1974 @Thomas Braun last edited by Marko1974
      @thomas-braun von dem spreche ich, ja....den hab ich einfach aus dem stable genommen...also unter der Oberfläche von iobroker installiert. neustart beschert nun das hier
      2022-03-06 15:50:24.626 - error: host.openhab Caught by controller[0]: internal/modules/cjs/loader.js:303
      2022-03-06 15:50:24.626 - error: host.openhab Caught by controller[0]: throw err;
      2022-03-06 15:50:24.630 - error: host.openhab Caught by controller[0]: ^
      2022-03-06 15:50:24.632 - error: host.openhab Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
      2022-03-06 15:50:24.633 - error: host.openhab Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:295:19)
      2022-03-06 15:50:24.634 - error: host.openhab Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:508:18)
      2022-03-06 15:50:24.635 - error: host.openhab Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:802:27)
      2022-03-06 15:50:24.635 - error: host.openhab Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      2022-03-06 15:50:24.636 - error: host.openhab Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      2022-03-06 15:50:24.639 - error: host.openhab Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      2022-03-06 15:50:24.640 - error: host.openhab Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:31:32)
      2022-03-06 15:50:24.641 - error: host.openhab Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      2022-03-06 15:50:24.641 - error: host.openhab Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      2022-03-06 15:50:24.642 - error: host.openhab Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32) {
      2022-03-06 15:50:24.642 - error: host.openhab Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2022-03-06 15:50:24.643 - error: host.openhab Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
      2022-03-06 15:50:24.644 - error: host.openhab Caught by controller[0]: requestPath: 'eufy-security-client'
      2022-03-06 15:50:24.644 - error: host.openhab Caught by controller[0]: }
      2022-03-06 15:50:24.646 - error: host.openhab instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      zusätzlich läuft jetzt irgendwie immer ein rebuild durch in schleife
      host.openhab
      	2022-03-06 15:56:20.221	info	iobroker npm-rebuild: > sharp@0.28.1 install /opt/iobroker/node_modules/sharp> (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
      host.openhab
      	2022-03-06 15:56:20.220	info	iobroker npm-rebuild:
      host.openhab
      	2022-03-06 15:56:19.950	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/noble/build“ wird verlassen
      host.openhab
      	2022-03-06 15:56:19.905	info	iobroker npm-rebuild: COPY Release/noble.node
      host.openhab
      	2022-03-06 15:56:19.438	info	iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/noble.node
      host.openhab
      	2022-03-06 15:56:19.430	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/@abandonware/noble/build“ wird betreten
      host.openhab
      	2022-03-06 15:56:16.832	info	iobroker npm-rebuild: > @abandonware/noble@1.9.2-15 install /opt/iobroker/node_modules/@abandonware/noble> node-gyp rebuild
      host.openhab
      	2022-03-06 15:56:15.538	info	iobroker npm-rebuild: [@abandonware/bluetooth-hci-socket] Success: "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node" already installedPass --update-binary to reinstall or --build-from-source to recompile
      host.openhab
      	2022-03-06 15:56:13.846	info	iobroker npm-rebuild: COPY Release/uwrap.nodemake: Verzeichnis „/opt/iobroker/node_modules/usocket/build“ wird verlassen> @abandonware/bluetooth-hci-socket@0.5.3-8 install /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket> node-pre-gyp install --fallback-to-build
      host.openhab
      	2022-03-06 15:56:11.137	info	iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/uwrap.node
      host.openhab
      	2022-03-06 15:55:55.908	info	iobroker npm-rebuild: CXX(target) Release/obj.target/uwrap/src/uwrap.o
      host.openhab
      	2022-03-06 15:55:55.886	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/usocket/build“ wird betreten
      host.openhab
      	2022-03-06 15:55:52.530	info	iobroker npm-rebuild: > usocket@0.3.0 install /opt/iobroker/node_modules/usocket> node-gyp rebuild
      host.openhab
      	2022-03-06 15:55:52.416	info	iobroker npm-rebuild: ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      host.openhab
      	2022-03-06 15:55:40.108	info	iobroker npm-rebuild: > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional> node rebuild.js
      host.openhab
      	2022-03-06 15:55:40.016	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
      host.openhab
      	2022-03-06 15:55:39.935	info	iobroker npm-rebuild: COPY Release/unix_dgram.node
      host.openhab
      	2022-03-06 15:55:39.389	info	iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      host.openhab
      	2022-03-06 15:55:31.082	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      host.openhab
      	2022-03-06 15:55:27.172	info	iobroker npm-rebuild: > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram> node-gyp rebuild
      host.openhab
      	2022-03-06 15:55:27.000	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/raw-socket/build“ wird verlassen
      host.openhab
      	2022-03-06 15:55:26.947	info	iobroker npm-rebuild: COPY Release/raw.node
      host.openhab
      	2022-03-06 15:55:26.449	info	iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/raw.node
      host.openhab
      	2022-03-06 15:55:16.785	info	iobroker npm-rebuild: CXX(target) Release/obj.target/raw/src/raw.o
      host.openhab
      	2022-03-06 15:55:16.774	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/raw-socket/build“ wird betreten
      host.openhab
      	2022-03-06 15:55:13.640	info	iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/diskusage.node COPY Release/diskusage.nodemake: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen> raw-socket@1.7.0 install /opt/iobroker/node_modules/raw-socket> node-gyp rebuild
      host.openhab
      	2022-03-06 15:55:10.630	info	iobroker npm-rebuild: CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      host.openhab
      	2022-03-06 15:55:04.251	info	iobroker npm-rebuild: CXX(target) Release/obj.target/diskusage/src/main.o
      host.openhab
      	2022-03-06 15:55:04.246	info	iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
      host.openhab
      	2022-03-06 15:55:00.383	info	iobroker npm-rebuild: > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage> node-gyp rebuild
      host.openhab
      	2022-03-06 15:55:00.381	info	iobroker npm-rebuild:
      host.openhab
      	2022-03-06 15:54:59.628	info	iobroker npm-rebuild: > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme> node scripts/postinstall
      host.openhab
      	2022-03-06 15:54:59.626	info	iobroker npm-rebuild:
      host.openhab
      	2022-03-06 15:54:57.458	info	iobroker npm-rebuild: > nodemon@2.0.15 postinstall /opt/iobroker/node_modules/nodemon> node bin/postinstall || exit 0
      vis.0
      	2022-03-06 15:54:54.661	info	Terminated (NO_ERROR): Without reason
      vis.0
      	2022-03-06 15:54:53.540	info	vis license is OK.
      vis.0
      	2022-03-06 15:54:53.246	info	starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.7, js-controller: 4.0.18
        Thomas Braun Most Active @Marko1974 last edited by Thomas Braun
        @marko1974 sagte in [Neuer Adapter] EuSec:
        node: v12.22.7
        Ich würde mal langsame (nee, eher schnell) auf die vorgesehene Version 14 wechseln.
        Auf meinem Test-System wird der ganz brav installiert:
        2022-03-06 15:55:00.815  - info: host.chet iobroker add eusec auto --host chet
        2022-03-06 15:55:04.190  - info: host.chet iobroker NPM version: 8.5.1
        2022-03-06 15:55:04.194  - info: host.chet iobroker Installing iobroker.eusec@0.8.5... (System call)
        2022-03-06 15:55:38.040  - info: host.chet iobroker
        2022-03-06 15:55:38.044  - info: host.chet iobroker added 40 packages in 33s53 packages are looking for funding  run `npm fund` for details
        2022-03-06 15:55:38.116  - info: host.chet iobroker host.chet install adapter eusec
        2022-03-06 15:55:38.171  - info: host.chet iobroker upload [14] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/eusec.png eusec.png image/png
        2022-03-06 15:55:38.250  - info: host.chet iobroker upload [13] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/de/translations.json i18n/de/translations.json application/json
        2022-03-06 15:55:38.262  - info: host.chet iobroker upload [12] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/en/translations.json i18n/en/translations.json application/json
        2022-03-06 15:55:44.483  - info: host.chet iobroker upload [11] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/es/translations.json i18n/es/translations.json application/json
        2022-03-06 15:55:44.512  - info: host.chet iobroker upload [10] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        2022-03-06 15:55:44.535  - info: host.chet iobroker upload [9] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/it/translations.json i18n/it/translations.json application/json
        2022-03-06 15:55:44.546  - info: host.chet iobroker upload [8] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        2022-03-06 15:55:44.559  - info: host.chet iobroker upload [7] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        2022-03-06 15:55:44.572  - info: host.chet iobroker upload [6] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        2022-03-06 15:55:44.589  - info: host.chet iobroker upload [5] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        2022-03-06 15:55:45.816  - info: host.chet iobroker upload [4] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        2022-03-06 15:55:45.832  - info: host.chet iobroker upload [3] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/index_m.html index_m.html text/html
        2022-03-06 15:55:45.845  - info: host.chet iobroker upload [2] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/jsonConfig.json jsonConfig.json application/json
        2022-03-06 15:55:45.856  - info: host.chet iobroker upload [1] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/style.css style.css text/css
        2022-03-06 15:55:45.867  - info: host.chet iobroker upload [0] eusec.admin /opt/iobroker/node_modules/iobroker.eusec/admin/words.js words.js application/javascript
        2022-03-06 15:55:46.002  - info: host.chet iobroker host.chet object system.adapter.eusec created/updated
        2022-03-06 15:55:46.014  - warn: web.0 (77575) Terminated (-100): Without reason
        2022-03-06 15:55:46.086  - info: host.chet iobroker host.chet create instance eusec
        2022-03-06 15:55:46.099  - info: host.chet iobroker host.chet object system.adapter.eusec.0.alive created
        2022-03-06 15:55:46.114  - info: host.chet iobroker host.chet object system.adapter.eusec.0.connected created
        2022-03-06 15:55:46.131  - info: host.chet iobroker host.chet object system.adapter.eusec.0.compactMode created
        2022-03-06 15:55:46.145  - info: host.chet iobroker host.chet object system.adapter.eusec.0.cpu created
        2022-03-06 15:55:46.160  - info: host.chet iobroker host.chet object system.adapter.eusec.0.cputime created
        2022-03-06 15:55:46.176  - info: host.chet iobroker host.chet object system.adapter.eusec.0.memHeapUsed created
        2022-03-06 15:55:46.190  - info: host.chet iobroker host.chet object system.adapter.eusec.0.memHeapTotal created
        2022-03-06 15:55:46.204  - info: host.chet iobroker host.chet object system.adapter.eusec.0.memRss created
        2022-03-06 15:55:46.221  - info: host.chet iobroker host.chet object system.adapter.eusec.0.uptime created
        2022-03-06 15:55:46.235  - info: host.chet iobroker host.chet object system.adapter.eusec.0.inputCount created
        2022-03-06 15:55:46.249  - info: host.chet iobroker host.chet object system.adapter.eusec.0.outputCount created
        2022-03-06 15:55:46.263  - info: host.chet iobroker host.chet object system.adapter.eusec.0.eventLoopLag created
        2022-03-06 15:55:46.275  - info: host.chet iobroker host.chet object system.adapter.eusec.0.sigKill created
        2022-03-06 15:55:46.288  - info: host.chet iobroker host.chet object system.adapter.eusec.0.logLevel created
        2022-03-06 15:55:46.299  - info: host.chet iobroker host.chet object eusec.0 created
        2022-03-06 15:55:46.360  - info: host.chet iobroker host.chet object system.adapter.eusec.0 created
        2022-03-06 15:55:46.651  - info: host.chet instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
        2022-03-06 15:55:46.651  - info: host.chet Restart adapter system.adapter.web.0 because enabled
        2022-03-06 15:55:47.393  - info: host.chet iobroker exit 0
        2022-03-06 15:55:47.749  - info: host.chet instance system.adapter.web.0 started with pid 84925
        2022-03-06 15:55:49.421  - info: host.chet instance system.adapter.eusec.0 started with pid 84936
        2022-03-06 15:55:57.123  - info: eusec.0 (84936) starting. Version 0.8.5 in /opt/iobroker/node_modules/iobroker.eusec, node: v17.6.0, js-controller: 4.0.19
        2022-03-06 15:55:59.175  - error: eusec.0 (84936) Response code not ok [{"code":10000,"msg":"Anfrage fehlgeschlagen."}]
        2022-03-06 15:55:59.176  - error: eusec.0 (84936) Token error
        • Marko1974
          @thomas-braun update den gerade....mal sehen
            Den Adapter oder die veraltete nodeJS-Installation?
            • Marko1974
              @thomas-braun die veraltete nodeJS
                @marko1974
                Mit
                sudo ln -s /usr/bin/node /usr/bin/nodejs
                which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                dann schauen ob das alles senkrecht im System hängt.
                Marko1974 1 Reply Last reply Reply Quote 0
                • Marko1974
                  @thomas-braun said in [Neuer Adapter] EuSec:
                  [16:16:01] openhabian@openhab:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/n        odejs
                  ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden:        Die Datei existiert bereits
                  [16:17:07] openhabian@openhab:/opt/iobroker$ which nodejs node npm && nodejs -v        && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo ap        t update && apt policy nodejs
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.19.0
                  v14.19.0
                  6.14.16
                  openhabian
                  /opt/iobroker
                  [16:15:56] openhabian@openhab:/opt/iobroker$ iobroker start
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.19.0
                  v14.19.0
                  6.14.16
                  openhabian
                  /opt/iobroker
                  OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:2 http://phoscon.de/apt/deconz buster-beta InRelease
                  OK:3 http://archive.raspberrypi.org/debian buster InRelease
                  OK:4 https://deb.nodesource.com/node_14.x buster InRelease
                  OK:5 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
                  Aktualisierung für 26 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,        um sie anzuzeigen.
                  nodejs:
                    Installiert:           14.19.0-deb-1nodesource1
                    Installationskandidat: 14.19.0-deb-1nodesource1
                    Versionstabelle:
                   *** 14.19.0-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                          100 /var/lib/dpkg/status
                       10.24.0~dfsg-1~deb10u1 500
                  [16:17:59] openhabian@openhab:/opt/iobroker$ [16:15:56] openhabian@openhab:/opt/        iobroker$ iobroker start
                  -bash: [16:15:56]: Kommando nicht gefunden.
                  [16:18:00] openhabian@openhab:/opt/iobroker$ [16:16:01] openhabian@openhab:/opt/        iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                  -bash: [16:16:01]: Kommando nicht gefunden.
                  [16:18:00] openhabian@openhab:/opt/iobroker$ ln: die symbolische Verknüpfung '/u        sr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                  -bash: ln:: Kommando nicht gefunden.
                  [16:18:00] openhabian@openhab:/opt/iobroker$ [16:17:07] openhabian@openhab:/opt/        iobroker$ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && p        wd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  -bash: [16:17:07]: Kommando nicht gefunden.
                  [16:18:00] openhabian@openhab:/opt/iobroker$ /usr/bin/nodejs
                  Welcome to Node.js v14.19.0.
                  Type ".help" for more information.
                  > /usr/bin/node
                  /usr/bin/node
                  Uncaught SyntaxError: Invalid regular expression flags
                  > /usr/bin/npm
                  /usr/bin/npm
                  > v14.19.0
                  v14.19.0
                  Uncaught SyntaxError: Unexpected number
                  > v14.19.0
                  v14.19.0
                  > 6.14.16
                  6.14.16
                  > openhabian
                  Uncaught ReferenceError: openhabian is not defined
                  > /opt/iobroker
                  /opt/iobroker
                    Okay, soweit schaut das sauber aus.
                    Die
                    würde ich aber auch noch eintüten.
                    • Marko1974
                      @thomas-braun also bisher läuft da nichts sauber....immer noch das gleiche wie vorher
                      eintüten?
                        @marko1974
                        sudo apt update
                        sudo apt full-upgrade
                        sudo reboot
                        • Marko1974
                          achso ja...das hatte ich soben gemacht...nur noch mal eben rebooten
                          • Marko1974
                            Marko1974 @Marko1974 last edited by Marko1974
                            @thomas-braun ursprünglich wollte ich eigentlich nur, wenn ein bild erfasst wird in einer meiner eufy 2c (keine cloud) dieses an telegram schicken. meinentwegen auch ein video. Ich hatte das schonmal probiert mit nem blockly ....klappte aber leider nicht, da keiin http link versendet wurde und somit auch keine vorschau bei telegram angezeigt wurde. Hoffe das geht mittlerweile überhaupt
                              @marko1974
                              Ich kenne den Adapter nicht. Keine Ahnung was der kann oder nicht.
                              • Marko1974
                                @thomas-braun aber wir sind doch hier in dem thread des adapters 🙂
                                  @marko1974
                                  Und? Für eine Installation eines Adapters muss man ja nicht wissen was der macht.
                                  • Marko1974
                                    @thomas-braun hehe...ja das stimmt schon 🙂
                                    zumindest bin ich hier damit dann aber nicht falsch
                                      @marko1974
                                      Ist der ioBroker jetzt zur Ruhe gekommen? Rebuilds durchgeführt?
                                      Ein (Neu)-Start des Adapters schaut jetzt wie aus?
                                      • Marko1974
                                        @thomas-braun es rödelt noch...melde mich sofort wenn er fertig ist
                                        • Marko1974
                                          @thomas-braun habe da immer noch die gleichen dinge in schleife drin -.-
                                          2022-03-06 16:44:08.612 - info: shuttercontrol.0 (3401) starting. Version 1.4.10 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.19.0, js-controller: 4.0.18
                                          2022-03-06 16:44:12.273 - info: fb-checkpresence.0 (2760) History function for Konrads-IphoneX disabled. Please select a history adapter in the configuration dialog!
                                          2022-03-06 16:44:12.275 - info: fb-checkpresence.0 (2760) createMemberObjects finished successfully
                                          2022-03-06 16:44:18.723 - info: wled.0 (3495) Bonjour service started, new devices will be detected automatically
                                          2022-03-06 16:44:18.836 - info: wled.0 (3495) WLED connected
                                          2022-03-06 16:44:28.738 - info: wled.0 (3495) WLED initialisation finalized, ready to do my job have fun !
                                          2022-03-06 16:44:39.445 - info: host.openhab iobroker npm-rebuild: > protobuf-typescript@6.8.8 postinstall /opt/iobroker/node_modules/protobuf-typescript> node scripts/postinstall
                                          2022-03-06 16:44:44.187 - info: host.openhab iobroker npm-rebuild: > iobroker.amazon-dash@1.1.0 preinstall /opt/iobroker/node_modules/iobroker.amazon-dash> apt install libpcap-dev -y || true
                                          2022-03-06 16:44:44.559 - info: host.openhab iobroker npm-rebuild: > pcap@3.1.0 install /opt/iobroker/node_modules/pcap> node-gyp rebuild
                                          2022-03-06 16:44:51.608 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
                                          2022-03-06 16:44:51.623 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
                                          2022-03-06 16:45:05.248 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/pcap_binding/pcap_session.o
                                          2022-03-06 16:45:08.420 - info: fb-checkpresence.0 (2760) createFbDeviceObjects finished successfully
                                          2022-03-06 16:45:08.424 - info: fb-checkpresence.0 (2760) states successfully subscribed
                                          2022-03-06 16:45:08.427 - info: fb-checkpresence.0 (2760) loop successfully started
                                          2022-03-06 16:45:15.730 - info: host.openhab iobroker npm-rebuild: SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
                                          2022-03-06 16:45:17.221 - info: host.openhab iobroker npm-rebuild: COPY Release/pcap_binding.nodemake: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
                                          2022-03-06 16:45:19.116 - info: host.openhab iobroker npm-rebuild: > @serialport/bindings@9.1.0 install /opt/iobroker/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                          2022-03-06 16:45:21.629 - info: alexa2.0 (2498) Subscribing to states...
                                          2022-03-06 16:45:25.463 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                                          2022-03-06 16:45:25.471 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport.o
                                          2022-03-06 16:45:34.388 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
                                          2022-03-06 16:45:34.470 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
                                          2022-03-06 16:45:34.529 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 3.
                                          2022-03-06 16:45:34.568 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
                                          2022-03-06 16:45:34.578 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
                                          2022-03-06 16:45:34.585 - info: hue-extended.0 (2824) Attempt 1x - Successfully set Flur Spot 4.
                                          2022-03-06 16:45:35.204 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                          2022-03-06 16:45:40.405 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/poller.o
                                          2022-03-06 16:45:50.021 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_linux.o SOLINK_MODULE(target) Release/obj.target/bindings.node COPY Release/bindings.nodemake: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen> @serialport/bindings@9.2.8 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                          2022-03-06 16:45:57.423 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird betreten CXX(target) Release/obj.target/bindings/src/serialport.o
                                          2022-03-06 16:46:07.980 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                          2022-03-06 16:46:13.766 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/poller.o
                                          2022-03-06 16:46:23.360 - info: host.openhab iobroker npm-rebuild: CXX(target) Release/obj.target/bindings/src/serialport_linux.o SOLINK_MODULE(target) Release/obj.target/bindings.node
                                          2022-03-06 16:46:23.864 - info: host.openhab iobroker npm-rebuild: COPY Release/bindings.node
                                          2022-03-06 16:46:23.960 - info: host.openhab iobroker npm-rebuild: make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/build“ wird verlassen
                                          2022-03-06 16:46:24.508 - info: host.openhab iobroker npm-rebuild:
                                          2022-03-06 16:46:24.510 - info: host.openhab iobroker npm-rebuild: > ffmpeg-static@4.4.0 install /opt/iobroker/node_modules/ffmpeg-static> node install.js
                                            @marko1974
                                            Da läuft noch diverses rebuild-Zeuch. Abwarten bis da Ruhe ist.
                                            1.0k
                                            adapter cameras doorbell eufy eufycam security
                                            158
                                            1171
                                            445822
